Home » Language IDEs » ServerTools (WTP) » JSDT - jsDoc not used for code completion?
JSDT - jsDoc not used for code completion? [message #216368] |
Mon, 30 June 2008 02:34 |
Bob Shields Messages: 7 Registered: July 2009 |
Junior Member |
On a fresh install of Ganymede with the Javascript Tools added, I entered:
* Demo function
* @param s String
function demoFunc(s)
var len = s.
With the cursor following the "s.", I pressed Ctrl+Space, but did not
get any form of code completion. (I was expecting the String methods
and properties to be displayed). If there had been no jsDoc, I could
understand why there would be no suggestions, but the jsDoc is present!
This is actually a simplified version of a larger issue: I have
attempted to generate a number of code-completion libraries for my
external Objects, and they work fine within the scope of the function
that obtains an instance of the Object. But if I then pass that Object
to another function, I lose code-completion even though the jsDoc
correctly defines the type of the Object for that function parameter.
On a side note, is this the best place for JSDT discussions? I would
think that with the number of (duplicated) news items about JSDT in this
release, there would be a lot more active discussion...?
Bob
Re: JSDT - jsDoc not used for code completion? [message #216408 is a reply to message #216368] |
Mon, 30 June 2008 18:14 |
Bradley Childs Messages: 14 Registered: July 2009 |
Junior Member |
content completion works for me on the string type-- see attached
screenshot. could you give an example/recreate for the other problem you
mentioned?
-brad
"Bob Shields" <java@resnbl.com> wrote in message
news:g49gne$mij$1@build.eclipse.org...
> * Demo function
> * @param s String
> var len = s.
> Bob
Re: JSDT - jsDoc not used for code completion? [message #216441 is a reply to message #216408] |
Mon, 30 June 2008 22:31 |
Junior Member |
--------------010900010609010507040802
<html>
<head>
</head>
Here is my screen shot (I'm so glad I finally learned how to make
these):<br>
<br>
<img alt="screen shot" src="cid:part1.06060605.08060802@resnbl.com"
height="345" width="421"><br>
<br>
Items I noticed about your screen shot:<br>
<br>
1) Window object definitions: you're obviously running with more than
the default ECMA-262 library, I am not.<br>
<br>
2) You list includes the String object itself, but I don't see the
"split" or "slice" methods that should be visible in your list (String
properties/methods are what I'm looking for). Even when I do get
code-completion (with, for example, " var x =
'abc'; x. "), there is no "String" class object with the green (C)^
icon in my proposal list.<br>
<br>
3) Why would you expect String proposals if you typed the parameter as
"anything"? Do *all* defined types in any source file or "libraried"
file show up in the list? That wouldn't seem helpful.<br>
<br>
I'll work up an example for the other item and append it to this thread
later...<br>
<br>
Bob Shields<br>
<br>
<br>
Bradley Childs wrote:
<blockquote cite="mid:g4b7n1$h6v$1@build.eclipse.org" type="cite">
<pre wrap="">content completion works for me on the string type-- see attached
mentioned?
-brad
"Bob Shields" <a class="moz-txt-link-rfc2396E" href="mailto:java@resnbl.com"><java@resnbl.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:g49gne$mij$1@build.eclipse.org">news:g49gne$mij$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">On a fresh install of Ganymede with the Javascript Tools added, I entered:
* Demo function
* @param s String
var len = s.
Bob
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<center><img src="cid:part2.04060303.09040500@resnbl.com"></center>
</blockquote>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="screenShot003.jpg"
Content-ID: <part1.06060605.08060802@resnbl.com>
Content-Disposition: inline;
filename="screenShot003.jpg"
/9j/4AAQSkZJRgABAgEAyADIAAD/wAARCAFZAaUDAREAAhEBAxEB/9sAhAAE AgMDAwIEAwMD
BAQEBQYKBgYFBQYMCQkHCg8NEA8PDQ4OEBMYFBARFxIODhUcFRcZGRsbGxAU HSAdGh8YGhsa
AQQEBAYFBgwGBgwaEQ4RERoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoaGhoa GhoaGhoaGhoa
GhoaGhoaGhoaGhr/xAGiAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQ AAIBAwMCBAMF
BQQEAAABfQECAwAEEQUSITFBBhNRYQcicRQygZGhCCNCscEVUtHwJDNicoIJ ChYXGBkaJSYn
KCkqNDU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6g4SF hoeIiYqSk5SV
lpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2drh4uPk 5ebn6Onq8fLz
9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEQACAQIEBAME BwUEBAABAncA
AQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZ GiYnKCkqNTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqS k5SVlpeYmZqi
o6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery 8/T19vf4+fr/
2gAMAwEAAhEDEQA/APrGxvCl1c30rCSYvLCuT92NGKbBng7ipP447V05dhl7 By/rdnNOvapy
mPaeJb6U6bYHxDYDWNR0+O+t7CPRbl1bfHJIieaJNgYiCXAJBOwnBrzKeJxM aC9nG616PudE
pwUuRs2NL12S6glE1tPbXUD+VNbOpyrYB4PQghlIIzkEZxXsYGdarH34/gzm rwSV0YmsfFXw
TpQ1L7b4nsk/s22a6uSrF8In2nft2gl2H2K6yiguvkPuUDmuyVFJ2aOaDnZH T/2kcjJcZOBx
z17Dv9Ov9LWHj2HzyEXUyVyNxGMgqCc5HA+vHbPUduaToRT2DnkY2kfELwlq viO70DS/Fei3
2qWe/wC1WFtfRSXFtsba/mRqxZcMQpyMgnGKPYQ7BzyNn+0zkDDk9CAOQfTn AzweM57Yo+rw
3sL2khBqmRlXDA/d2kncewGB+POOnTvR9Xh2D2siK+1+0soFmvbuK2haWOFZ ZW2qXdwiKC2A
SWZQBnJLqMc1Sw8ew/asS/1+1sdNuNQvryC2tbeNpp55pAkcMagku7ngLgN8 xwBg5PFN4eHY
FWZP/aYI3BvkyRknH5noOo/X0oVJLSwOq7XKms+Ihp9kJxb3N3I8sUCW8Hli R3klWJQNzhT8
zjqw75IrOtBQV7Dp1XJ2KWreMUttN1HdpWo3UunRNPqenxCMy2aKCSZA7qvI B24J3jJQOoLV
yxdOejNpqS1LcRW1kMmkvFasR80GG8iQ+m0YCn/aA59Cc1nXy1tXiv6+4qli Unqa2lX0F9bG
RQqOuFkSQDKN7n07g9CMV41bDSpuzO1SUtUW8D+6v/fIrnhe4Bgf3V/75FXL cpBgf3V/75FI
AwP7q/8AfIoAMD+6v/fIoAMD+6v/AHyKADA/ur/3yKADA/ur/wB8igAwP7q/ 98igAwP7q/8A
fIoAMD+6v/fIoAMD+6v/AHyKADA/ur/3yKADA/ur/wB8igAwP7q/98igAwP7 q/8AfIoAMD+6
v/fIoAMD+6v/AHyKADA/ur/3yKADA/ur/wB8igAwP7q/98igAwP7q/8AfIoA MD+6v/fIoAMD
+6v/AHyKADA/ur/3yKADA/ur/wB8igAwP7q/98igAwP7q/8AfIoAMD+6v/fI oAMD+6v/AHyK
ADA/ur/3yKADA/ur/wB8igAwP7q/98igAwP7q/8AfIoAMD+6v/fIoAMD+6v/ AHyKADA/ur/3
yKAPPru+EN/NGSCftM6jk8AzSHoM/wBK+zy2jfBJrrf8GeHWlH293/WhyV3o uu2Gj+HvGOm6
rfyTTw6e8dvaWEk9xahLB4gm8CcJFmSduLZjulwSAxYeXgatOOGjQk0mr7tJ 6u/5fgViYt13
Ui/6sbOm397Dq2px6rM8l6slr9peVEjYyfYoNxKoSgJPUKSvYEivTwFGUnZP TyIq1ZWszzf4
u+AfDv8AwjHjzxPpGm3cviPUvD11aKIJHlknbyrgBcA75AxmVfLYugEFuFVf KTHfWwSUm7sz
pV2rR6FCw1vUdO8U2mqeH28ZnwVZ3tvPcLqC6hPdNI1vfRygRz7rmaPfJpxC qGQMC6gYkaue
VKcdjojUurM5fx14i15vh/4q1bX7rx1Yp9g1a68PS2x1K1kgnN7fNmcQhWRB CbAKLgBFUHbt
HmVHs5vVj51zWR12g311faTH4WtdM1az1qy8Y3erJd3Onz20NpbDVZp5GjuH RQxkt3aIJEWL
CfBGwuVtUJMTqJfccp4YT4g3eki21TxD4ouLq6k02DXbe2tdQtRBM1/a+b5d y9wwIEf2tSbJ
Y4Sm5iQoiBPYzE5robMk/jq0gT7NceKpLe6l1CLU9811NILS31W3ii8vcS0c p0/7SVaLEkvM
mXkAaj2U+xPOiXxFeB/h4ZrjTdf1DTbTxfpd5oBvdOvLy+traOW1knlIkRrl cMl8AZMHYQq5
VowbVF21BPXfodl8d/Eksnwu8bWdp/a9hd2GgSajb6hZyyW+JdsrRrHKjBg6 tBuZOAVZAdwY
iqdFkRaurlL4b6lrB+L+uNdSarqsB+0N/aVw+oWkFuGmURWyWk37iXCRnFzA OQh3DLB5FSpy
9o4taBUnaCO71/VsaPIhQzxSPHburQPOFV3CMTGuTJtRmYr1IGP4sisdQtC8 FqLDz1Lfizxn
ZXfg6PTjHq0kOmRxz6fcTs1xLqjxIVC3UYXKFiN6uchXVXfYyhG8PD4WrzKV juqYiFuVinVA
ABuIGOBzjB+vUfX2zX01OleNpI82c4p6Mfaa09verdwSbZl+XceQ47qw7j/a 7dK87HZbGac1
/X4HRh8bNPkdrHb6Hqdpqdl59vIu4cPGW5U+n+HYjHNfG1qPsZe8j2YzjJaM unrWTTkuaOxS
UgpRhJ72LUGFNwkn0E4yTClyT8hcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qc sgo5J+Qcsgo5
J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qc sgo5J+Qcsgo5
J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qcsgo5J+Qc sgo5J+Qcsjyf
XSW1q8XYS32mZVBXOcyPjgj19fU88c/oeS8rwtOL8/zZ8rj3KNbT+tDDj8Pe H3U+VoemFQwb
KWqFVyCFzgcd+euB3wKccqwqtKdO7fkv8ivrEr2LdhY2dlbmGwtYbaEndshj CA++AMA/5NdU
ZYegrRVvuRFT2kloWCDuDAHduypA6HORiq+tUZat/kZRp1bbfmIq4XA4A4xz 09Pp/k0/rGH6
tfgaKNVdDP1nQND1e8sbvVtF02/uLCQS2k11apK9u+QSyFlJUnauSOTtHpUu th77r8Aftv6u
aK5UgqdpAABXIwAcjt61ar4fuvwFar2Ag4AHQAhQcsFBx0yD6D8qHXod1+Ac tUa6BlYHPzLt
Jyenp/L8h6Uvb0O6/AOWqObcXLZwST0yMew44HsOOnpSVagtE/yDlqkN/aW1 7biC7toZ4hIk
ojlTcA6MHVhkcEMqsMdCoI5GaPb0e/5By1f6uSsCy7TyPQ5PXGeo44GKft6H R/kDhVfQGXd9
7ngjPOcfXGaFiKD+J/kEIVY9PzFbexJLZJ65HXrnjHfNWquFS0a/Abp1ZPmY m3k+5yev+FQ8
VRez/IaoT6igcY49D1/wprF0fhk/yFKjUXwolsbm6s7hbi1mlimXhZEHb0Oe o9jXDi8DhK63
X4G+GqVoP3v1Ol07xveRFV1GzjlU9ZIDtYfRWOG/AjFfL4jJnGTVOWnr/wAA 9ZYuReHjvTP+
fG//AAEX/wAXXEsqqJ/F+P8AwDRYqQv/AAnemf8APhqH5Rf/ABdU8qqP7X4/ 8AbxMg/4TvTP
+fDUPyi/+Lpf2TU/m/H/AIAvrMg/4TvTP+fDUPyi/wDi6P7Jqfzfj/wA+syD /hO9M/58NQ/K
L/4uj+yan834/wDAD6zIP+E70z/nw1D8ov8A4uj+yan834/8APrMg/4TvTP+ fDUPyi/+Lo/s
mp/N+P8AwA+syD/hO9M/58NQ/KL/AOLo/smp/N+P/AD6zIP+E70z/nw1D8ov /i6P7Jqfzfj/
AMAPrMg/4TvTP+fDUPyi/wDi6P7Jqfzfj/wA+syD/hO9M/58NQ/KL/4uj+ya n834/wDAD6zI
P+E70z/nw1D8ov8A4uj+yan834/8APrMg/4TvTP+fDUPyi/+Lo/smp/N+P8A wA+syD/hO9M/
58NQ/KL/AOLo/smp/N+P/AD6zIP+E70z/nw1D8ov/i6P7Jqfzfj/AMAPrMg/ 4TvTP+fDUPyi
/wDi6P7Jqfzfj/wA+syD/hO9M/58NQ/KL/4uj+yan834/wDAD6zIP+E70z/n w1D8ov8A4uj+
yan834/8APrMg/4TvTP+fDUPyi/+Lo/smp/N+P8AwA+syD/hO9M/58NQ/KL/ AOLo/smp/N+P
/AD6zIP+E70z/nw1D8ov/i6P7Jqfzfj/AMAPrMg/4TvTP+fDUPyi/wDi6P7J qfzfj/wA+syD
/hO9M/58NQ/KL/4uj+yan834/wDAD6zIP+E70z/nw1D8ov8A4uj+yan834/8 APrMg/4TvTP+
fDUPyi/+Lo/smp/N+P8AwA+syD/hO9M/58NQ/KL/AOLo/smp/N+P/AD6zIP+ E70z/nw1D8ov
/i6P7Jqfzfj/AMAPrMg/4TvTP+fDUPyi/wDi6P7Jqfzfj/wA+syD/hO9M/58 NQ/KL/4uj+ya
n834/wDAD6zIP+E70z/nw1D8ov8A4uj+yan834/8APrMg/4TvTP+fDUPyi/+ Lo/smp/N+P8A
wA+syD/hO9M/58NQ/KL/AOLo/smp/N+P/AD6zIP+E70z/nw1D8ov/i6P7Jqf zfj/AMAPrMg/
4TvTP+fDUPyi/wDi6P7Jqfzfj/wA+syD/hO9M/58NQ/KL/4uj+yan834/wDA D6zI8y+JmnWF
7qd0L7T7WeJbq6G65hVlXls/MwGPlDE/vF4BPybTcQfR5ZUlHB0qkXrr+f8A X9aPyMZBTqXZ
z0+gaEzyPPountguS0tsny/f35JCBesueY8bWz5Xl/8AEv66uIruNlNpdk3/ AF/X35ciUrn1
9CFEajgg8Zr5SUmpWPcp048tzkh4zsnnAXVdGjkblLOWQCYggEZ+b5Tgjgjk VtOFo3Rk567I
v6t4ij03wO2twW63UsgVbS2MgT7RPK+2GHfghCzsi7iMDdk8VCi5bmsVF9BP HXi/T/Clraza
hZ6lcC5mjhT7Dp80+CzomWKKQvMgOCcsAQoYjFXQoyqSavt5iajfYh8V+N9L 0DSNP1G6stWm
ivniWEWumTyMN7ogLgL+7OZFO1sMcEKCw20sPTnVbTEkux0elzxXunQXkSyC OaMSIJI2RsEZ
GVYBlPsQCO4FYqTtqaRjFrYn2L6Cndj5I9g2L6Ci7Dkj2DYvoKLsOSPYCi+l F2HLHsJsX0ou
wcIvoLsXGMUtbC5IibFppsHTiAQYouxqKStYDGuOn6UlddROEX0EESY6celV zMSpRFVFAxz+
JpXGoIXaPSi4+VBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9 KLsOVBtHpRdh
yoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsO VBtHpRdhyoNo
9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtH pRdhyoNo9KLs
OVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdhyoNo9KLsOVBtHpRdh yoNo9KLsOVBt
HpRdhyo+ZvHQ2a5dT4Cbbu5HmkbcYcv9/wCXGNm7/WLjZu+TZ9ot/dy//kX0 kv73/pX9f1o/
HxPxmL/qmLcxiPo33Nu0jv8AIFx5PrHt8n/lj5QOn9E07f1/X9ffm9z6vjG6 IA4Oc818xP4z
3KfwnPt4Yk2tDFqAjtST8nkguoPZWzj9M1vOrdWMVSvqQR6Lc3PjGwaWExaV pUUktswkyZrl
y8fblRHFvGDkN9ozgNGDQpaGig0aXinwxonibT1s9bsxdQL5u1d7JjzIpIXw VIIJjldfbORg
81nTxEoNuI+UXxZ4Y0XxNYrZ63Zi5gXzNqeYyY8yJ4XwVIPMcrr14zkYODSp V5Q1Wg+Q2EGF
wBipTurjStoLTGFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQ AUAFABQAUAFA
BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQB8y+Oxs1y7mGF23d yPOKlcYcv9/5
cY2bv9YuNm75Nn2i397L/wDkX0kv73/pX9f1o/FxekzFH7pi3MYj6N9zbtI7 /IFx5PrHt8n/
AJY+UDp/RUTUb/1/X9eucHzSsz6xhH7sHOa+Zkveue3T+EVl9CRSkrlx0ViG yjHllgSDvfgd
PvGqvpYdzK8YeLfDfhRLf/hINcsNNFw4jhF1MqNIcqpKgnJALqWPRQcnA5op YectIq6IlI1d
Mu7e/wBOgvrSeG4t54xLFNC4dJEIyGVhwQQQQe9TNNOzGncxfE/jTQtA1uHS tUuZ7eaWFrgP
9ineJYlIDyPIqlERSy7mYgKGUsQCDWsYXV0DkjdE3P3eDjFS4voLmQjT4UFi qkgHn/P+cioc
Zv4Q50K0rA8KD+OKGpP4Rppj42LKCaG9B+hm+JtesdDtknvmlIeQRRxQQvNL IxBOEjjBdzhW
OFBICsTwpI1jC6JcrFqxvUurGG6jWRUlQSKssTRuqnkbkcBlPqCAQevQ1Di0 xqSauSvMqhck
DOQB6/T170csugnJIa0+APu5OOc8VE24LVN+hSaZHLfwR3kVo08H2iVGkjh3 gPIqkBioPUDc
uT23D1GaaaV7N+gJpi3l6ltCHkEhy6J+7iZyCzBQdq5OMkZPQDJJABII6uwr roSiVv7oz6E4
xSle9ojuDTBVUkgZ4APU/QfSrUXcXMh8bbkDccjPFS9HYL9hw6UDCgAoAKAC gAoAKACgAoAK
ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgD5l8djy9 du5gNm27uR5r
DbjDl/v/AC4xs3f6xcbN3ybPtFv72X/8i+kl/e/9K/r+tH4uL+MxR+6YtzGI +jfc27SO/wAg
XHk+se3yf+WPlA6f0VU+X+v6/r786XxH1lD/AKsc5r5qW57cNhW6/lSKRFY/ 6g/77/8AoRoG
ZHjjwza+J9OFjdXl/aRq5k32coRt/lsqtkg8ozLIp/heONv4aunXcZWSIlF3 NpFAAGT+JrKT
TdhpHFeNTr8HxM0rUdK8N3eowRaZdWpmW5giiWaaWApv3NvCgQMWZUYgMMKx yB002uWzMpp8
xxfin4cXka6LZXNnqev2GnaLaabbiytdOkEckW8SSMl+GCbwYseWWY7PmzhK 3jUX4+f6EcrI
db8GatJrdxe2fhbxC0yWGjIl6+pW8V3cPDMRcFpI51P2hreQxebkZAlVWCt8 9KpBxs3rd/18
uwnGV9DR07wlc2l03/CReAf+Ep05Vlg02xAtJRp0YvLpk2pcOixq0ElsoCZI EIVguxRUyqxa
tB2/4ZdvO5aiz0rwJZ6hp3gfR9O1a7+16hbWMMN1ceY0nnSqgDNublskE5PJ zXHVkpSbjtc2
inY4v4y+H4dX8X6DdN8OP+EiFpKZLq6MNiwaEwzoIf38isSJHjbGNvfOenRS nyxd2YyTJ9d0
Bhrmh63p3g+CaL+xbjSJtMk8iLyY5GheNJsEr5KCORWCb8b/AJVYE0nNezlH rdAou1zl9D8H
3Mkfg3+3/h3c3keneGZdM1BHe0dZpU8oxRSAS4lTMMhUEMoaZCQp3FeytWg3 V5X8Uk1p01+7
dEyjIt6XoWsyWGkXfi7wXquu3SaLa2YUXVs11p11GZRNMsjzKY2l3RESRuXP ljdtKjPPVqwT
laSim/v/AOGHGMrF/wAS+CNOS+8N3tz8O7LXLWx0h9Jk0xBBcNFkwtFh7koJ EjEco3EhsyZC
nc2JhV5U0p8v9eRSgy/8WdOvtS0jQrn/AIQt9W1a1vbS8E1q1u/2Ly54ZJQk kzRN86oyggDO
Pm2isqTvKUYvl+/X7r3Gk7EPijRzqPiSPVtb+Hs3iWzn063jt9OlWzmfTZg8 rS7lmlCKWDxL
ujZs+TgnCqTdKorWi+V/df7u36lNN7GXd+Drt9a8Lt4j8Ky+JfsPhuSw1O8W WGRL2ceS6JJ5
rq0y7opSN6ld8qtxyy7OpFuXJpd/cjKUXe53vwsTV4vhzokOv291BqsVnHFd rdSrJIZVUKzF
lZg24gtnJOCM4ORXHWactDaGx0A6VBYUAFABQAUAFABQAUAFABQAUAFABQAU AFABQAUAFABQ
AUAFABQAUAFABQAUAFABQAUAFABQAUAfM3j0FNfvJ8BNt5cjzSNuMOX+/wDL jGzd/rFxs3fJ
s+02/vZf/wAi+kl/e/8ASv6/rR+Ji/jMQfumLcxiPkN9zbtI7/IFx5PrHt8n /lj5QOn9FVPl
X9f1/Xzil8R9ZQ/6sc5r5qW57cNhW6/lSKRFY/6g/wC+/wD6EaBkeoXkFmoe 5nihRnSNWkcL
lmIVVGe5YgAdyQKqELjTRNCwkiDgjB7g5H51nOMlILopa3qGnabbefqN5b2k ZbYr3EoRWbGc
ZJ64B98AmtFFsmTXUsBgrKuBjHB9x2/L+vTFTJS6EqUWKAnlBxhEAGOcAD+V Z2ctymluhXVc
AMD061cl2CLY5G67ee/TrRuhu41X3PyMZ46kZ9McexqtSWl1HRBWhBDE55zj HNS/d3GuyGSF
Q5RgQBg9fWnytq4nJdR6xqUyRg9TWbV42mrlJq2hma1rOi6XqNlYalqtlZXF 2/l2kVzcpG9w
xIG1MnLHLLwOckVvGm3G7Vxc6RbsLq1vrOC7s7iCe3nRZoZYmDq6sMgqw4II PUcEHis+Wadl
0BSi9SVirHGCcDk84z/nvUNSnqmh3RFf3VrawCS6uYoY2dIgzuFDOzbFUEkD cWYKB6ke1XGX
W47xJll2rgBchQcE4PPtQ029yW0AlbPVcE4BAz/L/PNEU27MFKNtyWN9yA/U UpyUXZj32HDp
TTuAUwCgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgD
5m8eApr95OAE23lyPNI27cOX+/8ALjGzd/rFxs3fJs+02/vZf/uFJL+9/wCl f1/Wj8TF/GYv
+qctzGI+jfc27SO/yBceT6x7fJ/5Y+UDp+9VPlX9f1/XzzpfEfWMP+rHOa+b lue5DYVuv5Ui
kRWP+oP++/8A6EaBnJfF3wLZ+ONPgtrhbFJbd2kjmubCO5IJjbZgP0AlELkd HEQRsqxFbUqv
LojCUXzXOr0+2gs7GGztIIoLeFBHFDEgVI0AwFUDgAAAAVzVJvmNorTU4/x5 vg8Stc3V7DZ2
xt4kikuLpraOX5pPMjE6jMTEmB8Dl/KA5AbHTBqxhVvc47UY9W0/UYNGs7nW mEXhWOQW1g8o
H2hf3cbbCAyDcqfdAOfvgLvrVtNfMwipXNvxvJ4rbSrC2Md9DcrpTSyX9os7 s95hV8vZbsAC
cEhm3KPTilCML69zSU5pWRFe3er3F74PurlfEdtE1ox1f7Pb3I2t5e0BlVeG LlwWADAENkYU
huMbP8CI1J3LXxIj16GK20zTzq4ig01/Lv42upZJZxtURsIWX5iBne4YZ5A5 OVTjDd9y5VJn
NWSeMNQ1GGe5XxPHHNe6aJ1zcxAI0TG5+Ubdqh8AsAAOAMDFdC9mlpbZ9vkY SlU/q56J8Irz
WLnwHZLrqXY1CLfHObyJkc4Y7eoG75dvPfvzXJiYQVR8ux10G/Zrm3OW+MTX d34ogtotT8Q2
UcNssubPTNRubdyzMDg2MsbB/k5EhYAbCgU7yd6Cio30+9L80E4tnd+Aob23 8DaPBqSXSXsd
lClwt3cCeZZAgDB5AAHbOcsAATk4rir253bY0ppqKTOR+J0FpJ4ouYpR4rsU udPigvL3TNLj
vbe6jLSBIHRopmJXMzHCBQH+Y/MorqpP3en9fcZTT6GPreiEXXhHXPEeka5p yRaE9neW3hue
8VLS4Jt3WJY7RywT5JhuXKnYgZjiOtKE7OajbVre1+vfTsEIu2pZ+IMxm+IO jSXy+M7Cxl0m
Zr+20mK8lXzfNiaGNzahwrj9+S0bKxwoLFGAaMG+WErKN7rt599BqLuaHxWE Gl6LoTWkfiVr
m0vLXyhpzX04MCzw+cJvK3CT90G4kzu+bHJNZUKfMteX8AaaK3jNk1H4haNJ JP4xh0yfRbmW
6TT4L6KOQhoniR9i5ikwJjhSkpKqhyGCNtTilF2tv1t/X6dSJJ3MzS7/AFnV dO0W98Sp4wS4
m0a0+yrp9rc28g1IGQXPnRqqxrz5OPtCiLqRlS9W4RTai1v5bfn92vzIV76n bfA5pZfg74Yu
bm5u7m4uNMt7maa6uHmkeSRA7ku5JPzMeM4AwAAAAOLEQTm15nVB6HVr0rNK ysWwpgFABQAU
AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAH zN48BTX7ycAJ
tvLkeaRt24cv9/5cY2bv9YuNm75Nn2m397L/APcKSX97/wBK/r+tH4mL+Mxf 9U5bmMR9G+5t
2kd/kC48n1j2+T/yx8oHT96qfKv6/r+vnnS+I+sYf9WOc183Lc9yGwrdfypF Iisf9Qf99/8A
0I0DC42BiWAJ6EH8v8/jU2d/dC6I728gsrOa7u5ore3hQyyzTOFRFAJYsx6A AZJ6Yqox5noh
XJhGrgM2foDRfW6BpMoXPh3QrjUhqM+j2Mt4HWQXD26NIGGAG3EZyAoGevA9 BVc72EoJGiUG
Op9Khq7vcqyE8tc+nt2oab6iSS6C7BjvSS8x2QeWuOnHpTs+4WXYCg468UnG 6tcBBGm7OCTj
HNUrpWuFhyjAxkmlbSwCOiswY9R0NUm0rBYCgznnPrSBAqAAYJAHTmiw7g0a kY5H407isJ5S
YAOSOKLk8qMrxL4V8NeIhENf0HTNVEIYRC+tI5gm7G7G8HGcDP0HpVRnKOzF 7NGuFAGOazau
WlYWmAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAF
AHzN48BTX7ycAJtvLkeaRt24cv8Af+XGNm7/AFi42bvk2fabf3sv/wBwpJf3 v/Sv6/rR+Ji/
jMX/AFTluYxH0b7m3aR3+QLjyfWPb5P/ACx8oHT96qfKv6/r+vnnS+I+sYf9 WOc183Lc9yGw
rdfypFIisf8AUH/ff/0I0DON+NXhPUPFmm2kGmz+RPbzicM19c26kopkjBEJ GczJCCTyELlS
rhTXThK0acpKW3y/Xyv/AMMQ1qO8XWyXt3pXgi38yS1Ma3OpGeRpT9kiICxS OxYkyuAp35Ek
aXHORU0LRvJ/1/X52EkztIs+WM9a5ad+VXLjsOqxhQAUAFABQAUAFABQAUAF ABQAUAFABQAU
AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAf
M3jwFNfvJwAm28uR5pG3bhy/3/lxjZu/1i42bvk2fabf3sv/ANwpJf3v/Sv6 /rR+Ji/jMT/V
OX5jWP8Ai+4V28/e+QLjyfWPb5P/ACx8oHT+iony6/1/X9ecUviPpWLxE2Qv 2XPPXeOcnH86
8GdFJn0cKK5OY0pdRtElET3VusvGYzIM/wA6wnFpXRzqpBfHJL5jrOVhEdpU rvfB9fmNNR0u
x2lJ3g1YmHz/ADYIz7YrJR1u9ymn0IUsrVb+S9S2jW5kRI3mVAHdFLFVYjkg F3IB4BYkda0b
uK0iZWZW24AUdzQkrCi3d82yG+ewnCHaAaelrlQ95y7KwqyknnA4z9KWguZN XSY5JCVBI6+1
GnQG+yY4OScDr70gUk3YUNzg4zS5kHMr2I3kIkVflyQTjP8Anj/EU7p7FMkX OOaBC0ARySFZ
QnHIJ5P+eP8AEUAEjuFbaAWHQEdf8/59KAHxksgJGDQAx5GEwXA2YyT/AJ/z /QAehJUZ69+M
UALQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQ AUAFABQAUAFA
BQAUAfM3jwFNfvJwAm28uR5pG3bhy/3/AJcY2bv9YuNm75Nn2m397L/9wpJf 3v8A0r+v60fi
Yv4zDYeUzMcxiPo33Nm33/dhceT6x7fJ/wCWPlA6f0TT5f6/r+vvil8R7yDx ndxk/NkHj/J/
/XXj1PiPqY/wiglxqkKLaT3+mo2MS2htHa4J6MVIkyeQSMLxxnNZza5UeLjK XNTTjFt+h5p8
apfiHefGH4b+B4PGcOm6ZrRvneG1iuoJN9tbKT50kFzHJIu5mICtGBld4kwM aRUeW59Tl9Kh
DCzlKGqt26v0NDx18TvH/gbxjrfgm0vPDd5DovgQ+I7e8urK6d3lgdY5EkL3 JZlYJIQxYsPM
UkvtJkiFGMldkYfA0qkIzaavK3/DaGNd/Hf4nyTqbP8A4RGGI/DxPHGJ9LuX JcKA9vkXK4Bb
JD44BAIYgsa+rQOl5ZRS1Uvjt0/y38jq9G+LXi7xn8Q/DXhnw5HoOhLqng+H xZNcanby323z
ZFRYFVJIQMZYl8tnj5VxzLpQWxxVMFRVOaak2nbp/wAEwvHHiP4kal8WfglJ Z+ItK0ubXNLv
Zr20t0lnsXuBaLI5kWO4CzR5IEeG+U87pAwwlSideFw+GjRrc8ZXTVtu/odJ +0L4u1vSr/4e
anomp6Xe+H9X8SadZqIHuld/NLkTCeCdUeMrjEbo6MeW3DABGlGW5xZfhKUo yUua6V/6ViH4
7fFrxh4a+IOqeFvDVvocB0nwdc+LJ7jUreW4+0eXIUWBVSWPy/usS5LfeGF4 OSNKL1NcFhKN
RXnf4kunW/kzmPEPx0+I02syyaJB4asrB/h+vjqGG8sJ7iRflG62aRJ0DcnP mBRgHG04ydY0
IcptQwGHlTUpPVytuvv2Pevhh4hPi74eaF4oazNp/aunwX4t9+/yvNjD7d2B uxuxnAzXHVgk
7I8nEUYwm0mcb8TL/wCJJ+Pnh3w54Q8V6BpOmXugajeSwanoj3u6aC4s0Dlk uIW+7c4UAgDD
7t5dPLzSsrGTMb4lfEzx/ceO49B+E+jWutWEei2mtyapBa21/FPHdSXCxbfM 1CzCri1Zg6mU
MH/g2guxFnx942+MONEt/CvhPT4dSk0mC+1jS1W11O50+aXIEbrJf2SrGGjk VZVaUSFJBiPy
wZADPs/FfxS8UeKfhyfDnjTwhZWviDwXPrV0DoNxdW01wj2OZY908EqxkXR2 K20qN28OzL5Y
B1vxx1xJvgyL3w5rKrBr13pmlw6tp1wN8dtf3kFsbi3lXgOI5y8bjKhgrEMM ggFH40eKvidp
/im30j4c6TYakI7Vbm9Rba3vbmIyO6xl4Zr+z8qM+W+xw0u8rIMR+WDIAVrD xVqmot8GfFTa
rbXDeJ4msb+KxMyafOs+mSXpnijlAfcr2SCMyDKxzSqy7myoB61EAIxjGPag B1ABQAUAFABQ
AUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQB8zePAU1+
8nACbby5HmkbduHL/f8AlxjZu/1i42bvk2fabf3sv/3Ckl/e/wDSv6/rR+Ji /jMXAjcHLRhD
jcPk2bSO/wAgXHlese3yf+WPlA6ftUuo/wBf1/X3qik5H0WugXjKCZYCCcnk 8j/P8q8OpVbe
h9DGo+TlOjVAU5xz1x0NYN3MOXzOS1n4cfD3XtSn1bXPA3hnUr6aQia7vdNg lkfHyjczLk4A
AHXgAdOjU2lY6o4qrGPLGTt6lzWPh94D1vT7Cz1fwX4fv7XT4/Jsre606GSO 0QADbGrKQgAR
RgY+6PSmpySsRTr1qbvCbXo2R6T8MfhxpZuzpngHwxZG8ge1ufs2lQR+fC+N 8b7VG5GwMqeD
gZ6ChVJdy6mMxE7KVSX3sS9+GXw7vNKsdMu/A3hu4sbDzPslrNpkDxW+9tz+ WpXC7mAJxjJ5
OaHUZNPE1oNvnevm+hpeJ/CXhjxJYx2XiPQNM1i1jkEsdvqNrHPGjgEblVwQ DhiMjnBNDqSZ
EatSLlKMmr+ZT8WfD3wL4o1GO/8AEng/QdXu44xCk9/p8M7qmSdoZ1JAyzHH uaFUZVGvUotu
Enr5ia78PPA2t6bp+n6z4S0TUbXTo/JsoLywhlS1TCjbGGUhBhVGBj7o9KFU aDD16tC/JJ6+
ZYufBHg641fUNVn8LaNLf6lbtaX129lE0t3CVVTHK5XLoVRAVJIIUDsKFUkK FacUkmzQ8OaL
pGgaPDpOhaZZ6ZYQ7vKtbOFYok3MWOFUADLEk+pJPeod3uRKTk7sp+NfCHhX xjpkem+LvDek
6/ZRyidLXVbSO5iWQAqHCyAgNhmGR2Y+tAiDxx4C8EeNDanxh4Q0LxAbXd9m Oq2EVz5G7G7Z
vU7c7VzjGdo9KAM7XfhJ8LNbayOtfDbwjqX2G0jsLQXmjW0v2a3TOyKPch2R jJwgwoycAZNA
Gx4z8H+FfF+lx6Z4t8OaVr9lHKJ0tdWtI7qNZACA4WQEBsMwyOzEd6AF8eeG bDxZ4R1Dw/qE
tzBFdxFFubVgk1rIMGOeFiCEmjdUkR8ZV0Vh0oAzvGPwy+HXi7VI9S8W+BPD PiC9ihW3S61b
Sre5kSMEkIGdCQuWY7Rxknjk0AX9U8L2Go+MNK8RXc91JLpcNxHbWzODAsku wGfaRkTKivGr
ggqk8y9HNAG0owMD1zQAtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFAB
QAUAFABQAUAFABQAUAFABQB8zePAU1+8nACbby5HmkbduHL/AH/lxjZu/wBY uNm75Nn2m397
L/8AcKSX97/0r+v60fiYv4zFX9zIXGYxHzu+5t2+/wAgXb5XrHt8n/lj5Q/s /aqny6/1/X9e
cUX7x9XwjMY5z+NfOy3Pci9B5/wqSjhviBrWqWninwb4f0uf7MdW1eUXU7Iu RbQwzTskbuCn
mO6RIUAaQwtO6KPLaSIA7lPu45445oAWgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAK
ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoA+b/
ABPpmp6j4ovRpWn3N3Ml3Pn7PEzMoMwA+YAY+baeJFwVVvkI+023tYWtToYC gq0lFvm3duvn
/Wvyfl4nDznVkktrGBeW1zp9yY7mCW0kjRZAJVMTIpCsjHiPaAIgwJMeBHx5 Xk50+5Vo1aSd
J3f3rf8Ar+t8p0JUp2PpxNZshlfPGRngqc9a8WrCUfU9ulT5o3NEE1m276Ct Y5zxHoela3ca
Tc3dzcW15o+p/wBo2c9uwDRyASRMCGBVleGWWNsgkLISpVgrLSi2RKVjbju7 VI1RXUBRgADg
Cq5GJTHfbbb/AJ6D8qORhzIT7dBu/wBYMfSn7Nk1KsYJDTfRcfOpo9mKvWVN qwv26LH+sTP0
NHIaOcedRuAvot5+dQvaj2ehEa0ZcrXW44Xtv/z0H5UuRjU01cPttt/z0H5U ezY+ZB9ttv8A
noPyo9mw5kH222/56D8qPZsOZB9tt/8AnoPyp+zkPmQfbbb/AJ6j8qTgxcyD 7bb/APPUflRy
MakmzA0Lx/4W1jxtr/hPTtVWfVtA+z/2nbmGRPs/np5kXzsArZUE/KTjoeeK lRbKbSN5b632
jMmD9CP51XIyOcX7bbf89B+VHIw5kH222/56D8qORhzIPttt/wA9B+VHIw5k H222/wCeg/Kj
kYcyD7bbf89B+VHIw5kH222/56D8qORhzIPttt/z0H5UcjDmQfbbb/noPyo5 GHMg+223/PQf
lRyMOZB9ttv+eg/KjkYcyD7bbf8APQflRyMOZB9ttv8AnoPyo5GHMg+223/P QflRyMOZB9tt
v+eg/KjkYcyD7bbf89B+VHIw5kH222/56D8qORhzIPttt/z0H5UcjDmQfbbb /noPyo5GHMg+
223/AD0H5UcjDmQfbbb/AJ6D8qORhzIPttt/z0H5UcjDmQfbbb/noPyo5GHM g+223/PQflRy
MOZB9ttv+eg/KjkYcyD7bbf89B+VHIw5kH222/56D8qORhzIPttt/wA9B+VH Iw5kH222/wCe
g/KjkYcyD7bbf89B+VHIw5kH222/56D8qORhzIPttt/z0H5UcjDmQfbbb/no Pyo5GHMg+223
/PQflRyMOZHkvhSG2m8T6ydRMbaet7IJFkKmMSNIwUsp6455II+ZemM153E9 OtWw+Flh02vf
2v3XY3hUpurUT8vyM3xWNH1XUotEimuBeNbzXWli3ZckAQHAztIBkeHavmxc zh12mMSR+dkW
cOhip06ui0snp0fdnfisGpv2p3IAB2rjAJHynjqOntX1kmpzc3sYqHLGx3Pb r6Vw31scTMWU
nz5P99v5muymk0YSYmTW3KjK7DJo5UGoZNLlQnBT3PL/AIp/HPw38P8AxLrG ja/ouumTTNLi
1dpraOB0ngknjt18vMobd5khBDBeEJzyu61TvserQy36xT5v66+XkaXxW+LG kfDzQtP1LxFp
d5Eby3kuWtPtdjHcQbApaMpLcJ5rguF/c+ZkjHddyVO70Hgstddya6W/rYh8 QfGTQdO1vwrp
1po2u6uPFNm95pE+n28bJcYj8wIwZ1eMkFPmdQg3gsygMVfsh4XJ5RU29o2/ H5Hb+HNS/tfw
/Y6qLO8svtcCT/Zb6Lyp4Nyg7JEydjjOGXPBBHao5UeXJWdked/Gb4qzfDf4 jaXbapHBf6Pq
Oj3dxbaZZRINTur2G4tUEVu0syJMzR3TEQhQ5MXylywQZydhK9j0LwzqF3qe h299e6NfaPPK
CWsb5oGmjwSAWMMkkfIAYbXPBGcHIDi00LU4X4w/Grw58OfE9vomsWnmzz2y XSt/bWkWfyM7
r9y8u4ZDyh5ClT0DZDADaGkzuvC2rQ674Y03W7ZdkF/axXca+bFLhXQMPniZ 424P3kZlPUMR
gm1awanF/Gf4xeHfhrqlnYa1aXEst1C06Ob2wsosA4wsl7cQLI3UlYy5UFdw Xem7OVgVztPC
2qHWfDOnaw+n3+mG9tYrr7FqMPlXFvvUN5cqc7ZFzhl7EGh2sEb3PHfgUT/w 2f8AHjJI/wCR
f4z0/wBCf/Cpja5cr2PcckHqT9TmtlFGauGTT5UGoZNHKg1DJo5UGoZNHKg1 DJo5UGoZNHKg
1DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGo ZNHKg1DJo5UG
oZNHKg1DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGoZNHKg1D Jo5UGoZNHKg1
DJo5UGoZNHKg1DJo5UGoZNHKg1DJo5UGp4h4jvzp/iXUZC0kcctzPFJNA6Ry wqJvN3xyupVG
Volb5m2nbl12BpYdsHT58vop9Ob8zkrTcKsmuv6FWxu9HtEtES71CxhtLSa1 W1MG4QK2WYGS
SZAxQ2+1XkjBUby4Hk3Hl/I4rhjnxDqRk7f8C3Y+go5wlSVOdr/8H1PW16jk kdiSDxkY6Eiv
oFGUIKEjZzU4XidxXG/iucFrrUyXikaWRljdhvbkD3NddKSRhOIggm/55Sfl WzqLuQk+geRL
/wA8pPype0XcdmHkS/8APKT8qOddyVBptnG/Er4Yad418T+Hdc1C/wBcs5tC n8+KKxmVIrn9
7DLsmVlO9N9tEcAjkZ64IqNbl1R6OFzGrhqbpwSafe/n5+ZT+J/wf0jxr4gl 1ubUdc0i/uNJ
m0S7m00w/wCk2cjbmjZZY3VeS2GQK3znk8Yca9tC8JmdXDJqMU7tPW/TbZru Zp+Bdmj+D5Lb
xh4ut5fCNnJZaTIgsmMSOnlsWDW5DHy9icjGEU43ZYv6x10NlnVdKaUI+/a+ j6dtT1AQTY/1
Un/fNZyqq2h48Ys4L4l/Di08XeJJdS1KfXgF0efR7dLTyUFnJNLDN9phJjMg uFe3tykhcrG0
akKCGYedWxE1sdEKUXudV4R07UrDQYbLUtS1TVbyIt5t7qEMQllJYkZ8iOOP gEAbUXgDPOSe
ihUcqactzKpG0mo7GmbeUj/UueMcrn+YrbmXcizDyJf+eUn5U1JW3CzOT8Xe Btb1fxM2s6Z8
QfF/h3faxWslnpq2Ulu3lvIwk2XNvLtc+aQSpGQqZHyik3F9Q17GB4n8OfY7 Dwz4X8Pad410
vQ/CtzZSQ/8ACP3TQm5EEeIbOTzObi2ZSqyEsAGKZbAlaOnGPLe56dDB0501 OU0m+l/6/r5H
OfA3R/E2nftOfGDxB4i8PXOlW+qxaI9pK5DQ3HlW0sUhjkAwVBUnkKwV03Kh OKwhJXOPEcsN
ot+mp7UCDyOmcV0e1itGzCF5K9mvJ7hS9tHuPlYU/ax7hysKPax7hysKPbR7 hysKXto9w5WF
P2se4crCj2se4crCj20e4crCl7aPcOVhR7aPcTjIKPbR7hyy7BR7aPcpQdg4 /wA5pqqhNMCf
f9DR7WPViSYZ9x+Rpe2j3CzDPuPyNHto9wswz7j8jR7aPcLMM+4/I0e2j3Cz DPuPyNHto9ws
wz7j8jR7aPcLMM+4/I0e2j3CzDPuPyNHto9wswz7j8jR7aPcLMM+4/I0e2j3 CzDPuPyNHto9
wswz7j8jR7aPcLMM+4/I0e2j3CzDPuPyNHto9wswz7j8jR7aPcLMM+4/I0e2 j3CzDknqoGOp
J6/lT9tDuFmMjkjluZLaKRGmjRXkjU5ZAd2CR2B2nH+6aSqpvQLMnEE3eGT8 qrnXcLM8A8fb
l1y8lyUAvLn94cgDbIXHzHaBjYW/1i427vk2C5t/Qy+N8BRt/e/9K/r+tH5+ I+MxP9SSwzEs
Z3D+AJt9/kC48od49vk/8svJH9n7zk49P6/r+t7kaUZSu2e8p253e+c55Hfv /nrXkV2paH0t
OPJT0O5HT8q89qxxp3RFZf6g/wC+/wD6EaV2DRKOnQVSbtqKyFz7CmFkGfYU BZBn2FAWQZ9h
QFkGfYUBZAOuaTbHZCMgJJyQfrS5U9xO/QXaCMEAj0prTRB6igADoKLsLIQ9 egpphZBn2FAW
RG4YucZ7VXQluN9mZt9D5+txws8yptkkIjlZMkeWBnBGfvHjpWaumaKUt4nA X/j3S7X43D4Y
sNai1B9NGpRXbyn7M+55VW3Vy+4zFbedwuPuRSN0Vsc1WUuZtFJN/FuM8H/E jwp4itvDgt/F
ENnqHiLTINW07R73UhHfS28qGQOIgxLYVXztzgqeeOc25j5UQeJPiG+leObj wzB4c8X6s9lY
Qanf3mnNFJHZ28skyKWjM4mkYfZ5CVijkc4ACliAaTm+ocqNW28beFrjWNL0 e38Z6dPqeq2g
vtPso9XVpr2AqzCWFA5MiEI53D5cKxz8povMOVHLfD74z+Ete+G8fjnWPGHh /Q9Hu7oQ2csv
iRX2h41ljiuC2wQ3WwsXgBfbtPztSbnfQOVHcXGuaXCLky+IY4RbXMdncCW/ I8m4k8vy4Ww3
EjCaLahAZvMXA5GVzTDlRxvwS+Lmg/EeySC01B7HXUsbS9udFk1IPPHHNaW9 z5iKGDNCBdRx
+YVUb1bGeK0UpJByoNM+LulS6rKmr2PiHQtJF9fadDrepXUC2txPZtP56jbO 0kahbW4ffKiJ
iJssCVBfNIOVHSX3jTwrZXmn2d542023uNRupLCxil1dVa7uI5BFJFEN+XdX OwouWDEKQD1z
cp3DlQmh+OPCWteI7zw/o3jjS9R1exL/AGvTbTWUkubfYwR98YfK7WO0k4AJ HPTKvMOVEFn8
Q/A134RuvFVr8RNHn0G0lEFxq0esxm1hkO3CvJ5m1W/eR8E/xqBnPBeew0ok 8Hjbwpca7pui
2/jXTpNT1S2F5p1imrhp72BlZllhQNmRCEY7hxhWPQUXmHumV8PfiVoHiXQv CrXHiC103XvE
WkW+sW2gyauGuWSSLzCEUsGcKFkywX+A5AOQGpSTsOyPS9KsoprFJJJrtmOf m+1SjPJ5xu4r
og5MykkWDpttn/WXn/gVL/8AFVbjfUVkH9m23/PS8/8AAqX/AOKo5Asg/s22 /wCel5/4FS//
ABVHIFkH9m23/PS8/wDAqX/4qjkCyD+zbb/npef+BUv/AMVRyBZB/Ztt/wA9 Lz/wKl/+Ko5A
sg/s22/56Xn/AIFS/wDxVHIFkH9m23/PS8/8Cpf/AIqjkCyD+zbb/npef+BU v/xVHIFkH9m2
3/PS8/8AAqX/AOKo5Asg/s22/wCel5/4FS//ABVHIFkH9m23/PS8/wDAqX/4 qjkCyD+zbb/n
pef+BUv/AMVRyBZB/Ztt/wA9Lz/wKl/+Ko5Asg/s22/56Xn/AIFS/wDxVHIF kH9m23/PS8/8
Cpf/AIqjkCyD+zbb/npef+BUv/xVHIFkH9nWwIIku/8AwKl/+Ko5AsjhPhcC PjN47DO7ssVi
geRyzbVNwAMn8fzqbtSsOyPRgK1uKyPmjx6Cmv3k+Am28uR5pG3GHL/f+XGN m7/WLjZu+TZ9
ot/fy9v6hSS/vf8ApX9f1o/FxTtMxGHlEsC0YjP3vubNvv8AuwCvk+se3ySf 3Pk/8S/oqO0d
f6/r+vPKnBSqczbPQh8ZvhDux/wtbwRkkDJ121/T5+f89c14VaV2fT0qvucp 7ejbow3TODXK
1qYNWegyyH7g/wC+/wD6EaAuTAcUCCgAoAKACgAoAO9ArAaBgOlABQAUAFAC Ec9TTHcziCfE
if8AXKX/ANpVDYmeQ/FL4favrHjrxL4o0y5sIL82GmnRJbgsBDqFnPey/vWC ErDIt0sUgU7m
ieZON3PPJu9rFxWhyHw8+EPjHQPCGleDZ5tDm057vQdU1DUY7uUSwT6fBYx+ RFB5REqudOX9
60iFROf3bbAHTk+w7HY6/ofj61+LOo+JPC1r4bnsdU0bT9LM+p3c6y2UtvNd OZEt0iYTqBdA
iPzoiTGV3DO6nFu2qCxxmgfAmbw94qsrTTmbUPD0V3pV3Hcah4gv4WiNlb20 MaGwiKW1y5+w
xuJ3ZNrSDMbiJVeuZ9gsa/8AwrzxlYfCPwH4Z068gvG0PSIdPvrC31690WK5 nWCJEuEvLWMz
lVMcgEJULJ529trRClfXYLGH4Q+E3j/w54K0rwhb/wDCOXVq1/4f1LUtQa/m iktZbCOwjlih
hEDCZXGn7ldnjP73GwbcuNvsFjqv2dPAXiT4daMmgaidJu7KWxsXnvIbhzLD eQWFpZGFImi/
eREWvmCQsp+cAx8bjEmwsZV/8EUn+F/jXTnla41/WTrxsmudUu5bCzkvpbox OkLsYoZBFcBW
ZIw3Mo3EO28vK+wWLvxL+G2s3w1/TPCNtolto/iTwxF4WuEkmkt/7It4vtKi W3iSJlnGy8OI
90IHkgbsOdtJu2wWOVT4beMfHvgrVPCusxWPh3R49d8Tz2uoyTyy3c32qTUr aMvbNHGI4wt+
ZQwlfcqJgDzCUd/ILG94n8BeO/EOu3PjC90XQrbxG32G30+Cz8S3MKWJt1vs XQuPsZEjk37o
YJIGiKqS28MVC1FyoreK/hh8RNW1zRW1HX4PEKWt7o13NqdzrF3pyxLayW8s 0Z0uFGt52keK
aQNI2VNwFHyxISX8g5UWPgn8MfGPgnVNAhjubLS9Ps9MsoNZaz1SW6XW7mCw jtUzbzwKtrtM
YIlikBdYAJIzuBiHq9RXtoj6F0EL/ZMQXp82OMcZPbtW8NiblwDiqsAUWAKL AFFgCiwBRYAo
sAUWAKLAFFgCiwBRYAosAUWAKLAFFgCiwCN1FFgPOfhf/wAlp8ff7ll/6FcV nb3gPRxWoHzN
48BTX7ycAJtvLkeaRt24cv8Af+XGNm7/AFi42bvk2fabf3sv/wBwpJf3v/Sv 6/rR+Ji/jMVf
3MvmDMflHIY/Lt2+/wAgXHldjHt8n/lj5X/Ev2q3Uf6/r+vvwp35z3GD4FfB PaD/AMKg8BH/
ALl+0P8A7Tr52cnfU+ghex6AAFUAdBipKMLUvEtno+v6Jo17DcK2tXNxa2lw qgxmdEebyjzu
DNFHO4ONuIWBYMUVwDeQ5QHg/SgBaACgAoAKACgAoAKACgAoAKACgAoAz2/5 GOP/AK4y/wA4
qhgXTGpYNjBxjI60RirDuDRqRjAxjbjtj6U+VBcRoVII5Ge+eafKguKI1B4G PoaOVBcTyVyC
MjGe9HKguKYxxj5cdMdqOVBcQQpsK7RtxjHt6UuVBcVogeT1xjI4P5/hRyoL hJGHHPXrn37U
+VBcVkyfQ9aOVBcasKjPcEYIPPFHKguK0YJBzgg5BH+fejlQXE8ldoA+XAwC vb6VLhqIkUAD
A4FUlYApgFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACN1FAHnPwv/wCS 0+Pv9yy/9CuK
y+0B6OOlagfMvj/93rt7OAqst3c/vGITH7wv9/gjHl7vvrjZv+TZ9ot/oMGu TAUV/i/M8TMF
KNSfL0sYmfJcuxMSRH/WH5Cu3B/2NuBCD1j2+VwIvJzp++IhFJK/9f1/XfGl Gpz7H1lDkxgn
IPoTyK+XmnfQ+ghtqKen5UIZw/j7RNR17xV4OjtbRTY6frEuq394XSMokcE6 RxI4Pmq7yzRk
7QFaKO4jdtsnlysDuIc+Uuc5x3oAdQAUAFABQAUAFABQAUAFABQAUAFJsDOb /kY4/wDrjN/O
KoTuBojpVpWAKYBQAUrAFFgCiwBTAKACgApWAKLAFFgCmAUAFABQAUAFABQA UAFABQAUAFAB
QAUAFABQAUAFABQAjdRQB5z8L/8AktPj7/csv/QrisvtAejjpWoHjPh/QdD1 rXtcOs6Np+oi
K7l8sXlukuzLvnG4HHQdPQV04jGTpZfRa/vf+lHNXpxnVqX8jXPgHwMASPBu gBu7DT4gTzzz
t755rkea1J6f1+Z1Sw0YyuemqMAAdKSnJ7gw7flV3JRFZoDCScn5247cMaBk 4AAwKACgAoAK
ACgAoAKACgAoAKACgAoAKT2Azj/yMcf/AFxl/nFUR3A0R0rQAoAKACgAoAKA CgAoAKACgAoA
KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBG6igDzn4X/wDJ afH3+5Zf+hXF
ZfaA9HHStQPKfAX/ACHfEP8A1+Sf+hyVpjpc2X0U1/N/6UZ0YKriqsJbLl/I 6luh/wA9xXlw
ilI6eZyV2dbj613oyEP+FNARWP8AqD/vv/6EaAJqACgAoAKACgAoAKACgAoA KACgAoAKT2Az
j/yMcf8A1xl/nFUR3A0R0rQAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgBG6igDzn4X/APJafH3+5Zf+hXFZfaA9HHStQPKf AX/Id8Q/9fkn
/oclVjP+RfR/7e/9KJwn++1v+3fyOpbof89xXnR+I1j8KOtrtiQI3X8qaAis f9Qf99//AEI0
wJqACgAoAKACgAoAKACgAoAKACgAoAKT2Azj/wAjHH/1xl/nFUR3A0R0rQAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBG6i gDzn4X/8lp8f
f7ll/wChXFZfaA9HHStQPKfAX/Id8Q/9fkn/AKHJVYz/AJF9H/t7/wBKJwn+ +1v+3fyOpbof
89xXnR+I1j8KOtrtiQI3X8qaAisf9Qf99/8A0I0wJqACgAoAKACgAoAKACgA oAKACgAoAKT2
Azj/AMjHH/1xl/nFUR3A0R0rQAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKA
CgAoAKACgAoAKACgAoAKACgBG6igDzn4X/8AJafH3+5Zf+hXFZfaA9HHStQP KfAX/Id8Q/8A
X5J/6HJVYz/kX0f+3v8A0onCf77W/wC3fyOpbof89xXnR+I1j8KOtrtiQI3X 8qaAisf9Qf8A
ff8A9CNMCagAoAKACgAoAKACgAoAKACgAoAKACk9gM4/8jHH/wBcZf5xVEdw NEdK0AKACgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoARuooA85+
F/8AyWnx9/uWX/oVxWX2gPRx0rUDynwF/wAh3xD/ANfkn/oclVjP+RfR/wC3 v/SicJ/vtb/t
38jqW6H/AD3FedH4jWPwo62u2JAjdfypoCKx/wBQf99//QjTAmoAKACgAoAK ACgAoAKACgAo
AKACgApPYDOP/Ixx/wDXGX+cVRHcDRHStACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgA
oAKACgAoAKACgAoAKACgAoAKACgAoAKAEbqKAPOfhf8A8lp8ff7ll/6FcVl9 oD0cdK1A8p8B
f8h3xD/1+Sf+hyVWM/5F9H/t7/0onCf77W/7d/I6luh/z3FedH4jWPwo62u2 JAjdfypoCKx/
1B/33/8AQjTAmoAKACgAoAKACgAoAKACgAoAKACgApPYDOP/ACMcf/XGX+cV RHcDRHStACgA
oAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKA CgAoAKAEbqKA
POfhf/yWnx9/uWX/AKFcVl9oD0cdK1A8p8Bf8h3xD/1+Sf8AoclVjP8AkX0f +3v/AEonCf77
W/7d/I6luh/z3FedH4jWPwo62u2JAjdfypoCKx/1B/33/wDQjTAmoAKACgAo AKACgAoAKACg
AoAKACgApPYDOP8AyMcf/XGX+cVRHcDRHStACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKAC
gAoAKACgAoAKACgAoAKACgAoAKACgAoAKAEbqKAPOfhf/wAlp8ff7ll/6FcV l9oD0cdK1A8p
8Bf8h3xD/wBfkn/oclVjP+RfR/7e/wDSicJ/vtb/ALd/I6luh/z3FedH4jWP wo62u2JAjdfy
poCKx/1B/wB9/wD0I0wJqACgAoAKACgAoAKACgAoAKACgAoAKT2Azj/yMcf/ AFxl/nFUR3A0
R0rQAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKA
CgBG6igDzn4X/wDJafH3+5Zf+hXFZfaA9HHStQPKfAX/ACHfEP8A1+Sf+hyV WM/5F9H/ALe/
9KJwn++1v+3fyOpbof8APcV50fiNY/Cjra7YkCN1/KmgIrH/AFB/33/9CNMC agAoAKACgAoA
KACgAoAKACgAoAKACk9gM4/8jHH/ANcZf5xVEdwNEdK0AKACgAoAKACgAoAK ACgAoAKACgAo
AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoARuooA85+F/wDyWnx9 /uWX/oVxWX2g
PRx0rUDynwF/yHfEP/X5J/6HJVYz/kX0f+3v/SicJ/vtb/t38jqW6H/PcV50 fiNY/Cjra7Yk
CN1/KmgIrH/UH/ff/wBCNMCagAoAKACgAoAKACgAoAKACgAoAKACk9gM4/8A Ixx/9cZf5xVE
dwNEdK0AKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAK
ACgAoARuooA85+F//JafH3+5Zf8AoVxWX2gPRx0rUDynwF/yHfEP/X5J/wCh yVWM/wCRfR/7
e/8ASicJ/vtb/t38jqW6H/PcV50fiNY/Cjra7YkCN1/KmgIrH/UH/ff/ANCN MCagAoAKACgA
oAKACgAoAKACgAoAKACk9gM4/wDIxx/9cZf5xVEdwNEdK0AKACgAoAKACgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoARuooA85+F//ACWn x9/uWX/oVxWX
2gPRx0rUDynwF/yHfEP/AF+Sf+hyVWM/5F9H/t7/ANKJwn++1v8At38jqW6H /PcV50fiNY/C
jra7YkCN1/KmgIrH/UH/AH3/APQjTAmoAKACgAoAKACgAoAKACgAoAKACgAp PYDOP/Ixx/8A
XGX+cVRHcDRHStACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgAoAKAC
gAoAKACgAoAKAEbqKAPOfhf/AMlp8ff7ll/6FcVl9oD0cdK1A8p8Bf8AId8Q /wDX5J/6HJVY
z/kX0f8At7/0onCf77W/7d/I6luh/wA9xXnR+I1j8KOtrtiQI3X8qaAisf8A UH/ff/0I0wJq
ACgAoAKACgAoAKACgAoAKACgAoAKT2Azj/yMcf8A1xl/nFUR3A0R0rQAoAKA CgAoAKACgAoA
KACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBG6igDz n4X/APJafH3+
5Zf+hXFZfaA9HHStQPKfAX/Id8Q/9fkn/oclVjP+RfR/7e/9KJwn++1v+3fy Opbof89xXnR+
I1j8KOtrtiQI3X8qaAisf9Qf99//AEI0wJqACgAoAKACgAoAKACgAoAKACgA oAKT2Azj/wAj
HH/1xl/nFUR3A0R0rQAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACg AoAKACgAoAKA
CgAoAKACgAoAKACgBG6igDzn4X/8lp8ff7ll/wChXFZfaA9HHStQPKfAX/Id 8Q/9fkn/AKHJ
VYz/AJF9H/t7/wBKJwn++1v+3fyOpbof89xXnR+I1j8KOtrtiQI3X8qaAisf 9Qf99/8A0I0w
JqACgAoAKACgAoAKACgAoAKACgAoAKT2Azj/AMjHH/1xl/nFUR3A0R0rQAoA KACgAoAKACgA
oAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBG6ig Dzn4X/8AJafH
3+5Zf+hXFZfaA9HHStQPKfAX/Id8Q/8AX5J/6HJVYz/kX0f+3v8A0onCf77W /wC3fyOpbof8
9xXnR+I1j8KOtrtiQI3X8qaAisf9Qf8Aff8A9CNMCagAoAKACgAoAKACgAoA KACgAoAKACk9
gM4/8jHH/wBcZf5xVEdwNEdK0AKACgAoAKACgAoAKACgAoAKACgAoAKACgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoARuooA85+F/8AyWnx9/uWX/oVxWX2gPRx0rUD ynwF/wAh3xD/
ANfkn/oclVjP+RfR/wC3v/SicJ/vtb/t38jqW6H/AD3FedH4jWPwo62u2JAj dfypoCKx/wBQ
f99//QjTAmoAKACgAoAKACgAoAKACgAoAKACgApPYDNJH/CRJyM+VKOv/XKo juBog8f/AFq0
AM0AGaADNABmgAzQAZoAM0AGaADNADGlxIVOBgAnnp17fh+hoAerZUGgBjy4 Yj5eoHJxQA8H
j1oAM0AGaAGSSlZQvy5IJGT/AJ4/xFADweOlADXkw+AMn07mgAhffErjBBGQ VOQfcH0oAdmg
AzQAZoAM0AMeTEgUYznGM8n6UAPVsjPH4UAGaADNABmgAzQA15MPgDJ9O5oA SJ/MRWBUgjIK
nI/OgDzz4YDHxp8e5yPksuox/FcVl9oD0cdK1A8p8Bf8h3xD/wBfkn/oclVj P+RfR/7e/wDS
icJ/vtb/ALd/I6luh/z3FedH4jWPwo62u2JAjdfypoCKx/1B/wB9/wD0I0wJ qACgAoAKACgA
oAKACgAoAKACgAoAKT2AyL21trvXo47u3inQQykLIoYDmL1qI7gTjQtEx/yB 7D/wHT/CtAD+
wtE/6A9h/wCA6f4UAH9haJ/0B7D/AMB0/wAKAD+wtE/6A9h/4Dp/hQAf2Fon /QHsP/AdP8KA
D+wtE/6A9h/4Dp/hQAf2Fon/AEB7D/wHT/CgDw/V/iE9p8d9Y8JwSeArkWPi DT9Ig8Jrp/8A
xObu2uILN5bxHE5/dxfappGxblfLtXBZeXUAn8O/tAfCLVdX8L2Enh640uTx JFa3FgNUtba2
keK5Ijt3WBpPOlV5g8WYo3C+WZG2wtHK4Br+F/idoGuf8IwIfhHr9ofEN1Pa 25vItMQW5h2+
Z52Lk7HXM2YBmcfZrjMY8tqAL/xB/tPQ/HdvaWNloDweIzaaRoUF1aqY7K+W O9ubu4mCqrvG
YIYtqB8u8QTMIYygAx/FPjW5+HU8dh478HaTrqx6JrGvXGreHbVIAttYpbuS bWeQlSxuDGAs
snKI3CyMIQDHm+Ken6H4F+KPjbWfB2ozWmiam8WkaY+jMs/krpNtdIJRFE72 0cjPJJ5k4BiE
gWQIy7AAaXxA8YTR3ljdaLp+n+FvDs9r5/8AbXiHwNqF2pfzJFlW4jVoDYRx KiOZbghHWbcC
qxsWANbTviX4LupNeEnguexTSo9Unilvo7KKPUY9OuDb3bxP522NUk2Lm4MO RIGGVDlQCHQ/
i58MNa0L+3NL0QXOk22lS6zq2oxW0EkOkW8bXCFpSjnz8yWdyim288MYiwOx kdgCb4UeJdG+
KGqW3iXwgmkp4csob7TtW09haXEi6hm0ltyJrdpYnCwtOT5cxA85Vb5lYIAU Ifiv4QtNEvNQ
1jwFcW0drqGsxyfZ4baZV0/TbryLnUc7lPlKWjBjAMxZiEjlUbyAdb421jRP D/jDw14cPgS5
1SXXpJIo7m1t7VLe3MYVmEjTSISdjPII4xJIUhmYKQjUAeefBX4raVqnwh8J P4i8FahfeNdR
0vTJf7NW1sUn1d7m2lmFzCwkFuiOLS8k2yPEwELAopaNXAOl0D4q/C3WtQ06 DT7CBodQv4bG
3uZbWKJGEtjb3kc5V2DpEReWsOSufOuIo8AuuQCD4l+KDJ+y9L8WvAGmaDab dAPiSK313SDc
edALVrgQsIpk8tyNg3hnUYbhsg0AGrfEPwX4I8a+Hvh548m8P3nijU/J3z6f YRWUI+0XDw22
23lnkmfe67P3XnbSpeTykYGgCDwh8XvBOvW+j3D/AA71fSbbU4rC5FxqFrZb ba3vnEdjNIIp
nbbPLujUKGZGQmVYkKuQDO0L4naF401/4fxaH4ZuNFj1i/hubqw1KztHkutN uNM1C4tpQYnl
RVaWzzt3rKDD8yhWG8APD3x2+G2sS21xY+GoJdIi0/Vr/WdSjezuV0hbCO2k fzDbPIk4aO7i
Obd5SpZVK58wRgGhJ8UfCOvfs4eNfiT4J0fR7i68O6ffSvbXAtrqKO6gtjOq NJayyRSKVaJj
5cpwH2llcMqgGR4W+K+j22pf2bqFp4f+ISXd1b2Wm6z4C0tPs1xdyw3kpsyr XEqq6LZBmkMo
VRdRGRYkDSEA14Pi/wCCbwabFo/w61jVb3VZbc6ZYW1rYpLfWs9vc3EF4hln REieOyuSFkZJ
RsAaNdy5ALI+LPw6uIRdaN4Vv9dsZLTzLW703S0b7bdGw/tFLKKFmExne0xK uYxHyE3+YdlA
E118S/AFnB4Jk1vw5b6Wvi+bydPW4uNMlOWdEhwsM7mZZWlj2tbiYKHDSGNc kAFH9mLxpa+O
fCeh2Gs+EbiTVI/Del6nqOuXNtZQ293Nc2sUu6ONX80h3eUBxEsW+GZA25CK AN/4URrF8YvH
caRLEoissIq7QObjoMD/AOvWX2gPSh0rUDynwF/yHfEP/X5J/wChyVWM/wCR fR/7e/8ASicJ
/vtb/t38jqW6H/PcV50fiNY/Cjra7YkCN1/KmgIrH/UH/ff/ANCNMCagAoAK ACgAoAKACgAo
AKACgAoAKAChoDhvGvjJtC8VG3g8MeItTeOJlaSz02eSLLBDw6oVP3R0PByK wcnHYCkfipdZ
/wCSfeLj/wBwq5/+N1SnJq47IP8Ahal1/wBE+8Xf+Cq5/wDjdPmkFkH/AAtS 6/6J94u/8FVz
/wDG6OaQWQf8LUuv+ifeLv8AwVXP/wAbo5pBZB/wtS6/6J94u/8ABVc//G6O aQWQf8LUuv8A
on3i7/wVXP8A8bo5pBZB/wALUuv+ifeLv/BVc/8AxujmkFkZukeNrXTNU1XU LH4a+L4bjVbt
b69b+zrsiaYQxQBsFMD93BEuBgfLnGSSTmkFkc/aN4XshoH9m/DLx/pv9g2l vYWX9n/2nbbr
eD/UxT+Xj7SifNtWbzAPMk4+d8nNILIoWeleDLcwlfhx8TpjHqketMbq/wBa n8+8j8jy5Z/M
ZhPs+y2+0S71XyxgDJyc0gsjrvE3jW08QaBPo2rfDPxdPZzlWZV067jdXVg6 SI6oGSRXVXWR
SGVlVlIYAg5pBZHM3Np4KudAl0m6+Evja5jniuobm6ni1F7u7juYfJnWa4I8 2VWjWNcOxA8m
DbgwxbDmkFkbyeJ9IC68j/CrxRNF4gmM+qwXGlXMsV4xt47Yh0aMrtMUMaFQ NpC8gkkk5pBZ
Gf411HRvFuqR3eveAPiJPGIhbvYpLqkFlcR5JKTWqFYJkYFlbzEYMCFbK8Uc 0h2Rg+E9J8Oa
bZ6yNW+HnjfWLrVb++vWuZ7PUFNotxfPeBbZfmFoyuYSXgMbNJBHKTvVSDmk KyNDSLPwTptr
BbW/wl8bvCkdzDPFcx6lOuoJcPLJKt4JNwuwXuJ2An8zaZXK7Sxo5pBZG/4K 8V2/hbSn0/TP
A/xGnheQyl9UbU7+XJAGBJcb3C/KMKCACSQBk5OaQWRka03g/VWf7b8IvF7J JdzXkkUdpfxx
yGbaZ42VFAaCZkV5YCPKlcF3RnJYnNILIveNdc0nxZeaVca58OvH0x0u7jvr eKCPUbeFpo5I
5Y2liiCpNtkijZRIrAEcDk5OaQWRk/ZPBS6ba2UHwm8b2qWmn2Wl2k1pHqUF xa29oJVt1inQ
CWNlW4nUurBnWV1cspxRzSCyF8R2Pw7122vbfVfgRrFxFd6LD4ddP7EuEEdh E7SRwRBYx5Kq
7bgY9pDJGc5jTac0gsjpvFXjW18SeFtS8Oa38NfF93pmp2stjdwHTbpPNhkQ o6bljDDKsRkE
EZ4NHNILIoa/r2lax4osvEVz8O/H8Gp2mwLcWCajaeeqMXRJ1hCrcIrM5CSh 1G98DDtk5pBZ
GbYf8IbZWFnp1r8I/Fsdva2ulWcEYtb07YdNnaeyTJGf3cjlsnl8gOWBxRzS HZGF8NPDfg/w
z8PtA8Pan8MPF3iK40y0hglvtT0++m+1FLOW0KmOUPtgMdzchbbJij899qAk mjmkKyNfRLPw
Tpkc6r8JfG181zLPLcy6rFqV9JdCa3jtpYpnnDtLC0UMKmJyyEwxNt3IrA5p BZGha6no0XgX
VvB8/wAP/iRqGkarFNBeR6pLqt7K8csfluizTFpEUr2VhgkkYJJo5pBZGvrH ja11S/0m8vvh
r4vkn0m6N7YuNOu18mYwywFsBBu/dzyrg5HzZxkAg5pBZHAeIPDnha9k0ZNM +H/j3R7aw1YX
8qWEWoxTvEtpc28drDMrK9rBGbtnSKMrEoEiKg8xsnNIdkbw/wCEPW+F3a/C TxfYSC0FnGmn
Wl/awwAQ+QJYYogEinWH9ys6ASrGAgcKAKOaQrIo2+j+BIIdLji+FHj9f7Ou lvY2L6qWuJlu
2vEa5YnN1tuHeVRP5gVpHIxubJzSCyNDwdJ4X8L69Zaxo/wy+IEVxYaWuiWa znVLiK1swsK+
XFFJujTItoNzKoZimWJJJJzSCyOo+CT3t78QfF2s3OjanpsV5HZ+Wt/aSQFi DPuxvUZ+8Onr
TUb6sGenLyoJqxHlXgL/AJDviH/r8k/9DkqsZ/yL6P8A29/6UThP99rf9u/k dS3Q/wCe4rzo
/Eax+FHW12xIEbr+VNARWP8AqD/vv/6EaYE1ABQAUAFABQAUAFABQAUAFABQ AUAFACMoJzk1
DjcAVQFAz04ppWVguGB609AuGB60aBcMD1o0C4YHrRoFwwPWjQLhgetGgXDA 9aNAuGB60aBc
MD1o0C4YHrRoFwwPWjQLhgetGgXEZVPUk+2aNAuCqAMA0aBcXA9aNAuGB60a BcMD1o0C4YHr
RoFwwPWjQLhgetGgXDA9aNAuGB60aBcRlU9TkenajQLgihVCg8CjQLi4HrRo FwwPWjQLhget
GgXEZFLAknrmjQLigADgn86NAuGB60aBcCBnOcHGM0aBcQqM56HuR3pgOAAG B0oA8p8Bf8h3
xD/1+Sf+hyVWM/5F9H/t7/0onCf77W/7d/I6luh/z3FedH4jWPwo62u2JAjd fypoCKx/1B/3
3/8AQjTAmoAKACgAoAKACgAoAKACgAoAKACgAoAKAEbrUsBKACgAoAKACgAo AKACgAoAKACg
AoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAHL0poApgf/9k=
Content-ID: <part2.04060303.09040500@resnbl.com>
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAEMAagDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3Zrv/AImCWiJuPlmSRs/c GcD8Sc/kar2u
u6de3r2dvdRyTp1RWBPvkdRjoc454qTTYJUSW4uU23Nw5d1JB2Doq8ccDH4k nvUkNha29xJc
RQhJZMl3BOWyc8+vt6dBQTr0K9rrunXt69nb3Uck6dUVgT75HUY6HOOeK0ar Q2Frb3ElxFCE
lkyXcE5bJzz6+3p0FWaBq/UKKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABUMd3byyGNJkZhjgHrkZGPXjnipqzLLQNOsNRmv7eBVuJixk baOcnPpx+HXv
k80Cd+hp1n22rxXN35K29wsbFljnYKEkK9QvOfXqADg4zWhXI2NgF1WN7qNl FvE6TGe0OwIA
VwJSQuwg7toB75xS6ik2rWOuori/C8FvPbWEtjpyxyRMRLfRyRsGXB+QkNuP BX5SMDj0FT6T
pl9aa3FdNp88Zk3i6dfs6Rlm5yAnzsuc/eJIyOOuGTzvex1tFc5pOmQx6lNK +gy2rGUyQys0
W2MYAwoVyVyc5wMHvVCx0q8ttS+0S6VOwlSVbtVFsschbngAhmXOfvnPI45O FfQfM+x2VFcZ
ZaHLZtZzRaK8csSwEkPHlWBIk/j6kYOe4AHbFdnTHGTe6CiuU03RpF1+K/bT ri3cNI8jTtAw
+YH7rR/Oxyf48jGe+K6ujpcIu4UVyOlaZe2mtR3T6fOnmCQXTL9nSMs3OQE+ dlzn75JGRx1x
NpWlmxubOWHQ3tnM03nSKYgRGxJUHD5I5XgZxt6dKETzvsdRTBKjIzqwZVJB 288jqOO/tXNa
ZDp11qjWFuLGa10+U3EflFGId84BA6FTu/8AHfQ1Y0zTk02+kEGgwxkSSN9r QRLlCSQq4+bP
IGCAODz0yD5jbtriK7t0nhJMbjKkqVP5HkfjTlkVpHQBspjOVIHPoeh/Cuc0 3TntLiwuF0eW
G4Z5PtMu6MsFOcBiHJIzjAGcY7VY0uOW31W8K6HNaW9yVO4eSF3AHJYK5PP0 PvSBSfVG9RXL
aZpbWU1rJBoj2krSzCWVfKBVGJK5w/I5XgZxt6dKqaZDZPrthbDT4Re2oc3c oljcu4XG9grF
s7ifmcAjOO5poXO+x2lFFFBoFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTQ6M7IGUsuNwB5GfWnVj2H h+Kw1OW9FxNJ
v3YieRikfptBOBgZH48YHFAnfoaj3ESTxwM372QEquCcgYyfbqPzFSVm6aft k02pHlZf3cHt
Ep6/8COT9NvpWlQCdwooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
QAUUUUAFFebeHLfRtV8W6pdP4ggvr+O8Itd32SSR0EKYZD5e4BSWxtIXK8g/ NmfS/EVwuq6V
bXfiN5J5Z7i3u7aRYF8vbv2FtqAqxwCATzzgYzVuH5XOiWHabSe3qehUV5/4 d8UTz3WkifXo
L77c1zCYS0I5jJ2MNoB3EYz25GB3Muk61d3l5pLSeJ4xfzTEX2jGOPMQ2tlA qoZFKkL8zNjA
JzyBS5GJ0JK9+n/B/wAju6K4jw5PFp2vX9ld+IbmW8e/kC2EghLSAqCJGVIw 4GOc5C8Vb0HU
bf8A4SjxDYx6lBe3CMkipmFZSQpDA7FBO07Vy2SOATSa0v5XFKi035HWUVwe keIr24u9JVtY
Fze3e7+0dN8lF+wAISTgDem1gq/vC27d9KZ4b8UTXF5pC3GvwXovnuYTETEM eWx2MNoB3EYz
25GB3NODHKhJX/rv/kd/RQRkEZx71xPh2+Fvq1xYXHiq+1LU1nuF/syYQMUU OxV32RB0Urtw
WIT5gB1UVBh0udtRXmvhLxFrl5r9pBqPiDRZHmDi6006jG1xC4UkqkIt43Uq wwQ7vhQep5qT
QfEWo6p4yhii8S2V/YStMzW1nPFK8aAHYXj8lXhA4BLPJ82F75DsB6NRXFeG r1INZm0678WX
2oagLi4Q6dMsDNGoclXcRxB0XbtwSQvzADqorXjZpvHlykv3bXTomtwT3kkk 8w/+Q4x/+uiw
Pr5f52N6ivOtA8RahqfjOGOLxJY6hYStMzWtpPFK0aAHZvj8lJIQOASzud2F 75HUaAzJqWvW
iD/RYL0GLjhS8aSOB/wJif8AgVJB3XY3aKxNMiDeI9YuZoIluQYoldfmPlbc qNxAI5JO3oD3
Oa26ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKAIPtP+x+tH2n/Y/Wq9Fa8qM+Zlj7T/sf rR9p/wBj9ar0
yYStA4gdElKnYzoWUHsSARke2RRyoLst/af9j9aPtP8AsfrXF2es63c3VnaN LYJcJ5zaj/or
4jVGAG3951bPBOcjntgt0bxNqF7rdpbzxI1lfQyTWs32cQlkXGGA852IIPdU 7fSnyJmzpTSe
ux232n/Y/Wj7T/sfrXI6Nf8AiO/vboTnTPstpdtbuyxurzADlh8xCYyODuzz 93rXTUciImnB
2bLH2n/Y/Wj7T/sfrXnmgapq02vz6NbTxw2tpcTu76isk8tygmIAhYyDKqPl YtnaSnBBFdxK
XETmMZcKdoxnnt3H8xS5Va5LbTaLf2n/AGP1o+0/7H61w+l6h4zl1O3j1DTv LtGbEr/YIUwP
94XzkfgjfSuwo5ULmZY+0/7H61AywPex3jQ/6RGjRq4Yj5WIJHvyo6+lcdYa 94gm8TW1vdW1
rHpV08ohmVFPmBVLLskSZ92QM5aOMYB74FdhQorcG3sWPtP+x+tQWqwWcbJB DsV5Gkb5iSWY
kkknnqf6UlFHKg5mOC2y3jXgtIhdMgjaYKN5QEkKWxnGSTj3qb7T/sfrVeij lQczLH2n/Y/W
j7T/ALH61Xoo5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP+x+tV6KO VBzMsfaf9j9a
PtP+x+tV6KOVBzMsfaf9j9aPtP8AsfrVeijlQczLH2n/AGP1o+0/7H61Xoo5 UHMyx9p/2P1o
+0/7H61Xoo5UHMyx9p/2P1o+0/7H61Xoo5UHMyx9p/2P1o+0/wCx+tV6KOVB zMsfaf8AY/Wj
7T/sfrVeijlQczLH2n/Y/Wj7T/sfrVeijlQczLH2n/Y/Wj7T/sfrVeijlQcz LH2n/Y/Wj7T/
ALH61Xoo5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP+x+tV6KOVBzM sfaf9j9aPtP+
x+tV6KOVBzMsfaf9j9aPtP8AsfrVeijlQczLH2n/AGP1oqvRRyoOZk32d/Va Ps7+q1ZoqOdl
cqK32d/VaPs7+q1Zoo52HKihHpkMNzNcxQQJPPt82VUAaTAwNxxk4HTNVIvD GkwTLNFpWnxy
q/mK6W6Bg/8AeBx196w9B8Tapeazc6JbwpqTWNzKt7eXU4t2hTzSsYVVixIS obBGB8hBINdt
T53ZMrVNq5l2uhWNjPLPaWNpbzTHMskUSoznOfmIGTz61b+zv6rWXpU11b6t rNvd6jPdwwGO
WMzJGDGGUkqNiLkDHGcn3NZPh/xzd65qFtC+gXkFrdoXguPIucKNu5fNLwIi 5HGVd+SAMjmk
ptiavqzYj8LaPFNbzR6RpqS2xJgdbZA0RJySpx8uSSTj1rS+zv6rWDpXiTVL qeL+0tItrO2l
aeNJIb4zNviJBypjXCnaxByT0yBnhtl4k1i7u9MDaHbx2epAyQT/AG8lkj27 hvTy+HIx8oLD
73zcDJzMTijoPs7+q0ht5MHG0nsCcVkaDqPiDU/P/tHT9OtYFlmiE1revI4Z HKj5GhA7dc/h
zgVvDut6xKLGDU7NDDOJI4rxrhTNKyZ+Z4lQKoYAkEMe2VGcAcnsHKkT2vhf TtGmmvrDTNMt
p9jF5be1SN5B1KkgZxkfy9Ob5nCsVYAEcEGROP8Ax6r13/x5z/8AXNv5UW3+ qb/ro/8A6Eai
N46JlNJ7lD7Sv+z/AN/U/wDiqPtK/wCz/wB/U/8AiqbqXiK0025FsYp7iUAN IsCg+WD0LZI6
+gyfatK2uYby2jubeQSQyDcrDuKr2jva5CcW7Iz/ALSv+z/39T/4qj7Sv+z/ AN/U/wDiqUeJ
dBaC7nGt6aYbNglzILtNsDE4Ac5wpzxzSxeI9DmRni1nTpFWEzsVukIEYAJc 8/dAZeenI9af
OyuVDftK/wCz/wB/U/8AiqPtK/7P/f1P/iqz7/xlawGyfTUi1SC7XMctrcoV Y+dHFhT90nMn
qBlccdRLp/ir7XNeLdaLqGmwWeRc3V7LbCKIhQ2CUmY/dYHOMe9HNLcOVFv7 Sv8As/8Af1P/
AIqj7Sv+z/39T/4qo7nxHamysp9Kkt9Sa/n8i1MM4MbkZLHeoYAKFYng9MdT Vu91rStOure1
vtTs7W4uTiCKedUeU5xhQTluSBx60c0hWRB9pX/Z/wC/qf8AxVH2lf8AZ/7+ p/8AFU+XxBos
EdzJLrGnxpa4+0M9ygEOSVG85+XJBHPcEVHP4k0yKzsruGc3ltezpBBNZqZo yzNtBLrlVGe5
I9Bk8Uc0h8qF+0r/ALP/AH9T/wCKo+0r/s/9/U/+KrVqje61pWnXVva32p2d rcXJxBFPOqPK
c4woJy3JA49aOZhyog+0r/s/9/U/+Ko+0r/s/wDf1P8A4qny+INFgjuZJdY0 +NLXH2hnuUAh
ySo3nPy5II57giql94ptraxjv7K0udV09o3me7094pIo0XqxJcbu/CbjweKO dhyosfaV/wBn
/v6n/wAVR9pX/Z/7+p/8VT9K1VtQkvIZYBBPbS7Socsrow3I4JA6g8jHBBHO Mm1LfWkJnEt1
BGbeMSzBpAPLQ5wzei/K3J44PpRzSBRT2KX2lf8AZ/7+p/8AFUfaV/2f+/qf /FU6fxBpUM93
bLqFpLeWsRmmtEuYxKiAA5ILDaORycDkc1BceJ9Ni1+z0WK7tJr+eQpJbrcL 5sKiNn3FBk44
A7feFHNIOVEv2lf9n/v6n/xVH2lf9n/v6n/xVatYx8S2YktIzDchrm7ktACg +RkYqWbnhSQA
DzncvHNHMw5VuSfaV/2f+/qf/FUfaV/2f+/qf/FVFH4p0opNJdXEdjFEzAyX c0cYbDOuR82Q
P3bEEgZH0OI9Z8X6Lo+jDUW1KwcTQtLaIbtF+1YHSM5+bOR0z1FHNIOVFn7S v+z/AN/U/wDi
qPtK/wCz/wB/U/8Aiql/t3SBeT2bapYi7t4/NngNwm+JODuZc5Ucjk+oqyt7 aNK0S3UJkWTy
igkGQ+3dtx67fmx1xzRzSDlRR+0r/s/9/U/+Ko+0r/s/9/U/+KrVoo5mHKjK +0r/ALP/AH9T
/wCKo+0r/s/9/U/+KrVoo5mHKjK+0r/s/wDf1P8A4qj7Sv8As/8Af1P/AIqt Ws7VTtUNhSVR
iNyg4+ZB3pObDlRH9pX/AGf+/qf/ABVVrzV7axFv5wY/aLiO2jCMrHe7BRnB 4HOSfb8Kx4vE
FlNq8+kx3Vo2oQRrLLbhE3qrdCRj6fTK5+8M8vfyvL41Jc5xqGlgADAA8x+g 7UlUYciPVfs7
+q0fZ39VqzRVc7FyorfZ39Vo+zv6rVmijnYcqK32d/VaPs7+q1Zoo52HKit9 nf1WirNFHOw5
UFFFFSUFFFRzyNFBJIkLzMqkiOMgM59BuIGfqQKAMiDwlo9tf2t9FFdLc23m eXJ9tnJPmNvc
Nl/nBbBw2eg9BVy10XT7LV7/AFW3t9l7qAjFzLvY+ZsGF4JwMA9gKzIPFsdz /Zoi0nUS9+0g
SM+SGjEZwxceZwB7Z9OpALtO8YafqOuPpCxvFdqH+UzwSZ2HDAiORip/3gPz p8r2NHTnq7Et
j4U0zTtRN/bvqRuD94zapcyq/BA3K8hVsAnGQcdqfaeGNNsLwXNqb6MqWKwj UbjyFznIEO/y
wOeAFwO2MVV07xbHqV9JaR6PqqNBP9nuHeJCkD9QGKuc9uV3YyM4zXRE4BOM +1DViZRlF2kY
tr4U0qze0eEX2bSR5Yd+oXDgM/3iQzkNnnhsjk+prP0vwYNN8RjUvtatbQh1 tLZfOPkq3G0G
SZ1VcfwoiDhewAq7ofiC71iWRZfD2oWMaSSx+dNLbsmUcrj5JC2eP7uOvJ4J 2pZBDC8rdEUs
eQOnuePzpbak26GYnhrSk1R9REMpuGZnG65lKRuwwzpGW2IxBOWUA8nnk5Zb eFtLtDYeSL0f
YGdrcNqE7gFuu7Lnf3+9nGeKxdJ+Jekavqlvp8EO2Wdtqn+0rCTn/djuGY/g pNdkThSQCSB0
HejbUN2RXf8Ax5z/APXNv5UW3+qb/ro//oRrBtPFdrq0QiWzvLf7RFMInnCb WePIdPlY8j8v
Q5BFb1t/qm/66P8A+hGhqzKlFx0Zy2veErq91WS+sJoQbjBmSZmUKwUKGXAO eABg46da6DSd
LTSdHi0+NzIEDZdx95mJZjj3JPFGoa1p+lyJHd3Gx3GQqozkD1O0HA9zxV2O RJY1kjdXRwGV
lOQQehBqOWN2YQhBTbjucHp3hXXrCO3kSPTwLF4jZ6e968sQCq6sPOaLzFH7 zKqfMCkYBAOB
pSeHdQudM1RpYtPjv7y9gvRGHaSImIRYR22KSCYyM7eAQcHpXWVUutTtbKUx TO/meS8+yOJn
YomAxAUEk/MOByc8Crv1/rv+htu7nIL4Q1afVBqdy9lFNNdfaJoIpndI8SW5 wjFBuysBJJA+
ZvxrVv8Aw9d3NnqyRtbNLcX8V7AkuSjeWIiFfjjJjIyM4yDg9K2tM1K21fTo b+zMrW067o2l
heIkeu1wGAPbjkc9Kkgu4LmW4jhfc9vJ5UowRtbaGxz14YHj1p6r3e3/AAP8 kLzOTXTNT0u5
h1q6gR5ZNSee6tbMvOIY3iEWU+VWcgqjH5R1bjjl3jDw3rOvTyR2syG0ktvL RX1Ca2EMmTli
kS4mB+UYc4G3gHJz2NFLt5B38zidR0u50LRbK6igiuLiz1Sa88hIZpFl80yg Z8qJ3DASZ3bD
yMd80lvYa9d+DbFbews0vHvvtskN1cyRBF+0GYAHyi2SMDDKpGeQCMV0V94g s9Oe9WdZc2kU
UrBVB3+YzKiLzyxZcY45IqTSdXTVY582txaXFvJ5c9tcbPMjOARnYzKQQQQQ SOfUEUL/AIIP
+v6+YunXF/cXN/8Aa4EhgjmEduADucBFLMSeo3FgOBwPeue8YeG9Z16eSO1m Q2klt5aK+oTW
whkycsUiXEwPyjDnA28A5Oexpk0qwQvK4cqgLEIhdvwUAkn2FHZh5HGajpdz oWi2V1FBFcXF
nqk155CQzSLL5plAz5UTuGAkzu2HkY75qvbaf4nvPD+nxpp9gLWeWe5vLO5v JYGffKzom7yW
OzDZZSqseAcDcp7S5v4rS5soJFctdymKMqBgEIz8+2FNWqEBhaIs9zq2qalN bPbrJ5dtGrqV
3CMNuYBgDjc7AEgZCgjgil1rQ5NTv7WaJ41iI8m8V8/vIdwfaB0Jyu3n+F2+ ht/29pm62X7U
M3NxJawjY3zSoWDL04wUYZPH5ip7PUbbUPM+zM7iNmRmMTKuVZkIBIAOGU9P Y9CMvzC1lZ/1
/X6HGX/g7V7yOaxU6fHaJNeXMFwsjiWV51cbJE2YAHmnLBmzsXgdtCx0DVrX VbVGTTxp9rf3
F4JklfzpfNEnDJswCDJjO45Azx0ro9RvotM025vpldoreNpXCAFiAMnGe9Wg cgGhMHqVP7Ng
OpjUPMuvPCbNv2qXysf9ct2zPvtz71gXnhu+kvtXubeW2PmhZrBJGYBJxsZt +B90tFGeMnlq
6qikByFt4Qnt9Z0u6LWzwWUcCkNncWSOdSwGMZJlB/P8aM/hHWoYdSisl0yQ alBLBJJNK6NA
DNNIpUBDuyJeRlcEZy2a72infW4HFL4Rvp7pbO7WxGlxXF3cCaJ286fz1cFH QrtAHmtltxzs
XgZ4t6N4avrO/s7u9ngkcI0tzsJwbj5wCvAyNsjLk8/KvHp1VFJMHqFFFFAB RRRQAVz/AIo1
nTtHhiOoXkVv5yssYc8sQyE4H+e3rXQVTvuPLP15/I/09e3bG5UwPGbTTvhx Y6umrW0wTUEk
MouDe3BcsepJLfNnJznOcnOc1ZW+tdR8VG5s50mhbUtLAdTxkSPmvUuntj8M fy9Pbp2x8nO+
KuJdCH/UXteP+2ij+np27Y2qhnc0UUVQgooooAKKKKACiiigAooooAKKKjnm W3gkmcOVRSxC
IXbA9FUEk+wGaA3M+10G0tdUvL9XlZ7kEeWxGyLPL7MAEbiATknkdqoWHg+D T7jT5IdU1App
6slvE3lbFjIAKECMZHA5Pze9WY/FekTR2LxyXTLfsy22LGf5yOv8HHrk44BP QVYttdsbu++x
IbmO4wxVbi0lhDheu0uoDYyOmar3kat1Fe/9dBNL0YaVc3kqX93Ol1M0zRTC Pajt1K7UB9By
T0rTrDtPGGh3t6LOC6lNx5nlMj2sqGNznCvuUbCcHAbGe2a3KTv1JmpKXvqz Me20AWuqteLq
eoNAZHmSxMirCjvnc3yqHbkscMzKCcgcDGxWNB4p0i51WPTY5p/tErOkRa0l WOUoCW2SFQjY
APQmth2CIzHOFGTgEn8h1pX0I6i0hGVIBIJHUdqxrTxRp97dR20Vvq6vIcAz aPdxIPq7xhR+
JFbJO1STnAGeBmgDmU8JRWEFs66rqEv2Hz5I1k8nDGQHcGxGDjk9Mda6G2/1 Tf8AXR//AEI1
lQ+JNK1WF4bS4dnkhkZA8Eke7bwwBZQNw7r1HpWrbf6pv+uj/wDoRpu99S5u V/e3OP8AEHh/
Vn1ue9sFa4jutpKrIqGJlULzuP3eM8c5J4710eh6bJpOhQWMkollQMWZSQMs xYgewzgewq3d
X9nZeX9ru4LfzDtTzZAm4+gz1qxWfIrt9znhTjGbktzyNPBepnS3t00W4hsx PE08RSyN5eAL
JuMhJaCbDOpDSKjHGTlgCdy38NnT30S8Xw7d35tLS4hUXIs/tNszOGT7rLGF ADKNh+UEDGM4
9AqC4vrSzDG5uoIAsbSsZZAuEXG5jnsMjJ6DNW9f68rG17s8+i8I3OoaJM9/ oe3UItHt7ezW
4eJniuI/MG5CrEKclSGBBwRyOQGa74PuLi+1Mw6GxjuL9Lqaa0W0L3cPkhTG RMCrFZPnKyDb
/EG3YrvtN1fTNZgafS9RtL6FG2NJazrKobrglSeeRV2nJ3dxLQ4XQfBdtulG o6bcNbmxS3g/
tDyGliy029QIvkTCyADaANpA7EVDqXh/V7zRH+3af9tnmliguESO2mla3hVg jIJz5WWkJf5s
4VzxuHHexTRTpvhkSRNxXcjAjIOCOO4II/Co7q7gsolkuH2I0iRA4JyzMFUc epIFJ6v1BaHn
Nlomp6HpH2m/tH+z2b2rlWaNmEUVxKx4j+UbI3RsAAcYA4wOs0C7t9W1nVtU sJknsJBDBFPE
waOVkDFmVhwR84XI7qR2raa7gS+js2fFxJG0qpg8qpUE56dWX86bfahbabbe fdSFELqi7UZ2
ZmOAAqgkkk9AKd7/AD/4b9BWRi6/os99qCNbRBob6L7HqB3AfuQ27J7njzE4 /wCeuegNctqH
hXU57m+Fvovl3zteNLqnmxH7bFIriKHO7fwWj4YBV8rg9K9MopJ2KucHp/h6 4h8VWt3L4fUX
UV/cTT6wzxMZoXSQIoO7zMAMi7SABt4yBmux+xz/ANpi7/tK68jZt+x7YvKz /ezs35/4Fj2q
xJLHCoaWRUUsFBY4GScAfUkgfjUNlqFtqCzG2kLeTK0MisjIyOvUEMAR2I9Q QRkEGj9BeZy1
7ouqDUNVnhtvNihYXWnosqqZZSY3dOT8vzRdTgfvD6GqY8HTz6tpq39il1Yp FB9q8xlZXcR3
G/cpPzDfIvBBBz7Gu+pk00VvC800iRRICzu7BVUDqST0FC0Vv6/r/JB/X9f1 1PMb/wAH3Zsr
i0k8NJqKm2mh03LwlLA+dKykB2GzKNFgoCRsAOABV0eErq71eaOXSfs8ssl3 9r1fzI2+1wSK
4jiyG8z5d0fBAVfK4PSu9mvILea2hlk2vcuY4hgncwUsR7cKTz6VPR/wfxC+ v9f1/Whx2i6L
qqapa3l/B5fnFr25UOp8u42tGFODz+7dRkcfu/pXY1X+32f7r/S4P30jRR/v B87jOVHqRtbI
68H0pYL21upJI7e5hmeM4dY5AxU5K8gdOVYfVSO1Nu4WJ6Khu7uCws5ru5fZ BChkkbBOFAyT
gc1MDkZpAFFFFABRRRQAUUUUAFU77jyz9efyP9PXt2xuW5VO+48s/Xn8j/T1 7dsblTAqdPbH
4Y/l6e3Ttj5Od8VcS6EP+ova8f8AbRR/T07dsbV6Lp7Y/DH8vT26dsfJzvir iXQh/wBRe14/
7aKP6enbtjaqGdzRRRVCCiiigAooooAKKKKACiqVnqSXl3fWwhliks5RG3mb cOCoYMuCeCD3
weDxV2gAooooAxLLw6tprFxem53REOLWER4Nv5hDSYbJzuYAjgY6c1k6T4Hl 0nVrG/jvbEy2
wdJJF0/bLcq2MtJJ5hLPkZ3dOT8tdjRTUmjT2s9ddzH0XR7rSrrUXlu7eaK8 uWuQsdsY2Vmw
OW3ndwAOg/pWrLLHBE8srrHGilndzgKByST2FPopXJcuZ3Z59o+mxadry6re vZrOm97ia10U
2c7q/SS5k8whkOc42j5hk7fLcL6A6LIjI6hlYYKkZBHpS0U3a1hzlBu8Vb5m LaeD/DNhdR3V
n4c0i3uIjujlhso0dD6ghcitk52naQDjgkZpaKRByFv4Vv7CCyZ9TtZEsTcy FUsmQyebkkZ8
w4wSeea6m2/1Tf8AXR//AEI0Xf8Ax5z/APXNv5UW3+qb/ro//oRobuypTctW cP4msdVTXp7h
Lea6t7hFWIxwmXYAAChA+6M5bJ4O7rXU6BaXdj4etra9bNwiHIBzsBJKrnvt BC/hWrRUKCTb
7mEKSjNyPI0XxA2lvHFPrZg8+L7ZfSwX5eQFZCdttvWWPDGMHyHKng4AytWN X0q6m0qxllk1
jUJzpd5bwzx215FmQspjWWEsXxtBGZM7toJJOK9UorS/X+trf8MbN6/1/Xqe eanB4htl1jzD
I+qzw26x3mn2Ugha1STLgKHLiUCSTKiQMwKlDuBxmTx6rFpNqE1LXdQVZJjH bpY6lZl2IQKp
lLPKmCWYGXdG24jjaCPVqKE/6/r+riPOZftVxqWkW14PEUEwuppZJ4ftnllB cN5cTeX+7G7j
LPwEHYEEYzDWJ5ZZbhNa+xzNFNc28drfs1s63MTFUaRmLkKX+aFVBAJA4GPX 6KS0af8AX9f1
3uHldxa68EuZtMGrC02yraS3Mc8lwluZLYuCHZZc8TFRuD4Hy4OK09ISW3/s J76+u723XU5F
je6srm3MLtCwQEXLtIwyWAYsRlwB0Fd9LLHBE8ssixxopZ3c4CgdST2FVIpt K8QaZvhls9Ss
Jf4kZZonwfbIOCPzFNPSwPY47x5Jq7agi6aL+GSC3823e2hu5hcSZJKEQusS 42jmUMDuwBwQ
VntL6HS4rm9l15oZ9TmF8LeW4aZYA8vlCNI/nVcmPJjAYrjJKiu+qrqGmWGr WptdSsra8tyQ
xiuYlkTI6HDAil0sHU4NprabwXpN1La6jfNDq2+2kezuLq4iRLk5JyrSKRGC Pmwe3Xiuo0h0
m8Ta5NB/qcW6P8pH70IS2ffa0YrXjFpYRW1pEILePAighXCDAGQqr7AHgdhT re1t7OMx20EU
EZdnKxIFBZjljgdySST3Jp9/67f5CsYOvwaj/aCJZSXflajF9kkaJmxbENnz QeiHYZBu7sEH
pXLah/bgub4Wn9vf2puvPtG7z/s/2fa/k+Tj91vz5ONnz/e3d69MooWhR5/Z wXE3i2xluotb
kv4dQuDO0vn/AGSOEpKIig/1P3dgyvzZJ3HJNdr5eo/2mJBdWv8AZ+zBg+zN 5u718zfjHts/
GrE00VvC800iRRICzu7BVUDqST0FPpdELqcJe2N3BqWoutjO0GmTG/tTFCWM pkZJHVPV8rMM
DP8ArB61BBpWqvqWm2Uz6nDZyJFJdm2kkiUuyXLSDcuNvzlMkEHO3npXoVFC 2t/X9bfcD11/
r+t/vPK9UtNQk0y7stQTxFcBbWaLTkgNywdxLKP3zJ975BFjzSQw6ZJNaAt9 Yu9Wmtoptbg1
GWS7S6lkaZbZLcq4hMR/1QYHycbPn+9u716JRR/wRnHaK+tXOqWs12t7DBdF r1o5NwEWFaMR
MDwuQYm2+oY9cmuxooptiCiiikAUUUUAFU77jyz9efyP9PXt2xuW5VO+48s/ Xn8j/T17dsbl
TAqdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xtXountj8Mfy9Pbp2x 8nO+KuJdCH/U
XteP+2ij+np27Y2qhnc0UUVQgooooAKKKKACiiigDG020nGv6vfzwSQrIyRQ 7pBiRFUZfapI
5JIBYbsDHQCtmiqOn6vZ6nNdQ2xnElq4SVJraSEgnoRvUbgccEZB9aF2AvUU UUAFFRpNFJGz
xurqpZSUO7BBwRx3BBGKyrbxTpV22niJrzOoM6W2+wnTcUyWzuQbeAT82M4O M0eQGzRRVHT9
Xs9TmuobYziS1cJKk1tJCQT0I3qNwOOCMg+tAF6iqOn6vZ6nNdQ2xnElq4SV JraSEgnoRvUb
gccEZB9avUAFFFFAEN3/AMec/wD1zb+VFt/qm/66P/6EaLv/AI85/wDrm38q Lb/VN/10f/0I
0uoHn/jCWePX5BqEata4X7EZM7fujdt/292ffGO1djoDX/8Awj1s2ohhdbCT vGWC5O3d33bd
ue+c1q0VKhZt33MYUuWblfc8jTxhrLaW5j8QW87GeJbnUBcW4s7YMsjfu5lh Yx5KopWaMkZx
k7g1asKrrGp+HTrusWV3DdWdzCVheC4tb4iWMqhZogHYqASFC8ocAAGvR6K0 6/12sbPXY8re
0s/Dfh1L/RNP06xvTeagvnxWUW4BBcFBnbnA2j8OOlaF3q3iTS5LxodTk1F4 J57eK3lto/3h
Fr56k+WoYsG+UbcZXjBb5q9EopB1PL7HxNqT6fuuvF2mfYXuo0m1G0vILqSz Uo5IdvIjjjDM
qKC6N95hnJGJo/G1zbaNftf6rFHcNYGTTHkVFa7KvMolQYw5ZViYgAgbgcAG vSqKdwPN7nyh
qeuWl1q0zpNrFoZ7J/LAWJvJw2AoYqzYTJJBAI65NdZpYVPFGupDjyj5EjgH pMUIb8dqx1q3
lnb39nNaXUQlgmUo6HuD/L61DpmlWmkWzQWaSBXcyO8szyu7HuzuSzHAA5J4 AHQUlorf10/y
E1rf+upk6/falZaglvbXBUajF9ntT5at5E4blxxz8hZsHI/de5rk9W8SX+/U YRqyXNz/AKbH
c6Q8ERFpCiv5cpUrvO7bHyxKt5vA6V6fRTWhR55a6m2oeMNNW51xpLuLUriN tJVYlW2RY5Qj
EbfMyygHLNtO7IGMY7jzNR/tMRi1tf7P2ZM/2lvN3enl7MY99/4VbopdhdTz y9ZbPUrxXzHD
oN02pF2zgJKyuW75+Vrkfh0qGxfUo9WsbC2u/wCz3v0imuZIoI2kBlW6mYAu rfxAYzkDnjk1
6TRQtrf1/WwPX+v68/vPKNa1y7uNGvrHU/Eb2nl2c6wKI4VfUnWWWNgdyHOF RMiMKRvJ4BGN
Ia7q9zq01nZa1v1OSS7hfS/Ki/0KNFfypsbd/JWPlmKt5vAHGPRaKP8Ag/1/ X4D6/wBf1/Wt
zjtF1/UdU1S1Hm/6LeFryEFFH+jhWTaOM/e8p8nn58dOK7GiimxBRRRSAKKK KACiiigAoooo
AKp33Hln68/kf6evbtjctyqd9x5Z+vP5H+nr27Y3KmBU6e2Pwx/L09unbHyc 74q4l0If9Re1
4/7aKP6enbtjavRdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xtVDO5 oooqhBRRRQAU
UUUAFFFFAHm3hnQdW0zxZDqMmi3cBnEo1CRBYxwNIx3blEWJXQMDgyEsNw45 YjoNLudVk8Ra
g83h7UrKG8WNUuZZLZljKK3LBJmbkkYwD74rqaKOlg63PNfCXhG40XX7Seay 1pLmMOlxeAac
sFydpBZ2jCzyAn5hvBO7BPIJrR8N6BaR65dXE/g2509zO01tcSvblIQVAKos crFC3zFgqgN/
Fmu5op31uD1OM0DQodC1idLPwbaW7CWdzqcS28e6JmLKibTvJ5VdrBVG088A GnpGiXlrd6Nd
f2RrMVwXn+0G41FZo7bcGAYRmdkGd3Hlg4GRx0rv6qWOq6dqZmFhf2t2YH8u byJlk8tv7rYP
B9jS3B9zgPCXhG40XX7Seay1pLmMOlxeAacsFydpBZ2jCzyAn5hvBO7BPIJr otIutTbxLfS3
HhvUrS3uxGFnlltiqbFbO4JMzcnAGAevOK6iincDl9KutUk8SX8k/h3UrOC7 WMJcTS2zLHsV
uWCTM3JxjAPvis/RNEe21WxkHhmWxv4Wb7bq5eA/bBtIbLLIZH3NtYB1GMZ4 IAruKY00SzJC
0iCVwSiFhuYDGSB3xkfmKS0AJYxNC8TdHUqeAevsePzrj9J+GmkaRqlvqEE2 6WBtyj+zbCPn
/ejt1YfgwNdYt5avNPCtzC0tuAZkDgtFkZG4dsjnmn29xBd28dxbTRzQSDck kbBlYeoI4Ip8
rWtge1ht3/x5z/8AXNv5UW3+qb/ro/8A6EaLv/jzn/65t/Ki2/1Tf9dH/wDQ jU9QOH8Tavep
r09q8tzbwwKrQ+TKYt4IBLkj73OVwcgbfU11Xh++ur7w9a3d4m2Z0JORt3AE hW9twAP41cur
CzvvL+12kFx5Zynmxh9p9RnpVipUWm3cxhTlGbk3ocBp/ibWbrULS21NrS1u nff5XkSoIFaG
ZgS4lMdwnyD5lIHXKo2MQnxR4vMdnDBa2l3PfedPayQ2YTdbpsAYxSXSfeL5 BDkhcZXJO3sb
fw1oNpbyQW2iabDDISzxx2iKrEqVJIAwcqSPoSKj/wCES8N/2f8AYP8AhH9K +xeZ532f7FH5
e/GN23GN2OM9at7/ANf1/Wpv1MIaX9p8S6dNeNq9rNcWMt3cWaavcbEmVovl CrJswNzDA+U+
lZ1x4u1g6XDLcXNlFDqVol3HcWaEGwiM0aOXZiyuQsuQ21QCjZGOnfxWdrB5 PlW0Mfkx+VFs
QDYnHyr6DgcD0FQW2jaXZS3UtpptnBJdnNy8UCqZjzy5A+bqevqaeny/4f8A 4H3CRg3UR8PS
Wtlo1+/2rUZ0hDapeTXiQgJI+4K8m4lghUAMoJ57HOWni3xBc2V9dQDTI002 282cPBI32hlk
mRtmHGxW8rKk7sbuh611MXhXw7BYz2MOg6XHaXBBmgSzjEchHQsoGDjtmria Xp8dubeOxtlh
MSwGNYVCmNchUxjG0ZOB0GTQBxF3r3iHTtQ1NLSSC+a41ZbS1h8jLQf6Osn8 c6KwwMbcpyS2
T92p38R+K0tLyWe1sLKTT7JLq4gniLvL80oIGyUrHlYwR8z7d2DuxXV3Wg6P fNO15pNjcNcI
qTGa3RzKqnKhsjkA8gHpTrfRtLtLRrW202zhtmj8poY4FVCmSdpAGMZZuPc+ tJbWBnH3UupX
Umt2l1qUTWE+rwWflrGyvFG6xFk3FyMMrbcADlie+K3dAtLfSdZ1bS7CFILC MQzxQRKFjiZw
wZVUcAfIGwO7E96vX+gaZqKXRltIknuUVHuYkVZvlOUO/GcqQCM9CKdpOkJp Uc+bq4u7i4k8
ye5uNnmSHAAzsVVAAAAAAHHqSaForf10/wAr/MT3v/X9dCjrWs32mXjW8SQM bmALYl1P/Hxv
C7XweV+dGwMHCvz6c9qnizVYbS5uW+xPZzSXlrDBCsizRPCrne8gccHyzkAK V3r8xxz3klvD
NJFJLDG7wtviZlBKNgjIPY4JGR2JqodD0hr24vW0qxN3cx+VPObdN8qcfKzY yw4HB9BTWm5R
yyajqOp+ItGuZ57FLH+07mCG1SJjMDHHMhZpC+DnaTtCDGRycc9b9sn/ALTF p/Zt15Gzd9s3
ReVn+7jfvz/wHHvTE0XSotSfUo9Mskv3IL3SwKJWIG0ZfGTxx16VepdELqcL cahdW+pPbm9u
Auk3r3NyWlIDQyOhUMT1RUlkwOn7odxUFlrGtLf2lnayQifUFjmMt6ZZhEJR cygBN6j5diqA
NvHGeBjuJdPsp/tHnWdvJ9pQRz74lPmoMgK2R8w5PB9TS/YLMTpOLSDzkACS eWNygAgYPbAZ
h/wI+tC2s/6/r/MH/X9feefavr+tat4d1a1M+mWwtLGQ3jtA7Gf95LF+7HmD ywfKJyS/LAds
nRfxRrm8y266fLDcTXdpa2qxuZY5IVchpH3YIJjIKhQRvXk456e58P6LePE9 1pFhO0JcxmW2
Rihc5fGRxk9cdalj0jTIdTl1OLTrRL+Vdkl0sCiV144L4yRwOM9hR/wR9TC0 vxPc6nqcUEcU
Jt55S8LgHm3CupOc8t5iDkcbXX611NV4bCztjCYLSCIwx+VFsjC+WnHyrjoO BwOOBVim7dBB
RRRSAKKKKACiiigAqnfceWfrz+R/p69u2Ny3Kp33Hln68/kf6evbtjcqYFTp 7Y/DH8vT26ds
fJzviriXQh/1F7Xj/too/p6du2Nq9F09sfhj+Xp7dO2Pk53xVxLoQ/6i9rx/ 20Uf09O3bG1U
M7miiiqEFFFFABRRRQAUUUUAFFFFABRRRQB5t4ZutWj8WQyXJ1YQ3gl+020t lemK2kJ3Knmz
OyED5gGjRVOOvKg7uk61Fc+J9TENpqcZuliEElxpdzFGSitnLtGAB9SM9s11 lFHSwdbnmvhK
HWbfX7T+0dZ1Jrkh1vbeXSr/AMqR9pziWSV4FAYZBjCg4wMA4rR8Nx291rl0 ftfikGOdntY7
xLyOFY9oDDdIoD5JOA5YjHy7a7minfUGcV4as7XStZms0tfED3f2i4LPPPdP apGzllfdK/lM
SCo+Xc+Scj7xGvFu/wCE+u/O6f2ZF9mz/wBdJPNx/wCQs/8AAa3qY0MTTJM0 aGVAQjlRuUHG
QD2zgfkKL7A9b+f+dyrBp1tZ6jfaim/zrsJ5vfhAQMADPQmuW0UG1m0yeI60 ZruSdZUuIbkR
IvJUGMqEjAO3DYBIzyea7ait4YhxTUtb/oml/XkB53okWrQ3yfbtV1BrgxyL dwSabeeXI2w5
xK8jQqNwyCgUHGBgHFd9bf6pv+uj/wDoRou/+POf/rm38qLb/VN/10f/ANCN LE13Xnztfl+i
X9dQOQ1/xJeQ61PY2072q2u3JWJXMpZQ2TuB+XnHGDkHmuj0LU21bRLe/eLY 8gYFV6EqxXIz
2OMj2NLqOhabq0iSXtsJHQbQwdkJHodpGR7HiryRRxxLEiKsartVFGAB0wB6 VypSu3cxhCam
3J6HCt4z1jUNMeSy0+ytbyO7tUNrPeMsyJJLt2zRtDuiYjHZgQ2VY4GbV344 u7GCS7uNGj+x
k3EVu6XmZJZoVdmUrsAVT5cmG3E8DKjPGvH4Q0aOymtPJuXjm2ZaW9mkkXYd ybHZyybTyNpG
DyKr3vgjSbm3vhAssE91DLFvM8rpG0i4Z1jL7Q57sAGOTk8nOmhvpcoX+v6r cG40Se1j06/k
e2CTW10ZQIZnZSwYopVwEfjBAJU5PONXQkew1TU9I+0XE8EHlTwG4meZ0WQM CpdyWb5kYjJJ
w2OgFJJ4R08aXcWls9xHPK0ci3c9xJcSrJGQ0Z3SMWIVhnbnHJ9TVvR9MuLE 3VxfXaXd9dSB
5ZYoTEgAAVVVCzEAAd2OSSe+Aaf18v8Agku5DquuvplzNAbPzGNsJbX95jz5 N4Ty+ny/M0fP
P3zxxzi6l40ura3uJn07ybFzcwWtzHdAzNLCrk5QxlVU+W+Dlugyozx1V1p1 pez2s1xCJJLW
TzYSSflbBGffr374PUCs5/COiS3VzcPaOWuRIJE+0SeWC4w7LHu2ozc5ZQCc nnk0LzK/r+v6
+4y/7c1PUNf0kx2qW+lG/ngEv2s+bMY45Qd0QTaF3KSPnJ4BwO3Sf2lANTGn +XdeeU37vssv
lY/667dmfbdn2qnD4Y0mDVRqUdvKLgStMo+0SGNHYEMyxltik7jkgDJOTzzW vS7C6nHSa3qU
d/Ha/adxtNQkF5iJfmhZ0Ean+7hZ0bPBPln1NQWfinVPtMFvHbfbri+CyQLN OsMcaSefImSq
E8JGqk/MenGc56a50DTLttQae13NqEIguSHYF0AIA4PHU8jB/IU5dD01L2C8 W2AngVFjYO3y
hVdVGM44Ejj8fYULaz/r+v8AMH/X9ff+ByWreLNWvtA1FNP02KG4t7OR7yVr 4p5BDyR/uisZ
MhzE5GQnG3nJOL03jK7gLy/2Or2bvcQWji6/ezSwq7EMmzCK3lvhtxPAyBnj SuvB2h3mfOtJ
cMHVxHdSxiQOzOQ4VgHG5mIDZAycYqe38NaTbao+ow2zrcOXbBnkMas33mWM tsVm7sACcnJ5
OT/g/wBf1+I+v9f1/XQq2XihL7U/scVrkNOUSQSZ3RhXzJ04+eNkx9DnnFdB WdZaFpunG1Nr
bCM2sBt4fnY7UJBI5PJyOpyevPJrRpu3QQUUUUgCiiigAooooAKKKKACiiig AooooAKoam2w
KxLYVWb5SATyo64Prn8B6VfrN1b/AFR/65n/ANCSk9gRnfbE/uyj6Oo/9l+n 5D0Fcdq
Re: JSDT - jsDoc not used for code completion? [message #216840 is a reply to message #216408] |
Sat, 05 July 2008 10:24 |
Junior Member |
--------------010006020307050703030002
Bradley -- after some further testing, I think I've determined the
difference between your output and mine: you didn't type a period (".")
after the "var k = s"! If fact, in your test, if you were to select the
"String" entry from the list, the word "String" will be substituted in
place of the "s", which is not the intended effect at all. I'm
expecting the list of String properties and methods, not the String
class itself.
Can you re-test by typing a "." after the "s", and hitting Ctrl-Space to
induce code-completion?
Bob Shields
> mentioned?
> -brad
>> * Demo function
>> * @param s String
>> var len = s.
>> Bob
Content-Type: multipart/related;
boundary="------------020105000800070301030700"
--------------020105000800070301030700
<html>
<head>
<title></title>
</head>
the "String" entry from the list, the word "String" will be substituted
in place of the "s", which is not the intended effect at all. I'm
class itself.<br>
<br>
to induce code-completion?<br>
<br>
Bob Shields<br>
<br>
<br>
mentioned?
-brad
</pre>
* Demo function
* @param s String
var len = s.
Bob
</pre>
</blockquote>
</pre>
<center><img src="cid:part1.08070105.04000802@resnbl.com"></center>
</blockquote>
</body>
</html>
Content-ID: <part1.08070105.04000802@resnbl.com>
KxLYVWb5SATyo64Prn8B6VfrN1b/AFR/65n/ANCSk9gRnfbE/uyj6Oo/9l+n 5D0Fcdq2p3F5
4pgtHbFtbalppiTA4LSMWJIAz0A9gBXS1xt3/wAjo3/YR0v/ANDapRTPYaKK KskKKKKACiii
gAooooAwNIjEHifXo4IY0gd4pZCvynzigz8oGDkBSWznPGOMnfqjBpkVo0zW u2JppDNIVjUG
SQgAs+MbsgAf/qGL1RBtqzVhtLoFFFFWIKKKKACiiigAooooAKKKKAIbv/jz n/65t/Ki2/1T
f9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P/wChGl1A5rWvFU1nqktjZ/Z1Nvt8 1rhWO4lQwVcE
Y4I5564xxW7pGpR6vpUN9EhQSbgVJzhlJUjPcZB571T1bwvYatdC6keeCbG1 2gYDzAOgbIPT
1GD71qW1pBZ2kdrbRiKCNdqqvYf4+9SlK7uYwVRTbk9Dio/F2rpo+p305snv Leze4Gk/ZXgu
bcg8bvMkHmp1G9QgO35c541P+EvMgkB0vULQwXEME7zxxMqO5j+T5ZeSRIOR kDBzngGZfCMU
sdwmoarqWoiW1e0Q3LRhoY3xuCsiKSTtXltx+Uc9cyx+GIFsZbae9vLlprmO 6kmlMYdnTZj7
qBcfu1zgetX/AF+P+RsylF46tJLdJ5NL1SFJrdZ7QSRx7roMyqFQByQd0iD5 9vXOcAkNm1+8
1fyNPsoLzSbyW8NtO0whaSBVj81mXBkQkgqBnONxOOKl1PwnDNpFtBaNK1zY 2ot7QvOI8FWj
ZXLeW2GBiU/dI6gqQapWPhrXLWwS9lu4rjW0vzeYmmHlupjERjaRIk4KjORG MEDg4yXp/Xrp
+G4nf+vT+rG74furqa1uba9m8+6srh7d5toUyAAMrEAAAlWXOABnOAOlZtxr moR+KzYPcWNj
aCWOOJLu2kze7lBPlT7ggcZYCPDN8hPAPGrodhcWNnK160bXlzM9xP5RJRWb oqkgEhVCrkgZ
xnA6VDdeH/tmpC4m1XUGtfNSY2BMZhLpgqclPMGGVWwHAyOnJydVfyv+v9f0 jozK0rxncXjp
bXOh36XMktwEKCEp5cUuwuT5pxjIznBJB2g8U+x8b29zHbs2n37Qs8MM16Ik SFJJERlypkLY
PmKPlDYPU960LHwzb2GoS3aXl3IG88JDIyFIhK4dwuFDfeGRuJxkjpjDbXwn p9ppn9npJcND
50Ex3spJMQjCjp0IjXP1PTslt/Xf/L8RvyDSPFEWr30dumm39vHPA1xbXFwI wk8YKjcoDlxn
cpAZVODWlBqunXV9cWNvf2s15b48+3jmVpIs9Nyg5H41zfhnw3q2mawbi+uR 9htrZrWxthcr
P5cZZTjPkRsAAijDGQn1456+npp/X9aB1Zxv2/WrfwpqusRams08U9w6xXdu rRpHFI67EEex
uQo+Zi1Wp/HWn22vXGivbzNexRPIscc9u7S7U37VQS71JXON6qPfkZZB4a1C 6sLjTdRu2tbI
3M77LGZX+1xSSM+2XfFlMA4+Rs8nnpVu08J29pqUd2moXrQw3ElzDaHyxFG8 gbeeEDnO9j8z
HHakDF1DxdYWFlc3gikmt7eOGRpRLDEhEudoDyui5AwTkjhlxnNY83jSa++x XWnXVlYaZPAJ
Fu9Qt3likk3shiM0biOIgqACWYNvG0HHOs3hCzWyhgtry7tZYLo3UNzH5bSR sVKAAOjLgIdg
yvAA781EfBsf2Q2a63qy2cgdbm33RMtwHdmYNujJGd7AlCpxj0Bp6X/r+v62 DpYkufF0du0z
rpGpT2kc4txdxLEUklLiPaqmQOcMcZ244PNQ/wDCYOt5LZro2pXV2CzfZYEh DxKqRMwZml2E
gyjoeeQAcZNn/hFYhcMV1O/WzNwtyLEeV5SSCQSZBKb+WBJG7HzHGOMVr3wn PP4hOo2esXmn
rKkpna38ouWYRKAN8bALiLPrnvSX9f16jJdH8UPrOuNBbWMzaa9jBdw3nyKP 3m44YF938IAG
3ghs9qs22uN/wj13qt1EpFvJcBljZUyscjqOZGCjhcklgOvSn2Ph200y+huL GWeCKO1S0Nsp
UxuiZ2E5BbI3NyCM55zxVFvByvBc2za1qTWssxuI4CtuVgl83zQ6HyskhugY sOeQacrdBLz/
AK0K1l8QrDU7eN9N02/vpnEpMNq9vJt8spuy4l8s8SKRhz3HUYqf/hN7N2ie 207Ubi0doUe7
RI1jiaUKUVg7hicOhO1SBn1zi1p3he30++kvWvr26upRIJJbhky28RgnCqoH +qXGAByePTCf
wVfw6ra29hcmDREe3luFa5VmmaIKATH5GQSI0BKyqOM7eoK/4H/B+VhdH/Xo b0nimzjsILsQ
zsk1g1+qlo0xGuzILO4VT846nHB5rPs/H9hqdlFNplhe387vIptrWS3dkEe3 cxkEvlY+dOjk
/N04OF/4QO0MMcUmranKsEQitN5hP2ZVdHXb+7wxUxrgvuJ75qpqfhDUoFFz omoXEmqSSOZr
y5u44nKsiKVwLaRCD5aHAVcY4IyRQ/L+tdP+CNEsfxL0CTVbPT97LLdCEfPN ApjaVVZFMZk8
xidy8orKM9eDifxbrOo6eWXTpFi+y2U1/MzRh9+wAJHjrhiSTjBwuARnNT6V 4TbSfsxtdZv4
VSOJbiCMRGK4ZEVNxDozLkKAQrDp65NSeINAl1e4ieGbYkkEtndLv2kwyYyy naw3qVBGRg5I
NN2vp5/8D8fw3Bf5f8EybTxHrMsSQrPBcXd3OtvbmbQ7uwSI7XdnYSuTIAqH hSvOAWGciS/8
Q6x4e1Gyj1mfTJbFlkku7mGB4fLjBjRWw0jbcNJ82SRjnjBrRfwvJcWxivdf 1W7dJFltp3Fu
kltIucMhjiUEkEghgwIyCME5lt/DcKymXUL671V2ikhf7aIiro+zKlURVx8g 4x3Oc5o6/wBd
v8/+HD1/r+l/wxir4s1e50e8ltrO3GoPfeRYwSK3KGNZRvGc7thYnGOcCtiT UbfVdJtry3cF
Li1WZRnkKxQjI/P8jTbrwbouoXz3OoWqXyNK032a6RJIQ5RE3bSvULGAPTc3 rwg0q20TSVsL
PcLZBI0aHGIw0itsXAGFGcAdgBUvb7vy1DqUK427/wCR0b/sI6X/AOhtXZVx t3/yOjf9hHS/
/Q2qUUz2GiiirJCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KAIbv/jzn/65
t/Ki2/1Tf9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P/wChGl1AxdW8UJYX7Wdt bLcSRY87dN5Y
TIyAODlsEHHAwRzWtp9/BqdhFeWxJikBwCMEEHBB9wQR+FYmteEI9U1A3sF1 9mlkAE2YvMD4
GARyMHGB3HA4ra0/T4NL06KxtdyxRKQCTkkk5JPuSSfxqVzXd9jGHtOd82xh aN4tbUrCXVbm
2tINJAyJ4bszyRnIGyaMIPLYbuQCwXByRjJu3vi3RrC7ltZp52uIywaKC0mm b5QhbARTnAkT
JHTPPQ1RTwzcvdXd9rE9nqUz2D2W22s/szzRtglZGMjBjxx90Dc3HPEmheGp bC30+a5uS93H
aSx3Jb5jJLKyO7buOhUjp0x0xir/AK/P+vmb6XJY/F9hJqtxZpFdyxRWcV2k 8FpNMsiPuPGx
CDwBjBJOSAODU8XinR5Uhc3MkIlaRB9ot5ISrIu5lYOoKHb82GwSASMgVkXH gq5eyW0g1WJY
TY29pMktqXWUwkkEgSL8jBmDIc5Bxkc5gj+HkZ0iTS5rq1is5bo3jxWFiLdV lCII9g3MFCsu
/HO44BONwZu13/X9aCXT+un+Y5PHyT6++nwnRYo1ljRVvtUa3upAyK+VtzCT nDYAJBJHati2
8YaJeNaLb3E8hu+bfbZzfvV+XLL8nKDeuW+6Ocng4r22ieILW7uJE1rTWhu5 EluFfTH3FhGi
NtYTgKDsyMg4z3q3YeHxZNphNz5gsdPayI2Y8zPl/N14/wBX0569eKP6/D/P 8wIU8a+H3jlk
F64jjK4draVVkDPsVoyVxIpYgbkyORzyKg1DXNVnuJRocUPl2lot3OLy3kDS 7slYVBKmN8KS
SwOMr8vWq1v4JuRJZG71ZJ005Y4rLba7GWJZY5CJDvIdj5SDcAoGCdvNWdXg 1iy1S9n0uxa8
XUbZYQRIiC2mXcA77mBKEMM7ckbOhzSe2m49L+R0Nrcx3llBdQnMU0ayJ7gj I/nXO6N4tbUr
CXVbm2tINJAyJ4bszyRnIGyaMIPLYbuQCwXByRjJ37CzWw0y2so2+W3hWJT7 KAM/pXPp4ZuX
uru+1iez1KZ7B7LbbWf2Z5o2wSsjGRgx44+6BubjnhyaTdtiY3aV99C9e+Ld GsLuW1mnna4j
LBooLSaZvlCFsBFOcCRMkdM89DUUfi+wk1W4s0iu5YorOK7SeC0mmWRH3HjY hB4AxgknJAHB
qLQvDUthb6fNc3Je7jtJY7kt8xkllZHdt3HQqR06Y6YxVS48FXL2S2kGqxLC bG3tJkltS6ym
EkgkCRfkYMwZDnIOMjnKat6/8P8A8Aa1/r0/4JrxeKdHlSFzcyQiVpEH2i3k hKsi7mVg6god
vzYbBIBIyBWGnj5J9ffT4TosUayxoq32qNb3UgZFfK25hJzhsAEgkjtTY/h5 GdIk0ua6tYrO
W6N48VhYi3VZQiCPYNzBQrLvxzuOATjcG0rbRPEFrd3Eia1prQ3ciS3Cvpj7 iwjRG2sJwFB2
ZGQcZ70f1/X9f8A6Fi28YaJeNaLb3E8hu+bfbZzfvV+XLL8nKDeuW+6Ocng4 YnjXw+8csgvX
EcZXDtbSqsgZ9itGSuJFLEDcmRyOeRU1h4fFk2mE3PmCx09rIjZjzM+X83Xj /V9OevXism38
E3Iksjd6sk6acscVlttdjLEsschEh3kOx8pBuAUDBO3mnZXsHQ6yCZLm3jnQ SBJFDqJI2RgC
M8qwBU+xAIrL1y81C3uNLttOltopLu5MTyXELSgKI3c4CuvJ24znv0NX7/Tr HVbRrXUbK3vL
ZiCYbiJZEJHQ4YEVl65Bcwz6LNYadLdR2l0S8Nu0aFEMToCA7KMAsOAc46Ck HQD4hktdQ1K3
1CxdIrRYnjeyWW7eRJC4BMaR7lI2HIG4c9anj8TaRJaTXK3TCKG2+1SFoXUr HlgeCucgowK4
3AjBAJFYmoeDb/VvOm1DU9PuLmR48xPpzG0eNA+FkhM2X5kLZL4yqnHHNix8 FxWVlplstyir
ZyyM4htxGskbSeaIwoOFUOE9eFI78NeYPyL194p0+wku4ZI70z28Mk2w2cqL LsXcVjkZQjtg
dAx6H0NV7HxQW0n+0tTis47aQqLaTTLl78XGc8KFjDMwxyFU8c54OM4eBJU1 9tWiv7JLlZZp
Yrn+zg1186uoWSVnO9V3DC4UYUD3Ey+Eb8Xk2qnUrCPWXljkWaDTmSA7VdPn j80s7FZGG7eD
gL/d5S2Av/8ACX6XKzJA8pkSSNJVntZ4hGXKABiY/lfEikKcE+wBIrXHj3Rl 0q8vLRri4aC0
N3HGbWaPz4xj5oyyfOuSuSuQMjNSnw3cy2F1Hc30UlzcXkN47xW5Rd0Yj+UK XYgHy+5OM98V
l6d4O1K60OCDW7+ETR6U1hAlrbbPs4kVQ5YmRxIw2LgjaODxzw1tr/Wn+Y+p 0ba0hbSjFBKU
1CUxjzUaJ48Ru+SjKG/gxggdadda9YWWox2NybmOWTAWQ2kphyegMoXYCemC 2c4HcVV1DSdW
vLbTHi1Kyi1GylMrTPZM8UhKMhHliUEcNn756Vj3vgSbUdZTUry906WYSwzG ZtOLTI0e3KxS
NIfLjJUnaASCx5OTlPfQS2NSHxt4fngknS9kESQicO9rKglQkAGMso8zllGE ycsB1IFIdZst
ZtZnszP+5BjkSe2kgdGzGcFZFVuhB6d6o6p4VmXR7D7NPLLdaXZrFAsUS5kk R4nVsM6rjMQy
pYZBPzA81QtfD+r31lPdaxfXenXd1dPK0dmI4vlCIqhhulA+5nAkI7nHO0a/ r56AX6427/5H
Rv8AsI6X/wChtXSnweef+Kh1wf8AbePjr/sf4dD0525epeH4dGvtMnW8vLqa 51WyV2uWViAk
vGMKP7xHPp25AlIbPUKKKKoQUUUUAFFFFABRRRQBymieMpNW11tPfTjHbyCR ra7i89o5VQ9d
zwohyCCNjOPfHJ0NHe8j1rV7S51Ce8jiaJ4jMkYMYcElRsVcgY4zk+9ZFp4V /s6/gvYtNJms
8tHt1S4ZQjDBhiR32rj0ICHYnC5/dPsfDk+l6ib+G1uZLhfnlJ1m6lWdSCBG Fkk2llBblxtO
Fxt3Hy3Y3dB30a+9f1/Xkzr6KKKRgFFFFABRRRQAUUUUAFFFFAEN3/x5z/8A XNv5VWuLv7Bo
97eBN/kLNLt9dpY4/SrN3/x5z/8AXNv5U2KNJrWSKRQyO0ispGQQWORSB7aH mtzc6Qthpuo6
4t5f3WpbnEif8swDjCjtjPA4rpvBGqT3kF7azG5eK2ZTBJcqQ5jbOAc9cbev uKoXOh6t4ZsZ
ZLCc39jbnzLa1Nv5syOTgAcE4BOSRzjPGayvh7Jrmn61Pa31jqHkXqlmmmtJ VCyqCdzM2B8w
yCepO2nSoScHO+34nFFuFRJr+v8Ahzq18Z2o0q51a40++ttMitzcxXk3lCO4 j4wVw5Kk5GA4
UnP1xeTxPok4j+y6pY3TSbdqw3cRJUsq7uW5A3r09RjJIB56Pwpqk1vqcRtt M0lbmxlt/JsL
iR4JpnwfNaIoioRg8jcxDck7RVxfDuoz2V81xHZQXl5qNvduIpWdQsYiBG4o pJ/dtjjuOlH9
fidrNqHxFolyLkwaxp8otU8y4KXSN5KYzufB+UY5yan07VdO1e2Nzpl/a3sA YqZbaZZF3Dtl
SRnkVxuqeFri00HSmRbcnSrBI2iSKSQSyJLDIFCojMVJiIyFJGQdp6Vs+DpL 67tdR1C+svsb
3l4ZUi/efdEaJnEiI45Q/eQfiMEuy1/rr+on/X3HSUUUUhhRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAVR1Btuw5UYBYsxIxyPQZ6kf/AK8EXqzd W/1R/wCuZ/8A
QkpPYEVPtEY6Sxe3Lf8AxPsPy7YXbyOvasl5r1hp6R4FnqdgxkDcMXkPAGB0 Cj8/QCsfT9I8
bx+LpPtviXzdAixJHi2hEs2Sf3bYT5cY5YdQRjBJ2uu/+R0b/sI6X/6G1JDZ 7DRRRVCCiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAIbv8A485/+ubfyqmt +IA6sEAErqCz
HnnPZT61cu/+POf/AK5t/Kuf1MStBMIHRJjNMEZ0LKrYGCQCMjPbI+oqWNFO e0vLuaSa48QT
q5J2LbPJEiDsNoHP1NWfC+v3F94fiuruRJGM0sayOCrMqOVBIUEZwBXEfDyw 1ywsNZTxEzya
i+qPI0xOVmUxxgMh4+XAwAAMYxgYwNvwl/yJ1p/183X/AKNNJaakqEU7o7P+ 1o/WL/vpv/ia
P7Wj9Yv++m/+JrCoo5mXY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrCoo5mFjd/ taP1i/76b/4m
j+1o/WL/AL6b/wCJrCoo5mFjd/taP1i/76b/AOJo/taP1i/76b/4msKijmYW N3+1o/WL/vpv
/iaP7Wj9Yv8Avpv/AImsKijmYWN3+1o/WL/vpv8A4mj+1o/WL/vpv/iawqKO ZhY3f7Wj9Yv+
+m/+Jo/taP1i/wC+m/8AiawqKOZhY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrC oo5mFjd/taP1
i/76b/4mj+1o/WL/AL6b/wCJrCoo5mFjT0rxImqPfhLfYtpdNbE7878KrFug x949fTPrt0Pt
2Osf1+b/AD6H8u2G28f4PPOu89NVk79P3cfv7e3T2yvS9PbH4Y/l6e3Ttj5H cRb+3Y6x/X5v
8+h/Lthtp9ux1j+vzf59D+XbDbanT2x+GP5ent07Y+Q6e2Pwx/L09unbHyFw Lf27HWP6/N/n
0P5dsNtPt2Osf1+b/Pofy7YbbU6e2Pwx/L09unbHyHT2x+GP5ent07Y+QuBb +3Y6x/X5v8+h
/LthtrW1DbnMajA3EsxGOQPTPU+n65ArdPbH4Y/l6e3Ttj5IbjiKQf8ATPp/ wJR/T07dsbVL
gW/7Wj9Yv++m/wDia5fWNYv9Y1S40zTLmKy+xxo0szQ+d5vmZIABK7QNnXvn tjnltI0/xDH8
TfEF75vlaBL5Q8qVSfOlEMY3R8/LjGC3Q4xgkZXY07/kbtc/65Wv8npXHYP7 O8Q/9DBB/wCC
8f8AxdZ82k3VjqdjeXl8l1Nc6rYKSsHlgBJDjjcf736V1M00VtCZpmIQED5R lmY9FUd2PYfy
AJrC1GeWa80wTORImr2YaBOY4P3n3d38T/3j9B2wBAz0+iiirJCiiigAoooo AKKKKAKS6pby
6gbO3DzyISJmiGUhI7M3TPT5Rluc4xzSm6d9VFpEFKRx+ZOxHTPCqPc4J+g9 6x2kbRPEul6X
ZkLY3wmJgIG2Eou793joCeoOR6AVpaH+8sXuW5luJpHkPqQxUfgAoH4VTVtT GM3J28x8es2M
t6lokknmyMyoTC4RyuSdrkbTjB6GmprmnyXSW6zOXkcpG3kuEdhnIV8bT0PQ 9q4nwfrEmr+K
5I5rSzhkhSSRp7eHy5JjkL+8I+8Oc9OoBq/ouv30vi2Tw7ujWzst4R1X946p wFYnjHPYA8Dn
rRygqjt8zp4Nc0+4ufs0cshmDbGUwOuw9g2V+XPbOM9s1Jb6lFcS3aqrgW+N wMUgc8H+EqM9
OMZzXFeDvF1/qviG4sp4bZYpN8xKKwO4ADux44qv4Z8Z6jqXi8W00NqqXRKu UVgQEViMZajl
/IPafnY7i017Tr541t5ZG8zOxmgdVcgZIDFQCRg8ZzwfQ06x1i21CRkhju1Y FhmW1kRflOD8
xXH4ZzXFeGdeu73XbXQplh+y24MqOqkOSFyATnGOfTsPfOtper3b+N7/AEQM q2lvvuAQvzOW
wSGJ7ZcnjB4HPXJyh7R2v5nRWeqW95M9vh4bpBl7eYbXAzjcB0Zf9pSR71dr mPC8jeIbGLWt
RCyziR1hi2jy4NrEZQddxx1JJ64wCRXT0SViqcnJXCiiipNCC+bZYXLbXbbE xwilmPB6Ack+
w5rzLVdW1y8vpZLODWLa2LlkibQZHIz1Jbdz/n6n1SiiwHj32vxL/f1f/wAJ 1/8A4qorRtfs
bGOzthq6Qxs7gf8ACPSE5dixOS3v+lezUUrBc8e+1+Jf7+r/APhOv/8AFUfa /Ev9/V//AAnX
/wDiq9hoosO5499r8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePf a/Ev9/V//Cdf
/wCKo+1+Jf7+r/8AhOv/APFV7DRRYLnj32vxL/f1f/wnX/8AiqPtfiX+/q// AITr/wDxVew0
UWC5499r8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V/ /Cdf/wCKo+1+
Jf7+r/8AhOv/APFV7DRRYLnj32vxL/f1f/wnX/8AiqPtfiX+/q//AITr/wDx Vew0UWC5499r
8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V//Cdf/wCK o+1+Jf7+r/8A
hOv/APFV7DRRYLnl/h/UrrRre7WfSdcuprm5Nw0i6VLGASqjGOf7oPBH6AjX /wCEqkHTw7r3
t/xL5P8AD2H5dsLt7miiwrnDf8JVIOnh3Xvb/iXyf4ew/Lthdp/wlUg6eHde 9v8AiXyf4ew/
Lthdvc0UWHc4b/hKpB08O697f8S+T/D2H5dsLtP+EqkHTw7r3t/xL5P8PYfl 2wu3uaKLBc4b
/hKpB08O697f8S+T/D2H5dsLtzdW17VbyNE0/TtZshyJC+jSSlhxgDkAdB29 OgGK9LoosK54
99r8S/39X/8ACdf/AOKqbSZr6xvry8vLDW7qa5WNSV0aSMAJuxxk/wB79K9b oosO55hPqNxN
M8w0rX0kB2wsulyfuEP3tv8Atn+/+QHGICbm7vdLt7fSNYigi1K2kRJNPkjj hjWQEkkjrySz
HrjtgCvVqKLCCiiimAUUUUAFFFFABRRRQB//2Q==
--------------020105000800070301030700--
--------------010006020307050703030002--
Re: JSDT - jsDoc not used for code completion? [message #217128 is a reply to message #216840] |
Tue, 08 July 2008 20:41 |
Bradley Childs Messages: 14 Registered: July 2009 |
Junior Member |
------=_NextPart_000_001E_01C8E111.05FFC140
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_001F_01C8E111.05FFC140"
------=_NextPart_001_001F_01C8E111.05FFC140
charset="iso-8859-1"
Hi Bob,
I think I understanding your issue a bit better now. The problem is =
that even though function parameter 's' is listed as type "String" in =
the JsDoc, the inference engine isn't marking it as String for content =
completion within the function (it's of type 'any') . I was under the =
impression you weren't finding the type "String" when using code =
completion.
This isn't necessarily a bug since it requires some inferencing that s =
is String from JsDoc and not of type 'Any'. But I would consider it an =
uncomfortable missing feature. Please open a bug report and we can see =
about doing function parameter inferencing from JsDoc in the very near =
future.
-Brad
"Bob Shields" <java@resnbl.com> wrote in message =
news:g4ni59$mua$1@build.eclipse.org...
Bradley -- after some further testing, I think I've determined the =
difference between your output and mine: you didn't type a period (".") =
after the "var k =3D s"! If fact, in your test, if you were to select =
the "String" entry from the list, the word "String" will be substituted =
in place of the "s", which is not the intended effect at all. I'm =
expecting the list of String properties and methods, not the String =
class itself.
Can you re-test by typing a "." after the "s", and hitting Ctrl-Space =
Bob Shields
Bradley Childs wrote:=20
content completion works for me on the string type-- see attached=20
screenshot. could you give an example/recreate for the other problem =
you=20
mentioned?
-brad
"Bob Shields" <java@resnbl.com> wrote in message=20
news:g49gne$mij$1@build.eclipse.org...
On a fresh install of Ganymede with the Javascript Tools added, I =
entered:
* Demo function
* @param s String
function demoFunc(s)
var len =3D s.
With the cursor following the "s.", I pressed Ctrl+Space, but did not
get any form of code completion. (I was expecting the String methods
and properties to be displayed). If there had been no jsDoc, I could
understand why there would be no suggestions, but the jsDoc is present!
This is actually a simplified version of a larger issue: I have
attempted to generate a number of code-completion libraries for my
external Objects, and they work fine within the scope of the function
that obtains an instance of the Object. But if I then pass that Object
to another function, I lose code-completion even though the jsDoc
correctly defines the type of the Object for that function parameter.
On a side note, is this the best place for JSDT discussions? I would
think that with the number of (duplicated) news items about JSDT in this
release, there would be a lot more active discussion...?
Bob=20
=20
Content-Type: text/html;
<HTML><HEAD><TITLE></TITLE>
<META content=3D"MSHTML 6.00.2900.3059" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Bob,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I think I understanding your issue a =
bit better=20
now. The problem is that even though function parameter 's' is =
listed as=20
type "String" in the JsDoc, the inference engine isn't marking it as =
String=20
for content completion within the function (it's of type=20
'any') . I was under the impression you weren't finding the =
type=20
"String" when using code completion.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>This isn't necessarily a bug since it =
requires some=20
inferencing that s is String from JsDoc and not of type 'Any'. But =
I would=20
consider it an uncomfortable missing feature. Please open a bug =
report and=20
we can see about doing function parameter inferencing from JsDoc in the =
very=20
near future.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-Brad</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Bob Shields" <<A=20
href=3D"mailto:java@resnbl.com">java@resnbl.com</A>> wrote in =
message <A=20
href=3D"news:g4ni59$mua$1@build.eclipse.org">news:g4ni59$mua$1@build.ecli=
pse.org</A>...</DIV>Bradley=20
-- after some further testing, I think I've determined the difference =
between=20
your output and mine: you didn't type a period (".") after the "var k =
=3D=20
s"! If fact, in your test, if you were to select the "String" =
entry from=20
the list, the word "String" will be substituted in place of the "s", =
which is=20
not the intended effect at all. I'm expecting the list of String =
properties and methods, not the String class itself.<BR><BR>Can you =
re-test by=20
typing a "." after the "s", and hitting Ctrl-Space to induce=20
code-completion?<BR><BR>Bob Shields<BR><BR><BR>Bradley Childs wrote:=20
<BLOCKQUOTE cite=3Dmid:g4b7n1$h6v$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">content completion works for me on the =
you=20
mentioned?
-brad
"Bob Shields" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:java@resnbl.com"><java@resnbl.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:g49gne$mij$1@build.eclipse.org">news:g49gne$mij$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">On a fresh install of =
Ganymede with the Javascript Tools added, I entered:
* Demo function
* @param s String
var len =3D s.
Bob=20
</PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE>
<CENTER><IMG=20
src=3D"cid:001601c8e13a$ee290e80$51212909@IBMDA7121A1C93"></CENTER></BLOC=
KQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_001_001F_01C8E111.05FFC140--
Content-Type: image/jpeg
Content-ID: <001601c8e13a$ee290e80$51212909@IBMDA7121A1C93>
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRofHh0a
HBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgN DRgyIRwhMjIyMjIy
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/ wAARCAEMAagDASIA
AhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAA AgEDAwIEAwUFBAQA
AAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcY GRolJicoKSo0NTY3
ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKT lJWWl5iZmqKjpKWm
p6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP0 9fb3+Pn6/8QAHwEA
AwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQA AQJ3AAECAxEEBSEx
BhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2 Nzg5OkNERUZHSElK
U1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOk paanqKmqsrO0tba3
uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMB AAIRAxEAPwD3Zrv/
AImCWiJuPlmSRs/cGcD8Sc/kar2uu6de3r2dvdRyTp1RWBPvkdRjoc454qTT YJUSW4uU23Nw5d1J
B2Doq8ccDH4knvUkNha29xJcRQhJZMl3BOWyc8+vt6dBQTr0K9rrunXt69nb 3Uck6dUVgT75HUY6
HOOeK0arQ2Frb3ElxFCElkyXcE5bJzz6+3p0FWaBq/UKKKKBhRRRQAUUUUAF FFFABRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABUMd3byyGNJkZhjgHrkZGPXjnipqzLLQNOsN Rmv7eBVuJixkbaOc
nPpx+HXvk80Cd+hp1n22rxXN35K29wsbFljnYKEkK9QvOfXqADg4zWhXI2Ng F1WN7qNlFvE6TGe0
OwIAVwJSQuwg7toB75xS6ik2rWOuori/C8FvPbWEtjpyxyRMRLfRyRsGXB+Q kNuPBX5SMDj0FT6T
pl9aa3FdNp88Zk3i6dfs6Rlm5yAnzsuc/eJIyOOuGTzvex1tFc5pOmQx6lNK +gy2rGUyQys0W2MY
AwoVyVyc5wMHvVCx0q8ttS+0S6VOwlSVbtVFsschbngAhmXOfvnPI45OFfQf M+x2VFcZZaHLZtZz
RaK8csSwEkPHlWBIk/j6kYOe4AHbFdnTHGTe6CiuU03RpF1+K/bTri3cNI8j TtAw+YH7rR/Oxyf4
8jGe+K6ujpcIu4UVyOlaZe2mtR3T6fOnmCQXTL9nSMs3OQE+dlzn75JGRx1x NpWlmxubOWHQ3tnM
03nSKYgRGxJUHD5I5XgZxt6dKETzvsdRTBKjIzqwZVJB288jqOO/tXNaZDp1 1qjWFuLGa10+U3Ef
lFGId84BA6FTu/8AHfQ1Y0zTk02+kEGgwxkSSN9rQRLlCSQq4+bPIGCAODz0 yD5jbtriK7t0nhJM
bjKkqVP5HkfjTlkVpHQBspjOVIHPoeh/Cuc03TntLiwuF0eWG4Z5PtMu6MsF OcBiHJIzjAGcY7VY
0uOW31W8K6HNaW9yVO4eSF3AHJYK5PP0PvSBSfVG9RXLaZpbWU1rJBoj2krS zCWVfKBVGJK5w/I5
XgZxt6dKqaZDZPrthbDT4Re2oc3coljcu4XG9grFs7ifmcAjOO5poXO+x2lF FFBoFFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRR RQAUUUUAFFFFABTQ
6M7IGUsuNwB5GfWnVj2Hh+Kw1OW9FxNJv3YieRikfptBOBgZH48YHFAnfoaj 3ESTxwM372QEquCc
gYyfbqPzFSVm6aftk02pHlZf3cHtEp6/8COT9NvpWlQCdwooooGFFFFABRRR QAUUUUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFebeHLfRtV8W6pdP4ggvr+O8Itd32SSR 0EKYZD5e4BSWxtIX
K8g/NmfS/EVwuq6VbXfiN5J5Z7i3u7aRYF8vbv2FtqAqxwCATzzgYzVuH5XO iWHabSe3qehUV5/4
d8UTz3WkifXoL77c1zCYS0I5jJ2MNoB3EYz25GB3Muk61d3l5pLSeJ4xfzTE X2jGOPMQ2tlAqoZF
KkL8zNjAJzyBS5GJ0JK9+n/B/wAju6K4jw5PFp2vX9ld+IbmW8e/kC2EghLS AqCJGVIw4GOc5C8V
b0HUbf8A4SjxDYx6lBe3CMkipmFZSQpDA7FBO07Vy2SOATSa0v5XFKi035HW UVwekeIr24u9JVtY
Fze3e7+0dN8lF+wAISTgDem1gq/vC27d9KZ4b8UTXF5pC3GvwXovnuYTETEM eWx2MNoB3EYz25GB
3NODHKhJX/rv/kd/RQRkEZx71xPh2+Fvq1xYXHiq+1LU1nuF/syYQMUUOxV3 2RB0UrtwWIT5gB1U
VBh0udtRXmvhLxFrl5r9pBqPiDRZHmDi6006jG1xC4UkqkIt43UqwwQ7vhQe p5qTQfEWo6p4yhii
8S2V/YStMzW1nPFK8aAHYXj8lXhA4BLPJ82F75DsB6NRXFeGr1INZm0678WX 2oagLi4Q6dMsDNGo
clXcRxB0XbtwSQvzADqorXjZpvHlykv3bXTomtwT3kkk8w/+Q4x/+uiwPr5f 52N6ivOtA8Rahqfj
OGOLxJY6hYStMzWtpPFK0aAHZvj8lJIQOASzud2F75HUaAzJqWvWiD/RYL0G LjhS8aSOB/wJif8A
gVJB3XY3aKxNMiDeI9YuZoIluQYoldfmPlbcqNxAI5JO3oD3Oa26ACiiigAo oooAKKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igAooooAKKKKAIPt
P+x+tH2n/Y/Wq9Fa8qM+Zlj7T/sfrR9p/wBj9ar0yYStA4gdElKnYzoWUHsS ARke2RRyoLst/af9
j9aPtP8AsfrXF2es63c3VnaNLYJcJ5zaj/or4jVGAG3951bPBOcjntgt0bxN qF7rdpbzxI1lfQyT
Ws32cQlkXGGA852IIPdU7fSnyJmzpTSeux232n/Y/Wj7T/sfrXI6Nf8AiO/v boTnTPstpdtbuyxu
rzADlh8xCYyODuzz93rXTUciImnB2bLH2n/Y/Wj7T/sfrXnmgapq02vz6NbT xw2tpcTu76isk8ty
gmIAhYyDKqPlYtnaSnBBFdxKXETmMZcKdoxnnt3H8xS5Va5LbTaLf2n/AGP1 o+0/7H61w+l6h4zl
1O3j1DTvLtGbEr/YIUwP94XzkfgjfSuwo5ULmZY+0/7H61AywPex3jQ/6RGj Rq4Yj5WIJHvyo6+l
cdYa94gm8TW1vdW1rHpV08ohmVFPmBVLLskSZ92QM5aOMYB74FdhQorcG3sW PtP+x+tQWqwWcbJB
DsV5Gkb5iSWYkkknnqf6UlFHKg5mOC2y3jXgtIhdMgjaYKN5QEkKWxnGSTj3 qb7T/sfrVeijlQcz
LH2n/Y/Wj7T/ALH61Xoo5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP +x+tV6KOVBzMsfaf
9j9aPtP+x+tV6KOVBzMsfaf9j9aPtP8AsfrVeijlQczLH2n/AGP1o+0/7H61 Xoo5UHMyx9p/2P1o
+0/7H61Xoo5UHMyx9p/2P1o+0/7H61Xoo5UHMyx9p/2P1o+0/wCx+tV6KOVB zMsfaf8AY/Wj7T/s
frVeijlQczLH2n/Y/Wj7T/sfrVeijlQczLH2n/Y/Wj7T/sfrVeijlQczLH2n /Y/Wj7T/ALH61Xoo
5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP+x+tV6KOVBzMsfaf9j9a PtP+x+tV6KOVBzMs
faf9j9aPtP8AsfrVeijlQczLH2n/AGP1oqvRRyoOZk32d/VaPs7+q1ZoqOdl cqK32d/VaPs7+q1Z
oo52HKihHpkMNzNcxQQJPPt82VUAaTAwNxxk4HTNVIvDGkwTLNFpWnxyq/mK 6W6Bg/8AeBx196w9
B8Tapeazc6JbwpqTWNzKt7eXU4t2hTzSsYVVixISobBGB8hBINdtT53ZMrVN q5l2uhWNjPLPaWNp
bzTHMskUSoznOfmIGTz61b+zv6rWXpU11b6trNvd6jPdwwGOWMzJGDGGUkqN iLkDHGcn3NZPh/xz
d65qFtC+gXkFrdoXguPIucKNu5fNLwIi5HGVd+SAMjmkptiavqzYj8LaPFNb zR6RpqS2xJgdbZA0
RJySpx8uSSTj1rS+zv6rWDpXiTVLqeL+0tItrO2laeNJIb4zNviJBypjXCna xByT0yBnhtl4k1i7
u9MDaHbx2epAyQT/AG8lkj27hvTy+HIx8oLD73zcDJzMTijoPs7+q0ht5MHG 0nsCcVkaDqPiDU/P
/tHT9OtYFlmiE1revI4ZHKj5GhA7dc/hzgVvDut6xKLGDU7NDDOJI4rxrhTN KyZ+Z4lQKoYAkEMe
2VGcAcnsHKkT2vhfTtGmmvrDTNMtp9jF5be1SN5B1KkgZxkfy9Ob5nCsVYAE cEGROP8Ax6r13/x5
z/8AXNv5UW3+qb/ro/8A6EaiN46JlNJ7lD7Sv+z/AN/U/wDiqPtK/wCz/wB/ U/8AiqbqXiK0025F
sYp7iUANIsCg+WD0LZI6+gyfatK2uYby2jubeQSQyDcrDuKr2jva5CcW7Iz/ ALSv+z/39T/4qj7S
v+z/AN/U/wDiqUeJdBaC7nGt6aYbNglzILtNsDE4Ac5wpzxzSxeI9DmRni1n TpFWEzsVukIEYAJc
8/dAZeenI9afOyuVDftK/wCz/wB/U/8AiqPtK/7P/f1P/iqz7/xlawGyfTUi 1SC7XMctrcoVY+dH
FhT90nMnqBlccdRLp/ir7XNeLdaLqGmwWeRc3V7LbCKIhQ2CUmY/dYHOMe9H NLcOVFv7Sv8As/8A
f1P/AIqj7Sv+z/39T/4qo7nxHamysp9Kkt9Sa/n8i1MM4MbkZLHeoYAKFYng 9MdTVu91rStOure1
vtTs7W4uTiCKedUeU5xhQTluSBx60c0hWRB9pX/Z/wC/qf8AxVH2lf8AZ/7+ p/8AFU+XxBosEdzJ
LrGnxpa4+0M9ygEOSVG85+XJBHPcEVHP4k0yKzsruGc3ltezpBBNZqZoyzNt BLrlVGe5I9Bk8Uc0
h8qF+0r/ALP/AH9T/wCKo+0r/s/9/U/+KrVqje61pWnXVva32p2drcXJxBFP OqPKc4woJy3JA49a
OZhyog+0r/s/9/U/+Ko+0r/s/wDf1P8A4qny+INFgjuZJdY0+NLXH2hnuUAh ySo3nPy5II57giql
94ptraxjv7K0udV09o3me7094pIo0XqxJcbu/CbjweKOdhyosfaV/wBn/v6n /wAVR9pX/Z/7+p/8
VT9K1VtQkvIZYBBPbS7Socsrow3I4JA6g8jHBBHOMm1LfWkJnEt1BGbeMSzB pAPLQ5wzei/K3J44
PpRzSBRT2KX2lf8AZ/7+p/8AFUfaV/2f+/qf/FU6fxBpUM93bLqFpLeWsRmm tEuYxKiAA5ILDaOR
ycDkc1BceJ9Ni1+z0WK7tJr+eQpJbrcL5sKiNn3FBk44A7feFHNIOVEv2lf9 n/v6n/xVH2lf9n/v
6n/xVatYx8S2YktIzDchrm7ktACg+RkYqWbnhSQADzncvHNHMw5VuSfaV/2f +/qf/FUfaV/2f+/q
f/FVFH4p0opNJdXEdjFEzAyXc0cYbDOuR82QP3bEEgZH0OI9Z8X6Lo+jDUW1 KwcTQtLaIbtF+1YH
SM5+bOR0z1FHNIOVFn7Sv+z/AN/U/wDiqPtK/wCz/wB/U/8Aiql/t3SBeT2b apYi7t4/NngNwm+J
ODuZc5Ucjk+oqyt7aNK0S3UJkWTyigkGQ+3dtx67fmx1xzRzSDlRR+0r/s/9 /U/+Ko+0r/s/9/U/
+KrVoo5mHKjK+0r/ALP/AH9T/wCKo+0r/s/9/U/+KrVoo5mHKjK+0r/s/wDf 1P8A4qj7Sv8As/8A
f1P/AIqtWs7VTtUNhSVRiNyg4+ZB3pObDlRH9pX/AGf+/qf/ABVVrzV7axFv 5wY/aLiO2jCMrHe7
BRnB4HOSfb8Kx4vEFlNq8+kx3Vo2oQRrLLbhE3qrdCRj6fTK5+8M8vfyvL41 Jc5xqGlgADAA8x+g
7UlUYciPVfs7+q0fZ39VqzRVc7FyorfZ39Vo+zv6rVmijnYcqK32d/VaPs7+ q1Zoo52HKit9nf1W
irNFHOw5UFFFFSUFFFRzyNFBJIkLzMqkiOMgM59BuIGfqQKAMiDwlo9tf2t9 FFdLc23meXJ9tnJP
mNvcNl/nBbBw2eg9BVy10XT7LV7/AFW3t9l7qAjFzLvY+ZsGF4JwMA9gKzIP Fsdz/Zoi0nUS9+0g
SM+SGjEZwxceZwB7Z9OpALtO8YafqOuPpCxvFdqH+UzwSZ2HDAiORip/3gPz p8r2NHTnq7Etj4U0
zTtRN/bvqRuD94zapcyq/BA3K8hVsAnGQcdqfaeGNNsLwXNqb6MqWKwjUbjy FznIEO/ywOeAFwO2
MVV07xbHqV9JaR6PqqNBP9nuHeJCkD9QGKuc9uV3YyM4zXRE4BOM+1DViZRl F2kYtr4U0qze0eEX
2bSR5Yd+oXDgM/3iQzkNnnhsjk+prP0vwYNN8RjUvtatbQh1tLZfOPkq3G0G SZ1VcfwoiDhewAq7
ofiC71iWRZfD2oWMaSSx+dNLbsmUcrj5JC2eP7uOvJ4J2pZBDC8rdEUseQOn uePzpbak26GYnhrS
k1R9REMpuGZnG65lKRuwwzpGW2IxBOWUA8nnk5ZbeFtLtDYeSL0fYGdrcNqE 7gFuu7Lnf3+9nGeK
xdJ+Jekavqlvp8EO2Wdtqn+0rCTn/djuGY/gpNdkThSQCSB0HejbUN2RXf8A x5z/APXNv5UW3+qb
/ro//oRrBtPFdrq0QiWzvLf7RFMInnCbWePIdPlY8j8vQ5BFb1t/qm/66P8A +hGhqzKlFx0Zy2ve
Erq91WS+sJoQbjBmSZmUKwUKGXAOeABg46da6DSdLTSdHi0+NzIEDZdx95mJ Zjj3JPFGoa1p+lyJ
Hd3Gx3GQqozkD1O0HA9zxV2ORJY1kjdXRwGVlOQQehBqOWN2YQhBTbjucHp3 hXXrCO3kSPTwLF4j
Z6e968sQCq6sPOaLzFH7zKqfMCkYBAOBpSeHdQudM1RpYtPjv7y9gvRGHaSI mIRYR22KSCYyM7eA
QcHpXWVUutTtbKUxTO/meS8+yOJnYomAxAUEk/MOByc8Crv1/rv+htu7nIL4 Q1afVBqdy9lFNNdf
aJoIpndI8SW5wjFBuysBJJA+ZvxrVv8Aw9d3NnqyRtbNLcX8V7AkuSjeWIiF fjjJjIyM4yDg9K2t
M1K21fTob+zMrW067o2lheIkeu1wGAPbjkc9Kkgu4LmW4jhfc9vJ5UowRtba Gxz14YHj1p6r3e3/
AAP8kLzOTXTNT0u5h1q6gR5ZNSee6tbMvOIY3iEWU+VWcgqjH5R1bjjl3jDw 3rOvTyR2syG0ktvL
RX1Ca2EMmTlikS4mB+UYc4G3gHJz2NFLt5B38zidR0u50LRbK6igiuLiz1Sa 88hIZpFl80ygZ8qJ
3DASZ3bDyMd80lvYa9d+DbFbews0vHvvtskN1cyRBF+0GYAHyi2SMDDKpGeQ CMV0V94gs9Oe9WdZ
c2kUUrBVB3+YzKiLzyxZcY45IqTSdXTVY582txaXFvJ5c9tcbPMjOARnYzKQ QQQQSOfUEUL/AIIP
+v6+YunXF/cXN/8Aa4EhgjmEduADucBFLMSeo3FgOBwPeue8YeG9Z16eSO1m Q2klt5aK+oTWwhky
csUiXEwPyjDnA28A5Oexpk0qwQvK4cqgLEIhdvwUAkn2FHZh5HGajpdzoWi2 V1FBFcXFnqk155CQ
zSLL5plAz5UTuGAkzu2HkY75qvbaf4nvPD+nxpp9gLWeWe5vLO5vJYGffKzo m7yWOzDZZSqseAcD
cp7S5v4rS5soJFctdymKMqBgEIz8+2FNWqEBhaIs9zq2qalNbPbrJ5dtGrqV 3CMNuYBgDjc7AEgZ
Cgjgil1rQ5NTv7WaJ41iI8m8V8/vIdwfaB0Jyu3n+F2+ht/29pm62X7UM3Nx JawjY3zSoWDL04wU
YZPH5ip7PUbbUPM+zM7iNmRmMTKuVZkIBIAOGU9PY9CMvzC1lZ/1/X6HGX/g 7V7yOaxU6fHaJNeX
MFwsjiWV51cbJE2YAHmnLBmzsXgdtCx0DVrXVbVGTTxp9rf3F4JklfzpfNEn DJswCDJjO45Azx0r
o9RvotM025vpldoreNpXCAFiAMnGe9WgcgGhMHqVP7NgOpjUPMuvPCbNv2qX ysf9ct2zPvtz71gX
nhu+kvtXubeW2PmhZrBJGYBJxsZt+B90tFGeMnlq6qikByFt4Qnt9Z0u6LWz wWUcCkNncWSOdSwG
MZJlB/P8aM/hHWoYdSisl0yQalBLBJJNK6NADNNIpUBDuyJeRlcEZy2a72in fW4HFL4Rvp7pbO7W
xGlxXF3cCaJ286fz1cFHQrtAHmtltxzsXgZ4t6N4avrO/s7u9ngkcI0tzsJw bj5wCvAyNsjLk8/K
vHp1VFJMHqFFFFABRRRQAVz/AIo1nTtHhiOoXkVv5yssYc8sQyE4H+e3rXQV TvuPLP15/I/09e3b
G5UwPGbTTvhxY6umrW0wTUEkMouDe3BcsepJLfNnJznOcnOc1ZW+tdR8VG5s 50mhbUtLAdTxkSPm
vUuntj8Mfy9Pbp2x8nO+KuJdCH/UXteP+2ij+np27Y2qhnc0UUVQgooooAKK KKACiiigAooooAKK
KjnmW3gkmcOVRSxCIXbA9FUEk+wGaA3M+10G0tdUvL9XlZ7kEeWxGyLPL7MA EbiATknkdqoWHg+D
T7jT5IdU1App6slvE3lbFjIAKECMZHA5Pze9WY/FekTR2LxyXTLfsy22LGf5 yOv8HHrk44BPQVYt
tdsbu++xIbmO4wxVbi0lhDheu0uoDYyOmar3kat1Fe/9dBNL0YaVc3kqX93O l1M0zRTCPajt1K7U
B9ByT0rTrDtPGGh3t6LOC6lNx5nlMj2sqGNznCvuUbCcHAbGe2a3KTv1JmpK XvqzMe20AWuqteLq
eoNAZHmSxMirCjvnc3yqHbkscMzKCcgcDGxWNB4p0i51WPTY5p/tErOkRa0l WOUoCW2SFQjYAPQm
th2CIzHOFGTgEn8h1pX0I6i0hGVIBIJHUdqxrTxRp97dR20Vvq6vIcAzaPdx IPq7xhR+JFbJO1ST
nAGeBmgDmU8JRWEFs66rqEv2Hz5I1k8nDGQHcGxGDjk9Mda6G2/1Tf8AXR// AEI1lQ+JNK1WF4bS
4dnkhkZA8Eke7bwwBZQNw7r1HpWrbf6pv+uj/wDoRpu99S5uV/e3OP8AEHh/ Vn1ue9sFa4jutpKr
IqGJlULzuP3eM8c5J4710eh6bJpOhQWMkollQMWZSQMsxYgewzgewq3dX9nZ eX9ru4LfzDtTzZAm
4+gz1qxWfIrt9znhTjGbktzyNPBepnS3t00W4hsxPE08RSyN5eALJuMhJaCb DOpDSKjHGTlgCdy3
8NnT30S8Xw7d35tLS4hUXIs/tNszOGT7rLGFADKNh+UEDGM49AqC4vrSzDG5 uoIAsbSsZZAuEXG5
jnsMjJ6DNW9f68rG17s8+i8I3OoaJM9/oe3UItHt7ezW4eJniuI/MG5CrEKc lSGBBwRyOQGa74Pu
Li+1Mw6GxjuL9Lqaa0W0L3cPkhTGRMCrFZPnKyDb/EG3YrvtN1fTNZgafS9R tL6FG2NJazrKobrg
lSeeRV2nJ3dxLQ4XQfBdtulGo6bcNbmxS3g/tDyGliy029QIvkTCyADaANpA 7EVDqXh/V7zRH+3a
f9tnmliguESO2mla3hVgjIJz5WWkJf5s4VzxuHHexTRTpvhkSRNxXcjAjIOC OO4II/Co7q7gsolk
uH2I0iRA4JyzMFUcepIFJ6v1BaHnNlomp6HpH2m/tH+z2b2rlWaNmEUVxKx4 j+UbI3RsAAcYA4wO
s0C7t9W1nVtUsJknsJBDBFPEwaOVkDFmVhwR84XI7qR2raa7gS+js2fFxJG0 qpg8qpUE56dWX86b
fahbabbefdSFELqi7UZ2ZmOAAqgkkk9AKd7/AD/4b9BWRi6/os99qCNbRBob 6L7HqB3AfuQ27J7n
jzE4/wCeuegNctqHhXU57m+Fvovl3zteNLqnmxH7bFIriKHO7fwWj4YBV8rg 9K9MopJ2KucHp/h6
4h8VWt3L4fUXUV/cTT6wzxMZoXSQIoO7zMAMi7SABt4yBmux+xz/ANpi7/tK 68jZt+x7YvKz/ezs
35/4Fj2qxJLHCoaWRUUsFBY4GScAfUkgfjUNlqFtqCzG2kLeTK0MisjIyOvU EMAR2I9QQRkEGj9B
eZy17ouqDUNVnhtvNihYXWnosqqZZSY3dOT8vzRdTgfvD6GqY8HTz6tpq39i l1YpFB9q8xlZXcR3
G/cpPzDfIvBBBz7Gu+pk00VvC800iRRICzu7BVUDqST0FC0Vv6/r/JB/X9f1 1PMb/wAH3Zsri0k8
NJqKm2mh03LwlLA+dKykB2GzKNFgoCRsAOABV0eErq71eaOXSfs8ssl39r1f zI2+1wSK4jiyG8z5
d0fBAVfK4PSu9mvILea2hlk2vcuY4hgncwUsR7cKTz6VPR/wfxC+v9f1/Whx 2i6Lqqapa3l/B5fn
Fr25UOp8u42tGFODz+7dRkcfu/pXY1X+32f7r/S4P30jRR/vB87jOVHqRtbI 68H0pYL21upJI7e5
hmeM4dY5AxU5K8gdOVYfVSO1Nu4WJ6Khu7uCws5ru5fZBChkkbBOFAyTgc1M DkZpAFFFFABRRRQA
UUUUAFU77jyz9efyP9PXt2xuW5VO+48s/Xn8j/T17dsblTAqdPbH4Y/l6e3T tj5Od8VcS6EP+ova
8f8AbRR/T07dsbV6Lp7Y/DH8vT26dsfJzviriXQh/wBRe14/7aKP6enbtjaq GdzRRRVCCiiigAoo
ooAKKKKACiqVnqSXl3fWwhliks5RG3mbcOCoYMuCeCD3weDxV2gAooooAxLL w6tprFxem53REOLW
ER4Nv5hDSYbJzuYAjgY6c1k6T4Hl0nVrG/jvbEy2wdJJF0/bLcq2MtJJ5hLP kZ3dOT8tdjRTUmjT
2s9ddzH0XR7rSrrUXlu7eaK8uWuQsdsY2VmwOW3ndwAOg/pWrLLHBE8srrHG ilndzgKByST2FPop
XJcuZ3Z59o+mxadry6revZrOm97ia10U2c7q/SS5k8whkOc42j5hk7fLcL6A 6LIjI6hlYYKkZBHp
S0U3a1hzlBu8Vb5mLaeD/DNhdR3Vn4c0i3uIjujlhso0dD6ghcitk52naQDj gkZpaKRByFv4Vv7C
CyZ9TtZEsTcyFUsmQyebkkZ8w4wSeea6m2/1Tf8AXR//AEI0Xf8Ax5z/APXN v5UW3+qb/ro//oRo
buypTctWcP4msdVTXp7hLea6t7hFWIxwmXYAAChA+6M5bJ4O7rXU6BaXdj4e tra9bNwiHIBzsBJK
rnvtBC/hWrRUKCTb7mEKSjNyPI0XxA2lvHFPrZg8+L7ZfSwX5eQFZCdttvWW PDGMHyHKng4AytWN
X0q6m0qxllk1jUJzpd5bwzx215FmQspjWWEsXxtBGZM7toJJOK9UorS/X+tr f8MbN6/1/XqeeanB
4htl1jzDI+qzw26x3mn2Ugha1STLgKHLiUCSTKiQMwKlDuBxmTx6rFpNqE1L XdQVZJjHbpY6lZl2
IQKplLPKmCWYGXdG24jjaCPVqKE/6/r+riPOZftVxqWkW14PEUEwuppZJ4ft nllBcN5cTeX+7G7j
LPwEHYEEYzDWJ5ZZbhNa+xzNFNc28drfs1s63MTFUaRmLkKX+aFVBAJA4GPX 6KS0af8AX9f13uHl
dxa68EuZtMGrC02yraS3Mc8lwluZLYuCHZZc8TFRuD4Hy4OK09ISW3/sJ76+ u723XU5Fje6srm3M
LtCwQEXLtIwyWAYsRlwB0Fd9LLHBE8ssixxopZ3c4CgdST2FVIptK8QaZvhl s9SsJf4kZZonwfbI
OCPzFNPSwPY47x5Jq7agi6aL+GSC3823e2hu5hcSZJKEQusS42jmUMDuwBwQ VntL6HS4rm9l15oZ
9TmF8LeW4aZYA8vlCNI/nVcmPJjAYrjJKiu+qrqGmWGrWptdSsra8tyQxiuY lkTI6HDAil0sHU4N
prabwXpN1La6jfNDq2+2kezuLq4iRLk5JyrSKRGCPmwe3Xiuo0h0m8Ta5NB/ qcW6P8pH70IS2ffa
0YrXjFpYRW1pEILePAighXCDAGQqr7AHgdhTre1t7OMx20EUEZdnKxIFBZjl jgdySST3Jp9/67f5
CsYOvwaj/aCJZSXflajF9kkaJmxbENnzQeiHYZBu7sEHpXLah/bgub4Wn9vf 2puvPtG7z/s/2fa/
k+Tj91vz5ONnz/e3d69MooWhR5/ZwXE3i2xluotbkv4dQuDO0vn/AGSOEpKI ig/1P3dgyvzZJ3HJ
Ndr5eo/2mJBdWv8AZ+zBg+zN5u718zfjHts/GrE00VvC800iRRICzu7BVUDq ST0FPpdELqcJe2N3
BqWoutjO0GmTG/tTFCWMpkZJHVPV8rMMDP8ArB61BBpWqvqWm2Uz6nDZyJFJ dm2kkiUuyXLSDcuN
vzlMkEHO3npXoVFC2t/X9bfcD11/r+t/vPK9UtNQk0y7stQTxFcBbWaLTkgN ywdxLKP3zJ975BFj
zSQw6ZJNaAt9Yu9Wmtoptbg1GWS7S6lkaZbZLcq4hMR/1QYHycbPn+9u716J RR/wRnHaK+tXOqWs
12t7DBdFr1o5NwEWFaMRMDwuQYm2+oY9cmuxooptiCiiikAUUUUAFU77jyz9 efyP9PXt2xuW5VO+
48s/Xn8j/T17dsblTAqdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xt Xountj8Mfy9Pbp2x
8nO+KuJdCH/UXteP+2ij+np27Y2qhnc0UUVQgooooAKKKKACiiigDG020nGv 6vfzwSQrIyRQ7pBi
RFUZfapI5JIBYbsDHQCtmiqOn6vZ6nNdQ2xnElq4SVJraSEgnoRvUbgccEZB 9aF2AvUUUUAFFRpN
FJGzxurqpZSUO7BBwRx3BBGKyrbxTpV22niJrzOoM6W2+wnTcUyWzuQbeAT8 2M4OM0eQGzRRVHT9
Xs9TmuobYziS1cJKk1tJCQT0I3qNwOOCMg+tAF6iqOn6vZ6nNdQ2xnElq4SV JraSEgnoRvUbgccE
ZB9avUAFFFFAEN3/AMec/wD1zb+VFt/qm/66P/6EaLv/AI85/wDrm38qLb/V N/10f/0I0uoHn/jC
WePX5BqEata4X7EZM7fujdt/292ffGO1djoDX/8Awj1s2ohhdbCTvGWC5O3d 33bdue+c1q0VKhZt
33MYUuWblfc8jTxhrLaW5j8QW87GeJbnUBcW4s7YMsjfu5lhYx5KopWaMkZx k7g1asKrrGp+HTru
sWV3DdWdzCVheC4tb4iWMqhZogHYqASFC8ocAAGvR6K06/12sbPXY8re0s/D fh1L/RNP06xvTeag
vnxWUW4BBcFBnbnA2j8OOlaF3q3iTS5LxodTk1F4J57eK3lto/3hFr56k+Wo YsG+UbcZXjBb5q9E
opB1PL7HxNqT6fuuvF2mfYXuo0m1G0vILqSzUo5IdvIjjjDMqKC6N95hnJGJ o/G1zbaNftf6rFHc
NYGTTHkVFa7KvMolQYw5ZViYgAgbgcAGvSqKdwPN7nyhqeuWl1q0zpNrFoZ7 J/LAWJvJw2AoYqzY
TJJBAI65NdZpYVPFGupDjyj5EjgHpMUIb8dqx1q3lnb39nNaXUQlgmUo6HuD /L61DpmlWmkWzQWa
SBXcyO8szyu7HuzuSzHAA5J4AHQUlorf10/yE1rf+upk6/falZaglvbXBUaj F9ntT5at5E4blxxz
8hZsHI/de5rk9W8SX+/UYRqyXNz/AKbHc6Q8ERFpCiv5cpUrvO7bHyxKt5vA 6V6fRTWhR55a6m2o
eMNNW51xpLuLUriNtJVYlW2RY5QjEbfMyygHLNtO7IGMY7jzNR/tMRi1tf7P 2ZM/2lvN3enl7MY9
9/4VbopdhdTzy9ZbPUrxXzHDoN02pF2zgJKyuW75+Vrkfh0qGxfUo9WsbC2u /wCz3v0imuZIoI2k
BlW6mYAurfxAYzkDnjk16TRQtrf1/WwPX+v68/vPKNa1y7uNGvrHU/Eb2nl2 c6wKI4VfUnWWWNgd
yHOFRMiMKRvJ4BGNIa7q9zq01nZa1v1OSS7hfS/Ki/0KNFfypsbd/JWPlmKt 5vAHGPRaKP8Ag/1/
X4D6/wBf1/WtzjtF1/UdU1S1Hm/6LeFryEFFH+jhWTaOM/e8p8nn58dOK7Gi imxBRRRSAKKKKACi
iigAooooAKp33Hln68/kf6evbtjctyqd9x5Z+vP5H+nr27Y3KmBU6e2Pwx/L 09unbHyc74q4l0If
9Re14/7aKP6enbtjavRdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xt VDO5oooqhBRRRQAU
UUUAFFFFAHm3hnQdW0zxZDqMmi3cBnEo1CRBYxwNIx3blEWJXQMDgyEsNw45 YjoNLudVk8Rag83h
7UrKG8WNUuZZLZljKK3LBJmbkkYwD74rqaKOlg63PNfCXhG40XX7Seay1pLm MOlxeAacsFydpBZ2
jCzyAn5hvBO7BPIJrR8N6BaR65dXE/g2509zO01tcSvblIQVAKoscrFC3zFg qgN/Fmu5op31uD1O
M0DQodC1idLPwbaW7CWdzqcS28e6JmLKibTvJ5VdrBVG088AGnpGiXlrd6Nd f2RrMVwXn+0G41FZ
o7bcGAYRmdkGd3Hlg4GRx0rv6qWOq6dqZmFhf2t2YH8ubyJlk8tv7rYPB9jS 3B9zgPCXhG40XX7S
eay1pLmMOlxeAacsFydpBZ2jCzyAn5hvBO7BPIJrotIutTbxLfS3HhvUrS3u xGFnlltiqbFbO4JM
zcnAGAevOK6iincDl9KutUk8SX8k/h3UrOC7WMJcTS2zLHsVuWCTM3JxjAPv is/RNEe21WxkHhmW
xv4Wb7bq5eA/bBtIbLLIZH3NtYB1GMZ4IAruKY00SzJC0iCVwSiFhuYDGSB3 xkfmKS0AJYxNC8Td
HUqeAevsePzrj9J+GmkaRqlvqEE26WBtyj+zbCPn/ejt1YfgwNdYt5avNPCt zC0tuAZkDgtFkZG4
dsjnmn29xBd28dxbTRzQSDckkbBlYeoI4Ip8rWtge1ht3/x5z/8AXNv5UW3+ qb/ro/8A6EaLv/jz
n/65t/Ki2/1Tf9dH/wDQjU9QOH8Tavepr09q8tzbwwKrQ+TKYt4IBLkj73OV wcgbfU11Xh++ur7w
9a3d4m2Z0JORt3AEhW9twAP41curCzvvL+12kFx5Zynmxh9p9RnpVipUWm3c xhTlGbk3ocBp/ibW
brULS21NrS1unff5XkSoIFaGZgS4lMdwnyD5lIHXKo2MQnxR4vMdnDBa2l3P fedPayQ2YTdbpsAY
xSXSfeL5BDkhcZXJO3sbfw1oNpbyQW2iabDDISzxx2iKrEqVJIAwcqSPoSKj /wCES8N/2f8AYP8A
hH9K+xeZ532f7FH5e/GN23GN2OM9at7/ANf1/Wpv1MIaX9p8S6dNeNq9rNcW Mt3cWaavcbEmVovl
CrJswNzDA+U+lZ1x4u1g6XDLcXNlFDqVol3HcWaEGwiM0aOXZiyuQsuQ21QC jZGOnfxWdrB5PlW0
Mfkx+VFsQDYnHyr6DgcD0FQW2jaXZS3UtpptnBJdnNy8UCqZjzy5A+bqevqa eny/4f8A4H3CRg3U
R8PSWtlo1+/2rUZ0hDapeTXiQgJI+4K8m4lghUAMoJ57HOWni3xBc2V9dQDT I002282cPBI32hlk
mRtmHGxW8rKk7sbuh611MXhXw7BYz2MOg6XHaXBBmgSzjEchHQsoGDjtmria Xp8dubeOxtlhMSwG
NYVCmNchUxjG0ZOB0GTQBxF3r3iHTtQ1NLSSC+a41ZbS1h8jLQf6Osn8c6Kw wMbcpyS2T92p38R+
K0tLyWe1sLKTT7JLq4gniLvL80oIGyUrHlYwR8z7d2DuxXV3Wg6PfNO15pNj cNcIqTGa3RzKqnKh
sjkA8gHpTrfRtLtLRrW202zhtmj8poY4FVCmSdpAGMZZuPc+tJbWBnH3UupX Umt2l1qUTWE+rwWf
lrGyvFG6xFk3FyMMrbcADlie+K3dAtLfSdZ1bS7CFILCMQzxQRKFjiZwwZVU cAfIGwO7E96vX+ga
ZqKXRltIknuUVHuYkVZvlOUO/GcqQCM9CKdpOkJpUc+bq4u7i4k8ye5uNnmS HAAzsVVAAAAAAHHq
SaForf10/wAr/MT3v/X9dCjrWs32mXjW8SQMbmALYl1P/HxvC7XweV+dGwMH Cvz6c9qnizVYbS5u
W+xPZzSXlrDBCsizRPCrne8gccHyzkAKV3r8xxz3klvDNJFJLDG7wtviZlBK NgjIPY4JGR2JqodD
0hr24vW0qxN3cx+VPObdN8qcfKzYyw4HB9BTWm5RyyajqOp+ItGuZ57FLH+0 7mCG1SJjMDHHMhZp
C+DnaTtCDGRycc9b9sn/ALTFp/Zt15Gzd9s3ReVn+7jfvz/wHHvTE0XSotSf Uo9Mskv3IL3SwKJW
IG0ZfGTxx16VepdELqcLcahdW+pPbm9uAuk3r3NyWlIDQyOhUMT1RUlkwOn7 odxUFlrGtLf2lnay
QifUFjmMt6ZZhEJRcygBN6j5diqANvHGeBjuJdPsp/tHnWdvJ9pQRz74lPmo MgK2R8w5PB9TS/YL
MTpOLSDzkACSeWNygAgYPbAZh/wI+tC2s/6/r/MH/X9feefavr+tat4d1a1M +mWwtLGQ3jtA7Gf9
5LF+7HmDywfKJyS/LAdsnRfxRrm8y266fLDcTXdpa2qxuZY5IVchpH3YIJjI KhQRvXk456e58P6L
ePE91pFhO0JcxmW2Rihc5fGRxk9cdalj0jTIdTl1OLTrRL+Vdkl0sCiV144L 4yRwOM9hR/wR9TC0
vxPc6nqcUEcUJt55S8LgHm3CupOc8t5iDkcbXX611NV4bCztjCYLSCIwx+VF sjC+WnHyrjoOBwOO
BVim7dBBRRRSAKKKKACiiigAqnfceWfrz+R/p69u2Ny3Kp33Hln68/kf6evb tjcqYFTp7Y/DH8vT
26dsfJzviriXQh/1F7Xj/too/p6du2Nq9F09sfhj+Xp7dO2Pk53xVxLoQ/6i 9rx/20Uf09O3bG1U
M7miiiqEFFFFABRRRQAUUUUAFFFFABRRRQB5t4ZutWj8WQyXJ1YQ3gl+020t lemK2kJ3KnmzOyED
5gGjRVOOvKg7uk61Fc+J9TENpqcZuliEElxpdzFGSitnLtGAB9SM9s11lFHS wdbnmvhKHWbfX7T+
0dZ1Jrkh1vbeXSr/AMqR9pziWSV4FAYZBjCg4wMA4rR8Nx291rl0ftfikGOd ntY7xLyOFY9oDDdI
oD5JOA5YjHy7a7minfUGcV4as7XStZms0tfED3f2i4LPPPdPapGzllfdK/lM SCo+Xc+Scj7xGvFu
/wCE+u/O6f2ZF9mz/wBdJPNx/wCQs/8AAa3qY0MTTJM0aGVAQjlRuUHGQD2z gfkKL7A9b+f+dyrB
p1tZ6jfaim/zrsJ5vfhAQMADPQmuW0UG1m0yeI60ZruSdZUuIbkRIvJUGMqE jAO3DYBIzyea7ait
4YhxTUtb/oml/XkB53okWrQ3yfbtV1BrgxyLdwSabeeXI2w5xK8jQqNwyCgU HGBgHFd9bf6pv+uj
/wDoRou/+POf/rm38qLb/VN/10f/ANCNLE13Xnztfl+iX9dQOQ1/xJeQ61PY 2072q2u3JWJXMpZQ
2TuB+XnHGDkHmuj0LU21bRLe/eLY8gYFV6EqxXIz2OMj2NLqOhabq0iSXtsJ HQbQwdkJHodpGR7H
iryRRxxLEiKsartVFGAB0wB6VypSu3cxhCam3J6HCt4z1jUNMeSy0+ytbyO7 tUNrPeMsyJJLt2zR
tDuiYjHZgQ2VY4GbV344u7GCS7uNGj+xk3EVu6XmZJZoVdmUrsAVT5cmG3E8 DKjPGvH4Q0aOymtP
JuXjm2ZaW9mkkXYdybHZyybTyNpGDyKr3vgjSbm3vhAssE91DLFvM8rpG0i4 Z1jL7Q57sAGOTk8n
OmhvpcoX+v6rcG40Se1j06/ke2CTW10ZQIZnZSwYopVwEfjBAJU5PONXQkew 1TU9I+0XE8EHlTwG
4meZ0WQMCpdyWb5kYjJJw2OgFJJ4R08aXcWls9xHPK0ci3c9xJcSrJGQ0Z3S MWIVhnbnHJ9TVvR9
MuLE3VxfXaXd9dSB5ZYoTEgAAVVVCzEAAd2OSSe+Aaf18v8Agku5Dquuvplz NAbPzGNsJbX95jz5
N4Ty+ny/M0fPP3zxxzi6l40ura3uJn07ybFzcwWtzHdAzNLCrk5QxlVU+W+D lugyozx1V1p1pez2
s1xCJJLWTzYSSflbBGffr374PUCs5/COiS3VzcPaOWuRIJE+0SeWC4w7LHu2 ozc5ZQCcnnk0LzK/
r+v6+4y/7c1PUNf0kx2qW+lG/ngEv2s+bMY45Qd0QTaF3KSPnJ4BwO3Sf2lA NTGn+XdeeU37vssv
lY/667dmfbdn2qnD4Y0mDVRqUdvKLgStMo+0SGNHYEMyxltik7jkgDJOTzzW vS7C6nHSa3qUd/Ha
/adxtNQkF5iJfmhZ0Ean+7hZ0bPBPln1NQWfinVPtMFvHbfbri+CyQLNOsMc aSefImSqE8JGqk/M
enGc56a50DTLttQae13NqEIguSHYF0AIA4PHU8jB/IU5dD01L2C8W2AngVFj YO3yhVdVGM44Ejj8
fYULaz/r+v8AMH/X9ff+ByWreLNWvtA1FNP02KG4t7OR7yVr4p5BDyR/uisZ MhzE5GQnG3nJOL03
jK7gLy/2Or2bvcQWji6/ezSwq7EMmzCK3lvhtxPAyBnjSuvB2h3mfOtJcMHV xHdSxiQOzOQ4VgHG
5mIDZAycYqe38NaTbao+ow2zrcOXbBnkMas33mWMtsVm7sACcnJ5OT/g/wBf 1+I+v9f1/XQq2Xih
L7U/scVrkNOUSQSZ3RhXzJ04+eNkx9DnnFdBWdZaFpunG1NrbCM2sBt4fnY7 UJBI5PJyOpyevPJr
Rpu3QQUUUUgCiiigAooooAKKKKACiiigAooooAKoam2wKxLYVWb5SATyo64P rn8B6VfrN1b/AFR/
65n/ANCSk9gRnfbE/uyj6Oo/9l+n5D0Fcdq2p3F54pgtHbFtbalppiTA4LSM WJIAz0A9gBXS1xt3
/wAjo3/YR0v/ANDapRTPYaKKKskKKKKACiiigAooooAwNIjEHifXo4IY0gd4 pZCvynzigz8oGDkB
SWznPGOMnfqjBpkVo0zWu2JppDNIVjUGSQgAs+MbsgAf/qGL1RBtqzVhtLoF FFFWIKKKKACiiigA
ooooAKKKKAIbv/jzn/65t/Ki2/1Tf9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P /wChGl1A5rWvFU1n
qktjZ/Z1Nvt81rhWO4lQwVcEY4I5564xxW7pGpR6vpUN9EhQSbgVJzhlJUjP cZB571T1bwvYatdC
6keeCbG12gYDzAOgbIPT1GD71qW1pBZ2kdrbRiKCNdqqvYf4+9SlK7uYwVRT bk9Dio/F2rpo+p30
5snvLeze4Gk/ZXgubcg8bvMkHmp1G9QgO35c541P+EvMgkB0vULQwXEME7zx xMqO5j+T5ZeSRIOR
kDBzngGZfCMUsdwmoarqWoiW1e0Q3LRhoY3xuCsiKSTtXltx+Uc9cyx+GIFs Zbae9vLlprmO6kml
MYdnTZj7qBcfu1zgetX/AF+P+RsylF46tJLdJ5NL1SFJrdZ7QSRx7roMyqFQ ByQd0iD59vXOcAkN
m1+81fyNPsoLzSbyW8NtO0whaSBVj81mXBkQkgqBnONxOOKl1PwnDNpFtBaN K1zY2ot7QvOI8FWj
ZXLeW2GBiU/dI6gqQapWPhrXLWwS9lu4rjW0vzeYmmHlupjERjaRIk4KjORG MEDg4yXp/Xrp+G4n
f+vT+rG74furqa1uba9m8+6srh7d5toUyAAMrEAAAlWXOABnOAOlZtxrmoR+ KzYPcWNjaCWOOJLu
2kze7lBPlT7ggcZYCPDN8hPAPGrodhcWNnK160bXlzM9xP5RJRWboqkgEhVC rkgZxnA6VDdeH/tm
pC4m1XUGtfNSY2BMZhLpgqclPMGGVWwHAyOnJydVfyv+v9f0jozK0rxncXjp bXOh36XMktwEKCEp
5cUuwuT5pxjIznBJB2g8U+x8b29zHbs2n37Qs8MM16IkSFJJERlypkLYPmKP lDYPU960LHwzb2Go
S3aXl3IG88JDIyFIhK4dwuFDfeGRuJxkjpjDbXwnp9ppn9npJcND50Ex3spJ MQjCjp0IjXP1PTsl
t/Xf/L8RvyDSPFEWr30dumm39vHPA1xbXFwIwk8YKjcoDlxncpAZVODWlBqu nXV9cWNvf2s15b48
+3jmVpIs9Nyg5H41zfhnw3q2mawbi+uR9htrZrWxthcrP5cZZTjPkRsAAijD GQn1456+npp/X9aB
1Zxv2/WrfwpqusRams08U9w6xXdurRpHFI67EEexuQo+Zi1Wp/HWn22vXGiv bzNexRPIscc9u7S7
U37VQS71JXON6qPfkZZB4a1C6sLjTdRu2tbI3M77LGZX+1xSSM+2XfFlMA4+ Rs8nnpVu08J29pqU
d2moXrQw3ElzDaHyxFG8gbeeEDnO9j8zHHakDF1DxdYWFlc3gikmt7eOGRpR LDEhEudoDyui5AwT
kjhlxnNY83jSa++xXWnXVlYaZPAJFu9Qt3likk3shiM0biOIgqACWYNvG0HH Os3hCzWyhgtry7tZ
YLo3UNzH5bSRsVKAAOjLgIdgyvAA781EfBsf2Q2a63qy2cgdbm33RMtwHdmY NujJGd7AlCpxj0Bp
6X/r+v62DpYkufF0du0zrpGpT2kc4txdxLEUklLiPaqmQOcMcZ244PNQ/wDC YOt5LZro2pXV2Czf
ZYEhDxKqRMwZml2EgyjoeeQAcZNn/hFYhcMV1O/WzNwtyLEeV5SSCQSZBKb+ WBJG7HzHGOMVr3wn
PP4hOo2esXmnrKkpna38ouWYRKAN8bALiLPrnvSX9f16jJdH8UPrOuNBbWMz aa9jBdw3nyKP3m44
YF938IAG3ghs9qs22uN/wj13qt1EpFvJcBljZUyscjqOZGCjhcklgOvSn2Ph 200y+huLGWeCKO1S
0NspUxuiZ2E5BbI3NyCM55zxVFvByvBc2za1qTWssxuI4CtuVgl83zQ6Hysk hugYsOeQacrdBLz/
AK0K1l8QrDU7eN9N02/vpnEpMNq9vJt8spuy4l8s8SKRhz3HUYqf/hN7N2ie 207Ubi0doUe7RI1j
iaUKUVg7hicOhO1SBn1zi1p3he30++kvWvr26upRIJJbhky28RgnCqoH+qXG AByePTCfwVfw6ra2
9hcmDREe3luFa5VmmaIKATH5GQSI0BKyqOM7eoK/4H/B+VhdH/Xob0nimzjs ILsQzsk1g1+qlo0x
GuzILO4VT846nHB5rPs/H9hqdlFNplhe387vIptrWS3dkEe3cxkEvlY+dOjk /N04OF/4QO0MMcUm
ranKsEQitN5hP2ZVdHXb+7wxUxrgvuJ75qpqfhDUoFFzomoXEmqSSOZry5u4 4nKsiKVwLaRCD5aH
AVcY4IyRQ/L+tdP+CNEsfxL0CTVbPT97LLdCEfPNApjaVVZFMZk8xidy8orK M9eDifxbrOo6eWXT
pFi+y2U1/MzRh9+wAJHjrhiSTjBwuARnNT6V4TbSfsxtdZv4VSOJbiCMRGK4 ZEVNxDozLkKAQrDp
65NSeINAl1e4ieGbYkkEtndLv2kwyYyynaw3qVBGRg5INN2vp5/8D8fw3Bf5 f8EybTxHrMsSQrPB
cXd3OtvbmbQ7uwSI7XdnYSuTIAqHhSvOAWGciS/8Q6x4e1Gyj1mfTJbFlkku 7mGB4fLjBjRWw0jb
cNJ82SRjnjBrRfwvJcWxivdf1W7dJFltp3FukltIucMhjiUEkEghgwIyCME5 lt/DcKymXUL671V2
ikhf7aIiro+zKlURVx8g4x3Oc5o6/wBdv8/+HD1/r+l/wxir4s1e50e8ltrO 3GoPfeRYwSK3KGNZ
RvGc7thYnGOcCtiTUbfVdJtry3cFLi1WZRnkKxQjI/P8jTbrwbouoXz3OoWq XyNK032a6RJIQ5RE
3bSvULGAPTc3rwg0q20TSVsLPcLZBI0aHGIw0itsXAGFGcAdgBUvb7vy1DqU K427/wCR0b/sI6X/
AOhtXZVxt3/yOjf9hHS//Q2qUUz2GiiirJCiiigAooooAKKKKACiiigAoooo AKKKKACiiigAoooo
AKKKKAIbv/jzn/65t/Ki2/1Tf9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P/wCh Gl1AxdW8UJYX7Wdt
bLcSRY87dN5YTIyAODlsEHHAwRzWtp9/BqdhFeWxJikBwCMEEHBB9wQR+FYm teEI9U1A3sF19mlk
AE2YvMD4GARyMHGB3HA4ra0/T4NL06KxtdyxRKQCTkkk5JPuSSfxqVzXd9jG HtOd82xhaN4tbUrC
XVbm2tINJAyJ4bszyRnIGyaMIPLYbuQCwXByRjJu3vi3RrC7ltZp52uIywaK C0mmb5QhbARTnAkT
JHTPPQ1RTwzcvdXd9rE9nqUz2D2W22s/szzRtglZGMjBjxx90Dc3HPEmheGp bC30+a5uS93HaSx3
Jb5jJLKyO7buOhUjp0x0xir/AK/P+vmb6XJY/F9hJqtxZpFdyxRWcV2k8FpN MsiPuPGxCDwBjBJO
SAODU8XinR5Uhc3MkIlaRB9ot5ISrIu5lYOoKHb82GwSASMgVkXHgq5eyW0g 1WJYTY29pMktqXWU
wkkEgSL8jBmDIc5Bxkc5gj+HkZ0iTS5rq1is5bo3jxWFiLdVlCII9g3MFCsu /HO44BONwZu13/X9
aCXT+un+Y5PHyT6++nwnRYo1ljRVvtUa3upAyK+VtzCTnDYAJBJHati28YaJ eNaLb3E8hu+bfbZz
fvV+XLL8nKDeuW+6Ocng4r22ieILW7uJE1rTWhu5EluFfTH3FhGiNtYTgKDs yMg4z3q3YeHxZNph
Nz5gsdPayI2Y8zPl/N14/wBX0569eKP6/D/P8wIU8a+H3jlkF64jjK4draVV kDPsVoyVxIpYgbky
ORzyKg1DXNVnuJRocUPl2lot3OLy3kDS7slYVBKmN8KSSwOMr8vWq1v4JuRJ ZG71ZJ005Y4rLba7
GWJZY5CJDvIdj5SDcAoGCdvNWdXg1iy1S9n0uxa8XUbZYQRIiC2mXcA77mBK EMM7ckbOhzSe2m49
L+R0Nrcx3llBdQnMU0ayJ7gjI/nXO6N4tbUrCXVbm2tINJAyJ4bszyRnIGya MIPLYbuQCwXByRjJ
37CzWw0y2so2+W3hWJT7KAM/pXPp4ZuXuru+1iez1KZ7B7LbbWf2Z5o2wSsj GRgx44+6Bubjnhya
TdtiY3aV99C9e+LdGsLuW1mnna4jLBooLSaZvlCFsBFOcCRMkdM89DUUfi+w k1W4s0iu5YorOK7S
eC0mmWRH3HjYhB4AxgknJAHBqLQvDUthb6fNc3Je7jtJY7kt8xkllZHdt3HQ qR06Y6YxVS48FXL2
S2kGqxLCbG3tJkltS6ymEkgkCRfkYMwZDnIOMjnKat6/8P8A8Aa1/r0/4Jrx eKdHlSFzcyQiVpEH
2i3khKsi7mVg6godvzYbBIBIyBWGnj5J9ffT4TosUayxoq32qNb3UgZFfK25 hJzhsAEgkjtTY/h5
GdIk0ua6tYrOW6N48VhYi3VZQiCPYNzBQrLvxzuOATjcG0rbRPEFrd3Eia1p rQ3ciS3Cvpj7iwjR
G2sJwFB2ZGQcZ70f1/X9f8A6Fi28YaJeNaLb3E8hu+bfbZzfvV+XLL8nKDeu W+6Ocng4YnjXw+8c
sgvXEcZXDtbSqsgZ9itGSuJFLEDcmRyOeRU1h4fFk2mE3PmCx09rIjZjzM+X 83Xj/V9OevXism38
E3Iksjd6sk6acscVlttdjLEsschEh3kOx8pBuAUDBO3mnZXsHQ6yCZLm3jnQ SBJFDqJI2RgCM8qw
BU+xAIrL1y81C3uNLttOltopLu5MTyXELSgKI3c4CuvJ24znv0NX7/TrHVbR rXUbK3vLZiCYbiJZ
EJHQ4YEVl65Bcwz6LNYadLdR2l0S8Nu0aFEMToCA7KMAsOAc46CkHQD4hktd Q1K31CxdIrRYnjey
WW7eRJC4BMaR7lI2HIG4c9anj8TaRJaTXK3TCKG2+1SFoXUrHlgeCucgowK4 3AjBAJFYmoeDb/Vv
Om1DU9PuLmR48xPpzG0eNA+FkhM2X5kLZL4yqnHHNix8FxWVlplstyirZyyM 4htxGskbSeaIwoOF
UOE9eFI78NeYPyL194p0+wku4ZI70z28Mk2w2cqLLsXcVjkZQjtgdAx6H0NV 7HxQW0n+0tTis47a
QqLaTTLl78XGc8KFjDMwxyFU8c54OM4eBJU19tWiv7JLlZZpYrn+zg1186uo WSVnO9V3DC4UYUD3
Ey+Eb8Xk2qnUrCPWXljkWaDTmSA7VdPnj80s7FZGG7eDgL/d5S2Av/8ACX6X KzJA8pkSSNJVntZ4
hGXKABiY/lfEikKcE+wBIrXHj3Rl0q8vLRri4aC0N3HGbWaPz4xj5oyyfOuS uSuQMjNSnw3cy2F1
Hc30UlzcXkN47xW5Rd0Yj+UKXYgHy+5OM98Vl6d4O1K60OCDW7+ETR6U1hAl rbbPs4kVQ5YmRxIw
2LgjaODxzw1tr/Wn+Y+p0ba0hbSjFBKU1CUxjzUaJ48Ru+SjKG/gxggdadda 9YWWox2NybmOWTAW
Q2kphyegMoXYCemC2c4HcVV1DSdWvLbTHi1Kyi1GylMrTPZM8UhKMhHliUEc Nn756Vj3vgSbUdZT
Ury906WYSwzGZtOLTI0e3KxSNIfLjJUnaASCx5OTlPfQS2NSHxt4fngknS9k ESQicO9rKglQkAGM
so8zllGEycsB1IFIdZstZtZnszP+5BjkSe2kgdGzGcFZFVuhB6d6o6p4VmXR 7D7NPLLdaXZrFAsU
S5kkR4nVsM6rjMQypYZBPzA81QtfD+r31lPdaxfXenXd1dPK0dmI4vlCIqhh ulA+5nAkI7nHO0a/
r56AX6427/5HRv8AsI6X/wChtXSnweef+Kh1wf8AbePjr/sf4dD0525epeH4 dGvtMnW8vLqa51Wy
V2uWViAkvGMKP7xHPp25AlIbPUKKKKoQUUUUAFFFFABRRRQBymieMpNW11tP fTjHbyCRra7i89o5
VQ9dzwohyCCNjOPfHJ0NHe8j1rV7S51Ce8jiaJ4jMkYMYcElRsVcgY4zk+9Z Fp4V/s6/gvYtNJms
8tHt1S4ZQjDBhiR32rj0ICHYnC5/dPsfDk+l6ib+G1uZLhfnlJ1m6lWdSCBG Fkk2llBblxtOFxt3
Hy3Y3dB30a+9f1/Xkzr6KKKRgFFFFABRRRQAUUUUAFFFFAEN3/x5z/8AXNv5 VWuLv7Bo97eBN/kL
NLt9dpY4/SrN3/x5z/8AXNv5U2KNJrWSKRQyO0ispGQQWORSB7aHmtzc6Qth puo64t5f3WpbnEif
8swDjCjtjPA4rpvBGqT3kF7azG5eK2ZTBJcqQ5jbOAc9cbevuKoXOh6t4ZsZ ZLCc39jbnzLa1Nv5
syOTgAcE4BOSRzjPGayvh7Jrmn61Pa31jqHkXqlmmmtJVCyqCdzM2B8wyCep O2nSoScHO+34nFFu
FRJr+v8Ahzq18Z2o0q51a40++ttMitzcxXk3lCO4j4wVw5Kk5GA4UnP1xeTx Pok4j+y6pY3TSbdq
w3cRJUsq7uW5A3r09RjJIB56Pwpqk1vqcRttM0lbmxlt/JsLiR4JpnwfNaIo ioRg8jcxDck7RVxf
Duoz2V81xHZQXl5qNvduIpWdQsYiBG4opJ/dtjjuOlH9fidrNqHxFolyLkwa xp8otU8y4KXSN5KY
zufB+UY5yan07VdO1e2Nzpl/a3sAYqZbaZZF3DtlSRnkVxuqeFri00HSmRbc nSrBI2iSKSQSyJLD
IFCojMVJiIyFJGQdp6Vs+DpL67tdR1C+svsb3l4ZUi/efdEaJnEiI45Q/eQf iMEuy1/rr+on/X3H
SUUUUhhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA VR1Btuw5UYBYsxIx
yPQZ6kf/AK8EXqzdW/1R/wCuZ/8AQkpPYEVPtEY6Sxe3Lf8AxPsPy7YXbyOv asl5r1hp6R4Fnqdg
xkDcMXkPAGB0Cj8/QCsfT9I8bx+LpPtviXzdAixJHi2hEs2Sf3bYT5cY5YdQ RjBJ2uu/+R0b/sI6
X/6G1JDZ7DRRRVCCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKK KKAIbv8A485/+ubf
yqmt+IA6sEAErqCzHnnPZT61cu/+POf/AK5t/Kuf1MStBMIHRJjNMEZ0LKrY GCQCMjPbI+oqWNFO
e0vLuaSa48QTq5J2LbPJEiDsNoHP1NWfC+v3F94fiuruRJGM0sayOCrMqOVB IUEZwBXEfDyw1yws
NZTxEzyai+qPI0xOVmUxxgMh4+XAwAAMYxgYwNvwl/yJ1p/183X/AKNNJaak qEU7o7P+1o/WL/vp
v/iaP7Wj9Yv++m/+JrCoo5mXY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrCoo5m Fjd/taP1i/76b/4m
j+1o/WL/AL6b/wCJrCoo5mFjd/taP1i/76b/AOJo/taP1i/76b/4msKijmYW N3+1o/WL/vpv/iaP
7Wj9Yv8Avpv/AImsKijmYWN3+1o/WL/vpv8A4mj+1o/WL/vpv/iawqKOZhY3 f7Wj9Yv++m/+Jo/t
aP1i/wC+m/8AiawqKOZhY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrCoo5mFjd/ taP1i/76b/4mj+1o
/WL/AL6b/wCJrCoo5mFjT0rxImqPfhLfYtpdNbE7878KrFugx949fTPrt0Pt 2Osf1+b/AD6H8u2G
28f4PPOu89NVk79P3cfv7e3T2yvS9PbH4Y/l6e3Ttj5HcRb+3Y6x/X5v8+h/ Lthtp9ux1j+vzf59
D+XbDbanT2x+GP5ent07Y+Q6e2Pwx/L09unbHyFwLf27HWP6/N/n0P5dsNtP t2Osf1+b/Pofy7Yb
bU6e2Pwx/L09unbHyHT2x+GP5ent07Y+QuBb+3Y6x/X5v8+h/LthtrW1DbnM ajA3EsxGOQPTPU+n
65ArdPbH4Y/l6e3Ttj5IbjiKQf8ATPp/wJR/T07dsbVLgW/7Wj9Yv++m/wDi a5fWNYv9Y1S40zTL
mKy+xxo0szQ+d5vmZIABK7QNnXvntjnltI0/xDH8TfEF75vlaBL5Q8qVSfOl EMY3R8/LjGC3Q4xg
kZXY07/kbtc/65Wv8npXHYP7O8Q/9DBB/wCC8f8AxdZ82k3VjqdjeXl8l1Nc 6rYKSsHlgBJDjjcf
736V1M00VtCZpmIQED5RlmY9FUd2PYfyAJrC1GeWa80wTORImr2YaBOY4P3n 3d38T/3j9B2wBAz0
+iiirJCiiigAooooAKKKKAKS6pby6gbO3DzyISJmiGUhI7M3TPT5Rluc4xzS m6d9VFpEFKRx+ZOx
HTPCqPc4J+g96x2kbRPEul6XZkLY3wmJgIG2Eou793joCeoOR6AVpaH+8sXu W5luJpHkPqQxUfgA
oH4VTVtTGM3J28x8es2Mt6lokknmyMyoTC4RyuSdrkbTjB6GmprmnyXSW6zO XkcpG3kuEdhnIV8b
T0PQ9q4nwfrEmr+K5I5rSzhkhSSRp7eHy5JjkL+8I+8Oc9OoBq/ouv30vi2T w7ujWzst4R1X946p
wFYnjHPYA8DnrRygqjt8zp4Nc0+4ufs0cshmDbGUwOuw9g2V+XPbOM9s1Jb6 lFcS3aqrgW+NwMUg
c8H+EqM9OMZzXFeDvF1/qviG4sp4bZYpN8xKKwO4ADux44qv4Z8Z6jqXi8W0 0NqqXRKuUVgQEViM
Zajl/IPafnY7i017Tr541t5ZG8zOxmgdVcgZIDFQCRg8ZzwfQ06x1i21CRkh ju1YFhmW1kRflOD8
xXH4ZzXFeGdeu73XbXQplh+y24MqOqkOSFyATnGOfTsPfOtper3b+N7/AEQM q2lvvuAQvzOWwSGJ
7ZcnjB4HPXJyh7R2v5nRWeqW95M9vh4bpBl7eYbXAzjcB0Zf9pSR71drmPC8 jeIbGLWtRCyziR1h
i2jy4NrEZQddxx1JJ64wCRXT0SViqcnJXCiiipNCC+bZYXLbXbbExwilmPB6 Ack+w5rzLVdW1y8v
pZLODWLa2LlkibQZHIz1Jbdz/n6n1SiiwHj32vxL/f1f/wAJ1/8A4qorRtfs bGOzthq6Qxs7gf8A
CPSE5dixOS3v+lezUUrBc8e+1+Jf7+r/APhOv/8AFUfa/Ev9/V//AAnX/wDi q9hoosO5499r8S/3
9X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V//Cdf/wCKo+1+ Jf7+r/8AhOv/APFV
7DRRYLnj32vxL/f1f/wnX/8AiqPtfiX+/q//AITr/wDxVew0UWC5499r8S/3 9X/8J1//AIqj7X4l
/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V//Cdf/wCKo+1+Jf7+r/8AhOv/APFV 7DRRYLnj32vxL/f1
f/wnX/8AiqPtfiX+/q//AITr/wDxVew0UWC5499r8S/39X/8J1//AIqj7X4l /v6v/wCE6/8A8VXs
NFFguePfa/Ev9/V//Cdf/wCKo+1+Jf7+r/8AhOv/APFV7DRRYLnl/h/UrrRr e7WfSdcuprm5Nw0i
6VLGASqjGOf7oPBH6AjX/wCEqkHTw7r3t/xL5P8AD2H5dsLt7miiwrnDf8JV IOnh3Xvb/iXyf4ew
/Lthdp/wlUg6eHde9v8AiXyf4ew/Lthdvc0UWHc4b/hKpB08O697f8S+T/D2 H5dsLtP+EqkHTw7r
3t/xL5P8PYfl2wu3uaKLBc4b/hKpB08O697f8S+T/D2H5dsLtzdW17VbyNE0 /TtZshyJC+jSSlhx
gDkAdB29OgGK9LoosK5499r8S/39X/8ACdf/AOKqbSZr6xvry8vLDW7qa5WN SV0aSMAJuxxk/wB7
9K9boosO55hPqNxNM8w0rX0kB2wsulyfuEP3tv8Atn+/+QHGICbm7vdLt7fS NYigi1K2kRJNPkjj
hjWQEkkjrySzHrjtgCvVqKLCCiiimAUUUUAFFFFABRRRQB//2Q==
------=_NextPart_000_001E_01C8E111.05FFC140--
Re: JSDT - jsDoc not used for code completion? [message #217376 is a reply to message #217128] |
Thu, 10 July 2008 22:52 |
Bob Shields Messages: 7 Registered: July 2009 |
Junior Member |
--------------080400020103050500040806
<html>
<head>
</head>
I have opened bug #240106.
<br>
<br>
Bob Shields<br>
<br>
<blockquote cite="mid:g50j9m$v4t$1@build.eclipse.org" type="cite">
<title></title>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3059" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Hi Bob,</font></div>
<div> </div>
<div><font face="Arial" size="2">I think I understanding your issue a
bit better now. The problem is that even though function parameter 's'
is listed as type "String" in the JsDoc, the inference engine isn't
marking it as String for content completion within the function (it's
of type 'any') . I was under the impression you weren't finding the
type "String" when using code completion.</font></div>
<div> </div>
<div> </div>
<div><font face="Arial" size="2">This isn't necessarily a bug since
it requires some inferencing that s is String from JsDoc and not of
type 'Any'. But I would consider it an uncomfortable missing feature.
Please open a bug report and we can see about doing function parameter
inferencing from JsDoc in the very near future.</font></div>
<div> </div>
<div> </div>
<div><font face="Arial" size="2">-Brad</font></div>
<blockquote dir="ltr"
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Bob Shields" <<a moz-do-not-send="true"
href="mailto:java@resnbl.com">java@resnbl.com</a>> wrote in message
<a moz-do-not-send="true" href="news:g4ni59$mua$1@build.eclipse.org">news:g4ni59$mua$1@build.eclipse.org</a>...</div>
class itself.<br>
<br>
<br>
Bob Shields<br>
<br>
<br>
<blockquote cite="mid:g4b7n1$h6v$1@build.eclipse.org" type="cite">
<pre wrap="">content completion works for me on the string type-- see attached
screenshot. could you give an example/recreate for the other problem you
mentioned?
-brad
"Bob Shields" <a moz-do-not-send="true" class="moz-txt-link-rfc2396E"
href="mailto:java@resnbl.com"><java@resnbl.com></a> wrote in message
<a moz-do-not-send="true" class="moz-txt-link-freetext"
href="news:g49gne$mij$1@build.eclipse.org">news:g49gne$mij$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">On a fresh install of Ganymede with the Javascript Tools added, I entered:
* Demo function
* @param s String
var len = s.
Bob
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<center><img src="cid:part1.06030900.02040601@resnbl.com"></center>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
Content-ID: <part1.06030900.02040601@resnbl.com>
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAEMAagDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3Zrv/AImCWiJuPlmSRs/c GcD8Sc/kar2u
u6de3r2dvdRyTp1RWBPvkdRjoc454qTTYJUSW4uU23Nw5d1JB2Doq8ccDH4k nvUkNha29xJc
RQhJZMl3BOWyc8+vt6dBQTr0K9rrunXt69nb3Uck6dUVgT75HUY6HOOeK0ar Q2Frb3ElxFCE
lkyXcE5bJzz6+3p0FWaBq/UKKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
QAUUUUAFFFFABUMd3byyGNJkZhjgHrkZGPXjnipqzLLQNOsNRmv7eBVuJixk baOcnPpx+HXv
k80Cd+hp1n22rxXN35K29wsbFljnYKEkK9QvOfXqADg4zWhXI2NgF1WN7qNl FvE6TGe0OwIA
VwJSQuwg7toB75xS6ik2rWOuori/C8FvPbWEtjpyxyRMRLfRyRsGXB+QkNuP BX5SMDj0FT6T
W2MYAwoVyVyc5wMHvVCx0q8ttS+0S6VOwlSVbtVFsschbngAhmXOfvnPI45O FfQfM+x2VFcZ
ZaHLZtZzRaK8csSwEkPHlWBIk/j6kYOe4AHbFdnTHGTe6CiuU03RpF1+K/bT ri3cNI8jTtAw
+YH7rR/Oxyf48jGe+K6ujpcIu4UVyOlaZe2mtR3T6fOnmCQXTL9nSMs3OQE+ dlzn75JGRx1x
NpWlmxubOWHQ3tnM03nSKYgRGxJUHD5I5XgZxt6dKETzvsdRTBKjIzqwZVJB 288jqOO/tXNa
ZDp11qjWFuLGa10+U3EflFGId84BA6FTu/8AHfQ1Y0zTk02+kEGgwxkSSN9r QRLlCSQq4+bP
IGCAODz0yD5jbtriK7t0nhJMbjKkqVP5HkfjTlkVpHQBspjOVIHPoeh/Cuc0 3TntLiwuF0eW
G4Z5PtMu6MsFOcBiHJIzjAGcY7VY0uOW31W8K6HNaW9yVO4eSF3AHJYK5PP0 PvSBSfVG9RXL
aZpbWU1rJBoj2krSzCWVfKBVGJK5w/I5XgZxt6dKqaZDZPrthbDT4Re2oc3c oljcu4XG9grF
s7ifmcAjOO5poXO+x2lFFFBoFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTQ6M7IGUsuNwB5GfWnVj2H h+Kw1OW9FxNJ
v3YieRikfptBOBgZH48YHFAnfoaj3ESTxwM372QEquCcgYyfbqPzFSVm6aft k02pHlZf3cHt
Ep6/8COT9NvpWlQCdwooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
QAUUUUAFFebeHLfRtV8W6pdP4ggvr+O8Itd32SSR0EKYZD5e4BSWxtIXK8g/ NmfS/EVwuq6V
bXfiN5J5Z7i3u7aRYF8vbv2FtqAqxwCATzzgYzVuH5XOiWHabSe3qehUV5/4 d8UTz3WkifXo
L77c1zCYS0I5jJ2MNoB3EYz25GB3Muk61d3l5pLSeJ4xfzTEX2jGOPMQ2tlA qoZFKkL8zNjA
JzyBS5GJ0JK9+n/B/wAju6K4jw5PFp2vX9ld+IbmW8e/kC2EghLSAqCJGVIw 4GOc5C8Vb0HU
bf8A4SjxDYx6lBe3CMkipmFZSQpDA7FBO07Vy2SOATSa0v5XFKi035HWUVwe keIr24u9JVtY
25GB3NODHKhJX/rv/kd/RQRkEZx71xPh2+Fvq1xYXHiq+1LU1nuF/syYQMUU OxV32RB0Urtw
WIT5gB1UVBh0udtRXmvhLxFrl5r9pBqPiDRZHmDi6006jG1xC4UkqkIt43Uq wwQ7vhQep5qT
QfEWo6p4yhii8S2V/YStMzW1nPFK8aAHYXj8lXhA4BLPJ82F75DsB6NRXFeG r1INZm0678WX
2oagLi4Q6dMsDNGoclXcRxB0XbtwSQvzADqorXjZpvHlykv3bXTomtwT3kkk 8w/+Q4x/+uiw
Pr5f52N6ivOtA8RahqfjOGOLxJY6hYStMzWtpPFK0aAHZvj8lJIQOASzud2F 75HUaAzJqWvW
iD/RYL0GLjhS8aSOB/wJif8AgVJB3XY3aKxNMiDeI9YuZoIluQYoldfmPlbc qNxAI5JO3oD3
Oa26ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKAIPtP+x+tH2n/Y/Wq9Fa8qM+Zlj7T/sf rR9p/wBj9ar0
yYStA4gdElKnYzoWUHsSARke2RRyoLst/af9j9aPtP8AsfrXF2es63c3VnaN LYJcJ5zaj/or
4jVGAG3951bPBOcjntgt0bxNqF7rdpbzxI1lfQyTWs32cQlkXGGA852IIPdU 7fSnyJmzpTSe
ux232n/Y/Wj7T/sfrXI6Nf8AiO/vboTnTPstpdtbuyxurzADlh8xCYyODuzz 93rXTUciImnB
2bLH2n/Y/Wj7T/sfrXnmgapq02vz6NbTxw2tpcTu76isk8tygmIAhYyDKqPl YtnaSnBBFdxK
XETmMZcKdoxnnt3H8xS5Va5LbTaLf2n/AGP1o+0/7H61w+l6h4zl1O3j1DTv LtGbEr/YIUwP
94XzkfgjfSuwo5ULmZY+0/7H61AywPex3jQ/6RGjRq4Yj5WIJHvyo6+lcdYa 94gm8TW1vdW1
rHpV08ohmVFPmBVLLskSZ92QM5aOMYB74FdhQorcG3sWPtP+x+tQWqwWcbJB DsV5Gkb5iSWY
kkknnqf6UlFHKg5mOC2y3jXgtIhdMgjaYKN5QEkKWxnGSTj3qb7T/sfrVeij lQczLH2n/Y/W
j7T/ALH61Xoo5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP+x+tV6KO VBzMsfaf9j9a
PtP+x+tV6KOVBzMsfaf9j9aPtP8AsfrVeijlQczLH2n/AGP1o+0/7H61Xoo5 UHMyx9p/2P1o
7T/sfrVeijlQczLH2n/Y/Wj7T/sfrVeijlQczLH2n/Y/Wj7T/sfrVeijlQcz LH2n/Y/Wj7T/
ALH61Xoo5UHMyx9p/wBj9aPtP+x+tV6KOVBzMsfaf9j9aPtP+x+tV6KOVBzM sfaf9j9aPtP+
x+tV6KOVBzMsfaf9j9aPtP8AsfrVeijlQczLH2n/AGP1oqvRRyoOZk32d/Va Ps7+q1ZoqOdl
cqK32d/VaPs7+q1Zoo52HKihHpkMNzNcxQQJPPt82VUAaTAwNxxk4HTNVIvD GkwTLNFpWnxy
q/mK6W6Bg/8AeBx196w9B8Tapeazc6JbwpqTWNzKt7eXU4t2hTzSsYVVixIS obBGB8hBINdt
T53ZMrVNq5l2uhWNjPLPaWNpbzTHMskUSoznOfmIGTz61b+zv6rWXpU11b6t rNvd6jPdwwGO
WMzJGDGGUkqNiLkDHGcn3NZPh/xzd65qFtC+gXkFrdoXguPIucKNu5fNLwIi 5HGVd+SAMjmk
ptiavqzYj8LaPFNbzR6RpqS2xJgdbZA0RJySpx8uSSTj1rS+zv6rWDpXiTVL qeL+0tItrO2l
aeNJIb4zNviJBypjXCnaxByT0yBnhtl4k1i7u9MDaHbx2epAyQT/AG8lkj27 hvTy+HIx8oLD
73zcDJzMTijoPs7+q0ht5MHG0nsCcVkaDqPiDU/P/tHT9OtYFlmiE1revI4Z HKj5GhA7dc/h
zgVvDut6xKLGDU7NDDOJI4rxrhTNKyZ+Z4lQKoYAkEMe2VGcAcnsHKkT2vhf TtGmmvrDTNMt
p9jF5be1SN5B1KkgZxkfy9Ob5nCsVYAEcEGROP8Ax6r13/x5z/8AXNv5UW3+ qb/ro/8A6Eai
N46JlNJ7lD7Sv+z/AN/U/wDiqPtK/wCz/wB/U/8AiqbqXiK0025FsYp7iUAN IsCg+WD0LZI6
+gyfatK2uYby2jubeQSQyDcrDuKr2jva5CcW7Iz/ALSv+z/39T/4qj7Sv+z/ AN/U/wDiqUeJ
dBaC7nGt6aYbNglzILtNsDE4Ac5wpzxzSxeI9DmRni1nTpFWEzsVukIEYAJc 8/dAZeenI9af
OyuVDftK/wCz/wB/U/8AiqPtK/7P/f1P/iqz7/xlawGyfTUi1SC7XMctrcoV Y+dHFhT90nMn
qBlccdRLp/ir7XNeLdaLqGmwWeRc3V7LbCKIhQ2CUmY/dYHOMe9HNLcOVFv7 Sv8As/8Af1P/
AIqj7Sv+z/39T/4qo7nxHamysp9Kkt9Sa/n8i1MM4MbkZLHeoYAKFYng9MdT Vu91rStOure1
EdzJLrGnxpa4+0M9ygEOSVG85+XJBHPcEVHP4k0yKzsruGc3ltezpBBNZqZo yzNtBLrlVGe5
I9Bk8Uc0h8qF+0r/ALP/AH9T/wCKo+0r/s/9/U/+KrVqje61pWnXVva32p2d rcXJxBFPOqPK
c4woJy3JA49aOZhyog+0r/s/9/U/+Ko+0r/s/wDf1P8A4qny+INFgjuZJdY0 +NLXH2hnuUAh
ySo3nPy5II57giql94ptraxjv7K0udV09o3me7094pIo0XqxJcbu/CbjweKO dhyosfaV/wBn
/v6n/wAVR9pX/Z/7+p/8VT9K1VtQkvIZYBBPbS7Socsrow3I4JA6g8jHBBHO Mm1LfWkJnEt1
BGbeMSzBpAPLQ5wzei/K3J44PpRzSBRT2KX2lf8AZ/7+p/8AFUfaV/2f+/qf /FU6fxBpUM93
bLqFpLeWsRmmtEuYxKiAA5ILDaORycDkc1BceJ9Ni1+z0WK7tJr+eQpJbrcL 5sKiNn3FBk44
A7feFHNIOVEv2lf9n/v6n/xVH2lf9n/v6n/xVatYx8S2YktIzDchrm7ktACg +RkYqWbnhSQA
DzncvHNHMw5VuSfaV/2f+/qf/FUfaV/2f+/qf/FVFH4p0opNJdXEdjFEzAyX c0cYbDOuR82Q
P3bEEgZH0OI9Z8X6Lo+jDUW1KwcTQtLaIbtF+1YHSM5+bOR0z1FHNIOVFn7S v+z/AN/U/wDi
qPtK/wCz/wB/U/8Aiql/t3SBeT2bapYi7t4/NngNwm+JODuZc5Ucjk+oqyt7 aNK0S3UJkWTy
igkGQ+3dtx67fmx1xzRzSDlRR+0r/s/9/U/+Ko+0r/s/9/U/+KrVoo5mHKjK +0r/ALP/AH9T
/wCKo+0r/s/9/U/+KrVoo5mHKjK+0r/s/wDf1P8A4qj7Sv8As/8Af1P/AIqt Ws7VTtUNhSVR
iNyg4+ZB3pObDlRH9pX/AGf+/qf/ABVVrzV7axFv5wY/aLiO2jCMrHe7BRnB 4HOSfb8Kx4vE
FlNq8+kx3Vo2oQRrLLbhE3qrdCRj6fTK5+8M8vfyvL41Jc5xqGlgADAA8x+g 7UlUYciPVfs7
+q0fZ39VqzRVc7FyorfZ39Vo+zv6rVmijnYcqK32d/VaPs7+q1Zoo52HKit9 nf1WirNFHOw5
UFFFFSUFFFRzyNFBJIkLzMqkiOMgM59BuIGfqQKAMiDwlo9tf2t9FFdLc23m eXJ9tnJPmNvc
Nl/nBbBw2eg9BVy10XT7LV7/AFW3t9l7qAjFzLvY+ZsGF4JwMA9gKzIPFsdz /Zoi0nUS9+0g
j4U0zTtRN/bvqRuD94zapcyq/BA3K8hVsAnGQcdqfaeGNNsLwXNqb6MqWKwj UbjyFznIEO/y
wOeAFwO2MVV07xbHqV9JaR6PqqNBP9nuHeJCkD9QGKuc9uV3YyM4zXRE4BOM +1DViZRlF2kY
tr4U0qze0eEX2bSR5Yd+oXDgM/3iQzkNnnhsjk+prP0vwYNN8RjUvtatbQh1 tLZfOPkq3G0G
SZ1VcfwoiDhewAq7ofiC71iWRZfD2oWMaSSx+dNLbsmUcrj5JC2eP7uOvJ4J 2pZBDC8rdEUs
eQOnuePzpbak26GYnhrSk1R9REMpuGZnG65lKRuwwzpGW2IxBOWUA8nnk5Zb eFtLtDYeSL0f
YGdrcNqE7gFuu7Lnf3+9nGeKxdJ+Jekavqlvp8EO2Wdtqn+0rCTn/djuGY/g pNdkThSQCSB0
HejbUN2RXf8Ax5z/APXNv5UW3+qb/ro//oRrBtPFdrq0QiWzvLf7RFMInnCb WePIdPlY8j8v
Q5BFb1t/qm/66P8A+hGhqzKlFx0Zy2veErq91WS+sJoQbjBmSZmUKwUKGXAO eABg46da6DSd
LTSdHi0+NzIEDZdx95mJZjj3JPFGoa1p+lyJHd3Gx3GQqozkD1O0HA9zxV2O RJY1kjdXRwGV
lOQQehBqOWN2YQhBTbjucHp3hXXrCO3kSPTwLF4jZ6e968sQCq6sPOaLzFH7 zKqfMCkYBAOB
pSeHdQudM1RpYtPjv7y9gvRGHaSImIRYR22KSCYyM7eAQcHpXWVUutTtbKUx TO/meS8+yOJn
YomAxAUEk/MOByc8Crv1/rv+htu7nIL4Q1afVBqdy9lFNNdfaJoIpndI8SW5 wjFBuysBJJA+
ZvxrVv8Aw9d3NnqyRtbNLcX8V7AkuSjeWIiFfjjJjIyM4yDg9K2tM1K21fTo b+zMrW067o2l
heIkeu1wGAPbjkc9Kkgu4LmW4jhfc9vJ5UowRtbaGxz14YHj1p6r3e3/AAP8 kLzOTXTNT0u5
h1q6gR5ZNSee6tbMvOIY3iEWU+VWcgqjH5R1bjjl3jDw3rOvTyR2syG0ktvL RX1Ca2EMmTli
kS4mB+UYc4G3gHJz2NFLt5B38zidR0u50LRbK6igiuLiz1Sa88hIZpFl80yg Z8qJ3DASZ3bD
yMd80lvYa9d+DbFbews0vHvvtskN1cyRBF+0GYAHyi2SMDDKpGeQCMV0V94g s9Oe9WdZc2kU
UrBVB3+YzKiLzyxZcY45IqTSdXTVY582txaXFvJ5c9tcbPMjOARnYzKQQQQQ SOfUEUL/AIIP
whkycsUiXEwPyjDnA28A5Oexpk0qwQvK4cqgLEIhdvwUAkn2FHZh5HGajpdz oWi2V1FBFcXF
nqk155CQzSLL5plAz5UTuGAkzu2HkY75qvbaf4nvPD+nxpp9gLWeWe5vLO5v JYGffKzom7yW
OzDZZSqseAcDcp7S5v4rS5soJFctdymKMqBgEIz8+2FNWqEBhaIs9zq2qalN bPbrJ5dtGrqV
3CMNuYBgDjc7AEgZCgjgil1rQ5NTv7WaJ41iI8m8V8/vIdwfaB0Jyu3n+F2+ ht/29pm62X7U
M3NxJawjY3zSoWDL04wUYZPH5ip7PUbbUPM+zM7iNmRmMTKuVZkIBIAOGU9P Y9CMvzC1lZ/1
/X6HGX/g7V7yOaxU6fHaJNeXMFwsjiWV51cbJE2YAHmnLBmzsXgdtCx0DVrX VbVGTTxp9rf3
F4JklfzpfNEnDJswCDJjO45Azx0ro9RvotM025vpldoreNpXCAFiAMnGe9Wg cgGhMHqVP7Ng
OpjUPMuvPCbNv2qXysf9ct2zPvtz71gXnhu+kvtXubeW2PmhZrBJGYBJxsZt +B90tFGeMnlq
6qikByFt4Qnt9Z0u6LWzwWUcCkNncWSOdSwGMZJlB/P8aM/hHWoYdSisl0yQ alBLBJJNK6NA
DNNIpUBDuyJeRlcEZy2a72infW4HFL4Rvp7pbO7WxGlxXF3cCaJ286fz1cFH QrtAHmtltxzs
XgZ4t6N4avrO/s7u9ngkcI0tzsJwbj5wCvAyNsjLk8/KvHp1VFJMHqFFFFAB RRRQAVz/AIo1
nTtHhiOoXkVv5yssYc8sQyE4H+e3rXQVTvuPLP15/I/09e3bG5UwPGbTTvhx Y6umrW0wTUEk
MouDe3BcsepJLfNnJznOcnOc1ZW+tdR8VG5s50mhbUtLAdTxkSPmvUuntj8M fy9Pbp2x8nO+
KuJdCH/UXteP+2ij+np27Y2qhnc0UUVQgooooAKKKKACiiigAooooAKKKjnm W3gkmcOVRSxC
IXbA9FUEk+wGaA3M+10G0tdUvL9XlZ7kEeWxGyLPL7MAEbiATknkdqoWHg+D T7jT5IdU1App
6slvE3lbFjIAKECMZHA5Pze9WY/FekTR2LxyXTLfsy22LGf5yOv8HHrk44BP QVYttdsbu++x
IbmO4wxVbi0lhDheu0uoDYyOmar3kat1Fe/9dBNL0YaVc3kqX93Ol1M0zRTC Pajt1K7UB9By
T0rTrDtPGGh3t6LOC6lNx5nlMj2sqGNznCvuUbCcHAbGe2a3KTv1JmpKXvqz Me20AWuqteLq
APQmth2CIzHOFGTgEn8h1pX0I6i0hGVIBIJHUdqxrTxRp97dR20Vvq6vIcAz aPdxIPq7xhR+
JFbJO1STnAGeBmgDmU8JRWEFs66rqEv2Hz5I1k8nDGQHcGxGDjk9Mda6G2/1 Tf8AXR//AEI1
lQ+JNK1WF4bS4dnkhkZA8Eke7bwwBZQNw7r1HpWrbf6pv+uj/wDoRpu99S5u V/e3OP8AEHh/
Vn1ue9sFa4jutpKrIqGJlULzuP3eM8c5J4710eh6bJpOhQWMkollQMWZSQMs xYgewzgewq3d
X9nZeX9ru4LfzDtTzZAm4+gz1qxWfIrt9znhTjGbktzyNPBepnS3t00W4hsx PE08RSyN5eAL
JuMhJaCbDOpDSKjHGTlgCdy38NnT30S8Xw7d35tLS4hUXIs/tNszOGT7rLGF ADKNh+UEDGM4
9AqC4vrSzDG5uoIAsbSsZZAuEXG5jnsMjJ6DNW9f68rG17s8+i8I3OoaJM9/ oe3UItHt7ezW
4eJniuI/MG5CrEKclSGBBwRyOQGa74PuLi+1Mw6GxjuL9Lqaa0W0L3cPkhTG RMCrFZPnKyDb
/EG3YrvtN1fTNZgafS9RtL6FG2NJazrKobrglSeeRV2nJ3dxLQ4XQfBdtulG o6bcNbmxS3g/
tDyGliy029QIvkTCyADaANpA7EVDqXh/V7zRH+3af9tnmliguESO2mla3hVg jIJz5WWkJf5s
4VzxuHHexTRTpvhkSRNxXcjAjIOCOO4II/Co7q7gsolkuH2I0iRA4JyzMFUc epIFJ6v1BaHn
Nlomp6HpH2m/tH+z2b2rlWaNmEUVxKx4j+UbI3RsAAcYA4wOs0C7t9W1nVtU sJknsJBDBFPE
waOVkDFmVhwR84XI7qR2raa7gS+js2fFxJG0qpg8qpUE56dWX86bfahbabbe fdSFELqi7UZ2
ZmOAAqgkkk9AKd7/AD/4b9BWRi6/os99qCNbRBob6L7HqB3AfuQ27J7njzE4 /wCeuegNctqH
hXU57m+Fvovl3zteNLqnmxH7bFIriKHO7fwWj4YBV8rg9K9MopJ2KucHp/h6 4h8VWt3L4fUX
UV/cTT6wzxMZoXSQIoO7zMAMi7SABt4yBmux+xz/ANpi7/tK68jZt+x7YvKz /ezs35/4Fj2q
xJLHCoaWRUUsFBY4GScAfUkgfjUNlqFtqCzG2kLeTK0MisjIyOvUEMAR2I9Q QRkEGj9BeZy1
7ouqDUNVnhtvNihYXWnosqqZZSY3dOT8vzRdTgfvD6GqY8HTz6tpq39il1Yp FB9q8xlZXcR3
i0k8NJqKm2mh03LwlLA+dKykB2GzKNFgoCRsAOABV0eErq71eaOXSfs8ssl3 9r1fzI2+1wSK
4jiyG8z5d0fBAVfK4PSu9mvILea2hlk2vcuY4hgncwUsR7cKTz6VPR/wfxC+ v9f1/Whx2i6L
qqapa3l/B5fnFr25UOp8u42tGFODz+7dRkcfu/pXY1X+32f7r/S4P30jRR/v B87jOVHqRtbI
68H0pYL21upJI7e5hmeM4dY5AxU5K8gdOVYfVSO1Nu4WJ6Khu7uCws5ru5fZ BChkkbBOFAyT
gc1MDkZpAFFFFABRRRQAUUUUAFU77jyz9efyP9PXt2xuW5VO+48s/Xn8j/T1 7dsblTAqdPbH
4Y/l6e3Ttj5Od8VcS6EP+ova8f8AbRR/T07dsbV6Lp7Y/DH8vT26dsfJzvir iXQh/wBRe14/
7aKP6enbtjaqGdzRRRVCCiiigAooooAKKKKACiqVnqSXl3fWwhliks5RG3mb cOCoYMuCeCD3
weDxV2gAooooAxLLw6tprFxem53REOLWER4Nv5hDSYbJzuYAjgY6c1k6T4Hl 0nVrG/jvbEy2
wdJJF0/bLcq2MtJJ5hLPkZ3dOT8tdjRTUmjT2s9ddzH0XR7rSrrUXlu7eaK8 uWuQsdsY2Vmw
OW3ndwAOg/pWrLLHBE8srrHGilndzgKByST2FPopXJcuZ3Z59o+mxadry6re vZrOm97ia10U
2c7q/SS5k8whkOc42j5hk7fLcL6A6LIjI6hlYYKkZBHpS0U3a1hzlBu8Vb5m LaeD/DNhdR3V
n4c0i3uIjujlhso0dD6ghcitk52naQDjgkZpaKRByFv4Vv7CCyZ9TtZEsTcy FUsmQyebkkZ8
w4wSeea6m2/1Tf8AXR//AEI0Xf8Ax5z/APXNv5UW3+qb/ro//oRobuypTctW cP4msdVTXp7h
Lea6t7hFWIxwmXYAAChA+6M5bJ4O7rXU6BaXdj4etra9bNwiHIBzsBJKrnvt BC/hWrRUKCTb
7mEKSjNyPI0XxA2lvHFPrZg8+L7ZfSwX5eQFZCdttvWWPDGMHyHKng4AytWN X0q6m0qxllk1
jUJzpd5bwzx215FmQspjWWEsXxtBGZM7toJJOK9UorS/X+trf8MbN6/1/Xqe eanB4htl1jzD
I+qzw26x3mn2Ugha1STLgKHLiUCSTKiQMwKlDuBxmTx6rFpNqE1LXdQVZJjH bpY6lZl2IQKp
lLPKmCWYGXdG24jjaCPVqKE/6/r+riPOZftVxqWkW14PEUEwuppZJ4ftnllB cN5cTeX+7G7j
3uHldxa68EuZtMGrC02yraS3Mc8lwluZLYuCHZZc8TFRuD4Hy4OK09ISW3/s J76+u723XU5F
je6srm3MLtCwQEXLtIwyWAYsRlwB0Fd9LLHBE8ssixxopZ3c4CgdST2FVIpt K8QaZvhls9Ss
Jf4kZZonwfbIOCPzFNPSwPY47x5Jq7agi6aL+GSC3823e2hu5hcSZJKEQusS 42jmUMDuwBwQ
VntL6HS4rm9l15oZ9TmF8LeW4aZYA8vlCNI/nVcmPJjAYrjJKiu+qrqGmWGr WptdSsra8tyQ
xiuYlkTI6HDAil0sHU4NprabwXpN1La6jfNDq2+2kezuLq4iRLk5JyrSKRGC Pmwe3Xiuo0h0
m8Ta5NB/qcW6P8pH70IS2ffa0YrXjFpYRW1pEILePAighXCDAGQqr7AHgdhT re1t7OMx20EU
EZdnKxIFBZjljgdySST3Jp9/67f5CsYOvwaj/aCJZSXflajF9kkaJmxbENnz QeiHYZBu7sEH
pXLah/bgub4Wn9vf2puvPtG7z/s/2fa/k+Tj91vz5ONnz/e3d69MooWhR5/Z wXE3i2xluotb
kv4dQuDO0vn/AGSOEpKIig/1P3dgyvzZJ3HJNdr5eo/2mJBdWv8AZ+zBg+zN 5u718zfjHts/
GrE00VvC800iRRICzu7BVUDqST0FPpdELqcJe2N3BqWoutjO0GmTG/tTFCWM pkZJHVPV8rMM
DP8ArB61BBpWqvqWm2Uz6nDZyJFJdm2kkiUuyXLSDcuNvzlMkEHO3npXoVFC 2t/X9bfcD11/
r+t/vPK9UtNQk0y7stQTxFcBbWaLTkgNywdxLKP3zJ975BFjzSQw6ZJNaAt9 Yu9Wmtoptbg1
GWS7S6lkaZbZLcq4hMR/1QYHycbPn+9u716JRR/wRnHaK+tXOqWs12t7DBdF r1o5NwEWFaMR
MDwuQYm2+oY9cmuxooptiCiiikAUUUUAFU77jyz9efyP9PXt2xuW5VO+48s/ Xn8j/T17dsbl
TAqdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xtXountj8Mfy9Pbp2x 8nO+KuJdCH/U
XteP+2ij+np27Y2qhnc0UUVQgooooAKKKKACiiigDG020nGv6vfzwSQrIyRQ 7pBiRFUZfapI
5JIBYbsDHQCtmiqOn6vZ6nNdQ2xnElq4SVJraSEgnoRvUbgccEZB9aF2AvUU UUAFFRpNFJGz
xurqpZSUO7BBwRx3BBGKyrbxTpV22niJrzOoM6W2+wnTcUyWzuQbeAT82M4O M0eQGzRRVHT9
gccEZB9avUAFFFFAEN3/AMec/wD1zb+VFt/qm/66P/6EaLv/AI85/wDrm38q Lb/VN/10f/0I
0uoHn/jCWePX5BqEata4X7EZM7fujdt/292ffGO1djoDX/8Awj1s2ohhdbCT vGWC5O3d33bd
ue+c1q0VKhZt33MYUuWblfc8jTxhrLaW5j8QW87GeJbnUBcW4s7YMsjfu5lh Yx5KopWaMkZx
k7g1asKrrGp+HTrusWV3DdWdzCVheC4tb4iWMqhZogHYqASFC8ocAAGvR6K0 6/12sbPXY8re
0s/Dfh1L/RNP06xvTeagvnxWUW4BBcFBnbnA2j8OOlaF3q3iTS5LxodTk1F4 J57eK3lto/3h
Fr56k+WoYsG+UbcZXjBb5q9EopB1PL7HxNqT6fuuvF2mfYXuo0m1G0vILqSz Uo5IdvIjjjDM
qKC6N95hnJGJo/G1zbaNftf6rFHcNYGTTHkVFa7KvMolQYw5ZViYgAgbgcAG vSqKdwPN7nyh
qeuWl1q0zpNrFoZ7J/LAWJvJw2AoYqzYTJJBAI65NdZpYVPFGupDjyj5EjgH pMUIb8dqx1q3
lnb39nNaXUQlgmUo6HuD/L61DpmlWmkWzQWaSBXcyO8szyu7HuzuSzHAA5J4 AHQUlorf10/y
E1rf+upk6/falZaglvbXBUajF9ntT5at5E4blxxz8hZsHI/de5rk9W8SX+/U YRqyXNz/AKbH
c6Q8ERFpCiv5cpUrvO7bHyxKt5vA6V6fRTWhR55a6m2oeMNNW51xpLuLUriN tJVYlW2RY5Qj
EbfMyygHLNtO7IGMY7jzNR/tMRi1tf7P2ZM/2lvN3enl7MY99/4VbopdhdTz y9ZbPUrxXzHD
oN02pF2zgJKyuW75+Vrkfh0qGxfUo9WsbC2u/wCz3v0imuZIoI2kBlW6mYAu rfxAYzkDnjk1
6TRQtrf1/WwPX+v68/vPKNa1y7uNGvrHU/Eb2nl2c6wKI4VfUnWWWNgdyHOF RMiMKRvJ4BGN
Ia7q9zq01nZa1v1OSS7hfS/Ki/0KNFfypsbd/JWPlmKt5vAHGPRaKP8Ag/1/ X4D6/wBf1/Wt
zjtF1/UdU1S1Hm/6LeFryEFFH+jhWTaOM/e8p8nn58dOK7GiimxBRRRSAKKK KACiiigAoooo
AKp33Hln68/kf6evbtjctyqd9x5Z+vP5H+nr27Y3KmBU6e2Pwx/L09unbHyc 74q4l0If9Re1
4/7aKP6enbtjavRdPbH4Y/l6e3Ttj5Od8VcS6EP+ova8f9tFH9PTt2xtVDO5 oooqhBRRRQAU
g83h7UrKG8WNUuZZLZljKK3LBJmbkkYwD74rqaKOlg63PNfCXhG40XX7Seay 1pLmMOlxeAac
sFydpBZ2jCzyAn5hvBO7BPIJrR8N6BaR65dXE/g2509zO01tcSvblIQVAKos crFC3zFgqgN/
Fmu5op31uD1OM0DQodC1idLPwbaW7CWdzqcS28e6JmLKibTvJ5VdrBVG088A GnpGiXlrd6Nd
f2RrMVwXn+0G41FZo7bcGAYRmdkGd3Hlg4GRx0rv6qWOq6dqZmFhf2t2YH8u byJlk8tv7rYP
B9jS3B9zgPCXhG40XX7Seay1pLmMOlxeAacsFydpBZ2jCzyAn5hvBO7BPIJr otIutTbxLfS3
HhvUrS3uxGFnlltiqbFbO4JMzcnAGAevOK6iincDl9KutUk8SX8k/h3UrOC7 WMJcTS2zLHsV
uWCTM3JxjAPvis/RNEe21WxkHhmWxv4Wb7bq5eA/bBtIbLLIZH3NtYB1GMZ4 IAruKY00SzJC
0iCVwSiFhuYDGSB3xkfmKS0AJYxNC8TdHUqeAevsePzrj9J+GmkaRqlvqEE2 6WBtyj+zbCPn
/ejt1YfgwNdYt5avNPCtzC0tuAZkDgtFkZG4dsjnmn29xBd28dxbTRzQSDck kbBlYeoI4Ip8
rWtge1ht3/x5z/8AXNv5UW3+qb/ro/8A6EaLv/jzn/65t/Ki2/1Tf9dH/wDQ jU9QOH8Tavep
r09q8tzbwwKrQ+TKYt4IBLkj73OVwcgbfU11Xh++ur7w9a3d4m2Z0JORt3AE hW9twAP41cur
CzvvL+12kFx5Zynmxh9p9RnpVipUWm3cxhTlGbk3ocBp/ibWbrULS21NrS1u nff5XkSoIFaG
ZgS4lMdwnyD5lIHXKo2MQnxR4vMdnDBa2l3PfedPayQ2YTdbpsAYxSXSfeL5 BDkhcZXJO3sb
fw1oNpbyQW2iabDDISzxx2iKrEqVJIAwcqSPoSKj/wCES8N/2f8AYP8AhH9K +xeZ532f7FH5
e/GN23GN2OM9at7/ANf1/Wpv1MIaX9p8S6dNeNq9rNcWMt3cWaavcbEmVovl CrJswNzDA+U+
lZ1x4u1g6XDLcXNlFDqVol3HcWaEGwiM0aOXZiyuQsuQ21QCjZGOnfxWdrB5 PlW0Mfkx+VFs
QDYnHyr6DgcD0FQW2jaXZS3UtpptnBJdnNy8UCqZjzy5A+bqevqaeny/4f8A 4H3CRg3UR8PS
Wtlo1+/2rUZ0hDapeTXiQgJI+4K8m4lghUAMoJ57HOWni3xBc2V9dQDTI002 282cPBI32hlk
MSwGNYVCmNchUxjG0ZOB0GTQBxF3r3iHTtQ1NLSSC+a41ZbS1h8jLQf6Osn8 c6KwwMbcpyS2
T92p38R+K0tLyWe1sLKTT7JLq4gniLvL80oIGyUrHlYwR8z7d2DuxXV3Wg6P fNO15pNjcNcI
qTGa3RzKqnKhsjkA8gHpTrfRtLtLRrW202zhtmj8poY4FVCmSdpAGMZZuPc+ tJbWBnH3UupX
Umt2l1qUTWE+rwWflrGyvFG6xFk3FyMMrbcADlie+K3dAtLfSdZ1bS7CFILC MQzxQRKFjiZw
wZVUcAfIGwO7E96vX+gaZqKXRltIknuUVHuYkVZvlOUO/GcqQCM9CKdpOkJp Uc+bq4u7i4k8
ye5uNnmSHAAzsVVAAAAAAHHqSaForf10/wAr/MT3v/X9dCjrWs32mXjW8SQM bmALYl1P/Hxv
C7XweV+dGwMHCvz6c9qnizVYbS5uW+xPZzSXlrDBCsizRPCrne8gccHyzkAK V3r8xxz3klvD
NJFJLDG7wtviZlBKNgjIPY4JGR2JqodD0hr24vW0qxN3cx+VPObdN8qcfKzY yw4HB9BTWm5R
yyajqOp+ItGuZ57FLH+07mCG1SJjMDHHMhZpC+DnaTtCDGRycc9b9sn/ALTF p/Zt15Gzd9s3
ReVn+7jfvz/wHHvTE0XSotSfUo9Mskv3IL3SwKJWIG0ZfGTxx16VepdELqcL cahdW+pPbm9u
Auk3r3NyWlIDQyOhUMT1RUlkwOn7odxUFlrGtLf2lnayQifUFjmMt6ZZhEJR cygBN6j5diqA
NvHGeBjuJdPsp/tHnWdvJ9pQRz74lPmoMgK2R8w5PB9TS/YLMTpOLSDzkACS eWNygAgYPbAZ
h/wI+tC2s/6/r/MH/X9feefavr+tat4d1a1M+mWwtLGQ3jtA7Gf95LF+7HmD ywfKJyS/LAds
nRfxRrm8y266fLDcTXdpa2qxuZY5IVchpH3YIJjIKhQRvXk456e58P6LePE9 1pFhO0JcxmW2
Rihc5fGRxk9cdalj0jTIdTl1OLTrRL+Vdkl0sCiV144L4yRwOM9hR/wR9TC0 vxPc6nqcUEcU
Jt55S8LgHm3CupOc8t5iDkcbXX611NV4bCztjCYLSCIwx+VFsjC+WnHyrjoO BwOOBVim7dBB
RRRSAKKKKACiiigAqnfceWfrz+R/p69u2Ny3Kp33Hln68/kf6evbtjcqYFTp 7Y/DH8vT26ds
fJzviriXQh/1F7Xj/too/p6du2Nq9F09sfhj+Xp7dO2Pk53xVxLoQ/6i9rx/ 20Uf09O3bG1U
OyED5gGjRVOOvKg7uk61Fc+J9TENpqcZuliEElxpdzFGSitnLtGAB9SM9s11 lFHSwdbnmvhK
HWbfX7T+0dZ1Jrkh1vbeXSr/AMqR9pziWSV4FAYZBjCg4wMA4rR8Nx291rl0 ftfikGOdntY7
xLyOFY9oDDdIoD5JOA5YjHy7a7minfUGcV4as7XStZms0tfED3f2i4LPPPdP apGzllfdK/lM
SCo+Xc+Scj7xGvFu/wCE+u/O6f2ZF9mz/wBdJPNx/wCQs/8AAa3qY0MTTJM0 aGVAQjlRuUHG
QD2zgfkKL7A9b+f+dyrBp1tZ6jfaim/zrsJ5vfhAQMADPQmuW0UG1m0yeI60 ZruSdZUuIbkR
IvJUGMqEjAO3DYBIzyea7ait4YhxTUtb/oml/XkB53okWrQ3yfbtV1BrgxyL dwSabeeXI2w5
xK8jQqNwyCgUHGBgHFd9bf6pv+uj/wDoRou/+POf/rm38qLb/VN/10f/ANCN LE13Xnztfl+i
X9dQOQ1/xJeQ61PY2072q2u3JWJXMpZQ2TuB+XnHGDkHmuj0LU21bRLe/eLY 8gYFV6EqxXIz
2OMj2NLqOhabq0iSXtsJHQbQwdkJHodpGR7HiryRRxxLEiKsartVFGAB0wB6 VypSu3cxhCam
3J6HCt4z1jUNMeSy0+ytbyO7tUNrPeMsyJJLt2zRtDuiYjHZgQ2VY4GbV344 u7GCS7uNGj+x
k3EVu6XmZJZoVdmUrsAVT5cmG3E8DKjPGvH4Q0aOymtPJuXjm2ZaW9mkkXYd ybHZyybTyNpG
DyKr3vgjSbm3vhAssE91DLFvM8rpG0i4Z1jL7Q57sAGOTk8nOmhvpcoX+v6r cG40Se1j06/k
e2CTW10ZQIZnZSwYopVwEfjBAJU5PONXQkew1TU9I+0XE8EHlTwG4meZ0WQM CpdyWb5kYjJJ
w2OgFJJ4R08aXcWls9xHPK0ci3c9xJcSrJGQ0Z3SMWIVhnbnHJ9TVvR9MuLE 3VxfXaXd9dSB
5ZYoTEgAAVVVCzEAAd2OSSe+Aaf18v8Agku5DquuvplzNAbPzGNsJbX95jz5 N4Ty+ny/M0fP
P3zxxzi6l40ura3uJn07ybFzcwWtzHdAzNLCrk5QxlVU+W+Dlugyozx1V1p1 pez2s1xCJJLW
TzYSSflbBGffr374PUCs5/COiS3VzcPaOWuRIJE+0SeWC4w7LHu2ozc5ZQCc nnk0LzK/r+v6
+4y/7c1PUNf0kx2qW+lG/ngEv2s+bMY45Qd0QTaF3KSPnJ4BwO3Sf2lANTGn +XdeeU37vssv
d/Ha/adxtNQkF5iJfmhZ0Ean+7hZ0bPBPln1NQWfinVPtMFvHbfbri+CyQLN OsMcaSefImSq
E8JGqk/MenGc56a50DTLttQae13NqEIguSHYF0AIA4PHU8jB/IU5dD01L2C8 W2AngVFjYO3y
hVdVGM44Ejj8fYULaz/r+v8AMH/X9ff+ByWreLNWvtA1FNP02KG4t7OR7yVr 4p5BDyR/uisZ
MhzE5GQnG3nJOL03jK7gLy/2Or2bvcQWji6/ezSwq7EMmzCK3lvhtxPAyBnj SuvB2h3mfOtJ
cMHVxHdSxiQOzOQ4VgHG5mIDZAycYqe38NaTbao+ow2zrcOXbBnkMas33mWM tsVm7sACcnJ5
OT/g/wBf1+I+v9f1/XQq2XihL7U/scVrkNOUSQSZ3RhXzJ04+eNkx9DnnFdB WdZaFpunG1Nr
bCM2sBt4fnY7UJBI5PJyOpyevPJrRpu3QQUUUUgCiiigAooooAKKKKACiiig AooooAKoam2w
KxLYVWb5SATyo64Prn8B6VfrN1b/AFR/65n/ANCSk9gRnfbE/uyj6Oo/9l+n 5D0Fcdq2p3F5
4pgtHbFtbalppiTA4LSMWJIAz0A9gBXS1xt3/wAjo3/YR0v/ANDapRTPYaKK KskKKKKACiii
gAooooAwNIjEHifXo4IY0gd4pZCvynzigz8oGDkBSWznPGOMnfqjBpkVo0zW u2JppDNIVjUG
SQgAs+MbsgAf/qGL1RBtqzVhtLoFFFFWIKKKKACiiigAooooAKKKKAIbv/jz n/65t/Ki2/1T
f9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P/wChGl1A5rWvFU1nqktjZ/Z1Nvt8 1rhWO4lQwVcE
Y4I5564xxW7pGpR6vpUN9EhQSbgVJzhlJUjPcZB571T1bwvYatdC6keeCbG1 2gYDzAOgbIPT
1GD71qW1pBZ2kdrbRiKCNdqqvYf4+9SlK7uYwVRTbk9Dio/F2rpo+p305snv Leze4Gk/ZXgu
bcg8bvMkHmp1G9QgO35c541P+EvMgkB0vULQwXEME7zxxMqO5j+T5ZeSRIOR kDBzngGZfCMU
sdwmoarqWoiW1e0Q3LRhoY3xuCsiKSTtXltx+Uc9cyx+GIFsZbae9vLlprmO 6kmlMYdnTZj7
qBcfu1zgetX/AF+P+RsylF46tJLdJ5NL1SFJrdZ7QSRx7roMyqFQByQd0iD5 9vXOcAkNm1+8
1fyNPsoLzSbyW8NtO0whaSBVj81mXBkQkgqBnONxOOKl1PwnDNpFtBaNK1zY 2ot7QvOI8FWj
+G4nf+vT+rG74furqa1uba9m8+6srh7d5toUyAAMrEAAAlWXOABnOAOlZtxr moR+KzYPcWNj
aCWOOJLu2kze7lBPlT7ggcZYCPDN8hPAPGrodhcWNnK160bXlzM9xP5RJRWb oqkgEhVCrkgZ
xnA6VDdeH/tmpC4m1XUGtfNSY2BMZhLpgqclPMGGVWwHAyOnJydVfyv+v9f0 jozK0rxncXjp
bXOh36XMktwEKCEp5cUuwuT5pxjIznBJB2g8U+x8b29zHbs2n37Qs8MM16Ik SFJJERlypkLY
PmKPlDYPU960LHwzb2GoS3aXl3IG88JDIyFIhK4dwuFDfeGRuJxkjpjDbXwn p9ppn9npJcND
50Ex3spJMQjCjp0IjXP1PTslt/Xf/L8RvyDSPFEWr30dumm39vHPA1xbXFwI wk8YKjcoDlxn
cpAZVODWlBqunXV9cWNvf2s15b48+3jmVpIs9Nyg5H41zfhnw3q2mawbi+uR 9htrZrWxthcr
P5cZZTjPkRsAAijDGQn1456+npp/X9aB1Zxv2/WrfwpqusRams08U9w6xXdu rRpHFI67EEex
uQo+Zi1Wp/HWn22vXGivbzNexRPIscc9u7S7U37VQS71JXON6qPfkZZB4a1C 6sLjTdRu2tbI
3M77LGZX+1xSSM+2XfFlMA4+Rs8nnpVu08J29pqUd2moXrQw3ElzDaHyxFG8 gbeeEDnO9j8z
HHakDF1DxdYWFlc3gikmt7eOGRpRLDEhEudoDyui5AwTkjhlxnNY83jSa++x XWnXVlYaZPAJ
Fu9Qt3likk3shiM0biOIgqACWYNvG0HHOs3hCzWyhgtry7tZYLo3UNzH5bSR sVKAAOjLgIdg
yvAA781EfBsf2Q2a63qy2cgdbm33RMtwHdmYNujJGd7AlCpxj0Bp6X/r+v62 DpYkufF0du0z
rpGpT2kc4txdxLEUklLiPaqmQOcMcZ244PNQ/wDCYOt5LZro2pXV2CzfZYEh DxKqRMwZml2E
gyjoeeQAcZNn/hFYhcMV1O/WzNwtyLEeV5SSCQSZBKb+WBJG7HzHGOMVr3wn PP4hOo2esXmn
rKkpna38ouWYRKAN8bALiLPrnvSX9f16jJdH8UPrOuNBbWMzaa9jBdw3nyKP 3m44YF938IAG
3ghs9qs22uN/wj13qt1EpFvJcBljZUyscjqOZGCjhcklgOvSn2Ph200y+huL GWeCKO1S0Nsp
UxuiZ2E5BbI3NyCM55zxVFvByvBc2za1qTWssxuI4CtuVgl83zQ6HyskhugY sOeQacrdBLz/
RI1jiaUKUVg7hicOhO1SBn1zi1p3he30++kvWvr26upRIJJbhky28RgnCqoH +qXGAByePTCf
wVfw6ra29hcmDREe3luFa5VmmaIKATH5GQSI0BKyqOM7eoK/4H/B+VhdH/Xo b0nimzjsILsQ
zsk1g1+qlo0xGuzILO4VT846nHB5rPs/H9hqdlFNplhe387vIptrWS3dkEe3 cxkEvlY+dOjk
/N04OF/4QO0MMcUmranKsEQitN5hP2ZVdHXb+7wxUxrgvuJ75qpqfhDUoFFz omoXEmqSSOZr
y5u44nKsiKVwLaRCD5aHAVcY4IyRQ/L+tdP+CNEsfxL0CTVbPT97LLdCEfPN ApjaVVZFMZk8
xidy8orKM9eDifxbrOo6eWXTpFi+y2U1/MzRh9+wAJHjrhiSTjBwuARnNT6V 4TbSfsxtdZv4
VSOJbiCMRGK4ZEVNxDozLkKAQrDp65NSeINAl1e4ieGbYkkEtndLv2kwyYyy naw3qVBGRg5I
NN2vp5/8D8fw3Bf5f8EybTxHrMsSQrPBcXd3OtvbmbQ7uwSI7XdnYSuTIAqH hSvOAWGciS/8
Q6x4e1Gyj1mfTJbFlkku7mGB4fLjBjRWw0jbcNJ82SRjnjBrRfwvJcWxivdf 1W7dJFltp3Fu
kltIucMhjiUEkEghgwIyCME5lt/DcKymXUL671V2ikhf7aIiro+zKlURVx8g 4x3Oc5o6/wBd
v8/+HD1/r+l/wxir4s1e50e8ltrO3GoPfeRYwSK3KGNZRvGc7thYnGOcCtiT UbfVdJtry3cF
Li1WZRnkKxQjI/P8jTbrwbouoXz3OoWqXyNK032a6RJIQ5RE3bSvULGAPTc3 rwg0q20TSVsL
PcLZBI0aHGIw0itsXAGFGcAdgBUvb7vy1DqUK427/wCR0b/sI6X/AOhtXZVx t3/yOjf9hHS/
/Q2qUUz2GiiirJCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KAIbv/jzn/65
t/Ki2/1Tf9dH/wDQjRd/8ec//XNv5UW3+qb/AK6P/wChGl1AxdW8UJYX7Wdt bLcSRY87dN5Y
TIyAODlsEHHAwRzWtp9/BqdhFeWxJikBwCMEEHBB9wQR+FYmteEI9U1A3sF1 9mlkAE2YvMD4
GARyMHGB3HA4ra0/T4NL06KxtdyxRKQCTkkk5JPuSSfxqVzXd9jGHtOd82xh aN4tbUrCXVbm
2tINJAyJ4bszyRnIGyaMIPLYbuQCwXByRjJu3vi3RrC7ltZp52uIywaKC0mm b5QhbARTnAkT
aSx3Jb5jJLKyO7buOhUjp0x0xir/AK/P+vmb6XJY/F9hJqtxZpFdyxRWcV2k 8FpNMsiPuPGx
CDwBjBJOSAODU8XinR5Uhc3MkIlaRB9ot5ISrIu5lYOoKHb82GwSASMgVkXH gq5eyW0g1WJY
TY29pMktqXWUwkkEgSL8jBmDIc5Bxkc5gj+HkZ0iTS5rq1is5bo3jxWFiLdV lCII9g3MFCsu
/HO44BONwZu13/X9aCXT+un+Y5PHyT6++nwnRYo1ljRVvtUa3upAyK+VtzCT nDYAJBJHati2
8YaJeNaLb3E8hu+bfbZzfvV+XLL8nKDeuW+6Ocng4r22ieILW7uJE1rTWhu5 EluFfTH3FhGi
NtYTgKDsyMg4z3q3YeHxZNphNz5gsdPayI2Y8zPl/N14/wBX0569eKP6/D/P 8wIU8a+H3jlk
F64jjK4draVVkDPsVoyVxIpYgbkyORzyKg1DXNVnuJRocUPl2lot3OLy3kDS 7slYVBKmN8KS
SwOMr8vWq1v4JuRJZG71ZJ005Y4rLba7GWJZY5CJDvIdj5SDcAoGCdvNWdXg 1iy1S9n0uxa8
XUbZYQRIiC2mXcA77mBKEMM7ckbOhzSe2m49L+R0Nrcx3llBdQnMU0ayJ7gj I/nXO6N4tbUr
CXVbm2tINJAyJ4bszyRnIGyaMIPLYbuQCwXByRjJ37CzWw0y2so2+W3hWJT7 KAM/pXPp4ZuX
uru+1iez1KZ7B7LbbWf2Z5o2wSsjGRgx44+6BubjnhyaTdtiY3aV99C9e+Ld GsLuW1mnna4j
LBooLSaZvlCFsBFOcCRMkdM89DUUfi+wk1W4s0iu5YorOK7SeC0mmWRH3HjY hB4AxgknJAHB
qLQvDUthb6fNc3Je7jtJY7kt8xkllZHdt3HQqR06Y6YxVS48FXL2S2kGqxLC bG3tJkltS6ym
EkgkCRfkYMwZDnIOMjnKat6/8P8A8Aa1/r0/4JrxeKdHlSFzcyQiVpEH2i3k hKsi7mVg6god
vzYbBIBIyBWGnj5J9ffT4TosUayxoq32qNb3UgZFfK25hJzhsAEgkjtTY/h5 GdIk0ua6tYrO
W6N48VhYi3VZQiCPYNzBQrLvxzuOATjcG0rbRPEFrd3Eia1prQ3ciS3Cvpj7 iwjRG2sJwFB2
ZGQcZ70f1/X9f8A6Fi28YaJeNaLb3E8hu+bfbZzfvV+XLL8nKDeuW+6Ocng4 YnjXw+8csgvX
EcZXDtbSqsgZ9itGSuJFLEDcmRyOeRU1h4fFk2mE3PmCx09rIjZjzM+X83Xj /V9OevXism38
M8qwBU+xAIrL1y81C3uNLttOltopLu5MTyXELSgKI3c4CuvJ24znv0NX7/Tr HVbRrXUbK3vL
ZiCYbiJZEJHQ4YEVl65Bcwz6LNYadLdR2l0S8Nu0aFEMToCA7KMAsOAc46Ck HQD4hktdQ1K3
1CxdIrRYnjeyWW7eRJC4BMaR7lI2HIG4c9anj8TaRJaTXK3TCKG2+1SFoXUr HlgeCucgowK4
3AjBAJFYmoeDb/VvOm1DU9PuLmR48xPpzG0eNA+FkhM2X5kLZL4yqnHHNix8 FxWVlplstyir
ZyyM4htxGskbSeaIwoOFUOE9eFI78NeYPyL194p0+wku4ZI70z28Mk2w2cqL LsXcVjkZQjtg
dAx6H0NV7HxQW0n+0tTis47aQqLaTTLl78XGc8KFjDMwxyFU8c54OM4eBJU1 9tWiv7JLlZZp
Yrn+zg1186uoWSVnO9V3DC4UYUD3Ey+Eb8Xk2qnUrCPWXljkWaDTmSA7VdPn j80s7FZGG7eD
gL/d5S2Av/8ACX6XKzJA8pkSSNJVntZ4hGXKABiY/lfEikKcE+wBIrXHj3Rl 0q8vLRri4aC0
N3HGbWaPz4xj5oyyfOuSuSuQMjNSnw3cy2F1Hc30UlzcXkN47xW5Rd0Yj+UK XYgHy+5OM98V
l6d4O1K60OCDW7+ETR6U1hAlrbbPs4kVQ5YmRxIw2LgjaODxzw1tr/Wn+Y+p 0ba0hbSjFBKU
1CUxjzUaJ48Ru+SjKG/gxggdadda9YWWox2NybmOWTAWQ2kphyegMoXYCemC 2c4HcVV1DSdW
vLbTHi1Kyi1GylMrTPZM8UhKMhHliUEcNn756Vj3vgSbUdZTUry906WYSwzG ZtOLTI0e3KxS
NIfLjJUnaASCx5OTlPfQS2NSHxt4fngknS9kESQicO9rKglQkAGMso8zllGE ycsB1IFIdZst
ZtZnszP+5BjkSe2kgdGzGcFZFVuhB6d6o6p4VmXR7D7NPLLdaXZrFAsUS5kk R4nVsM6rjMQy
pYZBPzA81QtfD+r31lPdaxfXenXd1dPK0dmI4vlCIqhhulA+5nAkI7nHO0a/ r56AX6427/5H
Rv8AsI6X/wChtXSnweef+Kh1wf8AbePjr/sf4dD0525epeH4dGvtMnW8vLqa 51WyV2uWViAk
vGMKP7xHPp25AlIbPUKKKKoQUUUUAFFFFABRRRQBymieMpNW11tPfTjHbyCR ra7i89o5VQ9d
zwohyCCNjOPfHJ0NHe8j1rV7S51Ce8jiaJ4jMkYMYcElRsVcgY4zk+9ZFp4V /s6/gvYtNJms
Fxt3Hy3Y3dB30a+9f1/Xkzr6KKKRgFFFFABRRRQAUUUUAFFFFAEN3/x5z/8A XNv5VWuLv7Bo
97eBN/kLNLt9dpY4/SrN3/x5z/8AXNv5U2KNJrWSKRQyO0ispGQQWORSB7aH mtzc6Qthpuo6
4t5f3WpbnEif8swDjCjtjPA4rpvBGqT3kF7azG5eK2ZTBJcqQ5jbOAc9cbev uKoXOh6t4ZsZ
ZLCc39jbnzLa1Nv5syOTgAcE4BOSRzjPGayvh7Jrmn61Pa31jqHkXqlmmmtJ VCyqCdzM2B8w
yCepO2nSoScHO+34nFFuFRJr+v8Ahzq18Z2o0q51a40++ttMitzcxXk3lCO4 j4wVw5Kk5GA4
UnP1xeTxPok4j+y6pY3TSbdqw3cRJUsq7uW5A3r09RjJIB56Pwpqk1vqcRtt M0lbmxlt/JsL
iR4JpnwfNaIoioRg8jcxDck7RVxfDuoz2V81xHZQXl5qNvduIpWdQsYiBG4o pJ/dtjjuOlH9
fidrNqHxFolyLkwaxp8otU8y4KXSN5KYzufB+UY5yan07VdO1e2Nzpl/a3sA YqZbaZZF3Dtl
SRnkVxuqeFri00HSmRbcnSrBI2iSKSQSyJLDIFCojMVJiIyFJGQdp6Vs+DpL 67tdR1C+svsb
3l4ZUi/efdEaJnEiI45Q/eQfiMEuy1/rr+on/X3HSUUUUhhRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAVR1Btuw5UYBYsxIxyPQZ6kf/AK8EXqzd W/1R/wCuZ/8A
QkpPYEVPtEY6Sxe3Lf8AxPsPy7YXbyOvasl5r1hp6R4FnqdgxkDcMXkPAGB0 Cj8/QCsfT9I8
bx+LpPtviXzdAixJHi2hEs2Sf3bYT5cY5YdQRjBJ2uu/+R0b/sI6X/6G1JDZ 7DRRRVCCiiig
AooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAIbv8A485/+ubfyqmt +IA6sEAErqCz
HnnPZT61cu/+POf/AK5t/Kuf1MStBMIHRJjNMEZ0LKrYGCQCMjPbI+oqWNFO e0vLuaSa48QT
q5J2LbPJEiDsNoHP1NWfC+v3F94fiuruRJGM0sayOCrMqOVBIUEZwBXEfDyw 1ywsNZTxEzya
i+qPI0xOVmUxxgMh4+XAwAAMYxgYwNvwl/yJ1p/183X/AKNNJaakqEU7o7P+ 1o/WL/vpv/ia
P7Wj9Yv++m/+JrCoo5mXY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrCoo5mFjd/ taP1i/76b/4m
/iaP7Wj9Yv8Avpv/AImsKijmYWN3+1o/WL/vpv8A4mj+1o/WL/vpv/iawqKO ZhY3f7Wj9Yv+
+m/+Jo/taP1i/wC+m/8AiawqKOZhY3f7Wj9Yv++m/wDiaP7Wj9Yv++m/+JrC oo5mFjd/taP1
i/76b/4mj+1o/WL/AL6b/wCJrCoo5mFjT0rxImqPfhLfYtpdNbE7878KrFug x949fTPrt0Pt
2Osf1+b/AD6H8u2G28f4PPOu89NVk79P3cfv7e3T2yvS9PbH4Y/l6e3Ttj5H cRb+3Y6x/X5v
8+h/Lthtp9ux1j+vzf59D+XbDbanT2x+GP5ent07Y+Q6e2Pwx/L09unbHyFw Lf27HWP6/N/n
0P5dsNtPt2Osf1+b/Pofy7YbbU6e2Pwx/L09unbHyHT2x+GP5ent07Y+QuBb +3Y6x/X5v8+h
/LthtrW1DbnMajA3EsxGOQPTPU+n65ArdPbH4Y/l6e3Ttj5IbjiKQf8ATPp/ wJR/T07dsbVL
gW/7Wj9Yv++m/wDia5fWNYv9Y1S40zTLmKy+xxo0szQ+d5vmZIABK7QNnXvn tjnltI0/xDH8
TfEF75vlaBL5Q8qVSfOlEMY3R8/LjGC3Q4xgkZXY07/kbtc/65Wv8npXHYP7 O8Q/9DBB/wCC
8f8AxdZ82k3VjqdjeXl8l1Nc6rYKSsHlgBJDjjcf736V1M00VtCZpmIQED5R lmY9FUd2PYfy
AJrC1GeWa80wTORImr2YaBOY4P3n3d38T/3j9B2wBAz0+iiirJCiiigAoooo AKKKKAKS6pby
6gbO3DzyISJmiGUhI7M3TPT5Rluc4xzSm6d9VFpEFKRx+ZOxHTPCqPc4J+g9 6x2kbRPEul6X
ZkLY3wmJgIG2Eou793joCeoOR6AVpaH+8sXuW5luJpHkPqQxUfgAoH4VTVtT GM3J28x8es2M
t6lokknmyMyoTC4RyuSdrkbTjB6GmprmnyXSW6zOXkcpG3kuEdhnIV8bT0PQ 9q4nwfrEmr+K
5I5rSzhkhSSRp7eHy5JjkL+8I+8Oc9OoBq/ouv30vi2Tw7ujWzst4R1X946p wFYnjHPYA8Dn
rRygqjt8zp4Nc0+4ufs0cshmDbGUwOuw9g2V+XPbOM9s1Jb6lFcS3aqrgW+N wMUgc8H+EqM9
OMZzXFeDvF1/qviG4sp4bZYpN8xKKwO4ADux44qv4Z8Z6jqXi8W00NqqXRKu UVgQEViMZajl
/IPafnY7i017Tr541t5ZG8zOxmgdVcgZIDFQCRg8ZzwfQ06x1i21CRkhju1Y FhmW1kRflOD8
wSGJ7ZcnjB4HPXJyh7R2v5nRWeqW95M9vh4bpBl7eYbXAzjcB0Zf9pSR71dr mPC8jeIbGLWt
RCyziR1hi2jy4NrEZQddxx1JJ64wCRXT0SViqcnJXCiiipNCC+bZYXLbXbbE xwilmPB6Ack+
w5rzLVdW1y8vpZLODWLa2LlkibQZHIz1Jbdz/n6n1SiiwHj32vxL/f1f/wAJ 1/8A4qorRtfs
bGOzthq6Qxs7gf8ACPSE5dixOS3v+lezUUrBc8e+1+Jf7+r/APhOv/8AFUfa /Ev9/V//AAnX
/wDiq9hoosO5499r8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePf a/Ev9/V//Cdf
/wCKo+1+Jf7+r/8AhOv/APFV7DRRYLnj32vxL/f1f/wnX/8AiqPtfiX+/q// AITr/wDxVew0
UWC5499r8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V/ /Cdf/wCKo+1+
Jf7+r/8AhOv/APFV7DRRYLnj32vxL/f1f/wnX/8AiqPtfiX+/q//AITr/wDx Vew0UWC5499r
8S/39X/8J1//AIqj7X4l/v6v/wCE6/8A8VXsNFFguePfa/Ev9/V//Cdf/wCK o+1+Jf7+r/8A
hOv/APFV7DRRYLnl/h/UrrRre7WfSdcuprm5Nw0i6VLGASqjGOf7oPBH6AjX /wCEqkHTw7r3
t/xL5P8AD2H5dsLt7miiwrnDf8JVIOnh3Xvb/iXyf4ew/Lthdp/wlUg6eHde 9v8AiXyf4ew/
Lthdvc0UWHc4b/hKpB08O697f8S+T/D2H5dsLtP+EqkHTw7r3t/xL5P8PYfl 2wu3uaKLBc4b
/hKpB08O697f8S+T/D2H5dsLtzdW17VbyNE0/TtZshyJC+jSSlhxgDkAdB29 OgGK9LoosK54
99r8S/39X/8ACdf/AOKqbSZr6xvry8vLDW7qa5WNSV0aSMAJuxxk/wB79K9b oosO55hPqNxN
M8w0rX0kB2wsulyfuEP3tv8Atn+/+QHGICbm7vdLt7fSNYigi1K2kRJNPkjj hjWQEkkjrySz
--------------080400020103050500040806--
Current Time: Wed Apr 24 18:40:02 GMT 2024
Powered by FUDForum. Page generated in 0.03476 seconds
