Home » Newcomers » Newcomers » JUnit Plugin Test
JUnit Plugin Test [message #260810] Sat, 12 July 2008 06:44 Go to next message
Originally posted by: annamalai.ancitconsulting.com
Hello All
I have been wondering whats this JUnit Plugin Test ... what does it help me
in .. i wanna learn more about it .. any pointers or help would be great ..
i tried to search on the web .. but didnt find anything basic explaining the
use of JUnit Plugin test ...
HELP HELP !! :)
Malai
Re: JUnit Plugin Test [message #260813 is a reply to message #260810] Fri, 11 July 2008 19:19 Go to previous messageGo to next message
Malai,
There are two ways you could run the JUnit. Either as a normal Java
application, or running as an OSGi application. If the things you're
testing rely on OSGi for doing proper initialization and registration,
then you'll want to run it as JUnit Plugin Test. Other than how it's
invoked, there's no real significant difference.
Malai wrote:
> Hello All
> HELP HELP !! :)
> Regards
> Malai
Re: JUnit Plugin Test [message #261318 is a reply to message #260813] Thu, 17 July 2008 15:45 Go to previous message
Dear Ed
Thanks for your reply ... Now i am an Eclipse RCP Trainer and what i get
asked in al my trainings are ..how can we use Junit Plugin Test ...
Is it a misconception that it can be used for testing your plugins or rcp at
Unit Level ... And if it is not .. i would be really happy if i am provided
with an Example ... to check out the same.
Malai
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:g58bof$duc$2@build.eclipse.org...
> Malai,
> Malai wrote:
>> Hello All
>> me in .. i wanna learn more about it .. any pointers or help would be
>> great .. i tried to search on the web .. but didnt find anything basic
>> explaining the use of JUnit Plugin test ...
>> HELP HELP !! :)
>> Regards
>> Malai
Re: JUnit Plugin Test [message #261340 is a reply to message #261318] Thu, 17 July 2008 08:51 Go to previous message
Dani Megert is currently offline Dani MegertFriend
Malai wrote:
> Dear Ed
This is not about a special test but it's a launch configuration.
Compare it to launching your RCP or plug-in where you need to use the
'Eclipse Application' or 'OSGi Framework' launch configuration. If you
write a test for the RCP or plug-in you could run it with those
launchers but then it would not be connected to the JUnit view. The
'JUnit Plug-in Test' launch configuration basically combines the normal
launcher with the ability to connect to the JUnit view, so that the test
results can be watched.
Dani
> Regards
> Malai
>> Malai,
>> Malai wrote:
>>> Hello All
>>> HELP HELP !! :)
>>> Regards
>>> Malai
Previous Topic:using external text editor
Next Topic:Adding selection listeners
Current Time: Mon May 21 13:02:28 GMT 2018
Powered by FUDForum. Page generated in 0.03189 seconds
