Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » (org.eclipse.dltk.ui.text.completion.)ProposalInfo.getHTMLContentReader:150 - NullPointerException
(org.eclipse.dltk.ui.text.completion.)ProposalInfo.getHTMLContentReader:150 - NullPointerException [message #25257] Mon, 09 June 2008 23:51 Go to next message
Charles Doucette is currently offline Charles DoucetteFriend
Below I have pasted the exception I get repeatedely during attempted
completion since my model elements do not include any documentation.
FYI - Here is line 150 from that file:
nature = DLTKLanguageManager.getLanguageToolkit(member).getNatureId() ;
I assume getLanguageToolkit(member) is returning null.
Chuck
!ENTRY org.eclipse.jface.text 2 0 2008-06-09 19:00:09.054
!MESSAGE
!STACK 0
org.eclipse.dltk.ui.text.completion.ProposalInfo.getHTMLCont entReader(ProposalInfo.java:150)
org.eclipse.dltk.ui.text.completion.ProposalInfo.extractScri ptdoc(ProposalInfo.java:140)
org.eclipse.dltk.ui.text.completion.ProposalInfo.computeInfo (ProposalInfo.java:90)
org.eclipse.dltk.ui.text.completion.ProposalInfo.getInfo(Pro posalInfo.java:67)
org.eclipse.dltk.ui.text.completion.AbstractScriptCompletion Proposal.getAdditionalProposalInfo(AbstractScriptCompletionP roposal.java:440)
org.eclipse.jface.text.contentassist.AdditionalInfoControlle r$3.run(AdditionalInfoController.java:102)
Re: (org.eclipse.dltk.ui.text.completion.)ProposalInfo.getHTMLContentReader:150 - NullPointerExcepti [message #25459 is a reply to message #25257] Tue, 10 June 2008 06:42 Go to previous messageGo to next message
Andrei Sobolev is currently offline Andrei SobolevFriend
Member
Hi Chuck,
I've added check for this case to ProposalInfo class.
I suppose this could only happen if you return not correct model element from your completion engine.
Best regards, Andrei.
> Chuck
> !MESSAGE
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: (org.eclipse.dltk.ui.text.completion.)ProposalInfo.getHTMLContentReader:150 - NullPointerExcepti [message #25500 is a reply to message #25459] Tue, 10 June 2008 13:30 Go to previous message
I could certainly believe that there may also be something wrong with my
model elements.
If you care to venture a guess as to what that might be - I'll gladly look
for it.
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:g2l7ot$nbo$1@build.eclipse.org...
> Hi Chuck,
>> Chuck
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:FieldDeclaration not included in Outline view
Next Topic:ASTVisitor.visitGeneral
Current Time: Tue Apr 24 14:44:34 GMT 2018
Powered by FUDForum. Page generated in 0.01692 seconds
