Home » Newcomers » Newcomers » Ant Build is not showing anything in eclipse console
Ant Build is not showing anything in eclipse console [message #260009] Fri, 04 July 2008 03:25 Go to next message
Eclipse User
Originally posted by: kumar.saurav.wipro.com
<p><B>When I am doing an ant build for my project in eclipse, I am unable to
see anything on the eclipse console.</b> However the build is working fine and
the expected jar/code is placed in its proper location in server in accordance
with the ant script.</p>
<p>
I have gone through the eclipse online help, it says that the external
tools dialog will have an <b>capture output</b>
option. However I cant see that in my case. I am using eclipse Version:
3.3.1.1(Europa).
Any help will be deeply appreciated.
</p>
Re: Ant Build is not showing anything in eclipse console [message #260609 is a reply to message #260009] Wed, 09 July 2008 20:00 Go to previous message
Darin Swanson is currently offline Darin Swanson
The configuration has changed in 3.3.*
On the Common tab of your Ant launch configuration, ensure that in the
Standard Input and Output section that you are allocating a console.
HTH
Darins
http://runnerwhocodes.blogspot.com
"Saurav" <kumar.saurav@wipro.com> wrote in message
news:ee10d750b0eabdb32b4af57cb56175a6$1@www.eclipse.org...
> to see anything on the eclipse console.</b> However the build is working
> fine and the expected jar/code is placed in its proper location in server
> in accordance with the ant script.</p>
> <p>
> 3.3.1.1(Europa).
> </p>
Previous Topic:Schedule Nightly Product Exports - Eclipse 3.4SDK
Next Topic:Testing
Current Time: Fri May 24 00:34:01 EDT 2013
Powered by FUDForum. Page generated in 0.01486 seconds
