Home » Eclipse Projects » Eclipse Platform » Problem in eclipse.buildScript ant task
Problem in eclipse.buildScript ant task [message #254475] Tue, 22 June 2004 06:21 Go to next message
Originally posted by: xshen.actuate.com
I met some problem when migrating my Eclipse AntRunner from 2.1.2 to
3.0RC3, it is because of the eclipse.buildScript ant task. The script in
2.1.2 works well:
<eclipse.buildScript elements="plugin@myplugin" install="${eclipse_home}"/>
so I think the corresponding 3.0RC3 one should be:
workingDirectory="${eclipse_home}"/>
However, when I run this script, error occurs:
BUILD FAILED
D:\adb\build.xml:26: org.eclipse.core.runtime.CoreException: Unable to
find
element: myplugin
The build environment is exactly the same, so I don't know what's wrong
with my script, Could anybody be kind enough to help me solve this problem?
BTW, is there any document for eclipse's custom ant tasks, just like the
detailed ones in ant's manual? I've searched for a long time and can't
find
any:(
Re: Problem in eclipse.buildScript ant task [message #254625 is a reply to message #254475] Tue, 22 June 2004 11:51 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
If you are trying to build plugins that rely on 3.0, you have to set
buildingOSGi to true in eclipse.buildScript call.
<eclipse.buildScript ..... buildingOSGi="true">
There is a complete description of the 2.1 tasks in the PDE user guide,
I will complete them over week.
PaScaL
Erix wrote:
> 2.1.2 works well:
> BUILD FAILED
> find
> element: myplugin
> find
> any:(
Re: Problem in eclipse.buildScript ant task [message #254858 is a reply to message #254625] Wed, 23 June 2004 03:30 Go to previous messageGo to next message
Hi PaScaL:
I followed your suggestion and now my script is:
<eclipse.buildScript elements="plugin@${module.name}"
buildingOSGi="true"
The plugin directory is ${eclipse_home}\plugins\${module.name}_1.0.0. I've
noticed that after executing this script, there's a new file
${module.name}_1.0.0.MF in
${eclipse_home}\configuration\org.eclipse.osgi\manifests, and the
infomation in this file reflects the information in plugin.xml of my
plugin. So I think the eclipse.buildScript actually found the correct
place of my plugin. However, the build.xml still failed to generate:
find element: pluginname. So do you have any idea what's the problem here?
> PaScaL
> Erix wrote:
> > Hi,
> > 2.1.2 works well:
> > BUILD FAILED
> > D:adbbuild.xml:26: org.eclipse.core.runtime.CoreException: Unable to
> > find
> > element: myplugin
> > find
> > any:(
Re: Problem in eclipse.buildScript ant task [message #254897 is a reply to message #254858] Wed, 23 June 2004 12:02 Go to previous message
It is probably because the plugin you are trying to generate misses some
of its prerequisites. Look in the .log file (it should be in
eclipse/workspace of the eclipse install you are running the script
from), there should be more details about what is missing.
You can also try to add baseLocation="<pathToEclipseInstall>" as a
parameter to your task.
PaScaL
Erix wrote:
> Hi PaScaL:
> buildingOSGi="true"
>>PaScaL
>>Erix wrote:
>>>Hi,
>>>2.1.2 works well:
>>>BUILD FAILED
>>>find
>>>element: myplugin
>>>find
>>>any:(
Previous Topic:RC3
Next Topic:configuring menubar
Current Time: Fri Feb 23 08:59:53 GMT 2018
Powered by FUDForum. Page generated in 0.02382 seconds
