Home » Eclipse Projects » GEF » It is indirectly referenced from .class in eclipse
It is indirectly referenced from .class in eclipse [message #235993] Wed, 20 June 2007 05:34 Go to next message
Originally posted by: chaitannyam.yahoo.co.uk
why that error comes ?
Re: It is indirectly referenced from .class in eclipse [message #235999 is a reply to message #235993] Wed, 20 June 2007 07:10 Go to previous messageGo to next message
Originally posted by: alexjaquet.gmail.com
A class is referrenced and the dependencies are not defined so you need
to add dependencies.
Re: It is indirectly referenced from .class in eclipse [message #236005 is a reply to message #235993] Wed, 20 June 2007 07:21 Go to previous messageGo to next message
Originally posted by: alex_blewitt.yahoo.com
That's when A.class -> B.class, and B.class -> C.class, but you don't have C.class. So although A's dependency is directly met (you can see B), it's not possible to resolve B, since it requires C.
Alex.
Re: It is indirectly referenced from .class in eclipse [message #236055 is a reply to message #235993] Wed, 20 June 2007 14:05 Go to previous message
Originally posted by: none.ibm.com
This is most often due to a limitation in the way PDE handles classpaths for
external plug-ins. You can fix it by either adding the unneeded dependency,
or by importing the dependent plug-in as a binary project, which allows it
to have its own "node" in the classpath chain.
"chaitannya" <chaitannyam@yahoo.co.uk> wrote in message
news:1483634208.1721182317690525.JavaMail.root@cp9.dzone.com...
Previous Topic:How can I configure an Plugin.xml file
Next Topic:compartment list layout property
Current Time: Wed Jan 24 10:03:56 GMT 2018
Powered by FUDForum. Page generated in 0.01562 seconds
