Home » Language IDEs » Java Development Tools (JDT) » How to avoid search hits in JAR files?
| How to avoid search hits in JAR files? [message #247689] |
Fri, 07 September 2007 19:36  |
Originally posted by: nospam.nospam.com
A framework I am developing deploys JARs which end up in dozens of
projects in my workspace,
and hence any searches I make have copious duplicate hits, for each copy
of the JARs. How
can I filter searches to exclude these? None of the supplied filter
options seem slightly
relevant, which all relate to the *code context* of the hit, rather than
its packaging.
Antranig.
| Re: How to avoid search hits in JAR files? [message #247693 is a reply to message #247689] |
Sat, 08 September 2007 16:10   |
> of the JARs. How
> its packaging.
You can define a Working Set (or Working Sets) that only includes the
source that you want to search, then limit the scope of the search to
the Working Set(s).
Hope this helps,
Eric
| Re: How to avoid search hits in JAR files? [message #247697 is a reply to message #247693] |
Sat, 08 September 2007 16:41   |
On Sat, 08 Sep 2007 21:10:03 +0100, Eric Rizzo <eclipse5@rizzoweb.com>
>> copy of the JARs. How
>> than its packaging.
> the Working Set(s).
> Hope this helps,
> Eric
Cheers Eric -
Yes, I had considered working sets. The issue is, these JARs are
dependencies of projects that I *do* want searched, that is, I would
like the code directly within the projects to be marked as a
search target, but would like to exclude JARs within the same
project (really, a setting to exclude JARs from search across the entire
workspace would be ideal). Unless I use any option other than "group by
project", it is now extremely difficult to sort out the hits I need amongst
the dozens of "decoys".
Antranig.
| Re: How to avoid search hits in JAR files? [message #247706 is a reply to message #247697] |
Sun, 09 September 2007 16:26   |
>>> than its packaging.
>> the Working Set(s).
>> Hope this helps,
>> Eric
> Cheers Eric -
> project
A Working Set should still work or you - just include the source
directories and exclude the JARs.
Eric
| Re: How to avoid search hits in JAR files? [message #247710 is a reply to message #247706] |
Sun, 09 September 2007 17:54   |
Ah - thanks Eric - I hadn't realised this was possible. It will be somewhat
tedious to draw up the set (for a workspace of >100 projects) without a
"select resources by type" option but I think it will save a good amount
of time in the long run.
Thanks for this suggestion,
Antranig.
On Sun, 09 Sep 2007 21:26:48 +0100, Eric Rizzo <eclipse5@rizzoweb.com>
>>>> than its packaging.
>>> the Working Set(s).
>>> Hope this helps,
>>> Eric
>> Cheers Eric -
>> project
> Eric
| Re: How to avoid search hits in JAR files? [message #247731 is a reply to message #247689] |
Tue, 11 September 2007 08:21  |
Dani Megert Messages: 3801 Registered: July 2009 |
> than its packaging.
Simply uncheck 'Application libraries' on th Java Search page of the
search dialog (Ctrl+H).
Dani
> Cheers,
> Antranig.
Current Time: Sun May 19 22:07:00 EDT 2013
Powered by FUDForum. Page generated in 0.01764 seconds
