How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an exi [message #239472] |
Thu, 04 January 2007 22:34 |
Originally posted by: kwarner.uneedspeed.net
Ok, here's some thing that should be simple. I have a Java source file -- let's call it Foo.Java -- it defines a class. I want to bring it into my existing project -- lets call it Bar. I put Foo.Java into my source folder (src) and I can edit it. But I can't compile it or cause it to be built when I build my project.
How do I integrate the Java source into my project. I've looked in the Help System and get no help.
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239477 is a reply to message #239472] |
Fri, 05 January 2007 00:18 |
Ok, I see how to Import a file. I also see that Save'ing the file causes a compile.
Is there a Compile button somewhere that I'm overlooking? Seems that Save'ing to Compile is a little obtuse. A Compile button/menu item seems more direct.
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239482 is a reply to message #239477] |
Fri, 05 January 2007 02:58 |
Originally posted by: wegener.cboenospam.com
> causes a compile.
> seems more direct.
The Eclipse Java development tools are designed around an incremental
compiler that makes sure the project is always fully built. The build
process kicks in when whenever a resource (file) is saved. There is no
need for a separate compile button as long as the automatic build option
is turned on.
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239544 is a reply to message #239482] |
Fri, 05 January 2007 19:09 |
David Wegener wrote:
>> causes a compile. Is there a Compile button somewhere that I'm
> is turned on.
Ok... but, "...there is no need for a separate compile button..." With all the fine grained feature sets in Eclipse -- there's no compile this file button????
Ok... who am I to argue...
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239546 is a reply to message #239544] |
Sat, 06 January 2007 01:43 |
>> no need for a separate compile button as long as the automatic build
>> option is turned on.
> file button????
With automatic build turned on, all files that need to be are compiled
every time you save a file. All files are up to date. Hitting a
compile this file button would be a waste of time.
If you turn off automatic build, a Build All button is added to the tool
bar. You can also use Project->Build All to build the project in this mode.
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239554 is a reply to message #239546] |
Sat, 06 January 2007 18:56 |
> mode.
Oh... Thanks... That's good to know.
I've had to work on Java code that had circular dependencies in it. I know -- hard to believe that a Java project could have circular dependencies but it happened to me. A whole bunch of really bright programmers worked really hard to put together a large program with circular dependencies -- it should be in some kind of record book.
The only way I got it untangled was to compile one file at a time using the class files from the previous versions of the other class files so everything was not up to date at the same time. The app wouldn't have run but it could be compiled....
This is why I think a "compile this file" button is a good capability to have.
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239945 is a reply to message #239554] |
Sat, 20 January 2007 23:45 |
Originally posted by: thunderaxiom.gmail.com
DemonDuck skrev den 06-01-2007 19:56:
> have.
I inherited such a project. It turned out that some refactoring got rid
of the circular dependency.
You will most likely want to create a new project in your workspace for
the code that needs to be compiled first.
Thorbjørn
Re: How do I bring, integrate, include -- whatever you want to call it -- a Java source file into an [message #239954 is a reply to message #239945] |
Sun, 21 January 2007 00:43 |
>> to have.
Thankfully, that project I mentioned is history.
There's always a workaround but it would be nice simple addition to Eclipse to have a "Compile This File" button. But maybe Java can't just compile one file and leave unresolved links. Might need compiler mods to do that. Didn't think about that until now.
FUDForum. Page generated in 0.02239 seconds
