Model-Editpart-View [message #224236] |
Thu, 12 October 2006 10:59 |
Originally posted by: tom.parker.gmail.com
the problem is stated below:
model element: org.eclipse.uml2.comment
requirement: 2 figures for this model element
so editpart required: 1 or 2
Can 2 figures be associated with 1 editpart?
if yes,then how?
if no,that means I have to create 2 editparts.
Now the question is,in the editpart factory how do I create 2 editparts
for the same model element?
Tom
Re: Model-Editpart-View [message #224284 is a reply to message #224236] |
Fri, 13 October 2006 08:19 |
Andreas Werner Messages: 55 Registered: July 2009 |
Member |
Tom schrieb:
> if yes,then how?
> Tom
Hi Tom,
what about one figure with two figures inside?
Or do they appear not simultaneously? If so, you could change the
painting of only one figure, when it's necessary.
Regards, Andreas
FUDForum. Page generated in 0.01972 seconds
