Home » Language IDEs » Java Development Tools (JDT) » java.library.path issues with external library
java.library.path issues with external library [message #223730] Tue, 07 February 2006 03:56 Go to next message
Originally posted by: me2.nowhere.com
I am building my first swt app that uses an external library. I am trying
to use rxtx (http://www.rxtx.org/) to facilitate serial communications
from my Java application.
My app worked fine until I added the rxtx stuff. I added the necessary
imports and it builds fine. In Properties->JavaBuildPath->Order and
Export, I added RXTXcomm.jar.
When I run the application, I get:
java.lang.UnsatisfiedLinkError: no rxtxSerial in java.library.path thrown
while loading gnu.io.RXTXCommDriver
So, I add -Djava.library.path=/usr/java/jre1.5.0_05/lib/i386 to
Run...<RunID>->WM Arguments.
Then when I run the application I get:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no
swt-pi-gtk-3139 in java.library.path
How do I get both libraries to load at run time ?
Thanks.
Re: java.library.path issues with external library [message #223738 is a reply to message #223730] Tue, 07 February 2006 04:30 Go to previous messageGo to next message
I found the file libswt-pi-gtk-3139.so in /usr/lib.
I tried -Djava.library.path=/usr/java/jre1.5.0_05/lib/i386;/usr/lib with
no joy.
-Djava.library.path=/usr/java/jre1.5.0_05/lib/i386:/usr/lib and it seems
to have worked.
Re: java.library.path issues with external library [message #223779 is a reply to message #223730] Tue, 07 February 2006 13:18 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
When you get to your jar in the build path, you can also expand the jar
and add a native library entry that points to the correct native library
dir for that jar ... then eclipse will automatically compute the
java.library.path for you.
Later,
PW
Re: java.library.path issues with external library [message #223793 is a reply to message #223730] Tue, 07 February 2006 14:40 Go to previous messageGo to next message
Michael is currently offline MichaelFriend
Member
I think this problem is not because of the jar files. Both of the
libraries try to load a dll. Please check that the dlls can be found in
the search path. The easiest way to check this is to copy them to the
windows system32 folder. If this source of the problem you can try further
to adjust your paths.
HTH,
Michael
> Thanks.
Re: java.library.path issues with external library [message #223844 is a reply to message #223779] Wed, 08 February 2006 00:11 Go to previous messageGo to next message
> Later,
> PW
Thanks. I'll give that a try too.
Re: java.library.path issues with external library [message #223850 is a reply to message #223793] Wed, 08 February 2006 00:20 Go to previous messageGo to next message
On Tue, 07 Feb 2006 15:40:03 +0100, michael wrote:
> Hello,
> HTH,
> Michael
Err... I'm running Linux...
Re: java.library.path issues with external library [message #223878 is a reply to message #223850] Wed, 08 February 2006 14:12 Go to previous messageGo to next message
Member
Then it'll be a shared lib and your $PATH... ;)
Re: java.library.path issues with external library [message #223885 is a reply to message #223850] Wed, 08 February 2006 14:49 Go to previous messageGo to next message
Member
Now I just tried it...
rxtx stuff is relative to source code
Sample code:
import gnu.io.*;
import java.util.*;
class ShowPorts {
CommPortIdentifier portId;
Enumeration en = CommPortIdentifier.getPortIdentifiers();
while (en.hasMoreElements()) {
portId = (CommPortIdentifier) en.nextElement();
System.out.println(portId.getName());
Compiled with: javac -classpath rxtx-2.1-7-bins/RXTXcomm.jar
ShowPorts.java
Executed with: java -classpath .:rxtx-2.1-7-bins/RXTXcomm.jar
-Djava.library.path=rxtx-2.1-7-bins/Linux/i686-unknown-linux -gnu ShowPorts
Or executed with: LD_LIBRARY_PATH=rxtx-2.1-7-bins/Linux/i686-unknown-linux-gnu java
-classpath .:rxtx-2.1-7-bins/RXTXcomm.jar ShowPorts
Result:
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
/dev/ttyS0
It's the same for swt but with a different shlib.
HTH,
Michael
Re: java.library.path issues with external library [message #223892 is a reply to message #223878] Wed, 08 February 2006 14:50 Go to previous message
Member
LD_LIBRARY_PATH i mean
Previous Topic:Can I use multiple JDT model to represent the same file loaded at different time
Next Topic:difference between javac and eclipse compile when inheriting abstract Charset
Current Time: Fri Apr 20 18:50:52 GMT 2018
Powered by FUDForum. Page generated in 0.01874 seconds
