Home » Language IDEs » Java Development Tools (JDT) » A question about code assist
A question about code assist [message #250715] Sun, 20 January 2008 11:36 Go to next message
Originally posted by: neverov.andrey.gmail.com
Hi all,
I'm seeing some strange behavior with the code assist for variable names
in Eclipse.
Suppose I have an interface called "Element" and I'm trying to
auto-complete some variable's name:
First:
Element my<code assist>
==> "myElement" is inserted correctly
But:
Element service<code assist>
==> "servicElement" which is incorrect because the last letter was cut
As you can see from this example, in the case when the first part of
variable's name ends with the same letter as the type's name starts from,
one letter from the original variable's name gets cut. This happens also
for the other types.
I'm seeing this in 3.3.1.1 and 3.4M4.
Is it a bug? If so, should I open it?
Thank for your attention!
Best Regards,
Andrii
Re: A question about code assist [message #250739 is a reply to message #250715] Mon, 21 January 2008 12:20 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Andrii Neverov wrote:
> Hi all,
> names in Eclipse.
> First:
> But:
> from, one letter from the original variable's name gets cut. This
> happens also for the other types.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=215975
Dani
> Best Regards,
> Andrii
Re: A question about code assist [message #250773 is a reply to message #250739] Mon, 21 January 2008 20:14 Go to previous message
Thanks for filing it! ;-)
/Andrii
Previous Topic:eclipse does not start
Next Topic:How to let Eclipse without prompt when encountered a read-only file ?
Current Time: Sat May 26 20:02:23 GMT 2018
Powered by FUDForum. Page generated in 0.01894 seconds
