Home » Eclipse Projects » Web Tools Project (WTP) » Enterprise Application Project Help
Enterprise Application Project Help [message #233970] Tue, 21 July 2009 15:50 Go to next message
Chris Gardner is currently offline Chris Gardner
I created an Enterprise Application Project that points to a Dynamic Web
Project and a standard Java Project. The Dynamic Web Project depends on
the standard Java Project. The standard Java Project depends on Hibernate
via a User Library. When I deploy the Enterprise Application Project to
Glassfish, I expected that all the dependendcies would be ear'd up,
including Hibernate (even though it was specified in a User Library).
Only the war file for the Dynamic Web Project and the jar file for the
standard Java Project ended up being ear'd.
What do you have to do to get User Libraries ear'd up? Or can that even
be done?
Re: Enterprise Application Project Help [message #233977 is a reply to message #233970] Tue, 21 July 2009 16:58 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
This configuration should work. The first thing to check is whether the
EAR composition is correct when you export an EAR using the export EAR
wizard.
If the export wizard produced a correct EAR, then there is a bug in the
Glassfish server adapter.
If the export wizard did not produce a correct EAR, then we need to check
your configuration further. Do you see any warnings in the problems view?
WTP will flag classpath entries that are likely to be necessary, but are
not marked for deployment. If you find such warnings that refer to your
user library, you can access quick fixes that will let you properly tag
it. If you cannot find the warnings, you can also go to your java
project's project properties. In the Java EE Module Dependencies page, you
should see you user library listed. Check the checkbox next to it.
Hope this helps.
- Konstantin
Re: Enterprise Application Project Help [message #234016 is a reply to message #233977] Wed, 22 July 2009 12:21 Go to previous messageGo to next message
After I wrote this yesterday, I found the Java EE Module Dependencies and
checked the libraries. Thank you for your help.
> wizard.
> Hope this helps.
> - Konstantin
Re: Enterprise Application Project Help [message #234067 is a reply to message #233977] Thu, 23 July 2009 15:10 Go to previous message
Eclipse User
I know I'm a bit late but I'd like to clarify this. If the export wizard
produced a correct EAR, the bug could be in the Glassfish server
adapter, but is also quite likely to be somewhere in the module factory
and module delegate for the JEE projects ;)
There have been a myriad of bugs in that area lately which we're trying
very hard to fix.
Previous Topic:Update site for WTP 3.0.5
Next Topic:Debugging JSP's in Eclipse/WebSphere 6.1
Current Time: Sat May 18 22:45:33 EDT 2013
Powered by FUDForum. Page generated in 0.01479 seconds
