RunReport.java example question? [message #225366] |
Thu, 15 March 2007 13:19 |
Originally posted by: beta.designtech.se
I'm trying to create a report from a remote machine using the RunReport
example code and it seems that the report engine needs an X-server for the
report to be created successfully. If X-forwarding is not used the report
file size is zero with the error message:
X connection to localhost:12.0 broken (explicit kill or server shutdown)
Can anyone shed some light on this?
Fredrik
Re: RunReport.java example question? [message #225787 is a reply to message #225366] |
Fri, 16 March 2007 08:59 |
Originally posted by: martin.tauber.t-online.de
Sorry, I don't know the runReport.java example. Maybe you can add some
more information.
> Fredrik
Re: RunReport.java example question? [message #225874 is a reply to message #225787] |
Fri, 16 March 2007 14:05 |
Ok, thanks for replying.
I use this example ( http://www.eclipse.org/birt/deploy/RunReport.java ) to
make some easy test reports with the example database that is available
here: http://www.eclipse.org/birt/phoenix/db/
If I run the command 'java RunReport chart.rptdesign -p' with the Xserver
running everything is ok and the pdf report is created normally but if I run
the command from a shell without Xserver support I get the error message 'X
connection to localhost:12.0 broken (explicit kill or server shutdown)' and
the pdf report file has zero length.
I eventually want to call on the command from php either by using the
'system' command or running the RunReport class through the php-java bridge
but I'm suspecting I will run into trouble if the birt report engine needs
the X environment to be able to create the reports without errors.
Fredrik
"Martin Tauber" <martin.tauber@t-online.de> skrev i meddelandet
news:etdm9j$hru$1@utils.eclipse.org...
> more information.
>> the report to be created successfully. If X-forwarding is not used the
>> report file size is zero with the error message:
>> Regards,
>> Fredrik
FUDForum. Page generated in 0.03301 seconds
