Home » Eclipse Projects » GEF » Contributing menu/toolbar items to my GEF/RCP app
Contributing menu/toolbar items to my GEF/RCP app [message #234690] Mon, 28 May 2007 18:34 Go to next message
Originally posted by: mlevison.gmail.com
1) Why use ActionContributor vs. adding Actions in the ActionBarAdvisor?
2) What is RetargetAction (org.eclipse.gef.ui.actions)?
3) When adding actions via an ActionBarContributor should you add the
actions to a ‘global handler’:
• pageSite.getActionBars().setGlobalActionHandler() as per the logic
editor sample **or** editor handler
• getEditorSite().getService(IHandlerService.class).
activateHandler() as per the shapes example?
4) If you’re using the ActionBarContributor how do you contribute to a
menu that already exists – perhaps file? In a specific place in that menu?
5) Assuming the ActionBarContributor is right way to go how add the
PrintAction? There doesn’t seem to be a RetargetAction predefined for
print – but it can’t easily be added in the ActionBarAdvisor since its
constructor requires an edit part.
Thanks in advance for any help
Mark Levison
Blog: http://www.notesfromatooluser.com/
Most Popular posts:
Aperture vs. Lightroom - best comparisons
http://www.notesfromatooluser.com/2007/02/aperture_vs_lig.ht ml
Scrum in a Nutshell or 5 minutes to learn Scrum
http://www.notesfromatooluser.com/2006/11/scrum_in_a_nuts.ht ml
Getting Things Done!!! Can't Keep Track of all the tasks you have to do?
Need a better Tool to Implement GTD?
http://www.notesfromatooluser.com/2006/12/getting_things_.ht ml
Re: Contributing menu/toolbar items to my GEF/RCP app [message #234719 is a reply to message #234690] Tue, 29 May 2007 13:48 Go to previous messageGo to next message
Originally posted by: Lehmann.j.gmx.net
to 5)
just look at the IBM Redbook(
http://www.redbooks.ibm.com/abstracts/sg246302.html ) at side 144. There it
is explained.
kind regards
"Mark Levison" <mlevison@gmail.com> schrieb im Newsbeitrag
news:f3f7aq$o0r$1@build.eclipse.org...
> actions to a
Re: Contributing menu/toolbar items to my GEF/RCP app [message #234743 is a reply to message #234719] Tue, 29 May 2007 20:09 Go to previous message
Jens Lehmann wrote:
> to 5)
> is explained.
Jens thanks for the help - I've read that doc before so it was staring
me in the face. Unfortunately it doesn't seem to have done anything.
No menu or toolbar item were added - so it seems I'm back to my original
question. I know how to contribute the action through the
ActionBarAdvisor - I even wrote a shim DiagramPrintAction to work around
not having the edit part when its time to create the action - but this
all seems like hard work. I assume there's a better way to do this:
public class DiagramPrintAction extends BasicAction {
public DiagramPrintAction(String text, String iconPath, String
accelerator, IWorkbenchWindow inWindow) {
super(text, iconPath, accelerator, inWindow);
setActionDefinitionId("org.eclipse.ui.file.print");
public boolean isEnabled() {
IEditorPart editorPart = getActiveEditor();
return editorPart != null;
public void run() {
PrintAction printAction = new PrintAction(editorPart);
printAction.run();
// getActiveEditor is a method in our base class in that will get the
editor that is active at the moment
So my questions
1) What did registering the print action and declaring the global action
key do?
2) If I need strongly typed constructors and so don't want to use
plugin.xml is there an elegant/appropriate way to install a print action
in the menu?
3) Why isn't there a retargetAction for print? (A variation of the what
is a retargetAction question).
Cheers
Mark Levison
Previous Topic:How to get IFile object from the file other then workspace
Next Topic:Animation on Connection.
Current Time: Mon Feb 19 04:23:26 GMT 2018
Powered by FUDForum. Page generated in 0.01814 seconds
