Home » Eclipse Projects » BIRT » Removing Oracle hints
Removing Oracle hints [message #222750] Tue, 06 March 2007 22:28 Go to next message
Originally posted by: ybarkalov.yahoo.com
I'm developing report and using a lot of Oracle hints like MATERIALIZE,
NO_MERGE and USE_HASH() for performance reasons. And it seems that BIRT
strips out ALL the hints when executing this query. At least Oracle
Enterpise Manager shows SQL without any hits at all. And execution plan
that it chooses also matches to the query with hits striped out. And with
all the hints gone, the query never completes with execution path chosen
by Oracle
The same query runs fast from SQL Plus and other client tools. The
execution plan is exactly as hints define it. And the execution plan is
different from the one shown in Enterpise Mananger for BIRT session.
Is this the standard behavoir for BIRT to remove hints? Is there a way to
leave hits in the query?
Yevgeniy
Re: Removing Oracle hints [message #223043 is a reply to message #222750] Thu, 08 March 2007 01:27 Go to previous messageGo to next message
> with all the hints gone, the query never completes with execution path
> chosen by Oracle
> to leave hits in the query?
> Yevgeniy
Can you set you log level to FINEST and run the report again.
Look for QueryText in the log and verify it is the proper query.
Jason
Re: Removing Oracle hints [message #223711 is a reply to message #223043] Fri, 09 March 2007 19:04 Go to previous messageGo to next message
Hello Jason,
Thanks for the reply. I set logging to FINEST and can see that SQL in Birt
log has hints. But the SQL executed by Oracle doesn't have. Comments in
SQL are gone as well. I think the problem comes from the fact that Oracle
hints have a format similar to comments, for example:
/*+ NO_MERGE */ is a hint
/* NO_MERGE */ is a comment
For some reason, something in the process strips out SQL block comments
(/*...*/) and it doesn’t distinguish between comments and Oracle hints. It
seems that the issue could be in DTP module and our programmers are now
looking through the source code.
Do you know about the conditions in which the comments are removed?
I also tried the following things:
1) re-typing the entire SQL in the text box in Birt thinking that some
unrecognized invisible symbol would cause this behavior – didn’t help.
2) running report in designer and runtime engine – no difference
Yevgeniy
Re: Removing Oracle hints [message #224246 is a reply to message #223711] Mon, 12 March 2007 18:06 Go to previous messageGo to next message
Originally posted by: test.tes3456t.com
Could someone please give any additional pointer on this ? We are
currently stuck due to this. Any suggestion/workaround is highly
appreciated.
Mustafa
Yevgeniy wrote:
> Hello Jason,
> Yevgeniy
Re: Removing Oracle hints [message #224346 is a reply to message #224246] Mon, 12 March 2007 21:12 Go to previous messageGo to next message
Linda ChanFriend
This appears to be a bug in the BIRT oda.jdbc driver. It strips out comments
before passing a SQL query text to the JDBC driver:
Found in org.eclipse.birt.report.data.oda.jdbc's Statement.prepare method:
* call the JDBC Connection.prepareStatement(String) method to get
* the preparedStatement
this.preStat = conn.prepareStatement( SQLFormatter.formatQueryText( command )
Please submit a BIRT bug in Bugzilla on this issue.
In the mean time, a work-around is to add a driverBridge extension that
overrides the oda.jdbc's Statement.prepare method. A sample implementation of
driverBridge extension is in the connection pooling example that Jason has
posted (also attached in Bugzilla 135246).
Linda
> appreciated.
> Mustafa
> Yevgeniy wrote:
> > Hello Jason,
> > Thanks,
> > Yevgeniy
Re: Removing Oracle hints [message #225175 is a reply to message #224346] Wed, 14 March 2007 17:46 Go to previous message
Sunitha Kambhampati is currently offline Sunitha KambhampatiFriend
Member
Thanks Linda for your comments.
I was looking at the code in the birt.report.data.oda.jdbc directory and
realized once this issue is fixed, we can also cleanup the SQLFormatter
class.
Opened a bugzilla : https://bugs.eclipse.org/bugs/show_bug.cgi?id=177381
regards,
Sunitha.
Previous Topic:BIRT 2.2M5 postscript emitter
Next Topic:resource path syntax
Current Time: Tue Jan 23 00:22:35 GMT 2018
Powered by FUDForum. Page generated in 0.01518 seconds
