Compiler Crashes when used in Eclipse CDT (Windows) [message #226857] |
Mon, 17 November 2008 08:02 |
Guillaume B Messages: 3 Registered: July 2009 |
Junior Member |
Hello everyone.
I'm starting a new job in a company that uses a C SDK for their
applications.
They are aimed at running on embedded devices, so the common tools are
specific to the architecture (gcco replaces gcc, ldo replaces ld and so
on).
To compile under Eclipse, I use a Makefile that specifically uses these
tools, so I have no "standard" compiler installed on my machine, just the
ones I told you about above.
The problem is, sometimes the compilation process hangs in eclipse,
whereas launched in a Command Line it runs flawlessly. It can happend in
any step of the compilation (compilation, linking, ...). At the end I
receive a strange error like:
"gmake: *** [appli.ocd] Error -1073741819"
And a popup appears that says: "Instruction at 0x610baeeda uses memory
address 0x00000009. The memory
Re: Compiler Crashes when used in Eclipse CDT (Windows) [continued] [message #226867 is a reply to message #226857] |
Mon, 17 November 2008 08:06 |
Junior Member |
[Wrong click on the previous message, it's continued here]
Hello everyone.
applications.
on).
The problem is, sometimes (very randomly, but too often to be ignored) the
compilation process hangs in eclipse, whereas launched in a Command Line
it runs flawlessly.
It can happen in any step of the compilation (compilation, linking, ...).
At the end I receive a strange error like:
address 0x00000009. The memory cannot be written".
This has nothing to do with the tools I use, since my project compiles
both on my machine and the other developpers machines as well. I found
this behaviour only on my environment.
Do you have any idea of what happens?
Eclipse 3.4.1 and CDT 5.0.1
Thanks in advance!
FUDForum. Page generated in 0.02809 seconds
