Home » Eclipse Projects » GEF » Palette keyboard usage
Palette keyboard usage [message #245933] Sun, 26 October 2008 19:30 Go to next message
Brian Farn is currently offline Brian FarnFriend
How does a user use the keyboard to drag a palette item from the GEF palette to drop onto an editor?
Brian Farn
farn@ca.ibm.com
Re: Palette keyboard usage [message #245937 is a reply to message #245933] Mon, 27 October 2008 07:37 Go to previous messageGo to next message
Originally posted by: shady_86.sify.com
the palette have only mouse listeners for drag and drop... and i dont think there are any API for implementing key listeners...
one way is to override the needed classes...
other way is do not use a palette itself.
implement key listener to your viewer...
like when you press 'A' when the editor is selected a given edit part will be created on a default location.
Re: Palette keyboard usage [message #245947 is a reply to message #245937] Mon, 27 October 2008 12:45 Go to previous message
Thanks Sharad,
I'm wondering how the user uses the palette without a mouse which is a standard accessibility issue.
Brian Farn
Previous Topic:Edit Part Thread
Next Topic:Declaration for the UFacekit Project
Current Time: Tue May 22 00:22:20 GMT 2018
Powered by FUDForum. Page generated in 0.02133 seconds
