How to implement Container and Layout Policy [message #226050] |
Sat, 04 November 2006 17:18 |
Originally posted by: xylo3.o2.pl
I try to add to shape source code one feature :
One more model object called "Box" that can contain other shapes (shapes
can be drop into Box).
I have following problem:
When I drop shape into box :
model : shape is added to box children list
view : shape is still outside the box , but its location is changed (it
seems
that coordinates relative to left upper corner of box is used to
move
shape but, it is added to left upper corner of diagram instead of
left
corner of box)
What is more, when I reopen diagram I have box with shape inside it and
one extra shape ...
Below I attach my "Box" source code .
I look forward to hearing any suggestion from you :)
===================BOX.JAVA================================= ==================
public class Box extends Shape {
private static final Image BOX_ICON = createImage("icons/box16.gif");
List<Shape> children = new LinkedList<Shape>();
public Image getIcon() {
// TODO Auto-generated method stub
return BOX_ICON;
public String toString() {
return "Box " + hashCode();
public void addShape(Shape child) {
if (!children.contains(child)){
children.add(child);
public List<Shape> getChildren() {
return children;
public void removeShape(Shape child) {
children.remove(child);
===================================BOX_FIGURE.JAVA========== ==================
public class BoxFigure extends Figure{
IFigure contentPane;
public BoxFigure(){
setBorder(new FrameBorder("BOX"));
ScrollPane scrollpane = new ScrollPane();
contentPane = new FreeformLayer();
contentPane.setLayoutManager(new FreeformLayout());
contentPane.setBackgroundColor(ColorConstants.lightGray);
contentPane.setOpaque(true);
setLayoutManager(new StackLayout());
add(scrollpane);
scrollpane.setViewport(new FreeformViewport());
scrollpane.setContents(contentPane);
public IFigure getContentPane(){
return contentPane;
==================================BOX_EDIT_PART.JAVA======== =====================
public class BoxEditPart extends ShapeEditPart {
protected IFigure createFigure() {
return new BoxFigure();
public IFigure getContentPane() {
return ((BoxFigure)getFigure()).getContentPane();
protected void createEditPolicies() {
super.createEditPolicies();
installEditPolicy(EditPolicy.CONTAINER_ROLE,new BoxContainerPolicy());
installEditPolicy(EditPolicy.LAYOUT_ROLE, new BoxXYLayoutEditPolicy(
(XYLayout)getContentPane().getLayoutManager()));
protected List getModelChildren() {
List children = ((Box)getModel()).getChildren();
System.out.println("BoxEditPart - getModelChildren() - children = " +
children.size());
return children;
==========================BOX_CONTAINER_EDIT_POLICY========= ==================
public class BoxContainerPolicy extends ContainerEditPolicy {
protected Command getCreateCommand(CreateRequest request)
return null;
protected Command getOrphanChildrenCommand(GroupRequest request) {
//TODO : RETURN COMMAND THAT REMOVE SHAPE FROM BOX
return null;
=============================BOXXY_LAYOUT_EDIT_POLICY.JAVA== ===================
public class BoxXYLayoutEditPolicy extends XYLayoutEditPolicy {
public BoxXYLayoutEditPolicy(XYLayout layout) {
setXyLayout(layout);
protected Command createAddCommand(EditPart child, Object constraint) {
System.out.println("BoxXYLayoutEditPolicy - createAddCommand");
Shape part = (Shape)child.getModel();
Rectangle rect = (Rectangle)translateToModelConstraint(constraint);
AddToBoxCommand add = new AddToBoxCommand();
add.setParent((Box)getHost().getModel());
add.setChild(part);
SetConstraintCommand setConstraint = new SetConstraintCommand();
setConstraint.setLocation(rect);
setConstraint.setPart(part);
return add.chain(setConstraint);
protected Command createChangeConstraintCommand(
ChangeBoundsRequest request, EditPart child, Object constraint) {
SetConstraintCommand cmd = new SetConstraintCommand();
Shape part = (Shape) child.getModel();
cmd.setPart(part);
cmd.setLocation((Rectangle) constraint);
return cmd;
protected Command createChangeConstraintCommand(EditPart child,
return null;
protected Command getCreateCommand(CreateRequest request) {
return null;
protected Command getDeleteDependantCommand(Request request) {
return null;
=============================ADD_TO_BOX_COMMAND.JAVA======== ===================
public class AddToBoxCommand extends Command {
private Box parent;
private Shape child;
public void execute() {
parent.addShape(child);
public void setParent(Box box) {
parent = box;
public void setChild(Shape part) {
child = part;
public void undo() {
parent.removeShape(child);
============================SET_CONSTRAINT_COMMAND.JAVA===== ==================
public class SetConstraintCommand
extends org.eclipse.gef.commands.Command
private Point newPos;
private Dimension newSize;
private Point oldPos;
private Dimension oldSize;
private Shape part;
oldSize = part.getSize();
oldPos = part.getLocation();
redo();
public void redo() {
part.setSize(newSize);
part.setLocation(newPos);
public void setLocation(Rectangle r) {
setLocation(r.getLocation());
setSize(r.getSize());
public void setLocation(Point p) {
newPos = p;
public void setPart(Shape part) {
this.part = part;
public void setSize(Dimension p) {
newSize = p;
part.setSize(oldSize);
part.setLocation(oldPos);
Re: How to implement Container and Layout Policy [message #226075 is a reply to message #226050] |
Sun, 05 November 2006 12:55 |
Ok, I will answer myself ;)
I' ve forgot :
1. Add to Diagram (root class object of entire model) edit part Container
policy.
2. addShape and removeShape method in Box.java should fire property change
that is caught by propertyChange() method (in BoxEditPart), where
refreshing view is invoked.
Now I can drop shapes into Box and moving Box with children shapes is
serviced properly. But I can not take shapes from Box and drop in diagram
again...
I guess that there is still something wrong with my Container policy
implementation.
I have implemented Container policy that invoke the same command for
Diagram and Box as well.
==============ORPHAN_CHILD_COMMAND========================== =================
public class OrphanChildCommand extends Command {
private IShapeContainer parent;
private Point oldLocation;
public OrphanChildCommand(){
public void setChild(Shape child) {
this.child = child;
public void setParent(IShapeContainer parent) {
this.parent = parent;
System.out.println("OrphanChildCommand -- execute()");
oldLocation = child.getLocation();
parent.removeChild(child);
parent.addChild(child);
This command is created in getOrphanChildCommand() that looks the same
for DiagramContainerPolicy and BoxContainerPolicy :
List parts = request.getEditParts();
CompoundCommand result = new CompoundCommand();
for (int i = 0; i < parts.size(); i++) {
OrphanChildCommand orphan = new OrphanChildCommand();
orphan.setChild((Shape) ((EditPart) parts.get(i))
.getModel());
orphan.setParent((IShapeContainer) getHost().getModel());
result.add(orphan);
return result.unwrap();
When I try unpack shape from box, OrphanChildCommand object is created by
its execute() method is not invoked....
Any help will be appreciated
Max
Re: How to implement Container and Layout Policy [message #226113 is a reply to message #226075] |
Mon, 06 November 2006 06:04 |
Originally posted by: none.unknown.com
Your box get the ORPHAN request, and your diagram gets the ADD request. The
reparenting happens IFF both return executable commands.
"Max" <xylo3@o2.pl> wrote in message
news:eedda54edc6a1ea12a6ffc7f70c1d2a7$1@www.eclipse.org...
> I' ve forgot :
> policy.
> again...
> implementation.
> this.child = child;
> @Override
> @Override
> .getModel());
> result.add(orphan);
> Max
FUDForum. Page generated in 0.05092 seconds
