Home » Eclipse Projects » Eclipse Platform » Waiting for background work
Waiting for background work [message #245683] Wed, 26 May 2004 15:38 Go to next message
Steve Kinder is currently offline Steve KinderFriend
I have just installed M9. Project created and worked on with M6 previously.
I keep getting the following popping up now with my unit tests. Not
every time, every few times. Any clue or advice on how to find out what
is going on please. Linux/Motif version.
Cheers
Steve
Launching.
The user operation is waiting for background work to complete. - 1 work
items
left.
Re: Waiting for background work [message #246023 is a reply to message #245683] Thu, 27 May 2004 05:38 Go to previous messageGo to next message
Kevin Barnes is currently offline Kevin BarnesFriend
> Cheers
> Steve
> Launching.
> items
> left.
We really need a Thread dump to be sure what is happening. My guess is
the launch waits for the build to finish, but never gets notification
when it does.
What VM are you using? Do you have "Wait for build" on
(Preferences/Run-Debug/Launching)?
There have been a few similar bugs. Most have been solved now (I think),
but you may want to do a quick Bugzilla search anyway.
Kevin
Re: Waiting for background work [message #246852 is a reply to message #246023] Fri, 28 May 2004 14:22 Go to previous messageGo to next message
java version "1.4.1_07"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.1_07-b02)
Java HotSpot(TM) Client VM (build 1.4.1_07-b02, mixed mode)
I turned "wait for build ..." to Never and that seems to have improved
matters. Should I upgrade the VM? How do I get a thread dump?
Thanks for the help
Steve
> > Cheers
> > Steve
> > Launching.
> > items
> > left.
> when it does.
> Kevin
Re: Waiting for background work [message #247019 is a reply to message #246852] Fri, 28 May 2004 20:24 Go to previous message
Does the dialog eventually go away or are you stuck? We have made
changes to our launching framework to provide better user feedback when
a Job is blocked. In this case, your launch is blocked by a build, but
the launch should automatically go when the build completes (or is
canceled).
With that said there are still bugs to be worked out (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63633 for one example).
RC1 will be out next week and should be an improvement over M9 as there
have been a lot of bugs fixed this week.
I doubt that changing your vm will make a difference. It might be worth
a try though. To get a thread dump hit "Ctrl-Break" in the shell you
used to start eclipse (or "Ctrl-\" if you use linux).
Kevin
> Thanks for the help
> Steve
>>>Cheers
>>>Steve
>>>Launching.
>>>items
>>>left.
>>when it does.
>>Kevin
Previous Topic:Find and Install with M9
Next Topic:[ANN] Jetty Launching/Profiling Plug-in updated for Eclipse M9
Current Time: Mon May 21 21:04:29 GMT 2018
Powered by FUDForum. Page generated in 0.02058 seconds
