Home » Eclipse Projects » BIRT » using the birt viewer
using the birt viewer [message #240002] Sat, 26 May 2007 01:58 Go to next message
ice70 is currently offline ice70Friend
hai....
i would like to use the whole birt viewer in my system. how can i make it?
any idea or references from anyone? thanks...
as your references, i am using the eclipse 3.1 and as i know it only
support the birt 1.xx, am i right?
thanks for your reply...
Re: using the birt viewer [message #240040 is a reply to message #240002] Mon, 28 May 2007 08:47 Go to previous messageGo to next message
hi...
in other words, what i wish to do is something like that can view from url
below:
http://itext.ugent.be:8080/WebViewerExample/frameset?__repor t=test.rptdesign&sample=my+parameter
i wish to have this kind of the birt viewer in my system. how can i make
it?
thanks for reply.
Re: using the birt viewer [message #240117 is a reply to message #240040] Tue, 29 May 2007 08:04 Go to previous messageGo to next message
mr. burns is currently offline mr. burnsFriend
Hello 70,
on the BIRT webpage there you can find a step-by-step instruction how to
install the BIRT WebViewer.
Here is the link:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
Hope that helps ;-)
Re: using the birt viewer [message #240271 is a reply to message #240117] Wed, 30 May 2007 00:25 Go to previous messageGo to next message
Mr. Burns,
thanks for your information. But that is step-by-step instruction to
install the birt viewer in the eclipse.
What i wish to have is to deploy the whole viewer into my system. any idea
on it?
thanks.
Re: using the birt viewer [message #240276 is a reply to message #240271] Wed, 30 May 2007 01:11 Go to previous message
hi hi.... as more refers, i am using eclipse3.1 for my system. and i wish
to deploy the birt viewer in my system...
Previous Topic:Can anyone help me..
Next Topic:Strange behaviour in either RCP designer or my own mind :-)
Current Time: Fri May 25 05:35:05 GMT 2018
Powered by FUDForum. Page generated in 0.01452 seconds
