Home » Eclipse Projects » GEF » Making a diagram read-only
Making a diagram read-only [message #213866] Tue, 11 April 2006 15:44 Go to next message
Originally posted by: markp.softlanding.com
I am using GEF 3.0.0. I have a diagram app that is loosely based on
the Shapes example. I want to be able to allow a user to open this
diagram in "read-only" mode. Is there some easy way to do this? It is
relatively easy to make changes so that you do not save anything, but
the user can still manipulate the diagram and see and use the palette.
Is the only way to do this to create a second editor?
Mark
Re: Making a diagram read-only [message #213958 is a reply to message #213866] Wed, 12 April 2006 06:23 Go to previous messageGo to next message
Andreas Schosser is currently offline Andreas SchosserFriend
Member
Mark,
you could show the "read-only" diagram inside another view / another
editor or inside your exisiting editor.
If you like to create another view, you will just have to implement a
short ViewPart class:
http://www.eclipse.org/newsportal/article.php?id=16279&g roup=eclipse.tools.gef#16279
If you decide to use your existing editor, just remove the EditPolicys
installed to your diagram EditPart,
at least the COMPONENT_ROLE and the CONTAINER_ROLE policy.
Andreas
A. Schosser
Mind8 GmbH
> Mark
Re: Making a diagram read-only [message #214782 is a reply to message #213958] Sun, 23 April 2006 05:01 Go to previous messageGo to next message
Originally posted by: prostephen1983.hotmail.com
I think a short way is let all the EditPart install this
EditPolicy ----- RootComponentEditPolicy
this editpolicy make your model and view can not be removed.And you may
can not create a connection in your diagram.
I come from china and just a B.S in university.
And this is my first time here.
Thanks.
Re: Making a diagram read-only [message #214789 is a reply to message #213958] Sun, 23 April 2006 05:06 Go to previous messageGo to next message
Originally posted by: tracdor.tom.com
Like GEF
Re: Making a diagram read-only [message #519277 is a reply to message #213958] Mon, 08 March 2010 11:11 Go to previous message
daniele Mising name is currently offline daniele Mising nameFriend
Member
you can try --> [ActiveEditor] .getDiagramEditPart().disableEditMode();
you should do .disableEditMode for all the ShapeNodeEditPart of the editor.
However this method don't let you move the objects on the editor, but you can still change their property in the relativi sheet Sad
[Updated on: Mon, 08 March 2010 11:40]
Report message to a moderator
Previous Topic:move Anchor on node
Next Topic:Make shape not resizable
Current Time: Sat Feb 24 14:44:21 GMT 2018
Powered by FUDForum. Page generated in 0.02040 seconds
