Home » Eclipse Projects » Subversive » Hanging SVN actions
Hanging SVN actions [message #23110] Tue, 01 July 2008 06:28 Go to next message
Thomas Hallgren is currently offline Thomas Hallgren
I have frequent problems with hanging SVN actions. The process just
hangs when I do update, show history, or commit. The really annoying
thing is that clicking on 'Cancel' doesn't have any effect other then a
'Cancel requested' message. The action is never cancelled. If I try to
shut down my IDE, it hangs on this action.
I'm using the SVNKit connector. I've tried both the 1.1.7 and the 1.2.0.
The result is the same.
The only way out is to kill the process from the outside.
I would be nice if the commands were equipped with some timeout function
and functional cancellations.
Kind Regards,
Thomas Hallgren
Re: Hanging SVN actions [message #23540 is a reply to message #23110] Wed, 02 July 2008 09:20 Go to previous messageGo to next message
Eclipse User
Originally posted by: alexander.gurov.polarion.org
Hello Thomas,
I have never seen the described behaviour. Could you please provide a
stack traces of the frozen Eclipse IDE instance?
You can read more about stack traces capturing here:
http://wiki.eclipse.org/How_to_report_a_deadlock
Re: Hanging SVN actions [message #23972 is a reply to message #23540] Wed, 02 July 2008 14:50 Go to previous messageGo to next message
Hi Alexander,
There are two issues:
1. The fact that the commit hangs for a very long time (17 minutes on
this time).
2. The fact that it cannot be canceled while it hangs.
I don't think the actual hanging is your fault. It's probably due to
connection problems with dev.eclipse.org (that's the only server where I
experience this). Below is a sample trace of a commit of a few fairly
small files. The time was 17 minutes!
First nothing at all happens, and then, after 17 minutes, everything is
committed in a few seconds.
During this time, there's no way to cancel the commit. I have to kill my
IDE from the outside and then restart it. A normal exit doesn't help
since it waits for the SVN commit job to complete. This is very
annoying. I also feel that a timeout slightly lower then 17 minutes
would be appropriate :-)
Regarding a stacktrace; unfortunately, on this occasion, I used JDK 1.5
to start and it was not console enabled. The stdout from the process was
/dev/null since I started it using a gtk launcher.
I'm using JDK 1.6 now so the next time this happens, I promise I'll send
a stacktrace. Don't expect anything out of the ordinary though, since if
I wait long enough, the commit succeeds.
Kind Regards,
Thomas Hallgren
svn commit
" /home/thhal/workspaces/cirrus/plugins/org.eclipse.buckminste r.ant " -m
"Added buckminster.signatureCleaner ant-task"
M
/home/thhal/workspaces/cirrus/plugins/org.eclipse.buckminste r.ant/plugin.xml
A
/home/thhal/workspaces/cirrus/plugins/org.eclipse.buckminste r.ant/src/ant_tasks/org/eclipse/buckminster/ant/taskdefs/Sig natureCleaner.java
A
/home/thhal/workspaces/cirrus/plugins/org.eclipse.buckminste r.ant/src/java/org/eclipse/buckminster/ant/tasks/SignatureCl eanerTask.java
Transmitting file data:
Committed revision 9443
*** Ok (took 17:08.924)
Alexander Gurov wrote:
> Hello Thomas,
Re: Hanging SVN actions [message #24128 is a reply to message #23972] Thu, 03 July 2008 05:01 Go to previous messageGo to next message
Eclipse User
Unfortunately it looks like one issue. In Subversive plug-in cancellation
is performed by special cancellation thread which monitors return value of
IProgressMonitor.isCancelled method then calls
SVNClientInterface.cancelOperation method. Polling time is less than 1
second. So, regarding to your analysis of the problem I think that client
library does not check cancellation status during all this time.
Re: Hanging SVN actions [message #24330 is a reply to message #24128] Thu, 03 July 2008 11:02 Go to previous messageGo to next message
What can be done about this?
> cancellation is performed by special cancellation thread which monitors
> return value of IProgressMonitor.isCancelled method then calls
> client library does not check cancellation status during all this time.
Re: Hanging SVN actions [message #24411 is a reply to message #24330] Thu, 03 July 2008 11:44 Go to previous messageGo to next message
Eclipse User
I have no idea except asking SVN Kit developers about this situation. In
any case stack trace will help a lot.
Re: Hanging SVN actions [message #24452 is a reply to message #24411] Thu, 03 July 2008 12:13 Go to previous messageGo to next message
--------------050701060001020008070700
Here's a jstack output.
Thomas Hallgren
name="hanging.stack"
Content-Disposition: inline;
filename="hanging.stack"
2008-07-03 14:43:22
Full thread dump Java HotSpot(TM) Server VM (10.0-b19 mixed mode):
"Attach Listener" daemon prio=10 tid=0x096d7000 nid=0x9b1 waiting on condition [0x00000000..0x00000000]
java.lang.Thread.State: RUNNABLE
"SVN Kit 1.1 Connector" prio=10 tid=0xcf835400 nid=0x974 in Object.wait() [0xcf721000..0xcf721f30]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector$Progr essMonitorThread.run(SVNKitConnector.java:1347)
- locked <0xd5611c68> (a java.util.ArrayList)
"Worker-6" prio=10 tid=0x08831c00 nid=0x96c in Object.wait() [0xcf784000..0xcf7850b0]
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0xd51375a8> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
"Worker-5" prio=10 tid=0xcf106800 nid=0x96b in Object.wait() [0xcff7a000..0xcff7b130]
"SVN-HSNUP" prio=10 tid=0x0926a800 nid=0x965 runnable [0xcfaad000..0xcfaadeb0]
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.fill(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
- locked <0xd563cc28> (a java.io.BufferedInputStream)
at org.tmatesoft.svn.core.internal.io.dav.http.ChunkedInputStre am.read(ChunkedInputStream.java:69)
at java.util.zip.InflaterInputStream.fill(Unknown Source)
at java.util.zip.InflaterInputStream.read(Unknown Source)
at java.util.zip.GZIPInputStream.read(Unknown Source)
at sun.nio.cs.StreamDecoder.readBytes(Unknown Source)
at sun.nio.cs.StreamDecoder.implRead(Unknown Source)
at sun.nio.cs.StreamDecoder.read(Unknown Source)
- locked <0xd563cb08> (a java.io.InputStreamReader)
at java.io.InputStreamReader.read(Unknown Source)
at org.tmatesoft.svn.core.internal.io.dav.http.XMLReader.read(X MLReader.java:39)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.loa d(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLEntityScanner.ski pChar(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown Source)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.r eadData(HTTPConnection.java:686)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.r eadData(HTTPConnection.java:651)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPRequest.disp atch(HTTPRequest.java:207)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.r equest(HTTPConnection.java:300)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.r equest(HTTPConnection.java:246)
at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.r equest(HTTPConnection.java:234)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.doRepor t(DAVConnection.java:219)
at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.doRepor t(DAVConnection.java:211)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.update( DAVRepository.java:610)
at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdate Client.java:162)
at org.tmatesoft.svn.core.wc.SVNUpdateClient.doCheckout(SVNUpda teClient.java:344)
at org.tmatesoft.svn.core.javahl.SVNClientImpl.checkout(SVNClie ntImpl.java:370)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector.check out(SVNKitConnector.java:198)
at org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.checkout(ThreadNameModifier.java:76)
at org.eclipse.buckminster.subversive.internal.SubversiveRemote FileReader.innerMaterialize(SubversiveRemoteFileReader.java: 103)
at org.eclipse.buckminster.core.reader.AbstractCatalogReader.ma terialize(AbstractCatalogReader.java:164)
at org.eclipse.buckminster.core.materializer.FileSystemMaterial izer.materialize(FileSystemMaterializer.java:265)
at org.eclipse.buckminster.core.materializer.MaterializerJob.ru n(MaterializerJob.java:59)
"ModalContext" prio=10 tid=0x087bd000 nid=0x964 waiting on condition [0xcfc63000..0xcfc63f30]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at org.eclipse.core.internal.jobs.JobManager.join(JobManager.ja va:794)
at org.eclipse.buckminster.core.materializer.MaterializationJob .waitForJobs(MaterializationJob.java:258)
at org.eclipse.buckminster.core.materializer.MaterializationJob .internalRun(MaterializationJob.java:151)
at org.eclipse.buckminster.jnlp.JNLPMaterializationJob.runDeleg ated(JNLPMaterializationJob.java:26)
at org.eclipse.buckminster.jnlp.MaterializerRunnable.run(Materi alizerRunnable.java:45)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
"Java indexing" daemon prio=10 tid=0xcf146400 nid=0x963 in Object.wait() [0xcfafe000..0xcfafefb0]
java.lang.Thread.State: WAITING (on object monitor)
- waiting on <0xd4fe7348> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at java.lang.Object.wait(Object.java:485)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:371)
- locked <0xd4fe7348> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at java.lang.Thread.run(Unknown Source)
"Timer-0" prio=10 tid=0x08a88000 nid=0x959 in Object.wait() [0xd02c6000..0xd02c6e30]
- waiting on <0xd4ebb6b0> (a java.util.TaskQueue)
at java.util.TimerThread.mainLoop(Unknown Source)
- locked <0xd4ebb6b0> (a java.util.TaskQueue)
at java.util.TimerThread.run(Unknown Source)
"Start Level Event Dispatcher" daemon prio=10 tid=0x08afe400 nid=0x958 in Object.wait() [0xd0218000..0xd0218eb0]
- waiting on <0xd4ea0900> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:377)
- locked <0xd4ea0900> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:317)
"Framework Event Dispatcher" daemon prio=10 tid=0x08b32c00 nid=0x956 in Object.wait() [0xd0275000..0xd0275f30]
- locked <0xd4e8fa58> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
"State Data Manager" daemon prio=10 tid=0x08b1c000 nid=0x953 waiting on condition [0xd0317000..0xd0318030]
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:297)
"Low Memory Detector" daemon prio=10 tid=0x08742400 nid=0x94f runnable [0x00000000..0x00000000]
"CompilerThread1" daemon prio=10 tid=0x08740c00 nid=0x94e waiting on condition [0x00000000..0xd0495278]
"CompilerThread0" daemon prio=10 tid=0x0873e400 nid=0x94d waiting on condition [0x00000000..0xd05162f8]
"Signal Dispatcher" daemon prio=10 tid=0x0873d000 nid=0x94b runnable [0x00000000..0xd0567b90]
"Finalizer" daemon prio=10 tid=0x08726c00 nid=0x94a in Object.wait() [0xd07b8000..0xd07b8f30]
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0xd4dd9d60> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
"Reference Handler" daemon prio=10 tid=0x08722800 nid=0x949 in Object.wait() [0xd0809000..0xd0809fb0]
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0xd4ddd5f8> (a java.lang.ref.Reference$Lock)
"main" prio=10 tid=0x0869f800 nid=0x945 runnable [0xf7eec000..0xf7eed208]
at org.eclipse.swt.internal.gtk.OS.Call(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:3801)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:370)
at org.eclipse.buckminster.jnlp.ui.general.wizard.AdvancedWizar dDialog.run(AdvancedWizardDialog.java:189)
at org.eclipse.buckminster.jnlp.wizard.install.InstallWizard.pe rformFinish(InstallWizard.java:507)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
at org.eclipse.buckminster.jnlp.ui.general.wizard.AdvancedWizar dDialog.finishPressed(AdvancedWizardDialog.java:101)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3401)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.buckminster.jnlp.ui.general.wizard.AdvancedWizar dDialog.open(AdvancedWizardDialog.java:70)
at org.eclipse.buckminster.jnlp.Application.start(Application.j ava:296)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
"VM Thread" prio=10 tid=0x0871dc00 nid=0x948 runnable
"GC task thread#0 (ParallelGC)" prio=10 tid=0x086a6400 nid=0x946 runnable
"GC task thread#1 (ParallelGC)" prio=10 tid=0x086a7400 nid=0x947 runnable
"VM Periodic Task Thread" prio=10 tid=0x08743c00 nid=0x950 waiting on condition
JNI global references: 1178
--------------050701060001020008070700--
Re: Hanging SVN actions [message #25071 is a reply to message #24452] Tue, 08 July 2008 04:08 Go to previous messageGo to next message
Eclipse User
Hello Thomas,
I sent description of this problem and reference to this thread to SVN Kit
developers and I hope that provided stack trace will help them to find and
solve the problem. Thank you once again!
Re: Hanging SVN actions [message #25637 is a reply to message #25071] Tue, 15 July 2008 09:27 Go to previous messageGo to next message
--------------090002020303010003090105
Hello Alexander,
I have an update to this that might be relevant. Here I'm using a
JRockit JVM and it's a SVN update, not a check-out. The really
interesting thing is that this also took just above 17 minutes to
accomplish. A jstack thread-dump is attached. Here's the console trace:
Thomas Hallgren
*** Update
svn update
" /home/thhal/workspaces/bucky/plugins/org.eclipse.buckminster .pde " -r
HEAD --username "thallgren"
/home/thhal/workspaces/bucky/plugins/org.eclipse.buckminster .pde/src/java/org/eclipse/buckminster/pde/antscripts
At revision 9453
*** Ok (took 17:20.866)
> Hello Thomas,
> Kit developers and I hope that provided stack trace will help them to
> find and solve the problem. Thank you once again!
name="svnupdate.stack"
filename="svnupdate.stack"
===== FULL THREAD DUMP ===============
Tue Jul 15 15:01:57 2008
BEA JRockit(R) R27.5.0-110_o-99226-1.6.0_03-20080528-1505-linux-x86_64
"Main Thread" id=1 idx=0x4 tid=14036 prio=6 alive, in native
at org/eclipse/swt/internal/gtk/OS.Call(JJII)I(Native Method)
at org/eclipse/swt/widgets/Display.sleep(Display.java:3801)
at org/eclipse/ui/application/WorkbenchAdvisor.eventLoopIdle(Wo rkbenchAdvisor.java:364)
at org/eclipse/ui/internal/Workbench.runEventLoop(Workbench.jav a:2383)
at org/eclipse/ui/internal/Workbench.runUI(Workbench.java:2346)
at org/eclipse/ui/internal/Workbench.access$4(Workbench.java:21 98)
at org/eclipse/ui/internal/Workbench$5.run(Workbench.java:493)
at org/eclipse/core/databinding/observable/Realm.runWithDefault (Realm.java:288)
at org/eclipse/ui/internal/Workbench.createAndRunWorkbench(Work bench.java:488)
at org/eclipse/ui/PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at org/eclipse/ui/internal/ide/application/IDEApplication.start (IDEApplication.java:113)
at org/eclipse/equinox/internal/app/EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org/eclipse/core/runtime/internal/adaptor/EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseS tarter.java:382)
at org/eclipse/core/runtime/adaptor/EclipseStarter.run(EclipseS tarter.java:179)
at jrockit/vm/RNI.c2java(JJJJJ)V(Native Method)
at jrockit/vm/Reflect.invokeMethod(Ljava/lang/Object;Ljava/lang /Object;[Ljava/lang/Object;)Ljava/lang/Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke0(Ljava/lang/refl ect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/ Object;(Native Method)
at sun/reflect/NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun/reflect/DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java/lang/reflect/Method.invoke(Method.java:597)
at org/eclipse/equinox/launcher/Main.invokeFramework(Main.java: 549)
at org/eclipse/equinox/launcher/Main.basicRun(Main.java:504)
at org/eclipse/equinox/launcher/Main.run(Main.java:1236)
at org/eclipse/equinox/launcher/Main.main(Main.java:1212)
-- end of trace
"(Signal Handler)" id=2 idx=0x8 tid=14037 prio=5 alive, in native, daemon
"(GC Main Thread)" id=3 idx=0xc tid=14038 prio=5 alive, in native, native_waiting, daemon
"(GC Worker Thread 1)" id=? idx=0x10 tid=14039 prio=5 alive, in native, daemon
"(GC Worker Thread 2)" id=? idx=0x14 tid=14040 prio=5 alive, in native, daemon
"(Code Generation Thread 1)" id=4 idx=0x18 tid=14041 prio=5 alive, in native, native_waiting, daemon
"(Code Optimization Thread 1)" id=5 idx=0x1c tid=14042 prio=5 alive, in native, native_waiting, daemon
"(VM Periodic Task)" id=6 idx=0x20 tid=14043 prio=10 alive, in native, daemon
"Finalizer" id=7 idx=0x24 tid=14044 prio=8 alive, in native, native_waiting, daemon
at jrockit/memory/Finalizer.waitForFinalizees([Ljava/lang/Objec t;)I(Native Method)
at jrockit/memory/Finalizer.access$500(Finalizer.java:12)
at jrockit/memory/Finalizer$4.run(Finalizer.java:159)
at java/lang/Thread.run(Thread.java:619)
-- end of trace
"Reference Handler" id=8 idx=0x28 tid=14045 prio=10 alive, in native, native_waiting, daemon
at java/lang/ref/Reference.waitForActivatedQueue()Ljava/lang/re f/Reference;(Native Method)
at java/lang/ref/Reference.access$100(Reference.java:11)
at java/lang/ref/Reference$ReferenceHandler.run(Reference.java: 79)
-- end of trace
"(Sensor Event Thread)" id=9 idx=0x2c tid=14046 prio=5 alive, in native, daemon
"State Data Manager" id=11 idx=0x30 tid=14048 prio=5 alive, in native, sleeping, native_waiting, daemon
at java/lang/Thread.sleep(J)V(Native Method)
at org/eclipse/osgi/internal/baseadaptor/StateManager.run(State Manager.java:297)
-- end of trace
"Framework Event Dispatcher" id=12 idx=0x34 tid=14049 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/osgi/framework/eventmgr/EventManager$EventThread@0x46cf8f8[fat lock]
at jrockit/vm/Threads.waitForNotifySignal(JLjava/lang/Object;)Z (Native Method)
at java/lang/Object.wait(J)V(Native Method)
at java/lang/Object.wait(Object.java:485)
at org/eclipse/osgi/framework/eventmgr/EventManager$EventThread .getNextEvent(EventManager.java:377)
^-- Lock released while waiting: org/eclipse/osgi/framework/eventmgr/EventManager$EventThread@0x46cf8f8[fat lock]
at org/eclipse/osgi/framework/eventmgr/EventManager$EventThread .run(EventManager.java:317)
-- end of trace
"Start Level Event Dispatcher" id=13 idx=0x38 tid=14050 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/osgi/framework/eventmgr/EventManager$EventThread@0x46cf998[fat lock]
^-- Lock released while waiting: org/eclipse/osgi/framework/eventmgr/EventManager$EventThread@0x46cf998[fat lock]
-- end of trace
"Java indexing" id=17 idx=0x48 tid=14059 prio=4 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jdt/internal/core/search/indexing/IndexManager@0x47160c0[fat lock]
at org/eclipse/jdt/internal/core/search/processing/JobManager.r un(JobManager.java:371)
^-- Lock released while waiting: org/eclipse/jdt/internal/core/search/indexing/IndexManager@0x47160c0[fat lock]
-- end of trace
"Packet Send Manager" id=623 idx=0x58 tid=18233 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: java/util/LinkedList@0xeac4b80[fat lock]
at java/lang/Object.wait(J)V(Native Method)[optimized]
at org/eclipse/jdi/internal/connect/PacketSendManager.sendAvail ablePackets(PacketSendManager.java:98)
^-- Lock released while waiting: java/util/LinkedList@0xeac4b80[fat lock]
at org/eclipse/jdi/internal/connect/PacketSendManager.run(Packe tSendManager.java:53)
-- end of trace
"SVN Kit 1.2 Connector" id=31 idx=0x7c tid=14074 prio=5 alive, in native, waiting
-- Waiting for notification on: java/util/ArrayList@0x4712dd8[fat lock]
at org/polarion/team/svn/connector/svnkit/SVNKitConnector$Progr essMonitorThread.run(SVNKitConnector.java:1458)
^-- Lock released while waiting: java/util/ArrayList@0x4712dd8[fat lock]
-- end of trace
"org.eclipse.ant.internal.ui.editor.text.NotifyingReconciler " id=93 idx=0x174 tid=14148 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x4672878[fat lock]
at org/eclipse/jface/text/reconciler/AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:179)
^-- Lock released while waiting: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x4672878[fat lock]
-- end of trace
"Timer-59" id=94 idx=0x178 tid=14149 prio=6 alive, in native, waiting
-- Waiting for notification on: java/util/TaskQueue@0x44c8ee0[fat lock]
at java/util/TimerThread.mainLoop(Timer.java:483)
^-- Lock released while waiting: java/util/TaskQueue@0x44c8ee0[fat lock]
at java/util/TimerThread.run(Timer.java:462)
-- end of trace
"Thread-66" id=95 idx=0x17c tid=14160 prio=1 alive, in native, daemon
at jrockit/net/SocketNativeIO.readBytesPinned(Ljava/io/FileDesc riptor;[BIII)I(Native Method)
at jrockit/net/SocketNativeIO.socketRead(SocketNativeIO.java:46 )
at java/net/SocketInputStream.socketRead0(Ljava/io/FileDescript or;[BIII)I(SocketInputStream.java)
at java/net/SocketInputStream.read(SocketInputStream.java:129)
at com/trilead/ssh2/crypto/cipher/CipherInputStream.fill_buffer (CipherInputStream.java:41)
at com/trilead/ssh2/crypto/cipher/CipherInputStream.internal_re ad(CipherInputStream.java:52)
at com/trilead/ssh2/crypto/cipher/CipherInputStream.getBlock(Ci pherInputStream.java:79)
at com/trilead/ssh2/crypto/cipher/CipherInputStream.read(Cipher InputStream.java:108)
at com/trilead/ssh2/transport/TransportConnection.receiveMessag e(TransportConnection.java:232)
at com/trilead/ssh2/transport/TransportManager.receiveLoop(Tran sportManager.java:670)
at com/trilead/ssh2/transport/TransportManager$1.run(TransportM anager.java:469)
-- end of trace
"Thread-67" id=96 idx=0x180 tid=14161 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: com/trilead/ssh2/channel/Channel@0x367f078[fat lock]
at com/trilead/ssh2/channel/ChannelManager.getChannelData(Chann elManager.java:987)
^-- Lock released while waiting: com/trilead/ssh2/channel/Channel@0x367f078[fat lock]
at com/trilead/ssh2/channel/ChannelInputStream.read(ChannelInpu tStream.java:58)
at com/trilead/ssh2/channel/ChannelInputStream.read(ChannelInpu tStream.java:70)
at com/trilead/ssh2/StreamGobbler$GobblerThread.run(StreamGobbl er.java:47)
-- end of trace
"Output Stream Monitor" id=616 idx=0x1d4 tid=18213 prio=1 alive, in native, daemon
at jrockit/io/FileNativeIO.readBytesPinned(Ljava/io/FileDescrip tor;[BII)I(Native Method)
at jrockit/io/FileNativeIO.readBytes(FileNativeIO.java:46)
at java/io/FileInputStream.readBytes([BII)I(FileInputStream.jav a)
at java/io/FileInputStream.read(FileInputStream.java:199)
at java/io/BufferedInputStream.read1(BufferedInputStream.java:2 56)
at java/io/BufferedInputStream.read(BufferedInputStream.java:31 7)
^-- Holding lock: java/io/BufferedInputStream@0xe2f9c30[biased lock]
^-- Holding lock: java/io/BufferedInputStream@0xf2f9600[biased lock]
at java/io/FilterInputStream.read(FilterInputStream.java:90)
at org/eclipse/debug/internal/core/OutputStreamMonitor.read(Out putStreamMonitor.java:144)
at org/eclipse/debug/internal/core/OutputStreamMonitor.access$1 (OutputStreamMonitor.java:134)
at org/eclipse/debug/internal/core/OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:207)
-- end of trace
"Worker-52" id=586 idx=0x228 tid=18134 prio=5 alive, in native, waiting
-- Waiting for notification on: org/eclipse/ui/console/IOConsoleInputStream@0xf1829a8[fat lock]
at org/eclipse/ui/console/IOConsoleInputStream.waitForData(IOCo nsoleInputStream.java:147)
at org/eclipse/ui/console/IOConsoleInputStream.read(IOConsoleIn putStream.java:92)
^-- Lock released while waiting: org/eclipse/ui/console/IOConsoleInputStream@0xf1829a8[fat lock]
at org/eclipse/ui/console/IOConsoleInputStream.read(IOConsoleIn putStream.java:117)
at org/eclipse/debug/internal/ui/views/console/ProcessConsole$I nputReadJob.run(ProcessConsole.java:679)
at org/eclipse/core/internal/jobs/Worker.run(Worker.java:55)
-- end of trace
"org.eclipse.jface.text.reconciler.MonoReconciler" id=153 idx=0x264 tid=14766 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x5816780[fat lock]
^-- Lock released while waiting: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x5816780[fat lock]
-- end of trace
"org.eclipse.jdt.internal.ui.text.JavaReconciler" id=164 idx=0x294 tid=14828 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x5be5800[fat lock]
^-- Lock released while waiting: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0x5be5800[fat lock]
-- end of trace
"process reaper" id=615 idx=0x2a8 tid=18210 prio=5 alive, in native, daemon
at java/lang/UNIXProcess.waitForProcessExit(I)I(Native Method)
at java/lang/UNIXProcess.access$900(UNIXProcess.java:20)
at java/lang/UNIXProcess$1$1.run(UNIXProcess.java:132)
-- end of trace
"Output Stream Monitor" id=617 idx=0x2b4 tid=18214 prio=1 alive, in native, daemon
^-- Holding lock: java/io/BufferedInputStream@0xf183cd0[biased lock]
-- end of trace
"Input Stream Monitor" id=618 idx=0x2b8 tid=18215 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: java/lang/Object@0xf183ed0[fat lock]
at org/eclipse/debug/internal/core/InputStreamMonitor.writeNext (InputStreamMonitor.java:136)
^-- Lock released while waiting: java/lang/Object@0xf183ed0[fat lock]
at org/eclipse/debug/internal/core/InputStreamMonitor.write(Inp utStreamMonitor.java:109)
at org/eclipse/debug/internal/core/InputStreamMonitor$1.run(Inp utStreamMonitor.java:84)
-- end of trace
"Process monitor" id=619 idx=0x2c0 tid=18216 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: java/lang/UNIXProcess@0xf182ec8[fat lock]
at java/lang/UNIXProcess.waitFor(UNIXProcess.java:165)
^-- Lock released while waiting: java/lang/UNIXProcess@0xf182ec8[fat lock]
at org/eclipse/debug/core/model/RuntimeProcess$ProcessMonitorTh read.run(RuntimeProcess.java:405)
-- end of trace
"Packet Receive Manager" id=622 idx=0x2c4 tid=18232 prio=5 alive, in native, daemon
at java/net/SocketInputStream.read(SocketInputStream.java:182)
at java/io/DataInputStream.readInt(DataInputStream.java:370)
at org/eclipse/jdi/internal/connect/SocketConnection.readPacket (SocketConnection.java:60)
^-- Holding lock: java/io/DataInputStream@0x7917510[biased lock]
at org/eclipse/jdi/internal/connect/PacketReceiveManager.readAv ailablePacket(PacketReceiveManager.java:274)
at org/eclipse/jdi/internal/connect/PacketReceiveManager.run(Pa cketReceiveManager.java:82)
-- end of trace
"org.eclipse.jdt.debug: JDI Event Dispatcher" id=624 idx=0x2cc tid=18234 prio=5 alive, in native, waiting, daemon
-- Waiting for notification on: java/util/LinkedList@0xeac5008[fat lock]
at org/eclipse/jdi/internal/connect/PacketReceiveManager.waitFo rPacketAvailable(PacketReceiveManager.java:192)
at org/eclipse/jdi/internal/connect/PacketReceiveManager.getCom mand(PacketReceiveManager.java:103)
^-- Lock released while waiting: java/util/LinkedList@0xeac5008[fat lock]
at org/eclipse/jdi/internal/MirrorImpl.getCommandVM(MirrorImpl. java:277)
at org/eclipse/jdi/internal/event/EventQueueImpl.remove(EventQu eueImpl.java:63)
at org/eclipse/jdt/internal/debug/core/EventDispatcher.run(Even tDispatcher.java:226)
-- end of trace
"SessionScavenger" id=410 idx=0x2e0 tid=16099 prio=6 alive, in native, sleeping, native_waiting, daemon
at org/mortbay/jetty/servlet/AbstractSessionManager$SessionScav enger.run(AbstractSessionManager.java:617)
-- end of trace
"Acceptor ServerSocket[addr=0.0.0.0/0.0.0.0,port=0,localport=44057]" id=411 idx=0x2e4 tid=16100 prio=6 alive, in native
at java/net/PlainSocketImpl.socketAccept(Ljava/net/SocketImpl;) V(Native Method)
at java/net/PlainSocketImpl.accept(PlainSocketImpl.java:384)
^-- Holding lock: java/net/SocksSocketImpl@0x6408b50[biased lock]
at java/net/ServerSocket.implAccept(ServerSocket.java:453)
at java/net/ServerSocket.accept(ServerSocket.java:421)
at org/mortbay/util/ThreadedServer.acceptSocket(ThreadedServer. java:432)
at org/mortbay/util/ThreadedServer$Acceptor.run(ThreadedServer. java:634)
-- end of trace
"SocketListener0-0" id=412 idx=0x2e8 tid=16101 prio=6 alive, in native, waiting
-- Waiting for notification on: org/mortbay/util/ThreadPool$PoolThread@0x6409038[fat lock]
at org/mortbay/util/ThreadPool$PoolThread.run(ThreadPool.java:5 22)
^-- Lock released while waiting: org/mortbay/util/ThreadPool$PoolThread@0x6409038[fat lock]
-- end of trace
"SocketListener0-1" id=413 idx=0x2ec tid=16102 prio=6 alive, in native, waiting
-- Waiting for notification on: org/mortbay/util/ThreadPool$PoolThread@0x64090e8[fat lock]
^-- Lock released while waiting: org/mortbay/util/ThreadPool$PoolThread@0x64090e8[fat lock]
-- end of trace
"Worker-62" id=632 idx=0x2f0 tid=20135 prio=5 alive, in native, waiting
-- Waiting for notification on: java/lang/Object@0x3782770[fat lock]
at org/eclipse/core/internal/jobs/ThreadJob.joinRun(ThreadJob.j ava:189)
^-- Lock released while waiting: java/lang/Object@0x3782770[fat lock]
at org/eclipse/core/internal/jobs/ImplicitJobs.begin(ImplicitJo bs.java:87)
at org/eclipse/core/internal/jobs/JobManager.beginRule(JobManag er.java:230)
at org/eclipse/core/internal/utils/StringPoolJob.run(StringPool Job.java:99)
-- end of trace
"org.eclipse.jdt.internal.ui.text.JavaReconciler" id=637 idx=0x310 tid=20519 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0xf198a38[fat lock]
^-- Lock released while waiting: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0xf198a38[fat lock]
-- end of trace
"org.eclipse.jdt.internal.ui.text.JavaReconciler" id=643 idx=0x32c tid=20525 prio=1 alive, in native, waiting, daemon
-- Waiting for notification on: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0xf1b0660[fat lock]
^-- Lock released while waiting: org/eclipse/jface/text/reconciler/DirtyRegionQueue@0xf1b0660[fat lock]
-- end of trace
"SVN-CE22I" id=657 idx=0x364 tid=20708 prio=5 alive, in native, waiting
at com/trilead/ssh2/channel/ChannelManager.waitForChannelReques tResult(ChannelManager.java:179)
at com/trilead/ssh2/channel/ChannelManager.requestChannelTrilea dPing(ChannelManager.java:634)
at com/trilead/ssh2/Session.ping(Session.java:324)
at org/tmatesoft/svn/core/internal/io/svn/SVNSSHConnector.isSta le(SVNSSHConnector.java:199)
at org/tmatesoft/svn/core/internal/io/svn/SVNConnection.isConne ctionStale(SVNConnection.java:365)
at org/tmatesoft/svn/core/internal/io/svn/SVNRepositoryImpl.ope nConnection(SVNRepositoryImpl.java:1214)
at org/tmatesoft/svn/core/internal/io/svn/SVNRepositoryImpl.set Location(SVNRepositoryImpl.java:119)
at org/tmatesoft/svn/core/wc/DefaultSVNRepositoryPool.createRep ository(DefaultSVNRepositoryPool.java:211)
^-- Holding lock: org/tmatesoft/svn/core/wc/DefaultSVNRepositoryPool@0x46c47c0[biased lock]
at org/tmatesoft/svn/core/wc/SVNClientManager.createRepository( SVNClientManager.java:245)
at org/tmatesoft/svn/core/wc/SVNBasicClient.createRepository(SV NBasicClient.java:294)
at org/tmatesoft/svn/core/wc/SVNBasicClient.createRepository(SV NBasicClient.java:286)
at org/tmatesoft/svn/core/wc/SVNUpdateClient.doUpdate(SVNUpdate Client.java:220)
at org/tmatesoft/svn/core/javahl/SVNClientImpl.update(SVNClient Impl.java:730)
at org/polarion/team/svn/connector/svnkit/SVNKitConnector.updat e(SVNKitConnector.java:281)
at org/eclipse/team/svn/core/extension/factory/ThreadNameModifi er.update(ThreadNameModifier.java:616)
at org/eclipse/team/svn/core/operation/local/UpdateOperation$2. run(UpdateOperation.java:109)
at org/eclipse/team/svn/core/utility/ProgressMonitorUtility.doS ubTask(ProgressMonitorUtility.java:117)
at org/eclipse/team/svn/core/operation/AbstractActionOperation. protectStep(AbstractActionOperation.java:145)
at org/eclipse/team/svn/core/operation/AbstractActionOperation. protectStep(AbstractActionOperation.java:140)
at org/eclipse/team/svn/core/operation/local/UpdateOperation.ru nImpl(UpdateOperation.java:107)
at org/eclipse/team/svn/core/operation/AbstractActionOperation. run(AbstractActionOperation.java:76)
at org/eclipse/team/svn/core/utility/ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
at org/eclipse/team/svn/core/operation/CompositeOperation.runIm pl(CompositeOperation.java:94)
at org/eclipse/team/svn/core/operation/LoggedOperation.run(Logg edOperation.java:37)
at org/eclipse/team/svn/core/utility/ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
at org/eclipse/team/svn/ui/utility/WorkspaceModifyCancellableOp erationWrapper.execute(WorkspaceModifyCancellableOperationWr apper.java:58)
at org/eclipse/ui/actions/WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:104)
at org/eclipse/core/internal/resources/Workspace.run(Workspace. java:1800)
at org/eclipse/ui/actions/WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
^-- Holding lock: org/eclipse/team/svn/ui/utility/WorkspaceModifyCancellableOperationWrapper@0x7d75358[biased lock]
at org/eclipse/team/svn/ui/utility/SVNTeamOperationWrapper.run( SVNTeamOperationWrapper.java:35)
at org/eclipse/team/internal/ui/actions/JobRunnableContext.run( JobRunnableContext.java:144)
at org/eclipse/team/internal/ui/actions/JobRunnableContext$Reso urceJob.runInWorkspace(JobRunnableContext.java:72)
at org/eclipse/core/internal/resources/InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
-- end of trace
"Worker-70" id=658 idx=0x368 tid=20726 prio=5 alive, in native, waiting
-- Waiting for notification on: org/eclipse/core/internal/jobs/WorkerPool@0x46d0930[fat lock]
at org/eclipse/core/internal/jobs/WorkerPool.sleep(WorkerPool.j ava:185)
^-- Lock released while waiting: org/eclipse/core/internal/jobs/WorkerPool@0x46d0930[fat lock]
at org/eclipse/core/internal/jobs/WorkerPool.startJob(WorkerPoo l.java:217)
at org/eclipse/core/internal/jobs/Worker.run(Worker.java:51)
-- end of trace
"Worker-72" id=660 idx=0x370 tid=20897 prio=5 alive, in native, waiting
-- end of trace
"RMI Scheduler(0)" id=664 idx=0x374 tid=20940 prio=5 alive, in native, parked, daemon
at jrockit/vm/Locks.park0(J)V(Native Method)
at jrockit/vm/Locks.park(Locks.java:2490)
at sun/misc/Unsafe.park(ZJ)V(Native Method)
at java/util/concurrent/locks/LockSupport.parkNanos(LockSupport .java:198)
at java/util/concurrent/locks/AbstractQueuedSynchronizer$Condit ionObject.awaitNanos(AbstractQueuedSynchronizer.java:1963)
at java/util/concurrent/DelayQueue.take(DelayQueue.java:164)
at java/util/concurrent/ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:582)
at java/util/concurrent/ScheduledThreadPoolExecutor$DelayedWork Queue.take(ScheduledThreadPoolExecutor.java:575)
at java/util/concurrent/ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:946)
at java/util/concurrent/ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:906)
-- end of trace
"RMI TCP Accept-0" id=662 idx=0x378 tid=20935 prio=5 alive, in native, daemon
^-- Holding lock: java/net/SocksSocketImpl@0x83bbf50[biased lock]
at sun/rmi/transport/tcp/TCPTransport$AcceptLoop.executeAcceptL oop(TCPTransport.java:369)
at sun/rmi/transport/tcp/TCPTransport$AcceptLoop.run(TCPTranspo rt.java:341)
-- end of trace
"(Attach Listener)" id=661 idx=0x37c tid=20926 prio=5 alive, in native, daemon
"RMI TCP Connection(idle)" id=668 idx=0x380 tid=20955 prio=5 alive, in native, parked, daemon
at java/util/concurrent/SynchronousQueue$TransferStack.awaitFul fill(SynchronousQueue.java:424)
at java/util/concurrent/SynchronousQueue$TransferStack.transfer (SynchronousQueue.java:323)
at java/util/concurrent/SynchronousQueue.poll(SynchronousQueue. java:874)
at java/util/concurrent/ThreadPoolExecutor.getTask(ThreadPoolEx ecutor.java:944)
-- end of trace
===== END OF THREAD DUMP ===============
--------------090002020303010003090105--
Re: Hanging SVN actions [message #25688 is a reply to message #25637] Tue, 15 July 2008 12:44 Go to previous messageGo to next message
I have now confirmed that all my SVN actions always execute within a few
seconds or take between 17:06 and 17:20 minutes. What's special about that?
Well, 17 minutes is 1020 seconds. So when the delay occurs, the
execution time is between 1026 to 1040 seconds. Is there perhaps a
timeout of 1024 seconds somewhere? 2 - 16 seconds is very normal in
other cases.
Thomas Hallgren
Thomas Hallgren wrote:
> Hello Alexander,
> Thomas Hallgren
> *** Update
> svn update
> At revision 9453
>> Hello Thomas,
Re: Hanging SVN actions [message #26166 is a reply to message #25688] Sun, 20 July 2008 06:03 Go to previous messageGo to next message
Eclipse User
Hello Thomas,
I don't known anything about timeouts of 1024 seconds anywhere in
Subversive code. So, I sent the reference to last your posts to the SVN
Kit developers.
Re: Hanging SVN actions [message #48625 is a reply to message #25688] Tue, 07 July 2009 07:11 Go to previous messageGo to next message
This bug is tracked by https://bugs.eclipse.org/bugs/show_bug.cgi?id=260743 and at
http://svnkit.com/tracker/view.php?id=311.
Apparently there is a solution in the 1.3.x branch of SVNKit. When will this be available as a polarion bundle? Is there
anything I can do to patch the bundle that I have with the latest SVNKit code?
Needless to say, I'm very anxious to get rid of this problem since I'm hit by it very frequently.
Thomas Hallgren
> other cases.
> Thomas Hallgren
>> Hello Alexander,
>> Regards,
>> Thomas Hallgren
>> *** Update
>> svn update
>> At revision 9453
>>> Hello Thomas,
>>> SVN Kit developers and I hope that provided stack trace will help
>>> them to find and solve the problem. Thank you once again!
Re: Hanging SVN actions [message #49199 is a reply to message #48625] Fri, 10 July 2009 04:48 Go to previous messageGo to next message
Ping?
- thomas
> this be available as a polarion bundle? Is there anything I can do to
> Thomas Hallgren
>> few seconds or take between 17:06 and 17:20 minutes. What's special
>> about that?
>> other cases.
>> Regards,
>> Thomas Hallgren
>>> Hello Alexander,
>>> Regards,
>>> Thomas Hallgren
>>> *** Update
>>> svn update
>>> At revision 9453
>>>> Hello Thomas,
Re: Hanging SVN actions [message #49372 is a reply to message #49199] Fri, 17 July 2009 00:50 Go to previous messageGo to next message
Miles Parker is currently offline Miles Parker
Yeah, me too. In my case it doesn't resolve in 17 minutes -- in fact,
evertime I start the IDE it locks up. I have no idea why but ultimitly
it doesn't matter. **The real issue is that it's really terrible
behavior to run a blocking process that doesn't at the least give the
ability to kill it.**
re: Igor's comment onthat bug..
So we(Subversive) can't resolve this problem in any way and think this bug can
be closed.
See Thomas's reply about the very obvious way to handle this in a
recoverable way.
I'm sorry to be rude, but Subversion has been a consistent headache and
hijacking the entire IDE is going a bit too far.
On 2009-07-10 01:48:52 -0700, Thomas Hallgren <thomas@tada.se> said:
> Ping?
> - thomas
>> Regards,
>> Thomas Hallgren
>>> about that?
>>> other cases.
>>> Regards,
>>> Thomas Hallgren
>>>> Hello Alexander,
>>>> Regards,
>>>> Thomas Hallgren
>>>> *** Update
>>>> svn update
>>>> At revision 9453
>>>>> Hello Thomas,
Re: Hanging SVN actions [message #49403 is a reply to message #49372] Fri, 17 July 2009 01:12 Go to previous messageGo to next message
I should add that I realize that being the layer between these two
environments is very challenging and there are a lot of issues on the
client and server side as well so I am actually sorry to be rude. But
this does seem to be a general problem and has come up under other
scenarios. In a similar circumstance I set a
KILL_AFTER_NO_RESPONSE_TIME value -- if the cancel is hit again then I
simply stop the offending thread. I know that's not really safe
behavior either but if there is some kind of thread lock issue or
whatever at least it gives users some ability to recover and regain
control their environment.
> be closed.
> recoverable way.
>> Ping?
>> - thomas
>>> Regards,
>>> Thomas Hallgren
>>>> about that?
>>>> other cases.
>>>> Regards,
>>>> Thomas Hallgren
>>>>> Hello Alexander,
>>>>> Regards,
>>>>> Thomas Hallgren
>>>>> *** Update
>>>>> svn update
>>>>> At revision 9453
>>>>>> Hello Thomas,
Re: Hanging SVN actions [message #49433 is a reply to message #49372] Fri, 17 July 2009 15:58 Go to previous message
The immedaite issue resolved itself. I had the idea to restart my
machine -- something I don't do very often on my Mac and it went away.
It looks like it was some kind of issue with http authorization from
what I saw on the OS console. But again, the issue is not that a
problem occurred but that it isn't handled correctly.
> be closed.
> recoverable way.
>> Ping?
>> - thomas
>>> Regards,
>>> Thomas Hallgren
>>>> about that?
>>>> other cases.
>>>> Regards,
>>>> Thomas Hallgren
>>>>> Hello Alexander,
>>>>> Regards,
>>>>> Thomas Hallgren
>>>>> *** Update
>>>>> svn update
>>>>> At revision 9453
>>>>>> Hello Thomas,
Previous Topic:Subversive CVS repository
Next Topic:SVN externals
Current Time: Tue Oct 08 08:07:12 EDT 2013
Powered by FUDForum. Page generated in 0.02264 seconds
