Home » Language IDEs » ServerTools (WTP) » When I start then eclipse has got a lot of errors.
When I start then eclipse has got a lot of errors. [message #234102] Thu, 23 July 2009 23:42 Go to next message
Sunyoup, Kim is currently offline Sunyoup, KimFriend
--------------020808000704040906060509
Hello everyone!
I was starting eclipse at last day so didn't have problems... but, why
suddenly I start eclipse then has got a lot of errors since this morning.
Just a little message below to my errors.
1. An error occurred while automatically activating bundle
org.eclipse.jdt.ui (312).
2. Unable to create editor ID org.eclipse.jdt.ui.CompilationUnitEditor:
The editor class could not be instantiated. This usually indicates a
missing no-arg constructor or that the editor's class name was mistyped
in plugin.xml.
3. Ignored attempt to add saveable that was already registered
4. Unable to create view ID org.eclipse.jdt.ui.PackageExplorer: Plug-in
org.eclipse.jdt.ui was unable to load class
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.
For more error message and Exception stack trace, I attached a
file(errors.log). that was exported from Eclipse Log viewer.
Please help me I'm finished work today.
name="errors.log"
Content-Disposition: inline;
filename="errors.log"
!SESSION 2009-07-24 07:49:26.312 -----------------------------------------------
eclipse.buildId=I20090611-1540
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ko_KR
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
This is a continuation of log file D:\work\workspace\.metadata\.bak_0.log
Created Time: 2009-07-24 07:49:46.046
!ENTRY org.eclipse.osgi 4 0 2009-07-24 07:49:46.046
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (312).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.jdt.internal.ui.JavaPlugin for bundle org.eclipse.jdt.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:750)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:845)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jdt/core/IBufferFactory
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 62 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.core (303).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 68 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
... 78 more
Caused by: java.lang.NullPointerException
at org.eclipse.jdt.internal.core.JavaModelManager.containersRes et(JavaModelManager.java:748)
at org.eclipse.jdt.internal.core.JavaModelManager.loadVariables AndContainers(JavaModelManager.java:3001)
at org.eclipse.jdt.internal.core.JavaModelManager.startup(JavaM odelManager.java:4589)
at org.eclipse.jdt.core.JavaCore.start(JavaCore.java:4965)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
... 83 more
Root exception:
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:49:46.078
!MESSAGE Unable to create editor ID org.eclipse.jdt.ui.CompilationUnitEditor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (312).
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.jdt.internal.ui.JavaPlugin for bundle org.eclipse.jdt.ui is invalid
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 2 2 2009-07-24 07:49:46.171
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@c44cfb from part: org.eclipse.ui.internal.ErrorEditorPart@c44cfb
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
!ENTRY org.eclipse.equinox.registry 4 1 2009-07-24 07:50:07.031
!MESSAGE Unable to create view ID org.eclipse.jdt.ui.PackageExplorer: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.
!STACK 0
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:50:08.843
!STACK 0
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 2 2 2009-07-24 07:50:08.843
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@89eb77 from part: org.eclipse.ui.internal.ErrorEditorPart@89eb77
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1224)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:400)
at org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1409)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1416)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1380)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1435)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122 )
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:270)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:279)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:70 )
at org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:626)
at org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:21 99)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:327)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:50:09.812
!STACK 0
Re: When I start then eclipse has got a lot of errors. [message #422746 is a reply to message #234102] Thu, 30 July 2009 12:40 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
Sunyoup Kim wrote:
> Hello everyone!
To me it looks like your install is corrupt.
Dani
Re: When I start then eclipse has got a lot of errors. [message #443229 is a reply to message #422746] Fri, 31 July 2009 14:17 Go to previous messageGo to next message
Doug Clarke is currently offline Doug ClarkeFriend
I have also experienced this error in several of my workspaces. I assumed
it was a corrupted install so I started with a fresh Galileo JavaEE
install and am getting the same problem again. It works fine when I create
or re-open the workspace after the clean install but then fails the next
day when I attempt to re-open it.
I am going to try a couple of other things but I believe there is a bug in
here somewhere.
Doug
Re: When I start then eclipse has got a lot of errors. [message #490791 is a reply to message #443229] Sat, 10 October 2009 19:44 Go to previous messageGo to next message
Thomas Kuhlmann is currently offline Thomas KuhlmannFriend
did you solve this problem?
I got the same exceptions and do not want to discard my workspace. Sad
TIA for any help
Thomas
Re: When I start then eclipse has got a lot of errors. [message #491033 is a reply to message #490791] Mon, 12 October 2009 23:29 Go to previous messageGo to next message
Chris is currently offline ChrisFriend
Member
Thomas Kuhlmann wrote:
> I got the same exceptions and do not want to discard my workspace. :(
> TIA for any help
> Thomas
Try deleting the following file...
.metadata/.plugins/org.eclipse.jdt.core/variablesAndContaine rs.dat
It is related to a bug in the Data Tools plugins that should be fixed in
v1.7.2
Re: When I start then eclipse has got a lot of errors. [message #505666 is a reply to message #491033] Mon, 04 January 2010 05:30 Go to previous messageGo to next message
Gillis J. de Nijs is currently offline Gillis J. de NijsFriend
Removing the dat file did the trick for me. Thanks.
Eclipse Java EE IDE for Web Developers.
    Build id: 20090920-1017
Eclipse Platform
    Version: 3.5.1.R35x_v20090910-9gEeG1_FthkNDSP2odXdThaOu9GFDPn83DGB7
    Build id: M20090917-0800
Re: When I start then eclipse has got a lot of errors. [message #644849 is a reply to message #491033] Tue, 14 December 2010 13:22 Go to previous messageGo to next message
José Cláudio Aguiar is currently offline José Cláudio AguiarFriend
Chris wrote on Mon, 12 October 2009 19:29
v1.7.2
I uninstalled the Data Tools plugin and then deleted the file. It worked fine.
Re: When I start then eclipse has got a lot of errors. [message #1555016 is a reply to message #644849] Fri, 09 January 2015 15:01 Go to previous messageGo to next message
Ramas Sami is currently offline Ramas SamiFriend
Thanks Thomas Kuhlmann;
When I did delete the file ".metadata/.plugins/org.eclipse.jdt.core/variablesAndContaine rs.dat" from project workspace; BINGO! it's started working fine ....
Thanks for the solution...
Re: When I start then eclipse has got a lot of errors. [message #1754406 is a reply to message #1555016] Fri, 17 February 2017 10:46 Go to previous messageGo to next message
Aruna Devi is currently offline Aruna DeviFriend
I deleted the .dat file and started eclipse as - clean, but still the exception occurs Sad
Re: When I start then eclipse has got a lot of errors. [message #1774429 is a reply to message #234102] Sat, 14 October 2017 08:12 Go to previous messageGo to next message
Elenka Ilioska is currently offline Elenka IlioskaFriend
I am having the same issue with opening java file from my workspace and according your experience I am trying to fix the issue in the same way yet I cannot find the file
I use eclipse for testers version. Please help me to resolve the issue.
Thank you!
Elenka
Re: When I start then eclipse has got a lot of errors. [message #1775032 is a reply to message #1774429] Mon, 23 October 2017 18:24 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
The same issue, as in "java.lang.NullPointerException at org.eclipse.jdt.internal.core.JavaModelManager.containersRes et(JavaModelManager.java:748)" is part of the log output when Eclipse fails to start?
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Mon, 23 October 2017 18:36]
Report message to a moderator
Re: When I start then eclipse has got a lot of errors. [message #1779848 is a reply to message #1775032] Sun, 14 January 2018 16:32 Go to previous message
prashant mahto is currently offline prashant mahtoFriend
OMG, this is error..
Previous Topic:Exporting and importing Validation Filters
Next Topic:PHP Project Outline View - Constants
Current Time: Mon May 21 15:18:03 GMT 2018
Powered by FUDForum. Page generated in 0.02295 seconds
