Home » Language IDEs » Java Development Tools (JDT) » o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented
o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236212] Thu, 21 September 2006 21:13 Go to next message
Michael Giroux is currently offline Michael GirouxFriend
Javadocs for org.eclipse.jdt.core.IWorkingCopy.commit() indicate the method
is depricated, but do not indicate what the alternative is.
Should I file a bug report on this?
FWIW, destroy() is in the same boat.
Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236220 is a reply to message #236212] Thu, 21 September 2006 22:03 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
IWorkingCopy itself is deprecated. You shouldn't be using it. You should
be using ICompilationUnit.
An ICompilationUnit can become a working copy, this is through the
becomeWorkingCopy method on it. Then it can be treated just like the old
working copy concept, and then can finally be commited. Then the
ICompilationUnit is now marked as the primary copy.
> Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236233 is a reply to message #236212] Fri, 22 September 2006 09:11 Go to previous messageGo to next message
Philippe Mulet is currently offline Philippe MuletFriend
In fact, this method did not get specifically deprecated, but rather the
entire IWorkingCopy interface for release 3.1.
The idea is that IWorkingCopy functionalities got merged into
ICompilationUnit. So use ICompilationUnit#commitWorkingCopy(...) instead.
See also:
http://help.eclipse.org/help32/topic/org.eclipse.jdt.doc.isv /guide/jdt_api_manip.htm
> Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236256 is a reply to message #236233] Fri, 22 September 2006 14:57 Go to previous messageGo to next message
FWIW, I am using the ICompilationUnit.commitWorkingCopy.
My post has to do w/ the javadocs for IWorkingCopy. The issue is that the
javadocs for ICompilationUnit contain links to methods inherited from
IWorkingCopy. Clicking on any of the methods (commit, destroy, ..) get you
directly to the method javadoc which only says depricated. It does not
refer you to ICompilationUnit#commitWorkingCopy(...).
Since you enter the javadocs directly at the method you do not see the
global notice at the top of IWorkingCopy that it is depricated and should
use ICompilationUnit. Given the sheer magnitude of the overall API and the
fact that I managed to stumble into commit() before I found
commitWorkingCopy, it seemed to me that informing the reader that
ICompilationUnit#commitWorkingCopy should be used would be a useful
addition.
Michael
"Philippe Mulet" <philippe_mulet@fr.ibm.com> wrote in message
news:ef09bb$r5f$1@utils.eclipse.org...
> See also:
>> method is depricated, but do not indicate what the alternative is.
>> Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236440 is a reply to message #236256] Tue, 26 September 2006 13:49 Go to previous messageGo to next message
Frederic Fusier is currently offline Frederic FusierFriend
Problem is not in ICompilationUnit's javadoc comments, but in
CompilationUnit ones. But, you spotted a real problem!
There are also some other places where these invalid references to
IWorkingCopy are done in javadoc comments: SourceType and BinaryType.
Please open a bug against JDT/Core component and I'll fix it ASAP.
> addition.
> Michael
>> See also:
>>> Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #236500 is a reply to message #236440] Wed, 27 September 2006 11:21 Go to previous messageGo to next message
I opened bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=158951 as I
needed bug ID to follow-up work on this item...
> Thanks
>> the javadocs for ICompilationUnit contain links to methods inherited
>> from IWorkingCopy. Clicking on any of the methods (commit, destroy,
>> ..) get you directly to the method javadoc which only says
>> depricated. It does not refer you to
>> should use ICompilationUnit. Given the sheer magnitude of the overall
>> API and the fact that I managed to stumble into commit() before I
>> found commitWorkingCopy, it seemed to me that informing the reader
>> that ICompilationUnit#commitWorkingCopy should be used would be a
>> useful addition.
>> Michael
>>> the entire IWorkingCopy interface for release 3.1.
>>> instead.
>>> See also:
>>>> Michael Giroux.
Re: o.e.jdt.core.IWorkingCopy.commit depricated but no alternative documented [message #237208 is a reply to message #236500] Mon, 09 October 2006 14:55 Go to previous message
Frederic,
Thanks for opening the bug and sorry for not getting to this myself. I was
in a training session and was not monitoring the newsgroup.
Michael Giroux
"Frederic Fusier" <frederic_fusier@fr.ibm.com> wrote in message
news:efdmrk$n1v$1@utils.eclipse.org...
>> Thanks
>>> from IWorkingCopy. Clicking on any of the methods (commit, destroy, ..)
>>> get you directly to the method javadoc which only says depricated. It
>>> does not refer you to ICompilationUnit#commitWorkingCopy(...).
>>> API and the fact that I managed to stumble into commit() before I found
>>> addition.
>>> Michael
>>>> instead.
>>>> See also:
>>>>> Michael Giroux.
Previous Topic:running junit programmatically.. and opening junit view
Next Topic:Null reference warnings
Current Time: Fri Feb 23 16:57:30 GMT 2018
Powered by FUDForum. Page generated in 0.01703 seconds
