Home » Language IDEs » C / C++ IDE (CDT) » Re: eclipse-cpp-ganymede-SR1-win32 Problem
Re: eclipse-cpp-ganymede-SR1-win32 Problem [message #226578] |
Mon, 10 November 2008 11:39 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------060702040308040901040808
Bryan,
It might be better to ask on the CDT newsgroup. You might want to
search it for previous questions like this. Use the "Search this group"
box in:
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.cdt
I find that when I unzip I have to do chmod +x on the *.exe and *.dll in
the installation, so it might well be the case that your problems are
caused by the unzip utility you are using...
Bryan W. wrote:
> I've run into a problem while attempting to upgrade to the latest
> Ganymede release for C++ development.
> After unpacking the zip exactly as it came, into a brand new directory
> of course, I get the following error dialog when attempting to execute
> (eventually, "as an administrator") eclipse.exe:
> "The Eclipse executable launcher was unable to locate its companion
> shared library."
> Then eclipse fails to start.
> I am using Vista 32 HP, latest updates, with Sun Java 6 (Update 10)
> (build 1.6.0_10-rc2-b31) and MinGW/MSYS tools if its applicable. I did
> not have an issue when using the previous release zip:
> "eclipse-cpp-ganymede-win32" (Other than being a complete noob). Both
> are version 3.4 according to documentation. I will fall back to the
> later as a work around, but I thought I'd make it known that there's
> probably a configuration problem with the distribution and/or ask for
> help because I could be missing something face-palm-stupid. I don't
> know if it warrants a bug report, as I have a "weird" setup and I'm
> not sure if its my fault or not, which is why I bring it up here.
> Multiple re-install and re-download attempts were made with no
> difference in behavior. I also noticed that using the non-SR1 distro
> with a new install produced the same problem, which is weird, because it
> worked just fine in the past. I would guess that I am missing a critical
> library, but the install documentation only requests that I have a
> certain version, or higher, of Java, which I have and to simply unpack
> the contents into an empty directory. I tried many places, including
> "Program Files" and the root of my drive, with modified permissions just
> to make sure Windows wasn't the problem. Of course, maybe an "update" is
> messing with me here. I can only speculate at this point and the error
> message is very unhelpful in regards to helping me pinpoint the problem.
> Anyways, keep up the good work and thank you for freeing me from the
> bonds of Visual Studio!
<html>
<head>
<title></title>
</head>
Bryan,<br>
<br>
box in:<br>
<blockquote><a
href=" http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.cdt"> http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.cdt</a><br>
</blockquote>
in the installation, so it might well be the case that your problems
are caused by the unzip utility you are using...<br>
<br>
<br>
Bryan W. wrote:
<blockquote cite="mid:gf7rnq$qva$1@build.eclipse.org" type="cite">I've
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
shared library."
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
know if it warrants a bug report, as I have a "weird" setup and I'm not
<br>
<br>
<br>
<br>
it
<br>
critical
<br>
<br>
<br>
<br>
just
<br>
is
<br>
problem.
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------060702040308040901040808--
Ed Merks
Current Time: Thu Apr 25 20:42:42 GMT 2024
Powered by FUDForum. Page generated in 0.02611 seconds
