Home » Language IDEs » Java Development Tools (JDT) » Can I be notified of Java editor's currently selected element, like the content outline is?
Can I be notified of Java editor's currently selected element, like the content outline is? [message #212483] Sun, 14 August 2005 06:23 Go to next message
Guillaume Pothier is currently offline Guillaume PothierFriend
Whenever I move the caret to a certain position in the java editor, the
corresponding java element is automatically selected in the outline
view. I want to create a view with the same behavior, but it seems I
cannot do that using public API: the java editor directly tells the
outline view to change its selection, but the ISelectionService knows
nothing about it.
I guess I could listen to selection changes in the outline view, but
what if the user did not open it?
For now the only way I can think of doing it is accessing the
JavaEditor, which is an internal class, and use reflexion to call the
protected computeHighlightRangeSourceReference() method. Not exactly
clean...
Is there a better way to do it now? If not, is a better way planned?
Guillaume Pothier
Re: Can I be notified of Java editor's currently selected element, like the cont [message #212676 is a reply to message #212483] Tue, 16 August 2005 17:06 Go to previous messageGo to next message
Karen Butzke is currently offline Karen ButzkeFriend
Guillaume Pothier wrote:
> nothing about it.
> clean...
> Regards
> Guillaume Pothier
Take a look at JavaBrowsingPart.selectedChanged or more specifically
org.eclipse.jdt.internal.ui.browsing.setSelectionFromEditor( IWorkbenchPart,
ISelection). It's an internal class, but this is the code I looked at to
figure out how to make a view update from the JavaEditor selections.
You will also need to call
getViewSite().getPage().addPostSelectionListener(ISelectionL istener). The
WorkbenchPage actually handles notifying selectionListeners, not the
JavaEditor.
Karen
Re: Can I be notified of Java editor's currently selected element, like the cont [message #212707 is a reply to message #212483] Wed, 17 August 2005 06:50 Go to previous messageGo to next message
Originally posted by: prasadmpatil.gmail.com
Hi Guillaume,
This can also be done using AST. Take a look at the following plugin which
does something similar.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/jdt- ui-home/plugins/org.eclipse.jdt.astview/index.html
HTH
~Prasad
Re: Can I be notified of Java editor's currently selected element, like the cont [message #212730 is a reply to message #212676] Wed, 17 August 2005 14:31 Go to previous message
>> the corresponding java element is automatically selected in the
>> outline view. I want to create a view with the same behavior, but it
>> seems I cannot do that using public API: the java editor directly
>> tells the outline view to change its selection, but the
>> ISelectionService knows nothing about it.
>> clean...
>> Regards
>> Guillaume Pothier
> to figure out how to make a view update from the JavaEditor selections.
> The WorkbenchPage actually handles notifying selectionListeners, not the
> JavaEditor.
> Karen
Thanks, it helped a lot! I wrote an enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=107122
g
Previous Topic:[PDE/Build] Exporting a product with plugins needing bytecode-enhancement
Next Topic:superclass TypeDeclaration in DOM/AST
Current Time: Tue Jun 19 00:56:22 GMT 2018
Powered by FUDForum. Page generated in 0.01709 seconds
