Home » Language IDEs » ServerTools (WTP) » Can't start jboss from Eclipse Ganymede
Can't start jboss from Eclipse Ganymede [message #228881] Fri, 13 March 2009 10:02 Go to next message
Heiner is currently offline HeinerFriend
Dear all,
I'm using Eclipse3.4.2, JBoss 5.0.1 GA, JBoss Tools and try to start the
app server from eclipse. The log is fine at the beginning (extract):
10:28:28,593 INFO [JMXKernel] Legacy JMX core initialized
10:28:32,140 INFO [ProfileServiceImpl] Loading profile: default from:
org.jboss.system.server.profileservice.repository.Serializab leDeploymentRepository @161cd25(root=C:\Java\Tools\jboss-5.0.1.GA\server,
key=org.jboss.profileservice.spi.ProfileKey@143b82c3[domain=default,server=default,name=default])
10:28:32,140 INFO [ProfileImpl] Using
repository: org.jboss.system.server.profileservice.repository.Serializab leDeploymentRepository @161cd25(root=C:\Java\Tools\jboss-5.0.1.GA\server,
10:28:32,140 INFO [ProfileServiceImpl] Loaded profile:
ProfileImpl@165547d{key=org.jboss.profileservice.spi.ProfileKey@143b82c3[domain=default,server=default,name=default]}
10:28:48,203 INFO [WebService] Using RMI server codebase:
http://localhost:8083/
Then classloader errors occur:
DEPLOYMENTS IN ERROR:
Deployment "RarModuleJSR77Deployer" is in error due to the following
reason(s): java.lang.NoClassDefFoundError:
org/jboss/resource/metadata/ConnectorMetaData
Deployment
" vfsfile:/C:/Java/Tools/jboss-5.0.1.GA/server/default/deploye rs/jboss-jca.deployer/ "
is in error due to the following reason(s):
java.lang.UnsupportedClassVersionError: Bad version number in .class file
Deployment "JCAResourceJSR77Deployer" is in error due to the following
org/jboss/resource/metadata/mcf/ManagedConnectionFactoryDepl oymentGroup
Starting jboss directly also works fine. Has anyone an idea about the
problem ? Any help is appreciated. Thanks.
Re: Can't start jboss from Eclipse Ganymede [message #228891 is a reply to message #228881] Fri, 13 March 2009 13:59 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
what is the Java version for your JBoss? It seems that you picked JBoss 5.0.1GA
for JDK 1.6 (there are two different downloads available at jboss!), but you try
to run it on 1.5?
At least this message points to it: "java.lang.UnsupportedClassVersionError: Bad
version number in .class file".
If your JBoss has the correct version, there is maybe some JAR included in
"jboss-jca.deployer", which is compiled against java 1.6?
Best regards
Wolfgang
Ralph schrieb:
> Dear all,
> Deployment
Re: Can't start jboss from Eclipse Ganymede [message #228908 is a reply to message #228891] Fri, 13 March 2009 15:26 Go to previous message
Hi Wolfgang,
you're right: I used jre 1.5 instead of jre 1.6. Now jboss starts without
problems.
Thanks so much !
Previous Topic:which method is called when select "START" from server's context menu?
Next Topic:Latest Stable Build Required (M5 preferred)
Current Time: Sun Feb 25 00:16:34 GMT 2018
Powered by FUDForum. Page generated in 0.01650 seconds
