Home » Eclipse Projects » BIRT » Bar Chart SeriesPallete (Color) isnt acting as it should
Bar Chart SeriesPallete (Color) isnt acting as it should [message #242410] Wed, 13 June 2007 04:55 Go to next message
Peter Hoffmann is currently offline Peter Hoffmann
Hallo!
I guess i found a (disturbing) bug:
I have a bar chart with 20+ bars. What I want is to set more colors
(SeriesPalette), so that each bar of my chart has its own color. Birt does
provide a color picker which is initially set to 8 colors. When I m
extending it to lets say 15 colors, the additional colors wont be used in my
chart (wether html nor pdf output will use it). While looking deeper into
it, I found out, that in the generated xml document from the designer it
lists more than 8 colors, but the additional created ones are just ignored.
Plz see attached image. (I could have attached even the bar chart with 8
colors but it looks exactly the same :)
I didnt found a bugzilla entry, can anyone confirm this?
BTW:
Eclipse BIRT Designer Version 2.1.2.v20070205-1728
Cheer
Pete
  • Attachment: ex.JPG
    (Size: 28.06KB, Downloaded 29 times)
Re: Bar Chart SeriesPallete (Color) isnt acting as it should [message #242449 is a reply to message #242410] Wed, 13 June 2007 07:51 Go to previous messageGo to next message
Never mind, its working now!
stupid i was always adding/removing the colors from the wrong axe :)
sry,
Pete
"Peter Hoffmann" <petepack@gmx.de> schrieb im Newsbeitrag
news:f4obfa$jgf$1@build.eclipse.org...
> Hallo!
> my chart (wether html nor pdf output will use it). While looking deeper
> into it, I found out, that in the generated xml document from the designer
> it lists more than 8 colors, but the additional created ones are just
> ignored.
> BTW:
> Cheer
> Pete
Re: Bar Chart SeriesPallete (Color) isnt acting as it should [message #242467 is a reply to message #242449] Wed, 13 June 2007 08:13 Go to previous message
David Michonneau is currently offline David Michonneau
The UI has been improved in 2.2 to show only one Palette button so there is
no mistake possible now :)
David
"Peter Hoffmann" <petepack@gmx.de> wrote in message
news:f4olq2$chi$1@build.eclipse.org...
> sry,
> Pete
>> Hallo!
>> does provide a color picker which is initially set to 8 colors. When I m
>> designer it lists more than 8 colors, but the additional created ones are
>> just ignored.
>> BTW:
>> Cheer
>> Pete
Previous Topic:Define custom colors for special values for Y Series Grouping Values in Chart
Next Topic:Question about BIRT limitations..
Current Time: Tue May 21 07:09:59 EDT 2013
Powered by FUDForum. Page generated in 0.07085 seconds
