Home » Language IDEs » ServerTools (WTP) » Error in launching application on Tomcat 5.5
Error in launching application on Tomcat 5.5 [message #232084] Wed, 03 June 2009 08:50 Go to next message
Angelo Fabio Mulone is currently offline Angelo Fabio MuloneFriend
I use Eclipse 3.4.1 Ganymede and I have a problem in starting tomcat (also
I do not assign a project to tomcat 5.5 server).
The console log tells me this:
3-giu-2009 10.43.11 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
Files\Java\jdk1.5.0_16\jre\bin;.;C:\WINDOWS\system32;C:\WIND OWS;C:/Program
Files/Java/jre6/bin/client;C:/Program
Files/Java/jre6/bin;C:\oracle\product\10.2.0\client_1\bin;C: \WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\cyg win\bin;C:\axis2-1.4.1\bin;C:\apache-ant-1.7.1\bin;C:\gwt-wi ndows-1.5.3\gwt-windows-1.5.3;C:\j2sdk1.4.2_19\bin;C:\Progra m
Files\Microsoft SQL Server\80\Tools\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\binn\;C:\Program Files\Microsoft SQL
Server\90\DTS\Binn\;C:\Program Files\Microsoft SQL
Server\90\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Microsoft
Visual Studio 8\Common7\IDE\PrivateAssemblies\;C:\Program Files\cvsnt;
3-giu-2009 10.43.11 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8090
3-giu-2009 10.43.11 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 797 ms
3-giu-2009 10.43.11 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
3-giu-2009 10.43.11 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.27
3-giu-2009 10.43.11 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
log4j:WARN No appenders could be found for logger
(org.apache.catalina.startup.TldConfig).
log4j:WARN Please initialize the log4j system properly.
3-giu-2009 10.43.13 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Context [/TPS_WEB_USER] startup failed due to previous errors
3-giu-2009 10.43.14 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8090
3-giu-2009 10.43.14 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
3-giu-2009 10.43.14 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/31 config=null
3-giu-2009 10.43.14 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
3-giu-2009 10.43.14 org.apache.catalina.startup.Catalina start
INFO: Server startup in 3312 ms
When I try to open http://localhost:8090/TPS_WEB_USER/ I receive this
error:
HTTP Status 404 -
type Status report
message
description The requested resource () is not available.
TPS_WEB_USER is the project I try to run.
How can I solve?
In the console I do not see any errors, why?
Thanks, bye bye.
Re: Error in launching application on Tomcat 5.5 [message #232093 is a reply to message #232084] Wed, 03 June 2009 12:40 Go to previous messageGo to next message
I changed the jdk (now it is 1.5.0_16) And I see this error, when I try to
start web application from eclipse:
3-giu-2009 14.37.33 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
Files/Java/jre6/bin;C:\oracle\product\10.2.0\client_1\bin;C: \WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\cyg win\bin;C:\axis2-1.4.1\bin;C:\apache-ant-1.7.1\bin;C:\gwt-wi ndows-1.5.3\gwt-windows-1.5.3;C:\Program
Files\Java\jdk1.5.0_16\bin;C:\Program Files\Microsoft SQL
3-giu-2009 14.37.33 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
3-giu-2009 14.37.33 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 718 ms
3-giu-2009 14.37.33 org.apache.catalina.core.StandardService start
3-giu-2009 14.37.33 org.apache.catalina.core.StandardEngine start
3-giu-2009 14.37.33 org.apache.catalina.core.StandardHost start
3-giu-2009 14.37.35 org.apache.catalina.core.StandardContext start
3-giu-2009 14.37.35 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
3-giu-2009 14.37.35 org.apache.jk.common.ChannelSocket init
3-giu-2009 14.37.35 org.apache.jk.server.JkMain start
3-giu-2009 14.37.35 org.apache.catalina.storeconfig.StoreLoader load
3-giu-2009 14.37.35 org.apache.catalina.startup.Catalina start
INFO: Server startup in 2625 ms
3-giu-2009 14.38.30 org.apache.coyote.http11.Http11BaseProtocol pause
INFO: Pausing Coyote HTTP/1.1 on http-8080
3-giu-2009 14.38.31 org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
3-giu-2009 14.38.31 org.apache.catalina.core.StandardContext stop
INFO: Container
org.apache.catalina.core.ContainerBase.[Catalina].[localhost ].[/TPS_WEB_USER]
has not been started
3-giu-2009 14.38.31 org.apache.coyote.http11.Http11BaseProtocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-8080
3-giu-2009 14.38.31 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: Failed shutdown of Apache Portable Runtime
why? How can I solve?
Thanks, bye bye.
Re: Error in launching application on Tomcat 5.5 [message #232101 is a reply to message #232093] Wed, 03 June 2009 13:13 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
Angelo Fabio Mulone wrote:
> to start web application from eclipse:
> lifecycleEvent
> in production environments was not found on the java.library.path:
> C:\Program
> INFO: Container
> lifecycleEvent
> Thanks, bye bye.
Both of your startup logs included:
This typically indicates that a listener configured in the web.xml of
your webapp threw an uncaught exception during startup. In this case, I
believe Tomcat leaves the failed webapp off-line, which is why you get
the 404 error. If you have source for the listener, you can run in
debug mode and step through the listener to see where and what exception
is being thrown.
Larry
Re: Error in launching application on Tomcat 5.5 [message #232595 is a reply to message #232101] Tue, 16 June 2009 13:09 Go to previous messageGo to next message
I have not the source.
My web.xml configuration file is:
<web-app version="2.4"
         xmlns="http://java.sun.com/xml/ns/j2ee"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://java.sun.com/xml/ns/j2ee
         http://java.sun.com/xml/ns/j2ee/web-app_2_4.xsd" >
    <description>
      Transparent Portfolio System.
    </description>
    <display-name>Transparent Portfolio System</display-name>
    <session-config>
        <session-timeout>120</session-timeout>
    </session-config>
    <security-constraint>
	   <web-resource-collection>
	      <web-resource-name>TPS_WEB</web-resource-name>
	      <url-pattern>*.jsp</url-pattern>
		  <url-pattern>*.htm</url-pattern>
		  <url-pattern>*.html</url-pattern>
	   </web-resource-collection>
	    <auth-constraint>
	      <role-name>user</role-name>
	      <role-name>simulator</role-name>
	      <role-name>configurator</role-name>
	      <role-name>validator</role-name>
	   </auth-constraint>
	</security-constraint>
		<login-config>
		   <auth-method>FORM</auth-method>
		   <realm-name>TPS_WEB</realm-name>
		   <form-login-config>
		      <form-login-page>/WEB-INF/jsp/login.jsp</form-login-page>
<form-error-page>/WEB-INF/jsp/commons/loginError.jsp</form-error-page>
		   </form-login-config>
		</login-config>
	<security-role>
	</security-role>
	<security-role>
	</security-role>
     <security-role>
	</security-role>
	<security-role>
	</security-role>
  	<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
  	</listener>
	<filter>
		<filter-name>hibernate</filter-name>
		<filter-class>
			org.springframework.orm.hibernate3.support.OpenSessionInViewFilter
		</filter-class>
	</filter>
	<filter-mapping>
		<url-pattern>/*</url-pattern>
	</filter-mapping>
	  <servlet>
   		<servlet-name>tps</servlet-name>
		<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
   		<load-on-startup>1</load-on-startup>
   	 </servlet>
	 <servlet-mapping>
	 </servlet-mapping>
	 <servlet>
    		<servlet-name>report</servlet-name>
		<servlet-class>com.intesasanpaolo.tps.form.common.ReportDownloadController</servlet-class>
  	</servlet>
 	 <servlet-mapping>
   		<url-pattern>/report.html</url-pattern>
  	</servlet-mapping>
	<context-param>
	 	<param-name>contextConfigLocation</param-name>
		 <param-value>/WEB-INF/tps-services.xml</param-value>
	 </context-param>
	 <jsp-config>
	    <taglib>
	      <taglib-uri>/spring</taglib-uri>
	      <taglib-location>/WEB-INF/tld/spring-form.tld</taglib-location>
	    </taglib>
	 </jsp-config>
	  <welcome-file-list>
	    <welcome-file>
	      index.jsp
	    </welcome-file>
	  </welcome-file-list>
</web-app>
What can I do?
Thanks, bye bye.
Re: Error in launching application on Tomcat 5.5 [message #232599 is a reply to message #232595] Tue, 16 June 2009 13:53 Go to previous messageGo to next message
>    <description>
>    </description>
>       <session-config>
>    </session-config>
>         <auth-constraint>
>        </auth-constraint>
>         <login-config>
>            <form-login-config>
>         </login-config>
>     <security-role>
>     </security-role>
>     <security-role>
>     </security-role>
>     <security-role>
>     </security-role>
>     <security-role>
>     </security-role>                   <listener>
>      </listener>
>             <filter>
>         <filter-class>
>         </filter-class>
>     </filter>
>     <filter-mapping>
>     </filter-mapping>
>       <servlet>
>        </servlet>
>      <servlet-mapping>
>      </servlet-mapping>
>      <servlet>
>      </servlet>
>      <servlet-mapping>
>      </servlet-mapping>
>     <context-param>
>      </context-param>
>      <jsp-config>
>         <taglib>
>         </taglib>
>      </jsp-config>
>       <welcome-file-list>
>         <welcome-file>
>           index.jsp
>         </welcome-file>
> </web-app>
> What can I do?
> Thanks, bye bye.
The only listener in the web.xml is
org.springframework.web.context.ContextLoaderListener. This suggests
that you have something wrong in your spring configuration.
Larry
Re: Error in launching application on Tomcat 5.5 [message #232614 is a reply to message #232599] Wed, 17 June 2009 07:24 Go to previous messageGo to next message
I asked on spring forum but there everebody tell me that this is not a
spring error...
Re: Error in launching application on Tomcat 5.5 [message #232619 is a reply to message #232614] Wed, 17 June 2009 07:46 Go to previous messageGo to next message
Another information.
If I click on "Switch location" on the server properties and the I try to
run the server I receive this other message:
17-giu-2009 9.43.58 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
Files\Java\jdk1.5.0_16\jre\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:/Program
Files/Java/jre6/bin;C:\oracle\product\10.2.0\client_1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\cygwin\bin;C:\axis2-1.4.1\bin;C:\apache-ant-1.7.1\bin;C:\gwt-windows-1.5.3\gwt-windows-1.5.3;C:\Program
17-giu-2009 9.43.59 org.apache.coyote.http11.Http11BaseProtocol init
17-giu-2009 9.43.59 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 735 ms
17-giu-2009 9.43.59 org.apache.catalina.core.StandardService start
17-giu-2009 9.43.59 org.apache.catalina.core.StandardEngine start
17-giu-2009 9.43.59 org.apache.catalina.core.StandardHost start
17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext resourcesStart
GRAVE: Error starting static Resources
java.lang.IllegalArgumentException: Document base
C:\wrokspace2\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\wtpwebapps\TPS_WEB_USER
does not exist or is not a readable directory
org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:141)
org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:3855)
org.apache.catalina.core.StandardContext.start(StandardContext.java:4024)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1014)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:736)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
org.apache.catalina.core.StandardService.start(StandardService.java:448)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:700)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:552)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:295)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:433)
17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext start
GRAVE: Error in resourceStart()
GRAVE: Error getConfigured
17-giu-2009 9.43.59 org.apache.catalina.core.StandardContext stop
INFO: Container
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/TPS_WEB_USER]
17-giu-2009 9.43.59 org.apache.coyote.http11.Http11BaseProtocol start
17-giu-2009 9.43.59 org.apache.jk.common.ChannelSocket init
17-giu-2009 9.43.59 org.apache.jk.server.JkMain start
17-giu-2009 9.43.59 org.apache.catalina.storeconfig.StoreLoader load
17-giu-2009 9.44.00 org.apache.catalina.startup.Catalina start
INFO: Server startup in 1109 ms
What does it mean?
Thanks, bye bye.
Re: Error in launching application on Tomcat 5.5 [message #232627 is a reply to message #232614] Wed, 17 June 2009 14:31 Go to previous messageGo to next message
> spring error...
If the webapp is failing to start because a listener appears to be
throwing an exception, and there is only one listener present which is
for performing a Spring configuration, I would assume the issue is
related to Spring. Since the Spring forum does not seem likely to
provide much help, I would recommend digging for clues yourself.
The best way is to get source for the version of Spring you are using
and run the server in debug mode to debug what happening in
ContextLoaderListener. However, the log entries:
suggest that log4j is being used but not initialized. As a quick
alternative to debugging, you could add a log4j.properties file (I'm
assuming one isn't already present) with the following contents to see
if the extra logging provides any helpful clues:
log4j.rootLogger=WARN, console
log4j.appender.console=org.apache.log4j.ConsoleAppender
log4j.appender.console.layout=org.apache.log4j.PatternLayout
log4j.appender.console.layout.ConversionPattern=%r [%t] %p %c - %m%n
log4j.logger.org.springframework.web.context=DEBUG
Place the log4j.properties file in the root Java source folder for the
Dynamic Web Project (typically the "src" folder). It will get published
to the WEB-INF/classes folder of the webapp where it needs to be.
Larry
Re: Error in launching application on Tomcat 5.5 [message #232635 is a reply to message #232619] Wed, 17 June 2009 14:32 Go to previous message
> to run the server I receive this other message:
> lifecycleEvent
> C:\Program
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at
>     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>     at
>     at
> INFO: Container
> What does it mean?
> Thanks, bye bye.
This Switch Location operation moves the XML that defines the server
between its normal location in
"<workspace_root>/.metadata/.plugins/org.eclipse.wst.server.core/servers.xml "
(not related to Tomcat server.xml) to a file found in the Servers
project in your workspace. Once upon a time long ago, there was a use
case for manually modifying this XML. I'm not aware of any reason to
use this operation today.
There does appear to be a bug in that following the switch, publishing
fails to publish any modules. To correct the behavior, restart Eclipse
or remove all the modules from the server, publish the server, an add
the modules back.
Note that this issue is unrelated to your earlier problem and I would
recommend executing Switch Location again to move the XML back to its
normal location.
Larry
Previous Topic:How to conrol the stages of the web service in the eclipse web service wizard?
Next Topic:Can't get WSDL editor in 3.5RC3?
Current Time: Thu May 24 14:01:39 GMT 2018
Powered by FUDForum. Page generated in 0.02721 seconds
