Home » Language IDEs » C / C++ IDE (CDT) » Re: Eclipse CDT build question
Re: Eclipse CDT build question [message #227473] Mon, 01 December 2008 04:52
Originally posted by: nickboldt+eclipse+newsgroup.gmail.com
Actually, I've never used CDT. If you read the cited post, you'll see
that in that message, and in this, my advice is to to try the
eclipse.tools.cdt newsgroup, to which I've copied this question.
Good luck,
Nick
David Baum wrote:
> Nick hello,
> First let my apologize bothering you with such trifles.
> I'm knew to CDT, though not to eclipse.
> I'm having a tremendous problem building my projects.
> Once I hit the little hammer I get a "no binaries found" or so message.
> gccing it through the shell works fine.
> I'm harassing you regarding this, because I saw you had the same
> problem
> < http://www.eclipse.org/newsportal/article.php?id=25115&g roup=eclipse.newcomer>.
> Hoping this doesn't trouble you too much,
> Cheers, David.
> N.B.
> I have really read *a lot* about this - could not find the answer.
Nick Boldt :: http://wiki.eclipse.org/User:Nickb
Previous Topic:"Launch failed. Binary not found." question
Next Topic:Integrating a custom tool-chain in CDT
Current Time: Fri Apr 20 09:14:52 GMT 2018
Powered by FUDForum. Page generated in 0.01650 seconds
