Home » Eclipse Projects » JFace » Section gets larger when expand
Section gets larger when expand [message #22326] Tue, 21 July 2009 13:08 Go to next message
T. Wilhelm is currently offline T. WilhelmFriend
Hey all,
i have a problem using a Section from org.eclipse.ui.forms. I have a
Composite (with GridLayout) and put a Section on this Composite. If i
expand or collapse the section the composite gets a little bit larger. I
think layout() will be called and then the width will be calculated again.
Does anybody know why the new width is larger than the old ones?
Any advice?
Thanks alot
Thomas
Re: Section gets larger when expand [message #22990 is a reply to message #22326] Wed, 22 July 2009 19:53 Go to previous message
Will Horn is currently offline Will HornFriend
What's in the Section? If it's a table you might be seeing this bug
http://bugs.eclipse.org/215997
"T. Wilhelm" <t.wilhelm@msh.de> wrote in message
news:0b6312e64ed17cb0ad69626e4a88f9ac$1@www.eclipse.org...
> Hey all,
> Does anybody know why the new width is larger than the old ones? Any
> advice?
> Thanks alot
> Thomas
Previous Topic:DialogCellEditor and Navigation
Next Topic:Bind TableViewer to Multiple Objects?
Current Time: Tue Jan 23 08:13:42 GMT 2018
Powered by FUDForum. Page generated in 0.02257 seconds
