Home » Eclipse Projects » Eclipse Platform » <library name="?">
<library name="?"> [message #227012] Mon, 12 April 2004 16:35 Go to next message
David Bailey is currently offline David BaileyFriend
Member
I want to specify runtime libraries in my plugin.xml which do not reside
in the plugin directory. For example, I want to be able to specify a
<library> tag in a manner similar to the following:
<library name="C:\\MyProjects\\MyLibraries\\library.jar">
I realize that this isn't portable, so I've tried specifying a URL:
<library name="file:C:/MyProjects/MyLibraries/library.jar">
and ideally, of course, most of the path should be hidden behind a
variable of some sort:
<library name="MY_ECLIPSE_LIBRARIES/library.jar">
I've tried both of the first two mechanisms, along with some variants,
without success. Can someone please tell me whether it is possible to
specify runtime libraries which reside outside the plugin directory, and
if so, how to do it?
Re: <library name="?"> [message #227264 is a reply to message #227012] Tue, 13 April 2004 00:25 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
This is not supported.
library indicates a path relative to the plugin folder.
PaScaL
Re: <library name="?"> [message #229072 is a reply to message #227264] Thu, 15 April 2004 03:54 Go to previous message
Nico Guba is currently offline Nico GubaFriend
"Pascal Rapicault" <pascal@ibm.canada> wrote in message
news:c5fbnn$htt$1@eclipse.org...
Hmm, I'd be happy if that would just work (Eclipse 3.0M8). I cannot get the
plugin to see the library althought it is in the folder ;(
<runtime>
<library name="smtpkernel.jar">
<export name="*"/>
</library>
<library name="lib/mysql-connector-java-3.1.1-alpha-bin.jar"
type="resource">
<export name="*"/>
</library>
</runtime>
java.lang.ClassNotFoundException: org.gjt.mm.mysql.Driver
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:348)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:116)
This has been causing me a headache for days now. Any ideas what I forgot?
Hope this is not a bug...
> PaScaL
Previous Topic:"Save As" in M8
Next Topic:set as default editor for some extensions but not all
Current Time: Fri Apr 27 08:58:02 GMT 2018
Powered by FUDForum. Page generated in 0.10189 seconds
