| Re: BIRT 2.2.0 - csv format [message #258971 is a reply to message #258948] |
Mon, 22 October 2007 08:24   |
Originally posted by: brell.oio.de
You can export your report data to csv using WebViewer in frameset-mode by
clicking the export Button on top of the generated HTML-Page.
"Shomy Jose" <shomy.jose@hcl.in> schrieb im Newsbeitrag
news:259c111b2f6248c0306a28b8f86ebef0$1@www.eclipse.org...
> May I know whether BIRT 2.2.0 supports generating reports in .csv format?
> Thanks and Regards,
> Shomy
| Re: BIRT 2.2.0 - csv format [message #258993 is a reply to message #258977] |
Mon, 22 October 2007 09:23   |
You can have a look at the BIRT CVS project org.eclipse.report.viewer
BirtViewerReportServicejava method to see how to do it with the use of
Report Engine API.
You first have to create a .rptdocument, because Report Engine API can only
extract the data from a .rptdocument.
You can then call the method extractData on your ReportEngineService Object
with parameters: .rptdocument, resultSetId, columns, locale in which to
export, encoding if needed and the column seperator for csv.
There are also methods to list all available resultSetIds in your
..rptdocument with all its columns .
news:bb90e421491f2c4f5710349a709422fc$1@www.eclipse.org...
> Could you give me idea whether it is possible to do the export to csv
> programatically.
> Thanks and Regards,
> Shomy
| Re: BIRT 2.2.0 - csv format [message #258997 is a reply to message #258993] |
Mon, 22 October 2007 09:25   |
Sorry forgot to mention the method name in BirtViewerReportService.java
It s name is extractResultSet.
"Christian Brell" <brell@oio.de> schrieb im Newsbeitrag
news:ffi88e$11v$1@build.eclipse.org...
> Report Engine API.
only
Object
> > Hi,
> > programatically.
> > Thanks and Regards,
> > Shomy
FUDForum. Page generated in 0.01644 seconds
