Home » Language IDEs » Java Development Tools (JDT) » Code formatting question
Code formatting question [message #234237] Fri, 11 August 2006 12:43 Go to next message
Originally posted by: lw_mailme_00.yahoo.com
This may be simple, but I can't find a setting to make the Java code
formatter behave as follows.
I have a method call with several parameters, where some parameters are
the result of method calls. The formatter creates line breaks after the
'.' in method calls. E.g.
a.method(parameter1, parameter2, obj1.method(x), obj2.
method(y), parameter3);
I don't want each parameter on a separate line, but I don't want line
breaks in method calls either. The example above should look like
obj2.method(y), parameter3);
Is this possible?
Re: Code formatting question [message #234268 is a reply to message #234237] Fri, 11 August 2006 15:43 Go to previous message
Oops, there's a slight mistake in my first example. The break is
actually inserted before the period. This is what it looks like:
> Is this possible?
Previous Topic:Opening java from a non java editor
Next Topic:New JDT developer stupid question
Current Time: Fri Feb 23 05:01:02 GMT 2018
Powered by FUDForum. Page generated in 0.01594 seconds
