I've generated a build script from PDE export, however this script
contains a reference to "pde.exportFeatures". When I try to run the
script I (predictably) get the error:
Could not create task or type of type: pde.exportFeatures.
Where is the task pde.exportFeatures (for that matter - any of the PDE
related ant tasks) and how do I tell ant where to find these?
I am assuming you are using 3.0 (relatively latest?)
You will need to perform this build in the same VM as Eclipse as I believe
the pde.exportFeatures task requires the eclipse runtime to function.
See the JRE tab of the Ant launch configuration for the build
HTH
Darins
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:c5hggm$ahi$1@eclipse.org...
> Many thanks.
> James
> HTH
> Darins
> > Many thanks.
> > James
I have a further question regarding this. The ant script seems to kick
off pde.exportFeatures and then continue, since the next task is dependent
on the output of the exportFeatures task - this doesn't work too well.
What is the standard approach for dealing with this problem?
James
> HTH
> Darins
> > Many thanks.
> > James
I believe they are using an Eclipse Job and then immediately returning while
the Job is running in the background.
You should file a bug report against PDE with your problem as you really
want to wait on this task
Sorry I am not more help,
Darins
news:c5hout$kpf$1@eclipse.org...
> James
believe
> > HTH
> > Darins
> > > Many thanks.
> > > James
