Re: Build path problem [message #227719 is a reply to message #227712] |
Thu, 16 August 2007 11:16 |
Originally posted by: wir_hier_2004.yahoo.de
Srdan Bejakovic wrote:
> I posted this earlier but got no response so I am reposting. I created a
> plugin, which worked fine. Then, after a restart, the following error
> appeared:
> The type org.eclipse.swt.widgets.Shell cannot be resolved. It is
> indirectly referenced from required .class files
> Eclipse suggests that I configure my build path. On the Java Build Path
> properties page, under the Libraries tab, the Plug-in Dependencies lists
> org.eclipse.swt. So what's wrong?
Hi!
I'm a tenderfoot, but I think you have the problem, that a class you
import and use requires another one called
"org.eclipse.swt.widgets.Shell" which is not in your buildpath. (sounds
more like a translation than a real answer...).
Add the missing class (or the jar including the file) to your build path
and all should work fine.
Greetings
eventhorizon
Re: Build path problem [message #227743 is a reply to message #227737] |
Thu, 16 August 2007 11:47 |
Srdan,
Is org.eclipse.swt.win32.win32.x86* there too? That's where the actual
classes are...
>>> created a
>>> appeared:
>>> lists
>> Hi!
>> Greetings
>> eventhorizon
> I don't understand what you mean. It seems that the org.eclipse.swt
> package is already on my build path (that's what the Java Build Path
> page is saying).
Re: Build path problem [message #227748 is a reply to message #227743] |
Thu, 16 August 2007 11:57 |
Srdan Bejakovic Messages: 8 Registered: July 2009 |
Junior Member |
Ed Merks wrote:
> Srdan,
> classes are...
>>>> created a
>>>> appeared:
>>>> indirectly referenced from required .class files Eclipse suggests
>>>> lists
>>> Hi!
>>> Greetings
>>> eventhorizon
>> page is saying).
Nope, it wasn't there. I added it and the problem is gone. Thanks!
FUDForum. Page generated in 0.03612 seconds
