Home » Language IDEs » C / C++ IDE (CDT) » How to use math.h in Eclipse with gcc?
How to use math.h in Eclipse with gcc? [message #213974] Tue, 15 April 2008 15:00 Go to next message
Warren Tang is currently offline Warren TangFriend
Member
I tried to add the "-lm" option for gcc in the project properties:
-c -fmessage-length=0 -std=c99 -lm
However the eclipse still complains that:
undefined reference to `sqrt'
In the command line I can compile the code successfully.
Here is the code:
#include <stdio.h>
#include <math.h>
int main(void)
double x = 10;
double y;
y = sqrt(x);
printf("%.4f\n", y);
return 0;
Thanks for any help!
Warren
Re: How to use math.h in Eclipse with gcc? [message #214058 is a reply to message #213974] Wed, 16 April 2008 08:50 Go to previous messageGo to next message
Tracy Miranda is currently offline Tracy MirandaFriend
Hi Warren,
The "-lm" option is a linker option - looks like you've added it to the
Compiler 'Other flags', where it has no effect.
Add it to the linker options, Libraries-> add it in as a new library "m",
this will automatically add on the -l to the option.
(Alternately, you can add "-lm" to the Miscellaneous->Linker Flags box, but
I highly recommend the previous option).
Tracy
"Warren Tang" <warren.c.tang@gmail.com> wrote in message
news:fu2ftr$bai$1@build.eclipse.org...
> Here is the code:
> #include <stdio.h>
> #include <math.h>
> int main(void)
> double x = 10;
> double y;
> y = sqrt(x);
> return 0;
> Regards
> Warren
Re: How to use math.h in Eclipse with gcc? [message #214085 is a reply to message #214058] Wed, 16 April 2008 10:49 Go to previous messageGo to next message
Member
Hi, Tracy
You are absolutely right! It's so kind of you Tracy to tell me this.
Warren
Tracy Miranda wrote:
> Hi Warren,
> Tracy
>> Here is the code:
>> #include <stdio.h>
>> #include <math.h>
>> int main(void)
>> double x = 10;
>> double y;
>> y = sqrt(x);
>> return 0;
>> Regards
>> Warren
Re: How to use math.h in Eclipse with gcc? [message #232829 is a reply to message #213974] Fri, 10 April 2009 16:58 Go to previous messageGo to next message
Przemek is currently offline PrzemekFriend
you should add the -lm option to GCC C Linker, NOT TO GCC C Compiler. To
do that, you should go to:
Project -> Properties -> C/C++ Build -> Settings -> Tool Settings (tab) ->
GCC C Linker
and in the "Command" text field type: "gcc -lm" (by default there is only
"gcc").
It worked for me;)
Przemek.
Re: How to use math.h in Eclipse with gcc? [message #232836 is a reply to message #213974] Fri, 10 April 2009 17:01 Go to previous message
> Here is the code:
> #include <stdio.h>
> #include <math.h>
> int main(void)
> double x = 10;
> double y;
> y = sqrt(x);
> printf("%.4fn", y);
> return 0;
> Regards
> Warren
GCC C Linker
"gcc").
It worked for me;)
Przemek.
P.S. Sory for duplicating answers, but first time I didn't quote the
question;P
Previous Topic:Including Headers, help needed (dshow)
Next Topic:More on inactive ifdef's
Current Time: Sun Apr 22 09:04:21 GMT 2018
Powered by FUDForum. Page generated in 0.01985 seconds
