Link ending in a compartment [message #226188] |
Wed, 15 April 2009 12:15 |
Originally posted by: kalin.nakov.gmail.com
Greetings,
I have some symbols which have compartments. The generated GMF editor does
not allow me neither to start, nor to end a link on a symbol's compartment.
I can do this only if I start or end the link on the symbol's title area.
Where should I modify the generated code so that the compartment can become
a valid link source & target?
Thanks in advance,
Kalin
Re: Link ending in a compartment [message #226398 is a reply to message #226212] |
Thu, 16 April 2009 12:18 |
Hello again,
I have added the needed code, but no breakpoint was hit in the new code.
Then I have modified the getCommand() method of my compartment's
CreationEditPolicy() by converting the
CreateUnspecifiedTypeConnectionRequest to CreateRelationshipRequest and
passing it to the new compartment's getCreateRelationshipCommand() method.
This created the appropriate creation command for my link. Unfortunately the
cursor changed to a Hand cursor (ConnectionCreationTool.calculateCursor())
and creation of a link was impossible. As I see from the GMF source code,
there is a special handling when drawing links to/from a compartment which I
want to remove. Can you advise me how to continue with this?
Thanks in advance,
Kalin
"Alex Shatalin" <vano@borland.com> wrote in message
news:3c3172e62c2658cb8c00331d287c@news.eclipse.org...
> Hello Kalin,
> You have to implement
> <Compartment>ItemSemanticEditPolicy.getCreateRelationshipCommand() method.
> Alex Shatalin
Re: Link ending in a compartment [message #226403 is a reply to message #226398] |
Thu, 16 April 2009 12:49 |
Originally posted by: tobk42.gmx.de
Hello Kalin and Alex,
I have another suggestion: I think it would be cool if the popup-box for
selecting an element type to create or an existing element, that appears
when ending a connection on top of a compartment, could be given another
line: "create connection to this element". Alex, can you tell me where
I'd have to look in order to add this feature?
tobias
Kalin Nakov schrieb:
> Hello again,
> the
> which I
> Thanks in advance,
> Kalin
>> Hello Kalin,
>> method.
>> Alex Shatalin
Re: Link ending in a compartment [message #226531 is a reply to message #226410] |
Fri, 17 April 2009 09:21 |
Hello Alex,
you are right, it works in the Ecore diagram editor, but this is because
these compartments have a list layout. I tried it in my diagram editor,
and for those compartments that have a list layout (in my case, a BPMN
pool) links can be ended ontop of the compartment, while for
compartments with an XY layout (e.g. BPMN subprocess) they can not.
There seem to be some other curious differences between these two types
of compartments I wasn't aware of until now. E.g., it seems that in a
figure with a list layout compartment you can drop a new element from
the palette on the label, while for an XY layout compartment you have to
target the compartment itself (makes sense, as in the latter case the
figure needs some coordinates). I think I'll try to investigate the
differences between these two types of compartments in my diagram code.
Tobias
Alex Shatalin schrieb:
> Hello tobias,
> I've just tried to reproduce this problem with ecore diagram example
> from CVS:
> - I have two classes one contains a number of attributes.
> - I'm trying to create association link from one class to another one
> and drag this link above attributes compartment.
> It is possible to create this link by dropping mouse there.. So, are you
> sure you are using latest GMF to generate code? Can you provide me with
> the steps to repeat this problem on ecore example?
> Alex Shatalin
Re: Link ending in a compartment [message #226577 is a reply to message #226538] |
Fri, 17 April 2009 12:30 |
My situation is similar. I am trying to end a link on a XY layout
compartment. The problem is that I have a compartment with child elements
with infinite level of nesting so disabling child links is not an option for
my application :-( The optimal solution for me would be to accept the link
if the link is ended on the free space between the child items in the XY
layout compartment.
Kalin
news:3c3172e62c3788cb8d773b99e49d@news.eclipse.org...
> Hello tobias,
>> because these compartments have a list layout. I tried it in my
> Sounds reasonable. With list layout it is impossible to create link to a
> child element (XY-layouted compartment allows this).
>> code.
> It was exectly my suggestion. ;-) If you in the end came to an idea that
> it is reasonable to generate this code based on some property from .gmfgen
> model (newly added one - like .areChildLinksAllowed) - just file a
> bugzilla.
> Alex Shatalin
Re: Link ending in a compartment [message #234128 is a reply to message #226577] |
Thu, 18 June 2009 15:54 |
Esteban Dugueperoux Messages: 472 Registered: July 2009 |
Hi Kalin,
Hi Alex,
Hi Tobias,
I want to have the same feature as you want Kalin but without infinite
level, I want node which have links on elements in Compartement of other
Nodes (these nodes are similar to UMLClass with Property in Compartement).
If I set "List Layout" in my gmfgen to false, my compartment elements
disappears.
Alex, Tobias, you have said that with EcoreTools, we can add links to
elements in Compartement, I suppose you talk about Package node?
I would like to add link ending to property like in UMLClass with a
StackLayout in my gmfgraph.
How can do it?
FUDForum. Page generated in 0.03740 seconds
