Home » Eclipse Projects » BIRT » Conditional expressions are missing
Conditional expressions are missing [message #225760] Fri, 16 March 2007 06:18 Go to next message
Ravi is currently offline RaviFriend
Member
Using 211.
Is it that conditional statements like 'if', 'else' are not supported to
build data expressions?
A use case is -- if DataSet.columnA = X then the report Data element value
should be DataSet.columnB otherwise the value should be DataSet.columnC.
How can I do this?
Thanks in Advance,
Ravi Chamarthy
Re: Conditional expressions are missing [message #228224 is a reply to message #225760] Mon, 19 March 2007 18:24 Go to previous message
Ravi wrote:
> Using 211.
> value should be DataSet.columnB otherwise the value should be
> DataSet.columnC.
> How can I do this?
> Thanks in Advance,
> Ravi Chamarthy
This should work fine.
As a test I entered the following as my expression and it worked fine.
if( dataSetRow["QUANTITYORDERED"] == 30 ){
dataSetRow["PRICEEACH"]
}else{
dataSetRow["QUANTITYORDERED"];
Jason
Previous Topic:Report Parameter DATE
Next Topic:Error by run
Current Time: Wed Jan 24 05:59:56 GMT 2018
Powered by FUDForum. Page generated in 0.01958 seconds
