| Running JUnit test org.eclipse.jdt.ui.tests.quickfix.AdvancedQuickAssistTest [message #252552] |
Wed, 09 April 2008 14:52  |
Originally posted by: jack.NO.SPAM
I've added a "Qualify type name" quick assist, and i'd like to run my
tests before submitting my patch.
But if i try to run the
"org.eclipse.jdt.ui.tests.quickfix.AdvancedQuickAssistTest" test case, i
get an exception:
java.lang.IllegalStateException: Workspace is closed.
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:337)
org.eclipse.jdt.ui.tests.core.ProjectTestSetup.getProject(Pr ojectTestSetup.java:40)
org.eclipse.jdt.ui.tests.core.ProjectTestSetup.setUp(Project TestSetup.java:64)
at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.extensions.TestSetup.run(TestSetup.java:25)
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Have you any idea about what is the problem ?
I'm running eclipse 3.4M6 on Mac.
TIA
| Re: Running JUnit test org.eclipse.jdt.ui.tests.quickfix.AdvancedQuickAssistTest [message #252561 is a reply to message #252552] |
Wed, 09 April 2008 16:55   |
Originally posted by: wharley.bea.com
"Jack" <jack@NO.SPAM> wrote in message
news:ftj396$oce$1@build.eclipse.org...
> get an exception:
Are you trying to just run that single test, or the entire suite? Maybe the
suite contains some setup code that only runs if you run the whole suite.
Does the test pass if you run it without your plugin loaded? (E.g., close
your plugin project and then run the test again.)
| Re: Running JUnit test org.eclipse.jdt.ui.tests.quickfix.AdvancedQuickAssistTest [message #252568 is a reply to message #252552] |
Wed, 09 April 2008 17:31  |
Benjamin Muskalla Messages: 237 Registered: July 2009 |
Hi Jack,
this happens if you try to run the test as a regular Junit tests. You
need to start all these tests as "PDE Junit Tests".
Greets
Benny
Jack wrote:
> get an exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> TIA
FUDForum. Page generated in 0.01614 seconds
