Home » Eclipse Projects » XML Schema Definition (XSD) » creating XPATH 2.0 expressions while navigating schema
creating XPATH 2.0 expressions while navigating schema [message #25127] Wed, 16 July 2003 13:51 Go to next message
Originally posted by: carman.itc.it
Hello XSD users,
I am currently using the XSD API to perform semantic (dictionary based)
matching of XML schemas.
While navigating through a schema (starting from a global element
declaration / type definition and going right down to primitive type
definitions), I would like to record the path I am traversing using an
XPATH 2.0 expression, so that I can later easily access the instance data
from XML documents adhering to the schema.
Does anybody have any experience in creating such path expressions while
navigating the schema?
Any hints / example code would be much appreciated. Forgive me if the
process is extremely simple, or if I should be asking this question to a
different mailing list - my knowledge of XPATH is relatively limited.
Yours,
Mark Carman
Re: creating XPATH 2.0 expressions while navigating schema [message #25374 is a reply to message #25127] Thu, 24 July 2003 03:17 Go to previous messageGo to next message
Mark,
Sorry, we don't have any examples we can point you to...
Mark Carman wrote:
> Hello XSD users,
> Yours,
> Mark Carman
Re: creating XPATH 2.0 expressions while navigating schema [message #574864 is a reply to message #25127] Thu, 24 July 2003 03:17 Go to previous messageGo to next message
Mark,
Mark Carman wrote:
> Hello XSD users,
> Yours,
> Mark Carman
Re: creating XPATH 2.0 expressions while navigating schema [message #708206 is a reply to message #25127] Tue, 02 August 2011 15:10 Go to previous messageGo to next message
Mickael Istria, away until January 8th is currently offline Mickael Istria, away until January 8thFriend
8 years later, I come back with the same question: is there anything available at Eclipse to perform transformations/resolutions between an XPath expression and an org.eclipse.xsd.XSDSchemaContent ?
Re: creating XPATH 2.0 expressions while navigating schema [message #708280 is a reply to message #708206] Tue, 02 August 2011 15:18 Go to previous message
Michael,
No, there isn't. You might imagine there's something like that for DOM
itself, and you'd be able to reuse that because you can always get at
the underlying DOM of anything in the schema model and vice versa.
Previous Topic:mistake
Next Topic:XML editor
Current Time: Sat Feb 24 06:32:08 GMT 2018
Powered by FUDForum. Page generated in 0.01800 seconds
