Home » Eclipse Projects » GEF » How to center a multiline Label inside a RoundedRectangle?
How to center a multiline Label inside a RoundedRectangle? [message #221185] Thu, 10 August 2006 11:42 Go to next message
Originally posted by: am.andreasmeissner.de
since I'm developing with Eclipse 3.2 and the corresponding GEF 3.2
releases I get the following problem. My multiline label inside a
RoundedRectangle isn't centered anymore. The horizontal centering works
fine but not the vertical one. It's now places vertically on the top of
the rectangle.
Does anyone of you see a problem in my code or has some hints?
public class LabeledRoundedRectangle extends RoundedRectangle {
public LabeledRoundedRectangle() {
setLayoutManager(new BorderLayout());
TextFlow textFlow = new TextFlow();
textFlow.setText("some text");
FlowPage flowPage = new FlowPage();
flowPage.setHorizontalAligment(PositionConstants.CENTER);
flowPage.add(textFlow);
add(flowPage, BorderLayout.CENTER);
Andreas
Re: How to center a multiline Label inside a RoundedRectangle? [message #221199 is a reply to message #221185] Thu, 10 August 2006 15:48 Go to previous message
BorderLayout was changed in 3.2 so that the center figure is stretched to
fill the available space. This was to make it consistent with expectations
(AWT), and because of use cases which suggested this was a better default.
So now your flowpage is no longer centered in the middle of its parent.
It's obvious what you need to do but there's no quick fix.
"Andreas Meissner" <am@andreasmeissner.de> wrote in message
news:ebf63g$962$1@utils.eclipse.org...
> the rectangle.
> Andreas
Previous Topic:Selection in a viewer
Next Topic:EContentAdapter behaviour ?
Current Time: Thu May 24 08:11:13 GMT 2018
Powered by FUDForum. Page generated in 0.02076 seconds
