Home » Language IDEs » C / C++ IDE (CDT) » Breakpoints ignored when using GDB
Breakpoints ignored when using GDB [message #232161] Thu, 26 March 2009 15:32 Go to next message
David Eisner is currently offline David EisnerFriend
I'm using Eclipse 3.4.2 with CDT 5.0.2.200902130801 on a Vista SP1 box.
I'm trying to debug a project built with MinGW using the MinGW gdb,
version 6.6.
The debugger stops in main(), and I can step through the program.
However, any breakpoints I set by double-clicking the marker bar are
ignored.
If I enable verbose console mode and issue "info breakpoints", I don't
see any breakpoints listed. On the other hand, I can set breakpoints
manually in the console (e.g. "b foo.c:123"), and the breakpoint will be
honored (a temporary workaround).
Another observation: In the Breakpoints view, I do indeed see the
breakpoints I've set by double-clicking. But, if I press the "Show
Breakpoints Supported by Selected Target" button, the breakpoints are
all filtered out. I assume this is related to my problem.
Any ideas? Thanks.
-David
Re: Breakpoints ignored when using GDB [message #232197 is a reply to message #232161] Fri, 27 March 2009 14:18 Go to previous messageGo to next message
Anton Leherbauer is currently offline Anton LeherbauerFriend
> version 6.6.
> ignored.
> Any ideas? Thanks.
> -David
Do you have other plug-ins installed besides Eclipse and CDT?
Anton Leherbauer
Wind River Systems, Austria
CDT Committer - http://www.eclipse.org/cdt
Re: Breakpoints ignored when using GDB [message #232221 is a reply to message #232197] Fri, 27 March 2009 15:31 Go to previous messageGo to next message
Yes. I won't list them all (unless you want me to), but here are the
installed features: Mylin; CDT; Eclipse: CVS Client, JDT, Platform, and
RCP; EMF: Common, Common UI, Ecore, Ecore Edit, Edit, and Edit UI; GEF:
Draw2d and GEF Framework; Help System Base; and XSD: XML Schema
Definition Model, and Edit.
Thanks.
-David
Re: Breakpoints ignored when using GDB [message #232334 is a reply to message #232221] Tue, 31 March 2009 14:48 Go to previous message
In any case, if somebody else finds this, I've filed a bug report:
http://bugs.eclipse.org/270521
-David
Previous Topic:template
Next Topic:Building multiple targets in the same project
Current Time: Wed Feb 21 19:33:58 GMT 2018
Powered by FUDForum. Page generated in 0.01618 seconds
