Home » Eclipse Projects » Web Tools Project (WTP) » WSDL Editor error
WSDL Editor error [message #227399] Wed, 28 January 2009 03:00 Go to next message
Keshavrao  is currently offline Keshavrao
Member
I get the below error when i validate a WSDL file -
"The 'NewWSDLFile' port type specified for the 'NewWSDLFileSOAP' binding
is undefined. Check the 'NewWSDLFile' port type name and ensure it is
defined."
Initially i thought this could be because i dont have a xsd for the policy
i defined in operation tag, so i also added a reference to the policy XSD
but still the problem is not resolved.
But if if remove the policy tag in the operation tag then it works fine
and no error is reported.
you can download the policy XSD from -
http://schemas.xmlsoap.org/ws/2004/09/policy/ws-policy.xsd
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wsdl:definitions xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:tns="http://www.example.org/NewWSDLFile/"
xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema" name="NewWSDLFile"
targetNamespace="http://www.example.org/NewWSDLFile/"
xmlns:wsp="http://schemas.xmlsoap.org/ws/2004/09/policy policy.xsd">
<wsdl:types>
<xsd:schema targetNamespace="http://www.example.org/NewWSDLFile/">
<xsd:element name="NewOperation">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="in" type="xsd:string" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name="NewOperationResponse">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="out" type="xsd:string" />
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</wsdl:types>
<wsdl:message name="NewOperationRequest">
<wsdl:part element="tns:NewOperation" name="parameters" />
</wsdl:message>
<wsdl:message name="NewOperationResponse">
<wsdl:part element="tns:NewOperationResponse" name="parameters" />
</wsdl:message>
<wsdl:portType name="NewWSDLFile">
<wsdl:operation name="NewOperation">
<wsp:Policy>
<wsp:PolicyReference URI="http://example.uri" />
</wsp:Policy>
<wsdl:input message="tns:NewOperationRequest" />
<wsdl:output message="tns:NewOperationResponse" />
</wsdl:operation>
</wsdl:portType>
<wsdl:binding name="NewWSDLFileSOAP" type="tns:NewWSDLFile">
<soap:binding style="document"
transport="http://schemas.xmlsoap.org/soap/http" />
<soap:operation
soapAction="http://www.example.org/NewWSDLFile/NewOperation" />
<wsdl:input>
<soap:body use="literal" />
</wsdl:input>
<wsdl:output>
</wsdl:output>
</wsdl:operation>
</wsdl:binding>
<wsdl:service name="NewWSDLFile">
<wsdl:port binding="tns:NewWSDLFileSOAP" name="NewWSDLFileSOAP">
<soap:address location="http://www.example.org/" />
</wsdl:port>
</wsdl:service>
</wsdl:definitions>
Thanks and regards,
Keshav Veerapaneni.
Re: WSDL Editor error [message #227412 is a reply to message #227399] Wed, 28 January 2009 08:32 Go to previous message
Eclipse User
Originally posted by: valentinbaciu.hotmail.com
WTP 3.0 does not support extensibility elements for operations.
Your scenario is similar to the one reported in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235821 and is caused by a
discrepancy between the WSDL schema and the JWSDL/WSDL4J version used by the
WSDL validator.
This was addressed in WTP 3.1 M5 by upgrading to a newer version of WSDL4J.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=252257.
Regards, Valentin
"Keshavrao " <keshavrao.veerapaneni@sap.com> wrote in message
news:38e9ae12b0010e890a5ee02514293acf$1@www.eclipse.org...
> defined."
> <wsdl:types>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> </wsdl:types>
> </wsdl:message>
> </wsdl:message>
> <wsp:Policy>
> </wsp:Policy>
> </wsdl:operation>
> </wsdl:portType>
> <soap:operation
> <wsdl:input>
> </wsdl:input>
> <wsdl:output>
> </wsdl:output>
> </wsdl:operation>
> </wsdl:binding>
> </wsdl:port>
> </wsdl:service>
> </wsdl:definitions>
> Thanks and regards,
> Keshav Veerapaneni.
Previous Topic:.html files always Shift_JIS regardless of preferences or content
Next Topic:Deploy My Eclipse Web Service - Beginner
Current Time: Tue May 21 10:03:47 EDT 2013
Powered by FUDForum. Page generated in 0.01684 seconds
