Home » Language IDEs » ServerTools (WTP) » some server config is not exist in eclipse-jee-ganymede
some server config is not exist in eclipse-jee-ganymede [message #218637] Sat, 02 August 2008 10:09 Go to next message
opengloves is currently offline openglovesFriend
When I debug a webapp at bootstrap.
This happened:Server Tomcat v5.5 Server at localhost was unable to start
within 45 seconds. If the server requires more time, try increasing the
timeout in the server editor.
I check the option in this way:Window->Perferences->Server
find no option about "Server timeout delay [Longer]"
Old Eclipse-JEE version has this option.
How can this be fixed?
Re: some server config is not exist in eclipse-jee-ganymede [message #218645 is a reply to message #218637] Sat, 02 August 2008 18:14 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry IsaacsFriend
Gloves wrote:
> Hello,
> Thanks
Rather than having one setting that affects all servers, timeouts are
now per server. Double-click the server in the Servers view to open the
server editor. Then expand the Timeouts section on the right side of
the editor.
Larry
Re: some server config is not exist in eclipse-jee-ganymede [message #218677 is a reply to message #218645] Mon, 04 August 2008 01:22 Go to previous message
Thank you Larry, I will follow your suggestions.
Gloves
Previous Topic:j2ee preview + myfaces
Next Topic:Suppress XML Grammar warning
Current Time: Sat Feb 17 20:04:35 GMT 2018
Powered by FUDForum. Page generated in 0.02161 seconds
