Home » Language IDEs » ServerTools (WTP) » XML schemes provision
XML schemes provision [message #214036] Tue, 20 May 2008 12:17 Go to next message
Walter Brunauer is currently offline Walter BrunauerFriend
Hi!
I just started using WTP (I am currently on 3.0 M7) and I managed to
provide my own XML schemes (i.e. namespace names) to the XML catalog
within the preferences via the
org.eclipse.wst.xml.core.catalogContributions extension point. However,
this does not suffice the requirements I have to cover within my
application. Two questions:
1. Is there any way to (maybe programmatically) provide different schemes
or different versions of the same schemes per project? If so, do I need
any specific nature or other properties for such projects?
2. Is there any chance to tell the XML editor to still look for XML schema
definitions in the provided entries within the XML catalog, if e.g. a
"xsi:schemaLocation" schema location reference in the XML file itself
cannot be resolved directly? Right now, there seems to be no fallback
mechanism in place...
Thanks a lot in advance for any hints,
Walter
Re: XML schemes provision [message #214044 is a reply to message #214036] Tue, 20 May 2008 13:38 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Walter Brunauer wrote:
> Hi!
> schemes or different versions of the same schemes per project? If so, do
> I need any specific nature or other properties for such projects?
You will need to create a custom URIResolver or a Content-Type Describer
that handles the loading of the particular schema that you need loaded
at runtime. One such example is in the XSL Tooling incubator project
in the org.eclipse.wst.xsl.core plugin project.
> schema definitions in the provided entries within the XML catalog, if
> e.g. a "xsi:schemaLocation" schema location reference in the XML file
> itself cannot be resolved directly? Right now, there seems to be no
> fallback mechanism in place...
I think your best bet is to go with a Custom Resolver.
Re: XML schemes provision [message #214120 is a reply to message #214044] Wed, 21 May 2008 10:24 Go to previous message
Works like a charm, thanks!
Do you know by chance, how stable one could expect these extension points
and interfaces, i.e., when will they become official and public?
Thanks again,
Walter
Previous Topic:Tomcat-6
Next Topic:Changing plugin from custom to xml file extension
Current Time: Sun Feb 25 10:04:07 GMT 2018
Powered by FUDForum. Page generated in 0.02693 seconds
