Home » Language IDEs » ServerTools (WTP) » SAX parser in WST?
SAX parser in WST? [message #216475] Tue, 01 July 2008 09:40 Go to next message
Gerrit  is currently offline Gerrit Friend
Member
I am using the internal WST DOM model
(org.eclipse.wst.xml.core.internal.provisional.document.IDOM Model) to
parse XML documents, because it is the only one I could find that is able
to retrieve the original textual offsets of an XML node in the source
document. I couldn't figure out a way to do this with w3c.dom or jdom.
Is there maybe a SAX parser with the same functionality hidden somewhere
in the WST packages? I don't need the XML context, and it would make the
parsing much faster.
Gerrit
Re: SAX parser in WST? [message #216486 is a reply to message #216475] Tue, 01 July 2008 14:06 Go to previous messageGo to next message
> able to retrieve the original textual offsets of an XML node in the
> source document. I couldn't figure out a way to do this with w3c.dom or
> jdom.
WST does implement it's own SAX parser api, that does keep track of the
beginning column and ending column number of a tag. It's buried within
the XML validation routines as an internal class. So isn't callable
directly.
As you noticed the w3c.dom and jdom themselves don't keep track of this
information.
Re: SAX parser in WST? [message #216700 is a reply to message #216486] Thu, 03 July 2008 06:41 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
> directly.
> information.
I wouldn't say it's SAX exactly, since it doesn't even try to
implement that API, and actually has more in common with StaX (which
came along a lot later). If you make use of the platform's file
buffers APIs, the documents in the ITextFileBuffers for XML files
implement IStructuredDocument. That then breaks down into
IStructuredDocumentRegions, which for XML represent the start and
end tags individually. Inside of those are ITextRegions marking the
positions of the various syntactic tokens that make up the tag.
http://help.eclipse.org/stable/topic/org.eclipse.platform.do c.isv/reference/api/org/eclipse/core/filebuffers/ITextFileBu fferManager.html
would be the logical starting point, then.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: SAX parser in WST? [message #216746 is a reply to message #216700] Thu, 03 July 2008 13:46 Go to previous message
Nitin Dahyabhai wrote:
>> the beginning column and ending column number of a tag. It's buried
>> within the XML validation routines as an internal class. So isn't
>> callable directly.
>> this information.
> I wouldn't say it's SAX exactly, since it doesn't even try to implement
> that API, and actually has more in common with StaX (which came along a
> lot later).
I was referring to the Xerces Valadition routines which do override and
implement a SAX parser that keeps track of line numbers. It extends the
SAX pieces, when it instatiates the Xerces parser for validation against
a grammar.
If you make use of the platform's file buffers APIs, the
> documents in the ITextFileBuffers for XML files implement
> IStructuredDocumentRegions, which for XML represent the start and end
The problem with the above approach that while it can be done, it's not
one of the typical API's that most XML programmers are going to be
familiar with. It's again one of the reasons I keep strongly urging
WTP to try and leverage and use more of the existing XML APIs as much as
possible instead of re-inventing the wheel. It makes it much easier for
adopters familiar with these technologies to implement. It may be a
shell that wraps the underlying Eclipse API, but having these wrapper
classes can make adoption easier, just as has been partially done with
the DOM implementation of the SSE.
Previous Topic:I'm trying to use the ibmaio package and I can't seem to tell eclipse about the .so file.
Next Topic:JBoss Publish error on Eclipse 3.4
Current Time: Tue May 22 06:34:09 GMT 2018
Powered by FUDForum. Page generated in 0.01862 seconds
