| Launch Configuration [message #227138] |
Tue, 04 April 2006 07:28  |
Originally posted by: gosvig.gosvig.net
I want to make a shared java launch configuration dependant on the project
it is shared/saved within, like in:
<launchConfiguration type="org.eclipse.jdt.launching.localJavaApplication">
<stringAttribute key="org.eclipse.jdt.launching.MAIN_TYPE"
value="net.gosvig.foo.Foo"/>
<stringAttribute key="org.eclipse.jdt.launching.PROJECT_ATTR"
value="${project_name}"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables"
value="true"/>
</launchConfiguration>
This does not work. Eclipse seems to require that the value of the
PROJECT_ATTR is explicitly defined as the name of a project, not a
variable.
Can anyone enlighten me on how I can make this work. I need a launch
configuration to be the same in all the branches of a given SCM module.
Carsten
| Re: Launch Configuration [message #227187 is a reply to message #227138] |
Tue, 04 April 2006 11:39   |
Originally posted by: eclipse3.rizzoweb.com
Carsten Gosvig wrote:
> Hi
> project it is shared/saved within, like in:
> <booleanAttribute
> key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
> variable.
Can you explain why you are trying to write a launch config by hand
instead of using the GUI to create it?
Eric
| Re: Launch Configuration [message #227246 is a reply to message #227187] |
Tue, 04 April 2006 16:36   |
>> Hi
>> <?xml version="1.0" encoding="UTF-8"?>
>> <booleanAttribute
>> variable.
> Eric
Ok, I didn't write it by hand, I did use the GUI to create it, but I just
put it in the article for reference.
I did write ${project_name} in the project reference in the GUI, but it
complained with an unknown project name.
Carsten
| Re: Launch Configuration [message #227377 is a reply to message #227246] |
Thu, 06 April 2006 15:16  |
>>> Hi
>>> <booleanAttribute
>>> variable.
>> Eric
> just put it in the article for reference.
I see.
Unfortunately, I'm pretty sure Eclipse does not currently support a
variable as the project name. I suggest you submit an enhancement
request in the Eclipse bugzilla: http://bugs.exclipse.org
Hope this helps,
Eric
FUDForum. Page generated in 0.09003 seconds
