Home » Eclipse Projects » Eclipse Platform » How to export/import several projects at once
How to export/import several projects at once [message #213174] Thu, 18 March 2004 22:10 Go to next message
Oliver Plohmann is currently offline Oliver PlohmannFriend
Hello!
I have an application that consists of several projects. Now I need to
exchange the application with other people. Exporting all projects and
importing them into a virgin eclipse system requires that all projects are
first created manually (otherwise the import tool displays the error message
"cannot import into a workspace with no open projects") and are then
imported from the file system. This is a manual and tedious process which I
want to get around. What I do at the moment to avoid this is to distribute
the entire workspace and .config directory which is a brute force approach
and not really satisfactory.
Does anybody have an idea, has had this as well? I found a thread in the
archive about Envy config maps for eclipse. Apparently, this discussion did
not result in such a feature for eclipse.
Thanx for any ideas,
Oliver Plohmann
Re: How to export/import several projects at once [message #213362 is a reply to message #213174] Fri, 19 March 2004 08:15 Go to previous messageGo to next message
Originally posted by: jon.homan.enigmatecNOSPAM.net
Oliver Plohmann wrote:
> Hello!
> message "cannot import into a workspace with no open projects") and are
> then imported from the file system. This is a manual and tedious process
> which I want to get around. What I do at the moment to avoid this is to
> distribute the entire workspace and .config directory which is a brute
> force approach and not really satisfactory.
> did not result in such a feature for eclipse.
> Oliver Plohmann
Do you have network access to the other developers? Using a CVS repository
is one way (you could set one up on your local machine), and then you just
export a Team Project Set (*.psf file) and email that to the developers.
They just import it and Eclipse handles setting up the repository
information and automatically checks out the projects.
You do not need to import the projects if they are valid Eclipse projects.
Unzip them into the target workspace and fire up the New Project wizard.
Just select the Simple -> Project and enter the Project name so that it is
the same as in the exported workspace. Press Finish and you will see the
projects in the Navigator. This works because Eclipse does not overwrite
the .project file. So even if the projects are plugin projects this method
should still work.
Jon Homan
Re: How to export/import several projects at once [message #213482 is a reply to message #213174] Fri, 19 March 2004 13:44 Go to previous message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Oliver,
I have made a plugin for this exact purpose. It can be installed from
the update site located at http://eclipse-tools.sourceforge.net/updates.
The name of the plugin is Project Transfer. If you don't want to use
the update manager you can just grab the jar file (at
http://eclipse-tools.sourceforge.net/updates/plugins/dk.kams truplinnet.projecttransfer_1.0.2.jar)
and install its contents manually.
There is currently absolutely no documentation whatsoever... Basically,
this is how it works:
- The plugin depends on the existence of .project and .classpath files
where the project should be created.
- Select Import... e.g. from the package explorer and choose "Existing
project definitions".
- Browse (or type) the root from where you want to search for existing
projects to import.
- Select "Next". You will now be presented with a list of the projects
found. Select the ones you want to import and press "Finish". Now, the
projects are (hopefully) imported.
Be aware the the error handling is very primitive. You may be presented
with an ugly dialog showing misc. errors. However, I haven't had
problems using it so far for my own purposes (such as making initial
Eclipse installations).
I am working on an "official" release at the moment, so stay tuned...
If you need assistance, feel free to contact me directly.
Jesper
> Hello!
> Oliver Plohmann
Previous Topic:marker not show up right after added
Next Topic:TableViewer not displaying modified cell value
Current Time: Thu Feb 22 20:42:22 GMT 2018
Powered by FUDForum. Page generated in 0.01647 seconds
