Home » Language IDEs » ServerTools (WTP) » Deploying to Tomcat
Deploying to Tomcat [message #221553] Thu, 18 September 2008 00:47 Go to next message
Lenny Wintfeld is currently offline Lenny WintfeldFriend
I'm most of the way thru Russ Bateman's WTP tutorial from the eclipse
wtp tutorials page. I'd like to try and deploy the tutorial's test
servlet to the \tomcat6.0\webapps subdirectory and see it run
independently of Eclipse (instead of running it in a tab window inside
Eclipse).
Could you refer me to a how-to/tutorial/help-topic on how to do this? Or
as an alternative could yo refer me to a resource that explains how to
use WTP to define and make a .war .... from there I would manually drop
it in to the webapps subdir.
Thanks in advance for any advice
Lenny WIntfeld
Re: Deploying to Tomcat [message #221568 is a reply to message #221553] Thu, 18 September 2008 11:34 Go to previous message
Kaloyan Raev is currently offline Kaloyan RaevFriend
Lenny, you can export a Dynamic Web project from your workspace to a WAR
file.
Right-click on your web project > Export > WAR file.
Greetings, Kaloyan
"Lenny Wintfeld" <lennyw@comcast.net> wrote in message
news:gas8ei$ko2$1@build.eclipse.org...
> I'm most of the way thru Russ Bateman's WTP tutorial from the eclipse wtp
> tutorials page. I'd like to try and deploy the tutorial's test servlet to
> the \tomcat6.0\webapps subdirectory and see it run independently of
> Eclipse (instead of running it in a tab window inside Eclipse).
> as an alternative could yo refer me to a resource that explains how to use
> WTP to define and make a .war .... from there I would manually drop it in
> Lenny WIntfeld
Previous Topic:doPost doGet not generated
Next Topic:Eclipse download files for linux not working
Current Time: Tue Jan 16 11:45:14 GMT 2018
Powered by FUDForum. Page generated in 0.01991 seconds
